[Hardware] Quiz Trustable JN0-650 - Enterprise Routing and Switching, Professional (JNCIP-E
78
【Hardware】 Quiz Trustable JN0-650 - Enterprise Routing and Switching, Professional (JNCIP-E
Posted at 1/25/2026 02:01:29      View:144 | Replies:1        Print      Only Author   [Copy Link] 1#
We can send you a link within 5 to 10 minutes after your payment. You can click on the link immediately to download our JN0-650 real exam, never delaying your valuable learning time. If you want time - saving and efficient learning, our JN0-650 Exam Questions are definitely your best choice. And if you buy our JN0-650 learning braindumps, you will be bound to pass for our JN0-650 study materials own the high pass rate as 98% to 100%.
The JN0-650 test materials are mainly through three learning modes, Pdf, Online and software respectively. Among them, the software model is designed for computer users, can let users through the use of Windows interface to open the JN0-650 test prep of learning. It is convenient for the user to read. The JN0-650 test materials have a biggest advantage that is different from some online learning platform which has using terminal number limitation, the JN0-650 Quiz torrent can meet the client to log in to learn more, at the same time, the user can be conducted on multiple computers online learning, greatly reducing the time, and people can use the machine online of JN0-650 test prep more conveniently at the same time. As far as concerned, the online mode for mobile phone clients has the same function.
JN0-650 Valid Braindumps Ebook | Clear JN0-650 ExamIn today's technological world, more and more students are taking the Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam online. While this can be a convenient way to take a Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam dumps, it can also be stressful. Luckily, BraindumpsIT's best Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam questions can help you prepare for your Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) certification exam and reduce your stress. If you are preparing for the Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam dumps our JN0-650 Questions help you to get high scores in your JN0-650 exam.
Juniper Enterprise Routing and Switching, Professional (JNCIP-ENT) Sample Questions (Q22-Q27):NEW QUESTION # 22
Exhibit
Referring to the exhibit, which two statements are correct? (Choose two.)
  • A. This route has a hidden next hop.
  • B. The BGP configuration includes the multipath parameter.
  • C. This route has two next hops available.
  • D. The BGP configuration is for IBGP
The exhibit shows the output of the command show route protocol bgp on router R1 for the prefix 172.16.10.1
/32. To determine the correct characteristics of this route, we analyze the specific BGP attributes and next-hop information provided in the routing table entry:
Multipath Parameter (Option B): The routing table shows two distinct paths for the prefix 172.16.10.1/32. The first path has two next hops (192.168.10.1 and 192.168.20.1) and is marked with the plus symbol (+) and the asterisk (*), indicating it is both an active and the best route. The presence of multiple next hops being used simultaneously for a single BGP path is a clear indication that the multipath parameter is enabled in the BGP configuration. In Junos OS, BGP multipath allows the installation of multiple equal-cost BGP paths into the forwarding table to facilitate load balancing.
Available Next Hops (Option C): The output explicitly lists two functional next hops for the active path:
192.168.10.1 via ge-1/0/0.2 and 192.168.20.1 via ge-1/0/1.3. Both show an outgoing interface, confirming that this route has two next hops available for traffic forwarding.
IBGP vs. EBGP (Option A): The BGP routes shown have an AS path of 200 I. This indicates the routes were learned from an external Autonomous System (AS 200). Furthermore, the protocol preference is 170. In Junos OS, the default preference for External BGP (EBGP) is 170, whereas the default preference for Internal BGP (IBGP) is 200. Therefore, this configuration is for EBGP, not IBGP.
Hidden Next Hops (Option D): The summary line at the top of the exhibit mentions that there are "2 hidden" routes in the inet.0 table. However, these hidden routes are not the next hops for the 172.16.10.1/32 prefix. A hidden route is a prefix that was rejected by policy or has an unreachable next hop; it is not a "hidden next hop" belonging to an active route.
NEW QUESTION # 23
You are implementing an EVPN-VXLAN edge-routed bridging design using Layer 3 gateway operations. In this scenario, which statement is correct?
  • A. IRB interfaces are disabled; all routing happens through external routers only.
  • B. Only core switches have IRB interfaces; all Layer 3 routing happens in the core.
  • C. Distribution switches share the same anycast IP addresses for IRB interfaces; routing occurs at the distribution layer.
  • D. Each distribution switch has unique IP addresses for IRB interfaces; routing protocols run on IRB interfaces
In anEVPN-VXLAN Edge-Routed Bridging (ERB)architecture, also known as a collapsed fabric, the Layer
3 default gateway functionality is moved from the core/spine layer down to the edge (the leaf or distribution layer).
* Anycast Gateways:To support seamless host mobility and redundancy, multiple distribution/leaf switches are configured with thesame anycast IP addressandMAC addresson their IRB interfaces for a given VLAN. This allows a host to move between different switches without needing to update its default gateway configuration or ARP cache.
* Distributed Routing:Routing occurs locally at the edge (distribution layer). Traffic destined for a different subnet is routed by the first switch it hits (the ingress leaf), rather than being backhauled to a central core router.
* Symmetric vs. Asymmetric IRB:Junos OS 24.4 supports both models, but the ERB design typically utilizes symmetric routing for better scalability, where each leaf only needs to know the routes for its locally connected VNIs and uses a transit VNI for inter-subnet communication.
Option Ais incorrect because while unique IPscanbe used (Method 1 in some docs), the defining characteristic of an efficient ERB design is the use of shared Anycast IPs for the gateway.Option Cdescribes a Centrally-Routed Bridging (CRB) design, not ERB.
NEW QUESTION # 24
Which two statements are true regarding hierarchical queuing? (Choose two.)
  • A. VLANs and interface sets share port bandwidth.
  • B. Queuing resources are assigned through a traffic control profile applied to a logical interface.
  • C. VLANs take precedence over interface sets for port bandwidth.
  • D. Queuing resources are assigned through a scheduler applied to a logical interface.
NEW QUESTION # 25
Which two statements are true about IGMPv3? (Choose two.)
  • A. Hosts silently leave a multicast group.
  • B. Hosts actively leave a multicast group.
  • C. It supports source-specific multicast.
  • D. It does not have a querier election process.
NEW QUESTION # 26
You have an OSPF NSSA area that is also receiving IS-IS routes on the ASBR.
In this scenario, which LSA type is used to announce external IS-IS routes?
  • A. Type 8
  • B. Type 1
  • C. Type 4
  • D. Type 7
NEW QUESTION # 27
BraindumpsIT is unlike other exam materials that are available on the market, JN0-650 study torrent specially proposed different versions to allow you to learn not only on paper, but also to use mobile phones to learn. You can choose the version of JN0-650 training guide according to your interests and habits. And if you buy the value pack, you have all of the three versions, the price is quite preferential and you can enjoy all of the study experiences. This means you can study JN0-650 Exam Engine anytime and anyplace for the convenience these three versions bring.
JN0-650 Valid Braindumps Ebook: https://www.braindumpsit.com/JN0-650_real-exam.html
Juniper JN0-650 Reliable Exam Test As for the normal selling site, we are also serious about the privacy, Juniper JN0-650 Reliable Exam Test Sometimes choice is as important as effort, Juniper JN0-650 Reliable Exam Test Because this is a small investment in exchange for a great harvest, Juniper JN0-650 Reliable Exam Test You only need about 20 hours training to pass the exam successfully, To make preparation easier for you, BraindumpsIT has created an Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) PDF format.
We offer the one-year free update Enterprise Routing and Switching, Professional (JNCIP-ENT) test questions once JN0-650 you purchased, Now that you've got the inside scoop on what press people want, are you ready to broadcast your message to them?
Quiz 2026 JN0-650: Enterprise Routing and Switching, Professional (JNCIP-ENT) – Reliable Reliable Exam TestAs for the normal selling site, we are also serious about the JN0-650 Reliable Exam Test privacy, Sometimes choice is as important as effort, Because this is a small investment in exchange for a great harvest.
Posted at 2/20/2026 22:06:56        Only Author  2#
I’m truly amazed by your article, thank you for your generosity! This Agentforce-Specialist reliable test camp materials helped me move up in my career. Now it’s free for everyone. Hope you all reach your promotions soon!
