[General] 有難いPlat-Dev-210参考書 &合格スムーズPlat-Dev-210日本語認定 |正確的なPlat-Dev-210技術問題
67
【General】 有難いPlat-Dev-210参考書 &合格スムーズPlat-Dev-210日本語認定 |正確的なPlat-Dev-210技術問題
Posted at 1/25/2026 02:59:08      View:187 | Replies:2        Print      Only Author   [Copy Link] 1#
古くから成功は準備のできる人のためにあると聞こえます。多くの人々は我々社のPlat-Dev-210問題集を介して、SalesforceのPlat-Dev-210試験資格認定を取得しました.しかも、この優位を持ってよい仕事を探しました。成功を受けたいあなたはすぐに行動しませんでしょうか?Plat-Dev-210試験に興味があると、我々社Pass4Testをご覧になってください。
Salesforce Plat-Dev-210 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
トピック 2
  • Omniscripts: This portion of the exam measures the skills of a Business Analyst and focuses on the use of OmniScripts to create dynamic, guided user experiences. It includes comparing and contrasting various OmniScript elements and their configurations to fulfill given use cases. The section also examines the candidate's understanding of the JSON structure that supports OmniScripts, as well as the ability to select appropriate elements and properties to address functional requirements effectively.
トピック 3
  • Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
最高-ユニークなPlat-Dev-210参考書試験-試験の準備方法Plat-Dev-210日本語認定SalesforceのPlat-Dev-210ソフトを使用するすべての人を有効にするために最も快適なレビュープロセスを得ることができ、我々は、SalesforceのPlat-Dev-210の資料を提供し、PDF、オンラインバージョン、およびソフトバージョンを含んでいます。あなたの愛用する版を利用して、あなたは簡単に最短時間を使用してSalesforceのPlat-Dev-210試験に合格することができ、あなたのIT機能を最も権威の国際的な認識を得ます!
Salesforce Certified Omnistudio Developer 認定 Plat-Dev-210 試験問題 (Q104-Q109):質問 # 104
A customer has a new Engagement Manager who is going to be the new Primary Contact for the Account.
What type of mapping does a DataRaptor Load use to create the new contact and then add it as the new Primary Contact?
  • A. Linked Mapping
  • B. Lookup Mapping
  • C. Relationship Query
  • D. Lookup Key
According to the DataRaptor Load Overview page, a Linked Mapping is used to "create or update multiple records in different objects that are related by lookup fields".
質問 # 105
A healthcare company wants to enable its subscribers to add, edit, or delete dependents related to their policy Community portal. The developer on the project decides to use an MniScript.
How should the developer configure the OmniScript to providethis functionality?
  • A. Use an Edit Block element configured with Remote Actions.
  • B. Use an Input Block element and a DataRaptor Post Action element.
  • C. Use a Text Block element and a Remote Action element.
  • D. Use an Edit Block element configured with SOQL statements.
An Edit Block element configured with Remote Actions allows the developer to create a dynamic table that can display, add, edit, or delete records from a Salesforce object. The Remote Actions can be configured to perform CRUD operations on the object using SOQL or Apex.
質問 # 106
What JSON code correct represent the step in the OmniScript Structure panel shown?
  • A.
  • B.
  • C.
  • D.
According to the OmniScript Data JSON page, the OmniScript structure JSON defines the data elements and their properties that are used in an OmniScript. The exhibit shows an OmniScript structure JSON with three elements: Step, Block, and Telephone. The Step element is an empty object, the Block element is an object with two properties: Text and Telephone, and the Telephone element is a string. Therefore, the JSON code that correctly represents the step in the OmniScript Structure panel shown is option C, which has the following structure:
The other options have different structures that do not match the OmniScript structure shown. Therefore, the correct answer is C.
質問 # 107
A developer creates an OmniScript display FirstName, LastName, and BirthDate of a contact using a Type Ahead Block. The DataRaptor used in the Type Ahead has been tested and fetches the correct data.
When previewing Omniscript, the developer enters a name in the Type Ahead and makes a selection of a contact from the list. However, the text fields FirstName. LastName, and BirthDate are not getting populated with the data.
What is the reason that the fields fail to display the fetched data?
  • A. Lookup Mode is not selected in the properties of the Type A Head Block.
  • B. FirstName, LastName, and Birthdate are not placed inside the Type ahead Block.
  • C. The Typeghead ley is not in the correct format
  • D. Use Data JSON is not selected in the properties of the Type Ahead Block.
The FirstName, LastName, and BirthDate fields should be placed inside the Type Ahead Block, so that they can receive the data from the selected record in the Type Ahead list. The Type Ahead Block has a Data JSON Path property that specifies the path to the data node that contains the record fields. For example, if the Data JSON Path is set to Contact, then the FirstName field should have a Value property set to {{Contact.
FirstName}}.
質問 # 108
A healthcare company wants to enable its subscribers to add, edit, or delete dependents related to their policy via their Community portal. The developer on the project decides to use an OmniScript.
How should the developer configure the OmniScript to provide this functionality?
  • B. Use an Input Block element and a Data Mapper Post Action element.
In OmniStudio, the Edit Block element is purpose-built for allowing users to dynamically add, edit, or delete rows of related data, such as dependents under a policy. To save these changes, Remote Actions (typically backed by Apex or API) are used to process each record operation (Create/Update/Delete).
* A. Use an Edit Block element configured with Remote Actions - Correct. This is the recommended and most scalable way to support CRUD operations in OmniScripts for collections (e.g., dependents).
The Edit Block provides UI-level support, while Remote Actions handle back-end interaction with Salesforce or external systems.
Incorrect Options:
* B. Text Block is for display purposes and cannot manage data input or backend actions.
* C. Input Block elements do not support row-level add/edit/delete functionality as Edit Blocks do.
* D. SOQL is a read-only query language and cannot be used to update or delete records directly within an OmniScript.
Salesforce OmniStudio Guide # OmniScript Edit Block Element
OmniStudio Best Practices # CRUD Operations in OmniScripts
質問 # 109
Plat-Dev-210スタディガイドの優れた利点の1つは、高い合格率です。これは99%に達し、同業他社の平均合格率よりもはるかに高くなっています。当社の高い合格率は、当社が業界トップのPlat-Dev-210準備ガイドである理由を説明しています。自信の源は、素晴らしいPlat-Dev-210試験問題です。 Plat-Dev-210学習教材の練習を約20〜30時間続ける限り、試験に合格しても問題はありません。私たちの専門家は、実際の試験問題に合わせてPlat-Dev-210の質問と回答を設計しました。これは、高い能力で試験に合格するのに役立ちます。
Plat-Dev-210日本語認定: https://www.pass4test.jp/Plat-Dev-210.html
Posted at 1/28/2026 14:02:47        Only Author  2#
I walked away from the article feeling much more informed. The CDT free Brain dumps exam played a major role in my promotion and raise—get it for free today!
Posted at 2/19/2026 13:05:00        Only Author  3#
This article has been very helpful to me, and many of the ideas have been very inspiring. Best wishes for your exam! Here’s the free Well CPCE prep material.
