[General] Practice Test HPE7-A01 Fee & Download HPE7-A01 Pdf
87
【General】 Practice Test HPE7-A01 Fee & Download HPE7-A01 Pdf
Posted at 1/25/2026 03:55:21      View:174 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PracticeVCE HPE7-A01 dumps from Cloud Storage: https://drive.google.com/open?id=1zhHo8tMyOE-tIqd81isUUKLLp0zsEAJ2
Our website takes the lead in launching a set of test plan aiming at those office workers to get the HPE7-A01 exam certification. We have organized a team to research and study question patterns pointing towards various learners. Our company keeps pace with contemporary talent development and makes every learners fit in the needs of the society. Based on advanced technological capabilities, our HPE7-A01 Study Materials are beneficial for the masses of customers. Our experts have plenty of experience in meeting the requirement of our customers and try to deliver satisfied HPE7-A01 exam guides to them.
Additionally, PracticeVCE offers 12 months of free HP HPE7-A01 exam questions so that our customers prepare with the latest HP HPE7-A01 material. Perhaps the most significant concern for HP HPE7-A01 Certification Exam candidates is the cost. HP HPE7-A01 certification exam requires expensive materials, classes, and even flights to reach the exam centers.
First-grade Practice Test HPE7-A01 Fee & Passing HPE7-A01 Exam is No More a Challenging TaskThe HPE7-A01 study quiz is made from various experts for examination situation in recent years in the field of systematic analysis of finishing, meet the demand of the students as much as possible, at the same time have a professional staff to check and review HPE7-A01 practice materials, made the learning of the students enjoy the information of high quality. Due to the variety of examinations, so that students can find the information on HPE7-A01 guide engine they need quickly.
To earn the HPE7-A01 certification, candidates must pass a single exam that covers topics such as ArubaOS, wireless LAN fundamentals, RF fundamentals, and network design. HPE7-A01 Exam consists of 60 multiple-choice questions and has a time limit of 90 minutes. A passing score of 75% is required to earn the certification.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q43-Q48):NEW QUESTION # 43
You need to create a keepalive network between two Aruba CX 8325 switches for VSX configuration How should you establish the keepalive connection?
  • A. routed port in custom VRF
  • B. SVI, VLAN trunk allowed all on ISL in custom VRF
  • C. loopback 0 and OSPF area 0 in default VRF
  • D. SVI, VLAN trunk allowed all on ISL in default VRF
To establish a keepalive connection between two Aruba CX 8325 switches for VSX configuration, you need to use a routed port in custom VRF. A routed port is a physical port that acts as a layer
3 interface and does not belong to any VLAN. A custom VRF is a virtual routing and forwarding instance that provides logical separation of routing tables. By using a routed port in custom VRF, you can isolate the keepalive traffic from other traffic and prevent routing loops or conflicts. The other options are incorrect because they either do not use a routed port or do not use a custom VRF.
NEW QUESTION # 44
With the Aruba CX 6000 24G switch with uplinks of 1/1/25 and what does the switch do when a client port detects a loop and the do-not-disabie parameter is used?
  • A. An event log message is created.
  • B. The network analytics engine is triggered.
  • C. Port status will be validated once status is cleared
  • D. Port status led blinks in amber with 100hz.
The correct answer is B. An event log message is created.
The do-not-disable parameter is used to prevent the switch from disabling the port when a loop is detected by the loop-protect feature. Instead, the switch will generate an event log message that indicates the port number and the VLAN ID where the loop was detected. The switch will also send a trap to the SNMP manager, if configured1. The other options are incorrect because:
A) Port status will not be validated once status is cleared. The port will remain enabled even if a loop is detected, unless the loop-protect action is changed to tx-disable or tx-rx-disable1.
C) The network analytics engine will not be triggered by a loop detection. The network analytics engine is a feature that allows users to monitor and troubleshoot network issues using scripts and agents2.
D) Port status LED will not blink in amber with 100Hz. The port status LED will indicate the normal port status, such as link speed and activity, regardless of the loop detection3.
NEW QUESTION # 45
How is Multicast Transmission Optimization implemented in an HPE Aruba wireless network?
  • A. When this option is enabled the minimum default rate for multicast traffic is set to 12 Mbps for 5 GHz
  • B. The optimal rate for sending multicast frames is based on the lowest unicast rate across all associated clients.
  • C. The optimal rate for sending multicast frames is based on the lowest broadcast rate across all associated clients.
  • D. "The optimal rate for sending multicast frames is based on the highest broadcast rate across all associated clients
This is the correct definition of Multicast Transmission Optimization in an HPE Aruba wireless network.
Multicast Transmission Optimization is a feature that improves the performance and reliability of multicast traffic by dynamically adjusting the transmission rate based on the highest broadcast rate across all associated clients. This ensures that multicast frames are sent at the optimal rate for each client and reduces retransmissions and packet loss. The other options are incorrect because they either describe different features or use incorrect terms. References:
https://www.arubanetworks.com/te ... s/multicast/multica
NEW QUESTION # 46
A customer is using Aruba Cloud Guest, but visitors keep complaining that the captive portal page keeps coming up after devices go to sleep Which solution should be enabled to deal with this issue?
  • A. MAC Caching under the splash page
  • B. Wireless Caching under the splash page
  • C. MAC Caching under the WLAN
  • D. MAC Caching under the user-role
MAC Caching is a feature that allows a guest user to bypass the captive portal page after the first authentication based on their MAC address1 MAC Caching can be enabled under the splash page settings in Aruba Cloud Guest2 MAC Caching can improve the user experience and reduce the network overhead by eliminating the need for repeated authentication.
NEW QUESTION # 47
Two AOS-CX switches are configured with VSX at the the Access-Aggregation layer where servers attach to them An SVI interface is configured for VLAN 10 and serves as the default gateway for VLAN 10.
The ISL link between the switches fails, but the keepalive interface functions. Active gateway has been configured on the VSX switches.
What is correct about access from the servers to the Core? (Select two.)
  • A. Server 1 and Server 2 can communicate with each other via the core layer
  • B. Server 1 can access the core layer on only one uplink
  • C. Server 2 can access the core layer via the keepalive link
  • D. Server 1 can access the core layer via both uplinks
  • E. Server 2 cannot access the core layer.
  • F. Server 1 can access the core layer via the keepalrve link
These are the correct statements about access from the servers to the Core when the ISL link between the switches fails, but the keepalive interface functions. Server 1 can access the core layer via both uplinks because it is connected to VSX-A, which is still active for VLAN 10. Server 2 can also access the core layer via its uplink to VSX-B, which is still active for VLAN 10 because of Active Gateway feature.
Server 1 and Server 2 can communicate with each other via the core layer because they are in the same VLAN and subnet, and their traffic can be routed through the core switches. The other statements are incorrect because they either describe scenarios that are not possible or not relevant to the question.
References: https://www.arubanetworks.com/te ... TML/5200-6728/bk01-
NEW QUESTION # 48
In fact, on one side, our HPE7-A01 training braidumps can help you pass the exam and win the certification. On the othe side, i think it is even more important, that you can apply what you have learned on our HPE7-A01 Practice Guide into practices. Your speed of finishing the task will be greatly elevated. Everting will take positive changes because of our HPE7-A01 exam materials. Please cheer up for yourself.
Download HPE7-A01 Pdf: https://www.practicevce.com/HP/HPE7-A01-practice-exam-dumps.html
P.S. Free 2026 HP HPE7-A01 dumps are available on Google Drive shared by PracticeVCE: https://drive.google.com/open?id=1zhHo8tMyOE-tIqd81isUUKLLp0zsEAJ2
Posted at 1/29/2026 15:52:22        Only Author  2#
Thank you for sharing this insightful article, it really stood out to me. The material in Exam sample CRT-450 online is extensive and offered freely to support your learning goals.
Posted at 2/21/2026 18:06:28        Only Author  3#
Thank you so much for your article, it’s something I’ll remember. Free access to the Exam SCS-C03 syllabus test questions. Best of luck to everyone!
