[General] Valid NSE7_OTS-7.2 Exam Format | NSE7_OTS-7.2 Reliable Exam Tips
70
General Valid NSE7_OTS-7.2 Exam Format | NSE7_OTS-7.2 Reliable Exam Tips
Posted at 1/25/2026 03:58:04      View282 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet NSE7_OTS-7.2 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=13hnqxVSQWHU5gVfv-ShIzpszXE_nPSPx
Many exam candidates feel hampered by the shortage of effective NSE7_OTS-7.2 preparation quiz, and the thick books and similar materials causing burden for you. Serving as indispensable choices on your way of achieving success especially during this NSE7_OTS-7.2 Exam, more than 98 percent of candidates pass the exam with our NSE7_OTS-7.2 training guide and all of former candidates made measurable advance and improvement.
Fortinet NSE7_OTS-7.2, also known as Fortinet NSE 7 - OT Security 7.2 Exam, is a certification exam that assesses the knowledge and skills of candidates in securing operational technology (OT) networks. NSE7_OTS-7.2 exam is designed to test the candidate's ability to implement and manage security solutions for industrial control systems (ICS) and supervisory control and data acquisition (SCADA) systems. NSE7_OTS-7.2 Exam covers topics such as securing OT networks, securing ICS and SCADA systems, securing IoT devices, and securing cloud-based OT networks.
Fortinet NSE7_OTS-7.2 Reliable Exam Tips - Valid NSE7_OTS-7.2 TorrentLikewise, Web-Based Fortinet NSE7_OTS-7.2 exam questions are supported by all the major browsers like Chrome, Opera, Safari, Firefox, and IE. In the same way, the Web-based Fortinet NSE 7 - OT Security 7.2 pdf exam requires no special plugin. Lastly, the web-based Fortinet NSE 7 - OT Security 7.2 (NSE7_OTS-7.2) practice exam is customizable and requires an active Internet connection.
Fortinet NSE7_OTS-7.2 Exam is a vital certification for security professionals that specialize in OT security. It is designed to challenge the skills and knowledge of candidates, ensuring that only the most skilled professionals are awarded certification. Passing NSE7_OTS-7.2 exam marks an important milestone in a security professionals career, demonstrating their expertise and commitment to securing critical infrastructure and OT environments.
Fortinet NSE7_OTS-7.2 exam is a certification test designed to validate the skills and knowledge of network security professionals in the field of operational technology (OT) security. NSE7_OTS-7.2 Exam is part of the Fortinet Network Security Expert (NSE) program, which is a comprehensive training and certification program for Fortinet products and solutions. The NSE7_OTS-7.2 exam focuses on testing the candidate's ability to design, implement, and manage secure OT networks and systems.
Fortinet NSE 7 - OT Security 7.2 Sample Questions (Q56-Q61):NEW QUESTION # 56
Based on the Purdue model, which three measures can be implemented in the control area zone using the Fortinet Security Fabric? (Choose three.)
  • A. FortiGate for SD-WAN
  • B. FortiGate for application control and IPS
  • C. FortiSIEM for security incident and event management
  • D. FortiNAC for network access control
  • E. FortiEDR for endpoint detection
Answer: B,D,E
NEW QUESTION # 57
With the limit of using one firewall device, the administrator enables multi-VDOM on FortiGate to provide independent multiple security domains to each ICS network.
Which statement ensures security protection is in place for all ICS networks?
  • A. Each traffic VDOM must have a direct connection to FortiGuard services to receive the required security updates.
  • B. The management VDOM must have access to all global security services.
  • C. Each VDOM must have an independent security license.
  • D. Traffic between VDOMs must pass through the physical interfaces of FortiGate to check for security incidents.
In a multi-VDOM setup, one VDOM typically acts as the management VDOM (often called "root") which manages global settings and security services like FortiGuard updates.
This management VDOM handles access to global security services that benefit all traffic VDOMs.
Individual traffic VDOMs process their own traffic and enforce security policies but rely on the management VDOM for centralized access to global security services.
Each VDOM does not need an independent security license; the license is for the device as a whole.
Traffic between VDOMs does not need to pass through physical interfaces to be inspected; inter- VDOM links and policies handle traffic inspection.
Each VDOM does not require direct FortiGuard connections; this can be centralized in the management VDOM.
NEW QUESTION # 58
FortiAnalyzer is implemented in the OT network to receive logs from responsible FortiGate devices. The logs must be processed by FortiAnalyzer.
In this scenario, which statement is correct about the purpose of FortiAnalyzer receiving and processing multiple log messages from a given PLC or RTU?
  • A. To determine which type of messages from the PLC or RTU causes issues in the plant
  • B. To isolate PLCs or RTUs in the event of external attacks
  • C. To help OT administrators configure the network and prevent breaches
  • D. To configure event handlers and take further action on FortiGate
NEW QUESTION # 59
In the topology shown in the exhibit, both PLCs can communicate directly with each other, without going through the firewall.
Which statement about the topology is true?
  • A. This integration solution expands VLAN capabilities from Layer 2 to Layer 3.
  • B. There is no micro-segmentation in this topology.
  • C. An administrator can create firewall policies in the switch to secure between PLCs.
  • D. PLCs use IEEE802.1Q protocol to communicate each other.
NEW QUESTION # 60
An OT architect has implemented a Modbus TCP with a simulation server Conpot to identify and control the Modus traffic in the OT network. The FortiGate-Edge device is configured with a software switch interface ssw-01.
Based on the topology shown in the exhibit, which two statements about the successful simulation of traffic between client and server are true? (Choose two.)
  • A. Port5 is not a member of the software switch.
  • B. NAT is disabled in the FortiGate firewall policy from port3 to ssw-01.
  • C. The FortiGate devices is in offline IDS mode.
  • D. The FortiGate-Edge device must be in NAT mode.
NEW QUESTION # 61
NSE7_OTS-7.2 Reliable Exam Tips: https://www.prepawaypdf.com/Fortinet/NSE7_OTS-7.2-practice-exam-dumps.html
BTW, DOWNLOAD part of PrepAwayPDF NSE7_OTS-7.2 dumps from Cloud Storage: https://drive.google.com/open?id=13hnqxVSQWHU5gVfv-ShIzpszXE_nPSPx
Posted at 2/14/2026 15:00:45        Only Author  2#
I cant help but hit likethis content is that good. Strengthen your IT skills with free ICF-ACC exam topic. Best of luck in your preparations!
Posted at 3/7/2026 03:40:22        Only Author  3#
Thank you for your article, it really impressed me in a meaningful way. Ready to ace the 1z0-1065-25 latest associate level exam exam C wish me success!
