[Hardware] Plat-Dev-301 Preparation Store - Exam Plat-Dev-301 Assessment
67
Hardware Plat-Dev-301 Preparation Store - Exam Plat-Dev-301 Assessment
Posted at 1/25/2026 04:57:17      View222 | Replies3        Print      Only Author   [Copy Link] 1#
Our company is professional brand established for compiling Plat-Dev-301 exam materials for candidates, and we aim to help you to pass the examination as well as getting the related certification in a more efficient and easier way. Owing to the superior quality and reasonable price of our Plat-Dev-301 Exam Materials, our company has become a top-notch one in the international market. So you can totally depend on our Plat-Dev-301 exam torrents when you are preparing for the exam. If you want to be the next beneficiary, just hurry up to purchase.
TopExamCollection provides the most reliable and authentic Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) prep material there is. The 3 kinds of Salesforce Plat-Dev-301 preparation formats ensure that there are no lacking points in a student when he attempts the actual Plat-Dev-301 exam. The Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam registration fee varies between 100$ and 1000$, and a candidate cannot risk wasting his time and money, thus we ensure your success if you study from the updated Salesforce Plat-Dev-301 practice material. We offer the demo version of the actual Salesforce Plat-Dev-301 questions so that you may confirm the validity of the product before actually buying it, preventing any sort of regret.
Exam Salesforce Plat-Dev-301 Assessment | Plat-Dev-301 Study ReferenceIn this cut-throat competitive world of Salesforce, the Salesforce Plat-Dev-301 certification is the most desired one. But what creates an obstacle in the way of the aspirants of the Salesforce Plat-Dev-301 certificate is their failure to find up-to-date, unique, and reliable Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice material to succeed in passing the Salesforce Plat-Dev-301 Certification Exam. If you are one of such frustrated candidates, don't get panic. TopExamCollection declares its services in providing the real Plat-Dev-301 PDF Questions. It ensures that you would qualify for the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) certification exam on the maiden strive with brilliant grades.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q121-Q126):NEW QUESTION # 121
Business rules require a Contact ta always be created when a new Account is created.
What can be used when developing a custom screen to ensure an Account is not created if the creation of the Contact fails?
  • A. Disable validation rules on Contacts and set default values with a trigger.
  • B. Use the Database. Delete method if the Contact insertion fails.
  • C. Use setSaverpoint (1) and rollback() with a try-catch block.
  • D. Use the Database. Insect method with a11orNone SEL LO alee,
When developing a custom screen that requires both an Account and Contact to be created together, using setSavepoint() and rollback() within a try-catch block is a reliable way to ensure that if the Contact creation fails, the Account creation is also rolled back, maintaining data integrity.
NEW QUESTION # 122
When the code is executed, the callout is unsuccessful and the following error appears within the Developer Console:
System.CalloutException: Unauthorized endpoint
Which recommended approach should the developer implement
to resolve the callout exception?
  • A. Create a remote site setting configuration that includes the endpoint.
  • B. Annotate the getkRFCatalogContents method with @Future (Callout-true),
  • C. Change the access modifier for ERPCatalog from public to global.
  • D. Use the SetHeader() method to specify Basic Authentication,
The System.CalloutException with the message "Unauthorized endpoint" typically indicates that the endpoint to which the callout is being made has not been authorized in the Salesforce org's security settings. To resolve this, the developer must navigate to the Remote Site Settings in the Salesforce Setup and add the endpoint URL as a new remote site. This step is necessary to authorize the Salesforce org to send outbound callouts to that specific endpoint. Annotating with @Future(Callout=true) is necessary for making callouts from methods that perform DML operations, but it does not resolve endpoint authorization issues. Similarly, changing the access modifier or using SetHeader() for authentication would not address the unauthorized endpoint error.
Apex Developer Guide: Making Callouts Using Apex
NEW QUESTION # 123
Refer to the Lightning component below:
The Lightning Component allows users to click a button to save their changes and then redirects them to a different page. Currently when the user hits the Save button, the records are getting saved, but they are not redirected. Which three techniques can a developer use to debug the JavaScript? Choose 3 answers
  • A. Use console.log () messages in the JavaScript.
  • B. Use the browser's dev tools to debug the JavaScript.
  • C. Use Developer Console to view checkpoints.
  • D. Use Developer Console to view the debug log.
  • E. Enable Debug Mode for Lightning components for the user.
Answer: A,B,E
When debugging JavaScript in a Lightning Component, developers can utilize the following techniques:
A . Use console.log() messages in the JavaScript: This is a standard debugging technique to log information to the browser console, which can help trace the execution flow or output variable values.
B . Use the browser's dev tools to debug the JavaScript: Modern browsers come equipped with developer tools that can be used to set breakpoints, step through code, and inspect variables at runtime.
C . Enable Debug Mode for Lightning components for the user: Enabling Debug Mode for users provides more detailed error messages and unminified versions of client-side libraries, making it easier to debug issues.
Using the Developer Console to view checkpoints (Option D) and debug logs (Option E) is more relevant for Apex debugging rather than JavaScript.
Salesforce Documentation on Debugging Lightning Components: Debugging
NEW QUESTION # 124
The Account object has a field, Audit_Code_c, that is used to specify what type of auditing the Account needs and a Lookup to User, zudizar_c, that is the assigned auditor. When an Account is initially created, the user specifies the Audit_Code c. Each User in the org has a unique text field, Audit_Code _e, that is used to automatically assign the correct user to the Account's Auditor_c field.
What should be changed to most optimize the code's efficiency? Choose 2 answers
  • A. Add a WHERE clause to the SOQL query to filter on audit codes.
  • B. Build a Map<Id, List<string>>of Account Id to audit codes.
  • C. Add an initial SOQL query to get all distinct audit codes.
  • D. Build a Map<string, List<Account>> of audit code to accounts.
To optimize the code's efficiency when assigning users to the Account's Auditor field based on the audit code, the following changes should be considered:
B . Building a map of audit code to accounts (Map<string, List<Account>>) would allow for efficient grouping of accounts by their audit code. This would make it easier to process accounts with the same audit code in a single operation, reducing the number of SOQL queries and DML operations needed.
D . Adding a WHERE clause to the SOQL query to filter on audit codes would limit the number of records returned by the query. This means the code only processes relevant User records with matching audit codes, thereby reducing the processing time and memory consumption.
Option A is not recommended because querying for all distinct audit codes without any context of the accounts being processed could be inefficient. Option C is less effective because it would involve creating a mapping of Account Ids to audit codes, which doesn't aid in the efficient assignment of auditor to accounts.
Salesforce Developer Guide on Maps: Apex Maps
Salesforce Developer Guide on SOQL Queries: SOQL SELECT Syntax
NEW QUESTION # 125
A developer wrote a trigger on Opportunity that will update a custom Last Sold Date field on the Opportunity's Account whenever an Opportunity is closed. In the test class for the trigger, the assertion to validate the Last Sold Date field fails.
What might be causing the failed assertion?
  • A. The test class has not re-queried the Account record after updating the Opportunity.
  • B. The test class is not using System. runs () to run tests as a Salesforce administrator.
  • C. The test class has not implemented seealldata=true in the test method.
  • D. The test class has not defined an Account owner when inserting the test data.
The test class may not be re-querying the Account record after updating the Opportunity, which is necessary to verify the updated field values. If the test does not query the database to get the most recent data after the trigger runs, it will not see the changes made by the trigger.
NEW QUESTION # 126
Our Plat-Dev-301 exam questions provide with the software which has a variety of self-study and self-assessment functions to detect learning results. This function is conductive to pass the Plat-Dev-301 exam and improve you pass rate. Our software is equipped with many new functions, such as timed and simulated test functions. After you set up the simulation test timer with our Plat-Dev-301 Test Guide which can adjust speed and stay alert, you can devote your mind to learn the knowledge. There is no doubt that the function can help you pass the Plat-Dev-301 exam.
Exam Plat-Dev-301 Assessment: https://www.topexamcollection.com/Plat-Dev-301-vce-collection.html
It takes you at most one minute to download the Plat-Dev-301 exam braindumps successfully, By exploring the easiest way of passing the Plat-Dev-301 quiz torrent, we determined to figure out how to help customers master the knowledge in limited time, there are a group of specialists have been researched the most useful knowledge of Plat-Dev-301 pass-sure materials all the time, and they have been dedicated in this area for over ten years, The desktop-based Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice test software is compatible with Windows only.
That research division might want to have special security in Exam Plat-Dev-301 Assessment place and thus require its own domain, A cookie is simply a piece of data that the Web server stores in your browser.
It takes you at most one minute to download the Plat-Dev-301 Exam Braindumps successfully, By exploring the easiest way of passing the Plat-Dev-301 quiz torrent, we determined to figure out how to help customers master the knowledge in limited time, there are a group of specialists have been researched the most useful knowledge of Plat-Dev-301 pass-sure materials all the time, and they have been dedicated in this area for over ten years.
100% Pass Quiz Salesforce - Plat-Dev-301 - Trustable Salesforce Certified Platform Developer II - Multiple Choice Preparation StoreThe desktop-based Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice test software is compatible with Windows only, At TopExamCollection, you dont have to worry about payment security.
Moreover, we are also providing Plat-Dev-301 a money-back guarantee on all of Salesforce Certified Platform Developer II - Multiple Choice test products.
Posted at 1/27/2026 03:36:55        Only Author  2#
Wegen der Beliebtheit der SAP C-BCSCX-2502 Zertifizierungsprfung haben viele Leute an der SAP C-BCSCX-2502 Zertifizierungsprfung teilgenommen. Sie können ganz unbesorgt die Fragen und Antworten zur SAP C-BCSCX-2502 Zertifizierungsprfung von ITZert benutzen, die Ihnen helfen, die SAP C-BCSCX-2502 Prfung ganz einfach zu bestehen, und Ihnen auch viele Bequemlichkeiten bringen. Es ist allen bekannt, dass ITZert eine spezielle Website ist, die Fragen und Antworten zur SAP C-BCSCX-2502 Zertifizierungsprfung bietet.
Posted at 2/2/2026 00:24:40        Only Author  3#
I took away so much from reading that article. Free Study Virginia-Real-Estate-Salesperson center resourcesyour key to unlocking a brighter career and better pay!
Posted at 2/9/2026 11:16:18        Only Author  4#
Instant likethis is fantastic. I used the CTFL-AcT latest exam tips to get promoted and raise my salary. Its free for everyone now. Wishing you quick career growth!
Posted at 2/15/2026 03:26:50        Only Author  5#
This article has given me a lot of space for reflection, and Ive gained a lot. Free 300-610 examinations actual questions to improve your IT knowledge. Wishing you all the best!
