AP-219 Latest Exam Experience - Reliable AP-219 Test Blueprint
Posted at 1/25/2026 07:53:43
View213
Replies3
If you are going to buy AP-219 training materials online, the security of the website is important. We have technicians to examine the website every day, if you chose us, we provide you with a clean and safe online shopping environment. In addition, AP-219 exam materials are compiled by professional experts, and therefore the quality can be guaranteed. We offer you free demo to have a try before buying, so that you can have a deeper understanding of what you are going to buy. AP-219 Training Materials contain also have certain number of questions, and if will be enough for you to pass the exam. We have online and offline chat service stuff, if you have any questions, you can consult us.
Salesforce AP-219 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
| | Topic 2 | - Deployment and Debugging: Deployment options, lifecycle management, building processes with pre-configured data, and understanding supporting objects and system runtime.
| | Topic 3 | - User Experience and Customization: Customizing Lightning UI for different user roles using declarative tools like Lightning Page Editor and Report Builder.
Top AP-219 Latest Exam Experience C The Best Reliable Test Blueprint for AP-219 - Professional AP-219 Actual BraindumpsIf you are confusing while preparing for your test, you can choose to trust our information resource and experienced experts rather than waste a lot of time on learning aimlessly. Our Salesforce AP-219 exam guide materials are edited by professional experts based on latest and exact information about the real test. Generally the passing rate is high up to 99.79%. If you want to pass exam as soon as possible, our AP-219 Exam Guide Materials will be most useful product for you.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q80-Q85):NEW QUESTION # 80
A developer needs to create ascheduled job in an external system to move Order data into aSalesforce org every 24 hours. In which two ways can this off-platform job be established without additional third-party tools?
- A. Install a minimal set of dev tools on a machine such as theCommand Line Interface (CLI) and create appropriate scripts to import files containing the data
- B. Authorize a machine against the Salesforce org's APIs withappropriate security measures and create a script to call the APIs
- C. Set up an SFTP server as a waystation. drop the files there using the off-platform job and schedule a job in-platform to process the file
- D. Create a job inthe org (on-platform) to drop a file of existing data. Use the off-platform machine to generate a file and identify the details between the two. Push the changes to the org's "Import" directory
Two ways that this off-platform job can be established without additional third-party tools are:
Install a minimal set of dev tools on a machine such as the Command Line Interface (CLI) and create appropriate scripts to import files containing the data. The CLI is a tool that allows developers to interact with Salesforce from the command line. The developer can use the CLI to create scripts that use commands such as force:data:bulk:upsert or force:data:tree:import to import data from CSV or JSON files into Salesforce.
Authorize a machine against the Salesforce org's APIs with appropriate security measures and create a script to call the APIs. The APIs are interfaces that allow developers to access data and functionality in Salesforce from external systems. The developer can use the APIs, such as REST API or Bulk API, to create a script that authenticates with Salesforce using OAuth 2.0 or JWT, and then performs operations such asinsert, update, or delete on Order data.
Verified Reference: https://developer.salesforce.com ... ence_force_data.htm https://developer.salesforce.com ... hat_is_rest_api.htm https://developer.salesforce.com ... synch_api_intro.htm
NEW QUESTION # 81
Where are the gift message and gift flag stored by default as it relates to an Order Summary?
- A. Order Item
- B. Order Delivery Group Summary
- C. Order Delivery Item
- D. Gift Checkbox on OrderSummary
NEW QUESTION # 82
An administrator is attempting to deploy aChange Set from a development org to a test org but the test org is not available in the list of target organizations. What are two reasons that could cause this issue?
- A. The components in the Change set could not be found within the test org
- B. The development org has not been approved to upload Change Sets from within the test org
- C. ChangeSets can only be deployed from a sandbox org to a production org, not another sandbox org.
- D. The development org and test org are not associated with the same production org.
Two reasons that could cause the issue of not being able to deploy a Change Set from a development org to a test org are:
The development org has not been approved to upload Change Sets from within the test org. To deploy ChangeSets between two sandbox orgs, the administrator needs to establish a deployment connection between them. A deployment connection allows one org to send outbound Change Sets and another org to receive inbound Change Sets. The administrator can create a deployment connection request from the development org and approve it from the test org.
The development org and test org are not associated with the same production org. To deploy Change Sets between two sandbox orgs, they must be linked to the same production org. A production org is an org that contains live data and business processes. A sandbox org is a copy of a production org that is used for development, testing, or training purposes. Sandbox orgs inherit the deployment connections of their source production orgs. Reference: Deploy Using Change Sets, Deploy a Change Set
NEW QUESTION # 83
A developer is creating a flow to generate Fulfillment Orders for Order Summaries. What object is used to generate the Fulfillment Groups?
- A. Order Fulfillment Summaries
- B. Order Product Summaries
- C. Fulfillment Summaries
- D. Products
NEW QUESTION # 84
A customer orders 10 products. The products must be shipped to three different locations. Two of the orders are fulfilled at the same location. How many Fulfillment Orders would be created for this order?
- A. One Fulfillment Order
- B. One Fulfillment Order per Fulfillment Location, totaling 2
- C. One Fulfilment Order per item in the order, totaling 10
- D. One Fulfillment Order pet destination, totaling 3
The number of Fulfillment Orders that would be created for this order is one per destination, totaling 3. A Fulfillment Order is a record that represents a group of products in an order that are fulfilled together from the same location. A Fulfillment Order has a lookup relationship to the Order Summary object, and it contains information such as the fulfillment location, delivery method, status, etc. The number of Fulfillment Orders created depends on three factors: Fulfillment Location, Delivery Method and Recipient Address. These factors determine how the Order Items are grouped and allocated to Fulfillment Orders based on routing rules and inventory availability. In this case, since the products must be shippedto three different locations, three Fulfillment Orders are created for each destination. Verified Reference:https://help.salesforce.com/s/ar ... rder.htm&type=5
NEW QUESTION # 85
What happens when you are happiest? It must be the original question! The hit rate of AP-219 study materials has been very high for several reasons. Our company has collected the most comprehensive data and hired the most professional experts to organize. They are the most authoritative in this career. At the same time, we are very concerned about social information and will often update the content of our AP-219 Exam Questions.
Reliable AP-219 Test Blueprint: https://www.actualtorrent.com/AP-219-questions-answers.html
- Realistic AP-219 Latest Exam Experience - 100% Pass AP-219 Exam 🍷 Enter ▷ [url]www.troytecdumps.com ◁ and search for ✔ AP-219 ️✔️ to download for free 🏓Reliable AP-219 Test Pattern[/url]
- AP-219 Latest Exam Experience - Salesforce Realistic Reliable Salesforce Order Management Administrator Accredited Professional Test Blueprint 🦜 Easily obtain free download of AP-219 by searching on ▷ [url]www.pdfvce.com ◁ 🍴AP-219 Free Vce Dumps[/url]
- Reliable AP-219 Test Tutorial 🏊 Test AP-219 Practice 🚋 Latest AP-219 Test Guide 🥅 Search for ➡ AP-219 ️⬅️ on [ [url]www.examdiscuss.com ] immediately to obtain a free download 💔AP-219 Cert Exam[/url]
- AP-219 Free Vce Dumps 🎑 Reliable AP-219 Test Questions 🤔 AP-219 Latest Test Practice 🖌 The page for free download of ➠ AP-219 🠰 on ➥ [url]www.pdfvce.com 🡄 will open immediately 😮Valid AP-219 Practice Questions[/url]
- 100% Pass Quiz Salesforce - Fantastic AP-219 Latest Exam Experience 😺 Search on ▶ [url]www.easy4engine.com ◀ for ⇛ AP-219 ⇚ to obtain exam materials for free download 💥Valid AP-219 Exam Materials[/url]
- AP-219 Latest Training 🧥 AP-219 Cost Effective Dumps 🕧 AP-219 Exam Assessment 🐻 Download ➡ AP-219 ️⬅️ for free by simply searching on [url]www.pdfvce.com 🥍AP-219 Valid Braindumps Ebook[/url]
- Pass Guaranteed Salesforce - Accurate AP-219 - Salesforce Order Management Administrator Accredited Professional Latest Exam Experience 📚 Go to website ▷ [url]www.prep4sures.top ◁ open and search for ☀ AP-219 ️☀️ to download for free 💲Latest AP-219 Test Guide[/url]
- 2026 Salesforce AP-219 CValid Latest Exam Experience ➡️ Search for AP-219 and download it for free immediately on [url]www.pdfvce.com 😟AP-219 Exam Assessment[/url]
- Latest AP-219 Test Guide 🅰 Valid AP-219 Practice Questions 😑 AP-219 Exam Questions And Answers 🎍 Easily obtain free download of ⇛ AP-219 ⇚ by searching on ✔ [url]www.troytecdumps.com ️✔️ 🕰Reliable AP-219 Test Questions[/url]
- [url=https://confrontationpills.com/?s=Reliable%20AP-219%20Test%20Questions%20%f0%9f%8d%98%20AP-219%20Exam%20Assessment%20%f0%9f%a9%ba%20Valid%20AP-219%20Practice%20Questions%20%f0%9f%92%a6%20Open%20[%20www.pdfvce.com%20]%20enter%20%ef%bc%88%20AP-219%20%ef%bc%89%20and%20obtain%20a%20free%20download%20%e2%8f%abAP-219%20Cert%20Exam]Reliable AP-219 Test Questions 🍘 AP-219 Exam Assessment 🩺 Valid AP-219 Practice Questions 💦 Open [ www.pdfvce.com ] enter AP-219 and obtain a free download ⏫AP-219 Cert Exam[/url]
- Realistic AP-219 Latest Exam Experience - 100% Pass AP-219 Exam 🍝 Search for ➡ AP-219 ️⬅️ and download it for free on [url]www.prepawaypdf.com website 🍚Valid AP-219 Exam Materials[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.mixcloud.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
