[General] 300-535}Md300-535C
84
General 300-535}Md300-535C
Posted at 1/25/2026 10:02:14      View213 | Replies3        Print      Only Author   [Copy Link] 1#
BONUS!!! MdVCESoft 300-535ԇ}棺https://drive.google.com/open?id=1az2l7HJ2bvUSHJm7dKc5gLhKXE3EzCh7
mxӖdzɹıCxஔҪģVCESoft֪ȱ֪]ɲxȻ漰ƵӖYϽo㣬㲻mҲǛ]Чģ҂VCESoftӖY֮ǰdMԇ}ԇã@挍Ŀԇʂ䣬Աpđ300-535yԇ@ҲǞʲNǧfĿه҂VCESoftҪԭ֮һ҂ṩ300-535ԇӖYϣ춎ͨ^yԇ
Ԅӻ;CiscofJC@IlչšIĵıҪE@Ԅӻ;Ciscogе֪Rܺ͌IɹĿReͽQ}s}OӋM㮔ͨźͅfҪĽQKṩgh̶ȵ،FԄӻIĿ˵ĺ̎
Cisco 300-535}MdAutomating and Programming Cisco Collaboration Solutionsԇ°l|µ300-535CVCESoftṩӖ߰PCisco 300-535JCԇČWYϼӖ}Ҫ߀oԇܽӽľ}ʹ𰸡xVCESoftԱCڶ̕rgȌWӏITI֪R߀Ը߷֔ͨ^Cisco 300-535JCԇ
µ CCNP Service Provider 300-535 Mԇ} (Q119-Q124):} #119
What are two characteristics of the NFV architecture approach? (Choose two.)
  • A. It provides 70% more efficiency of network infrastructure.
  • B. It is specially designed for Internet providers.
  • C. It is specially designed for telecommunications service providers.
  • D. It decouples the network functions from proprietary hardware appliances.
  • E. It typically includes a hypervisor.
𰸣D,E
}f
Section: 2.0 Automation APIs and Protocols
Explanation/Reference: https://www.ciscolive.com/c/dam/ ... pdf/LTRSPM-2022.pdf
} #120
𰸣D,E
}f
} #121
Refer to the Cisco IOS XR configuration exhibit.
Which statement is correct?
  • A. The backup tunnel-te 10 tunnel is using the highest setup and hold priority settings of 7.
  • B. Interface gi0/0/0/10 is the protected link.
  • C. The fast-reroute command is missing under the (config-mpls-te-if)# configuration mode.
  • D. The backup tunnel path is learned dynamically.
𰸣B
}f
} #122
On the Cisco IOS XR, when using the match protocol command within a class-map to classify traffic, you noticed that the match protocol option on the Cisco IOS XR shows much fewer protocol options than on the Cisco IOS or IOS XE, like there is no option such as the match protocol yahoo-messenger command on the Cisco IOS XR. Why is this?
  • A. because the Cisco IOS XR router does not have the correct software packages installed
  • B. because flexible packet matching has not been enabled on the Cisco IOS XR router
  • C. because NBAR is not supported on the Cisco IOS XR
  • D. because when defining the class-map, the class-map type should be set to type inspect: class-map type inspect class-map-name command
𰸣C
}f
} #123
Which NETCONF datastore is locked while the network device configuration is edited?
  • A. startup
  • B. running
  • C. common
  • D. working
𰸣B
}f
Section: Automation and Orchestration Platforms
} #124
y㲻Ĺһx͵ijɿ᣿϶ϣǘӰɡNбҪrԼˡCiscoИI㑪ԓԼˮأ䌍ITJCԇ@JCYһ÷CiscoJCԇYǺҪY˅300-535ԇ׃ԽԽˡ
300-535C: https://www.vcesoft.com/300-535-pdf.html
Ciscoͬӕܾʣ֮ǰ300-535IJtⲻ࣬N@ЩA֪RЎ300-535 }߂ͨ^ʣ녢300-535JCԇᣬܶھ300-535}rڿijһ}XϤ^XeMһ}˼·ͽYˣ˽300-535ԇϢCisco 300-535}Md ̕rgȾͿͨ^ԇITJCWṩߙCisco 300-535C Cisco 300-535CJCԇ}죬ُIITJCCisco 300-535Cȫԇ}CҼpͨ^Cisco 300-535 C ԇ^ȫ~˿mȻϾWվҲPCisco 300-535JCԇPӖߣ҂ĮaƷƷ|Ƿdzá
ҲԵ֪@Nw|ҼLBnɑ֣࣬͏Ҽ^ıOTѣCiscoͬӕܾʣ֮ǰ300-535IJtⲻ࣬N@ЩA֪RЎ300-535 }߂ͨ^ʡ
ς300-535}Md &300-535Automating and Programming Cisco Collaboration Solutions녢300-535JCԇᣬܶھ300-535}rڿijһ}XϤ^XeMһ}˼·ͽYˣ˽300-535ԇϢ
Posted at 1/26/2026 12:28:01        Only Author  2#
Im so appreciative of your article, it really made an impression. FCP_FCT_AD-7.4 reliable new exam format questions shared for free! Best of luck in your exam preparations!
Posted at 1/27/2026 07:36:02        Only Author  3#
Your article is exceptional, thank you for sharing it with us! Free Test Workday-Pro-Integrations test materials for everyoneyour key to the next level in your career!
Posted at 1/31/2026 07:45:07        Only Author  4#
220-1102JʂYϤ20〜30rgѧֱˡԇYŤ֤ĤȤǤȤFϤޤ󡣺ˤΤ͘ԇYYϤζ{ܤ220-1102JԇY˺g˺ϸ񤷤ޤǩ`ϡ˽ΥϥѥʤŤʤۤ98100Ǥ뤳Ȥʾޤg`ʤʤγɹ220-1102Jȥ`˥󥰥ɤ100^Ƥޤ󥯤򥯥åǸҪʾǤΤǤꡢN220-1102JЩ`YǤޤ
