100% Pass 2026 Plat-Dev-301: Salesforce Certified Platform Developer II - Multip
78
Posted at 1/25/2026 10:21:45      View:133 | Replies:1        Print      Only Author   [Copy Link] 1#
We have handled professional Plat-Dev-301 practice materials for over ten years. Our experts have many years’ experience in this particular line of business, together with meticulous and professional attitude towards jobs. Their abilities are unquestionable, besides, Plat-Dev-301 practice materials are priced reasonably with three kinds. We also have free demo offering the latest catalogue and brief contents for your information, if you do not have thorough understanding of our materials. Many exam candidates build long-term relation with our company on the basis of our high quality Plat-Dev-301 practice materials.
CertkingdomPDF provides the most reliable and authentic Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) prep material there is. The 3 kinds of Salesforce Plat-Dev-301 preparation formats ensure that there are no lacking points in a student when he attempts the actual Plat-Dev-301 exam. The Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam registration fee varies between 100$ and 1000$, and a candidate cannot risk wasting his time and money, thus we ensure your success if you study from the updated Salesforce Plat-Dev-301 practice material. We offer the demo version of the actual Salesforce Plat-Dev-301 questions so that you may confirm the validity of the product before actually buying it, preventing any sort of regret.
Latest Plat-Dev-301 Exam Pass4sure - Valid Exam Plat-Dev-301 RegistrationCertkingdomPDF is a rich-experienced website specialized in the Salesforce dump torrent and real pdf dumps. These pdf study materials are concluded by our professional IT trainers who have a good knowledge of Plat-Dev-301 Exam Questions torrent. They check the updating of vce braindumps every day to ensure the accuracy of Plat-Dev-301 test questions and answers.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q166-Q171):NEW QUESTION # 166
A developer created a Lightning web component for the Account record page that displays the five most recently contacted Contacts for an Account. The Apex method, Contacts, returns a list of Contacts and will be wired to a property in the component.
Which two lines must change in the above code to make the Apex method able to be wired? Choose 2 answers
  • A. Remove private from line 09.
  • B. Add public to line 04.
  • C. Add @AuraEnabled {cacheable=true) to line 03.
  • D. Add @AuraEnabled {cacheable=trues) to line 08.
To make an Apex method callable from a Lightning Web Component, you need to annotate the method with @AuraEnabled and mark it as cacheable if it's only retrieving data without modifying it. Additionally, the method must be public to be accessible from the component.
Line 04: Needs @AuraEnabled(cacheable=true) to allow the method to be called from the Lightning Web Component and indicate that the method doesn't modify any data, making it suitable for caching.
Line 09: The method getFiveMostRecent should not be private because private methods cannot be called from a Lightning Web Component. Changing it to public (or default, which is equivalent to public within the same namespace) is required.
Lightning Web Components and Salesforce Data: Developer Documentation
@AuraEnabled Annotation: Apex Developer Guide
NEW QUESTION # 167
A developer created a JavaScript library that simplifies the development of repetitive tasks and features and uploaded the library as a static resource called rsutils in Salesforce. Another developer is coding a new Lightning web component (LWC) and wants to leverage the library, Which statement properly loads the static resource within the LWC?
  • A. impore {jsUtilities} from '@salasforce/resourceUrl/jsUtils';
  • B. const jsUtilivy = SA.get{'SResource.isUtils');
  • C. <lightning-require scripts="{|$Resource,jaUtils}"/>
  • D. import jsUtilities from '@salesforce/rescurceUr1/jaUtiles';
To load a static resource within a Lightning web component, you should use an import statement with the @salesforce/resourceUrl module. This statement correctly refers to the static resource by its name.
NEW QUESTION # 168
The Salesforce admin et Cloud Kicks created a custom object called Region_c to store all postal zip codes in the United States and the Cloud Kicks sales region the zip code belongs to.
Cloud Kicks wants a trigger on the Lead to populate the Region based on the Lead's zip code. Which code segment is the most efficient way to fulfill this request? A)
B)
C)
D)
  • A. Option A
  • B. Option C
  • C. Option B
  • D. Option D
NEW QUESTION # 169
A business requires that every parent record must have a child record. A developer writes an Apex method with two DML statements to insert a parent record and a child record.
A validation rule blocks child records from being created. The method uses a try/catch block to handle the DML exception.
What should the developer do to ensure the parent always has a child record?
  • A. Delete the parent record in the catch statement when an error occurs on the child record DML operation.
  • B. Set a database savepoint to rollback if there are errors.
  • C. Use addExror() on the parent record if an error occurs on the child record.
  • D. Use Catabase.inserc() and set the all = parameter to true,
By setting a savepoint before the DML operations and rolling back to that savepoint in the event of an exception, the developer can ensure that the parent record is not committed without a corresponding child record.
NEW QUESTION # 170
An org has a requirement that an Account must always have one and only one Contact listed as Primary. So selecting one Contact will de-select any others. The client wants a checkbox on the Contact called 'Is Primary' to control this feature.
The client also wants to ensure that the last name of every Contact is stored entirely in uppercase characters.
What is the optimal way to implement these requirements?
  • A. Write a single trigger on Contact for both after update and before update and callout to helper classes to handle each set of logic.
  • B. Write an after update trigger on Contact for the Is Primary logic and a separate before update trigger on Contact for the last name logic.
  • C. Write a Validation Rule on the Contact for the Is Primary logic and a before update trigger on Contact for the last name logic.
  • D. Write an after update trigger on Account for the Is Primary logic and a before update trigger on Contact for the last name logic.
A single trigger on Contact that handles both after update and before update events, utilizing helper classes for each logic set, is the most optimal implementation. It centralizes the logic for maintaining primary contacts and normalizing last names while allowing for clear separation of concerns through helper classes.
NEW QUESTION # 171
Our after sales services are also considerate. If you get any questions with our Plat-Dev-301 guide question, all helps are available upon request. Once you place your order this time, you will enjoy and experience comfortable and convenient services immediately. Besides, we do not break promise that once you fail the Plat-Dev-301 Exam, we will make up to you and relieve you of any loss. Providing with related documents, and we will give your money back. We have been always trying to figure out how to provide warranty service if customers have questions with our Plat-Dev-301 real materials.
Latest Plat-Dev-301 Exam Pass4sure: https://www.certkingdompdf.com/Plat-Dev-301-latest-certkingdom-dumps.html
Salesforce Exam Plat-Dev-301 Pattern As we all know, if the content of your exam materials is complex and confusing, then if you want to pass the exam, you will be quite worried, If you are not fortune enough to acquire the Plat-Dev-301 certification at once, you can unlimitedly use our product at different discounts until you reach your goal and let your dream comes true, CertkingdomPDF provide different training tools and resources to prepare for the Salesforce Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice Ebook exam.
From the time our company was just established until now, we have Valid Exam Plat-Dev-301 Registration conducted multiple surveys of users, It starts with the basics of using R and progresses into data manipulation and model building.
Why do you need valid and updated Salesforce Plat-Dev-301 Exam Questions?As we all know, if the content of your exam materials is Plat-Dev-301 complex and confusing, then if you want to pass the exam, you will be quite worried, If you are not fortune enough to acquire the Plat-Dev-301 certification at once, you can unlimitedly use our product at different discounts until you reach your goal and let your dream comes true.
CertkingdomPDF provide different training tools and resources to prepare for the Salesforce Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice Ebook exam, Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 test torrent materials.
After compilation and verification, they make the more useful and updated Plat-Dev-301 exam training material for all of you.
Posted at 2/22/2026 22:43:32        Only Author  2#
I sincerely thank you for sharing this impactful article! I used the Examcollection WRT free dumps to get promoted and earn more. Now, it’s available for free. Best of luck with your career!
