[General] Exam AWS-Certified-Developer-Associate Tests, New AWS-Certified-Developer-Associ
99
【General】 Exam AWS-Certified-Developer-Associate Tests, New AWS-Certified-Developer-Associ
Posted at 1/25/2026 12:10:50      View:166 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ValidDumps AWS-Certified-Developer-Associate PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=12ZM7HRLW48c4WP-CKsDN1qGUN3FDlXtp
For one thing, the most advanced operation system in our company which can assure you the fastest delivery speed on our AWS-Certified-Developer-Associate exam questions. For another thing, with the online app version of our AWS-Certified-Developer-Associate actual exam, you can just feel free to practice the questions in our AWS-Certified-Developer-Associate Training Materials on all kinds of electronic devices. In addition, under the help of our AWS-Certified-Developer-Associate exam questions, the pass rate among our customers has reached as high as 98% to 100%. We are look forward to become your learning partner in the near future.
The AWS Certified Developer - Associate certification is an excellent choice for developers who want to validate their skills and knowledge in cloud computing. With its focus on AWS services and best practices for application development, this certification can help professionals stand out in a crowded job market and advance their careers in cloud computing.
New Amazon AWS-Certified-Developer-Associate Dumps Files, AWS-Certified-Developer-Associate Valid Test DurationAbout the oncoming AWS-Certified-Developer-Associate exam, every exam candidates are wishing to utilize all intellectual and technical skills to solve the obstacles ahead of them to go as well as it possibly could. So the pending exam causes a panic among the exam candidates. The help of our AWS-Certified-Developer-Associate Exam prepare is just in time. In the present posture, our AWS-Certified-Developer-Associate study materials are your best choice. We provide you with excellent prepare materials for you to pass the exam and get the certification.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q18-Q23):NEW QUESTION # 18
What item operation allows the retrieval of multiple items from a DynamoDB table in a single API call?
  • A. GetMultipleItems
  • B. GetItem
  • C. BatchGetItem
  • D. GetItemRange
https://docs.aws.amazon.com/amaz ... I_BatchGetItem.html
NEW QUESTION # 19
A developer is creating an application that must be able to generate API responses without backend integrations. Multiple internal teams need to work with the API while the application is still in development.
Which solution will meet these requirements with the LEAST operational overhead?
  • A. Create an Amazon API Gateway HTTP API. Provision a VPC link, and set up a private integration on the API to connect to a VPC.
  • B. Create an Amazon API Gateway REST API. Set up a proxy resource that has the HTTP proxy integration type.
  • C. Create an Amazon API Gateway HTTP API. Enable mock integration on the method of the API resource.
  • D. Create an Amazon API Gateway REST API. Enable mock integration on the method of the API resource.
Comprehensive Detailed and Lengthy Step-by-Step Explanation with All AWS Developer References:
1. Understanding the Use Case:
The API needs to:
* Generate responses without backend integrations: This indicates the use of mock responses for testing.
* Be used by multiple internal teams during development.
* Minimize operational overhead.
2. Key Features of Amazon API Gateway:
* REST APIs: Fully managed API Gateway option that supports advanced capabilities like mock integrations, request/response transformation, and more.
* HTTP APIs: Lightweight option for building APIs quickly. It supports fewer features but has lower operational complexity and cost.
* Mock Integration: Allows API Gateway to return pre-defined responses without requiring backend integration.
3. Explanation of the Options:
* Option A:"Create an Amazon API Gateway REST API. Set up a proxy resource that has the HTTP proxy integration type."A proxy integration requires a backend service for handling requests. This does not meet the requirement of "no backend integrations."
* Option B:"Create an Amazon API Gateway HTTP API. Provision a VPC link, and set up a private integration on the API to connect to a VPC."This requires setting up a VPC and provisioning resources, which increases operational overhead and is unnecessary for this use case.
* Option C:"Create an Amazon API Gateway HTTP API. Enable mock integration on the method of the API resource."While HTTP APIs can enable mock integrations, they have limited support for advanced features compared to REST APIs, such as detailed request/response customization. REST APIs are better suited for development environments requiring mock responses.
* Option D:"Create an Amazon API Gateway REST API. Enable mock integration on the method of the API resource."This is the correct answer. REST APIs with mock integration allow defining pre- configured responses directly within API Gateway, making them ideal for scenarios where backend services are unavailable. It provides flexibility for testing while minimizing operational overhead.
4. Implementation Steps:
To enable mock integration with REST API:
* Create a REST API in API Gateway:
* Open the API Gateway Console.
* Choose Create API > REST API.
* Define the API Resource and Methods:
* Add a resource and method (e.g., GET or POST).
* Set Up Mock Integration:
* Select the method, and in the Integration Type, choose Mock Integration.
* Configure the Mock Response:
* Define a 200 OK response with the desired response body and headers.
* Deploy the API:
* Deploy the API to a stage (e.g., dev) to make it accessible.
5. Why REST API Over HTTP API?
* REST APIs support detailed request/response transformations and robust mock integration features, which are ideal for development and testing scenarios.
* While HTTP APIs offer lower cost and simplicity, they lack some advanced features required for fine- tuned mock integrations.
Amazon API Gateway REST API Features
Mock Integration in API Gateway
Comparison of REST and HTTP APIs in API Gateway
AWS API Gateway Pricing
NEW QUESTION # 20
A company needs to secure its existing website running behind an Elastic Load Balancer. The website's Amazon EC2 instances are CPU-constrained.
What should be done to secure the website while not increasing the CPU load on the EC2 web servers? (Select TWO.)
  • A. Configure an Elastic Load Balancer with SSL pass-through.
  • B. Configure an Elastic Load Balancer with SSL termination.
  • C. Configure an Elastic Load Balancer with a Loadable Storage System.
  • D. Configure SSL certificates on an Elastic Load Balancer.
  • E. Install SSL certificates on the EC2 instances.
Answer: D,E
NEW QUESTION # 21
TestAWS (with AWS account ID 111122223333) has created 50 IAM users for its organization's employees. TestAWS wants to make the AWS console login URL for all IAM users as: https:// TestAWS.signin.aws.amazon.com/console/. How can this be configured?
  • A. Create a bucket with the name TestAWS and map it with the IAM alias
  • B. It is not possible to have capital letters as a part of the alias name
  • C. For the AWS account, create an alias TestAWS for the IAM login
  • D. The user needs to use Route 53 to map the TestAWS domain and IAM URL
If a user wants the URL of the AWS IAM sign-in page to have the company name instead of the AWS account ID, he can create an alias for his AWS account ID. The alias must be unique across all Amazon Webservices products and contain only digits, lowercase letters, and hyphens.
http://docs.aws.amazon.com/IAM/latest/UserGuide/AccountAlias.html
NEW QUESTION # 22
A Developer is writing an application that will run on Amazon EC2 instances in an Auto Scaling group. The Developer wants to externalize session state to support the application.
Which services will meet these needs? (Choose two.)
  • A. Amazon SQS
  • B. Amazon DynamoDB
  • C. Amazon Cognito
  • D. Amazon EBS
  • E. Amazon ElastiCache
https://forums.aws.amazon.com/thread.jspa?threadID=238457
NEW QUESTION # 23
Getting the test AWS-Certified-Developer-Associate certification maybe they need to achieve the goal of the learning process, have been working for the workers, have more qualifications can they provide wider space for development. The AWS-Certified-Developer-Associate actual exam guide can provide them with efficient and convenient learning platform so that they can get the certification as soon as possible in the shortest possible time. A high degree may be a sign of competence, getting the test AWS-Certified-Developer-Associate Certification is also a good choice. When we get the AWS-Certified-Developer-Associate certificates, we have more options to create a better future.
New AWS-Certified-Developer-Associate Dumps Files: https://www.validdumps.top/AWS-Certified-Developer-Associate-exam-torrent.html
What's more, part of that ValidDumps AWS-Certified-Developer-Associate dumps now are free: https://drive.google.com/open?id=12ZM7HRLW48c4WP-CKsDN1qGUN3FDlXtp
Posted at 2/2/2026 03:52:01        Only Author  2#
Your article is breathtakingly good, thank you for sharing it! Free Valid practice CIS-RCI test online materials are the stepping stones to your career advancement and salary growth!
Posted at 2/23/2026 11:36:42        Only Author  3#
当社SplunkのSPLK-1003学習ツールでは、選択できる3つのバージョンがあり、PDFバージョン、PCバージョン、APPオンラインバージョンが含まれます。各バージョンはさまざまな状況や機器に対応しており、最も便利な方法を選択してSPLK-1003テストトレントを学習できます。たとえば、APPオンラインバージョンは印刷可能で、ダウンロードへの即時アクセスを促進します。 SPLK-1003ガイドトレントはいつでもどこでも学習できます。 SPLK-1003学習ツールのPCバージョンは、実際の試験のシナリオを刺激できます。 365日間の無料アップデートと無料デモを提供しています。
Posted at 3/5/2026 12:20:02        Only Author  4#
The article was quite thought-provoking. New N10-009 test blueprint offers great insights, and it's completely free to access.
