[General] FCSS_SDW_AR-7.4 - Valid Current FCSS - SD-WAN 7.4 Architect Exam Content
95
General FCSS_SDW_AR-7.4 - Valid Current FCSS - SD-WAN 7.4 Architect Exam Content
Posted at 1/25/2026 13:36:54      View137 | Replies2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Actual4Labs FCSS_SDW_AR-7.4 dumps from Cloud Storage: https://drive.google.com/open?id=1LVzEx20kgwIMFobo4IZpKp0wNXNco8Kr
Once you have used our FCSS_SDW_AR-7.4 exam training in a network environment, you no longer need an internet connection the next time you use it, and you can choose to use FCSS_SDW_AR-7.4 exam training at your own right. Our FCSS_SDW_AR-7.4 Exam Training do not limit the equipment, do not worry about the network, this will reduce you many learning obstacles, as long as you want to use FCSS_SDW_AR-7.4 test guide, you can enter the learning state.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • Centralized Management: This domain evaluates network administrators competence in deploying and managing SD-WAN configurations centrally using FortiManager. It includes tasks such as implementing branch configurations and utilizing overlay templates to streamline network management.
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
Free PDF Quiz Fortinet - FCSS_SDW_AR-7.4 - FCSS - SD-WAN 7.4 Architect Pass-Sure Current Exam ContentWith our FCSS_SDW_AR-7.4 study matetials, you can make full use of those time originally spent in waiting for the delivery of exam files so that you can get preparations as early as possible. There is why our FCSS_SDW_AR-7.4 learning prep exam is well received by the general public. I believe if you are full aware of the benefits the immediate download of our PDF study exam brings to you, you will choose our FCSS_SDW_AR-7.4 actual study guide. Just come and buy it! You will be surprised about our high quality.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q57-Q62):NEW QUESTION # 57
Your FortiGate is in production. To optimize WAN link use and improve redundancy, you enable and configure SD-WAN.
What must you do as part of this configuration update process?
  • A. Replace references to interfaces used as SD-WAN members in the firewall policies.
  • B. Replace references to interfaces used as SD-WAN members in the routing configuration.
  • C. Purchase and install the SD-WAN license, and reboot the FortiGate device.
  • D. Disable the interface that you want to use as an SD-WAN member.
When you enable SD-WAN and add interfaces as SD-WAN members, those interfaces are no longer referenced directly in routing. You must replace routing configuration references (e.g., static routes, policy routes) with the SD-WAN zone. Firewall policies, however, can still point to the SD-WAN zone without requiring replacement of individual member interfaces.
NEW QUESTION # 58
Which three characteristics apply to provisioning templates available on FortiManager? (Choose three.)
  • A. A CLI template can be of type CLI script or Perl script.
  • B. CLI templates are applied in order, from top to bottom.
  • C. Each template group can contain up to three IPsec tunnel templates.
  • D. A CLI template group can contain CLI templates of both types.
  • E. A template group can include a system template and an SD-WAN template.
Answer: B,D,E
Template groups can include both system and SD-WAN templates to streamline configuration deployment.
A CLI template group can include both CLI Script and CLI Snippet types.
CLI templates are applied in top-to-bottom order, which affects configuration precedence.
NEW QUESTION # 59
Refer to the exhibits.
You use FortiManager to configure SD-WAN on three branch devices.
When you install the device settings. FortiManager prompts you with the error "Copy Failed" for the device branch1_fat When you click the log button. FortiManager displays the message shown in the exhibit.
  • A. Based on the exhibits, which statement best describes the issue and how you can resolve it?
  • B. Check the connection between branch1_fgt and FortiManager
  • C. Remove the installation target for the SD-WAN member port4. You cannot combine metadata variable and installation targets.
  • D. Check the metadata variable definitions, and review the per-device mapping configuration.
  • E. Gateways for all members in a zone must be defined the same way. Specify the gateway of the SD- WAN member port! without metadata variables.
NEW QUESTION # 60
You want FortiGate to use SD-WAN rules to steer local-out traffic.
Which two constraints should you consider? (Choose two.)
  • A. By default, local-out traffic does not use SD-WAN.
  • B. You must configure each local-out feature individually to use SD-WAN.
  • C. You can steer local-out traffic only with SD-WAN rules that use the manual strategy.
  • D. By default, FortiGate uses SD-WAN rules only for local-out traffic that corresponds to ping and traceroute.
By default, local-out traffic does not use SD-WAN # FortiGate normally sends local-out traffic (e.g., DNS, NTP, FortiGuard updates) directly through its interfaces without applying SD-WAN rules.
You must configure each local-out feature individually to use SD-WAN # To steer local-out traffic via SD- WAN, you must explicitly configure the desired local-out features (e.g., DNS, FortiGuard, CAPWAP) to use SD-WAN rules.
NEW QUESTION # 61
Refer to the exhibits. You connect to a device behind a branch FortiGate device and initiate a ping test. The device is part of the LAN subnet and its IP address is 10.0.1.101.
Based on the exhibits, which interface uses branch 1_fgt to steer the test traffic?
  • A. port2
  • B. HUB1-VPN1
  • C. port1
  • D. port4
The ping target IP 157.240.19.35 matches an App Control entry for Facebook (ID 15832).
According to the diagnose firewall route list output, this application is handled by vwl_service=2 (Non-Critical-DIA), which routes traffic via oif=4 (port2). Therefore, FortiGate steers the Facebook test traffic through port2.
NEW QUESTION # 62
The Fortinet PDF Questions format designed by the Actual4Labs will facilitate its consumers. Its portability helps you carry on with the study anywhere because it functions on all smart devices. You can also make notes or print out the Fortinet FCSS_SDW_AR-7.4 pdf questions. The simple, systematic, and user-friendly Interface of the Fortinet FCSS_SDW_AR-7.4 Pdf Dumps format will make your preparation convenient. The Actual4Labs is on a mission to support its users by providing all the related and updated Fortinet FCSS_SDW_AR-7.4 exam questions to enable them to hold the Fortinet FCSS_SDW_AR-7.4 certificate with prestige and distinction.
FCSS_SDW_AR-7.4 Certification Questions: https://www.actual4labs.com/Fortinet/FCSS_SDW_AR-7.4-actual-exam-dumps.html
What's more, part of that Actual4Labs FCSS_SDW_AR-7.4 dumps now are free: https://drive.google.com/open?id=1LVzEx20kgwIMFobo4IZpKp0wNXNco8Kr
Posted at 1/31/2026 19:45:26        Only Author  2#
Your article was so impressive, thank you for sharing! I owe my promotion and raise to the Certification C_BCBTM_2502 book torrent questions, and today Im sharing them for free with all of you!
Posted at 2/16/2026 02:59:35        Only Author  3#
I cant thank you enough for your article, it really opened my mind. I got promoted and received a raise thanks to this Valid visual FCP_FSM_AN-7.2 cert exam. Now, Im sharing it for free with everyone. Best of luck with your career growth!
