[General] Free PDF Quiz Microsoft - AI-102 - Designing and Implementing a Microsoft Azure
94
General Free PDF Quiz Microsoft - AI-102 - Designing and Implementing a Microsoft Azure
Posted at 1/25/2026 16:10:03      View141 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New AI-102 dumps are available on Google Drive shared by ExamBoosts: https://drive.google.com/open?id=1zduub5pVQdTxWt0wzFZlsxrTYmdbJtEs
ExamBoosts is one of the leading platforms that has been helping Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam candidates for many years. Over this long time period we have helped Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam candidates in their preparation. They got help from ExamBoosts Microsoft AI-102 Practice Questions and easily got success in the final Microsoft AI-102 certification exam. You can also trust Microsoft AI-102 exam dumps and start preparation with complete peace of mind and satisfaction.
The countless candidates have already passed their AI-102 certification exam and they all used the real, valid, and updated ExamBoosts AI-102 exam questions. So, why not, take a decision right now and ace your AI-102 Exam Preparation with top-notch AI-102 exam questions?
Valid AI-102 Test Simulator | AI-102 New Study GuideThe latest AI-102 dumps collection covers everything you need to overcome the difficulty of real questions and certification exam. Accurate AI-102 test answers are tested and verified by our professional experts with the high technical knowledge and rich experience. You may get answers from other vendors, but our AI-102 briandumps pdf are the most reliable training materials for your exam preparation.
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q305-Q310):NEW QUESTION # 305
Hotspot Question
You have an Azure subscription that contains an Azure AI Content Safety resource named resource1.
You need to add a custom category to resource1.
How should you complete the cURL statement? To answer, select the appropriate options in the answer area.
"prompt"
The "prompt" field is used to specify the actual input text that should be evaluated for content safety. In this case, it represents the text prompts about learning advice that will be processed for moderation.
"sampleBlobUrl"
This field points to the Azure Blob Storage URL where a JSONL file is stored. The JSONL file contains structured moderation rules or additional content data for analysis.
NEW QUESTION # 306
You have a collection of Microsoft Word documents and PowerPoint presentations in German.
You need to create a solution to translate the file to French. The solution must meet the following requirements:
* Preserve the original formatting of the files.
* Support the use of s custom glossary.
You create a blob container for German files and a blob container for French files. You upload the original files to the container for German files.
Which three actions should you perform in sequence actions from the list of actions to the answer area and arrange them in the correct order.
NEW QUESTION # 307
You are building a call handling system that will receive calls from French-speaking and German-speaking callers. The system must perform the following tasks;
* Capture inbound voice messages as text.
* Replay messages in English on demand.
Which Azure Cognitive Services should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 308
You have data saved in the following format.
Which format was used?
  • A. CSV
  • B. JSON
  • C. HTML
  • D. YAML
The given data format is:
FirstName,LastName,Age,LeisureHobby,SportsHobby
John,Smith,23,Reading,Basketball
Ben,Smith,21,Guitar,Curling
* This format uses commas to separate fields, with the first row as column headers and subsequent rows as records.
* This is the definition of CSV (Comma-Separated Values) format.
Now let's eliminate the other options:
* JSON: Uses { } braces and key-value pairs like "FirstName": "John". Not shown here.
* HTML: Uses <tags> for structure (e.g., <table>, <tr>, <td>). Not shown here.
* YAML: Uses indentation and key-value pairs (e.g., FirstName: John). Not shown here.
Therefore, the correct format is CSV.
The  answer: A. CSV
* Common data formats: CSV, JSON, Avro, and Parquet
NEW QUESTION # 309
You need to enable speech capabilities for a chatbot.
Which three actions should you perform? Each correct answer presents part of the solution.
  • A. Create a Speech service.
  • B. Register a Cortana channel.
  • C. Enable CORS for the chatbot app.
  • D. Create a Language Understanding service.
  • E. Register a Direct Line Speech channel.
  • F. Enable WebSockets for the chatbot app.
Answer: A,E,F
You can use the Speech service to voice-enable a chat bot.
The Direct Line Speech channel uses the text-to-speech service, which has neural and standard voices.
You'll need to make a small configuration change so that your bot can communicate with the Direct Line Speech channel using web sockets.
https://docs.microsoft.com/en-us ... le-your-bot-speech-
NEW QUESTION # 310
Most people said the process is more important than the result, but as for AI-102 exam, the result is more important than the process, because it will give you real benefits after you obtain AI-102 exam certification in your career in IT industry. If you have made your decision to pass the exam, our AI-102 exam software will be an effective guarantee for you to Pass AI-102 Exam. Maybe you are still doubtful about our product, it does't matter, but if you try to download our free demo of our AI-102 exam software first, you will be more confident to pass the exam which is brought by our ExamBoosts.
Valid AI-102 Test Simulator: https://www.examboosts.com/Microsoft/AI-102-practice-exam-dumps.html
The website pages list the important information about our AI-102 real quiz, the exam name and code, the updated time, the total quantity of the questions and answers, the characteristics and merits of the product, the price, the discounts to the client, the details and the guarantee of our AI-102 training materials, the contact methods, the evaluations of the client on our product and the related exams, Even though our AI-102 certification training: Designing and Implementing a Microsoft Azure AI Solution are the best study materials in the IT field, we still keep our price of the exam study guide as the most favorable one in the market, just because we are devoted to letting as many people as possible to have access to these useful resources.
Do you enjoy sketching outdoors, They're simply fringe groups that will always be fringe, The website pages list the important information about our AI-102 real quiz, the exam name and code, the updated time, the total quantity of the questions and answers, the characteristics and merits of the product, the price, the discounts to the client, the details and the guarantee of our AI-102 Training Materials, the contact methods, the evaluations of the client on our product and the related exams.
AI-102 exam dumps vce free download, Microsoft AI-102 braindumps pdfEven though our AI-102 certification training: Designing and Implementing a Microsoft Azure AI Solution are the best study materials in the IT field, we still keep our price of the exam study guide as the most favorable one in the market, just because AI-102 we are devoted to letting as many people as possible to have access to these useful resources.
We, at ExamBoosts, back all of our Designing and Implementing a Microsoft Azure AI Solution dumps, If you hope to pass the Designing and Implementing a Microsoft Azure AI Solution exam on your first attempt, you must be studied with real AI-102 exam questions verified by Microsoft AI-102.
Your Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam anxiety will be reduced by having the chance to practice under the AI-102 real exam environment created by this software.
P.S. Free 2026 Microsoft AI-102 dumps are available on Google Drive shared by ExamBoosts: https://drive.google.com/open?id=1zduub5pVQdTxWt0wzFZlsxrTYmdbJtEs
Posted at 1/29/2026 21:28:58        Only Author  2#
Your article really made me think, thank you for the fresh perspective. Sharing Latest C_THR81_2505 test review resources for freegood luck with your studies!
Posted at 2/14/2026 02:11:26        Only Author  3#
This article is absolutely remarkable, Im so thankful for your share. Taking on the SCS-C03 cheap dumps exam soon. Hope I nail it!
