SOA-C02 Free Exam Dumps | Certification SOA-C02 Questions
Posted at 1/25/2026 16:55:31
2026 Latest TorrentExam SOA-C02 PDF Dumps and SOA-C02 Exam Engine Free Share: https://drive.google.com/open?id=15ZahEtaekOnN-QZf-DEo1VGiu2nUi55k
Browsers including MS Edge, Internet Explorer, Safari, Opera, Chrome, and Firefox also support the online version of the Amazon SOA-C02 practice exam. Features we have discussed in the above section of the TorrentExam AWS Certified SysOps Administrator - Associate (SOA-C02) (SOA-C02) practice test software are present in the online format as well. But the web-based version of the SOA-C02 practice exam requires a continuous internet connection.
We provide you free demo with you to help you have a deeper understanding about SOA-C02 study materials. Free demo can be found in our website, and we recommend you to have a try before buying. Furthermore, SOA-C02 exam materials of us have the questions and answers, and you can have a convenient check of your answers after you finish practicing. We are pass guarantee and money back guarantee for your failure after purchasing SOA-C02 Study Materials. You just need to give your failure scanned and we will give you full refund. Choose us, and we can help you to pass the exam successfully.
Certification SOA-C02 Questions & Brain SOA-C02 ExamIt is a matter of common sense that pass rate of a kind of SOA-C02 exam torrent is the only standard to testify weather it is effective and useful. I believe that you already have a general idea about the advantages of our SOA-C02 exam question, but now I would like to show you the greatest strength of our SOA-C02 Guide Torrent --the highest pass rate. According to the statistics, the pass rate among our customers who prepared the exam under the guidance of our SOA-C02 guide torrent has reached as high as 98% to 100% with only practicing our SOA-C02 exam torrent for 20 to 30 hours.
The SOA-C02 exam is a computer-based exam that consists of 65 multiple-choice and multiple-response questions. Candidates have 130 minutes to complete the exam, and the passing score is 720 out of 1000. SOA-C02 Exam is available in English, Japanese, and Simplified Chinese.
Amazon AWS Certified SysOps Administrator - Associate (SOA-C02) Sample Questions (Q139-Q144):NEW QUESTION # 139
A company runs a web application on three Amazon EC2 instances behind an Application Load Balancer (ALB). The company notices that random periods of increased traffic cause a degradation in the application's performance. A SysOps administrator must scale the application to meet the increased traffic.
Which solution meets these requirements?
- A. Create an Amazon EventBridge (Amazon CloudWatch Events) rule to monitor application latency and add an EC2 instance to the ALB if the desired threshold is reached.
- B. Deploy the application to an Auto Scaling group of EC2 instances with a target tracking scaling policy.
Attach the ALB to the Auto Scaling group. - C. Create an Amazon CloudWatch alarm to monitor application latency and increase the size of each EC2 instance if the desired threshold is reached.
- D. Deploy the application to an Auto Scaling group of EC2 instances with a scheduled scaling policy.
https://docs.aws.amazon.com/auto ... arget-tracking.html
NEW QUESTION # 140
An organization with a large IT department has decided to migrate to AWS. With different job functions in the IT department, it is not desirable to give all users access to all AWS resources.
Currently the organization handles access via LDAP credentials?
- A. Use AWS CloudFormation to create IAM roles. Deploy Direct Connect to allow access to the on- premises LDAP server.
- B. Create an AWS Directory Service Simple AD. Replicate the on-premises LDAP directory to Simple AD.
- C. Create a Lambda function to read LDAP groups and automate the creation of IAM users.
- D. Federate the LDAP directory with IAM using SAML. Create different IAM roles to correspondent to different LDAP groups to limit permissions.
NEW QUESTION # 141
A SysOps administrator is setting up a fleet of Amazon EC2 instances in an Auto Scaling group for an application. The fleet should have 50% CPU available at that times to accommodate bursts of traffic. The load will increase significantly between the hours of 09:00 and 17:00,7 days a week How should the SysOps administrator configure the scaling of the EC2 instances to meet these requirements?
- A. Create a target tracking scaling policy that runs when the CPU utilization is higher than 50%. Create a scheduled scaling policy that ensures that the fleet is available at 09:00 Create a second scheduled scaling policy that scales in the fleet at 17:00
- B. Set the Auto Scaling group to start with 2 instances by setting the desired instances maximum instances, and minimum instances to 2 Create a scheduled scaling policy that ensures that the fleet is available at
09:00 - C. Create a scheduled scaling policy that ensures that the fleet is available at 09.00. Create a second scheduled scaling policy that scales in the fleet at 17:00
- D. Create a target tracking scaling policy that runs when the CPU utilization is higher than 90%
NEW QUESTION # 142
A company deploys AWS infrastructure in a VPC that has an internet gateway. The VPC has public subnets and private subnets. An Amazon RDS for MySQL DB instance is deployed in a private subnet. An AWS Lambda function uses the same private subnet and connects to the DB instance to query data.
A developer modifies the Lambda function to require the function to publish messages to an Amazon Simple Queue Service (Amazon SQS) queue. After these changes, the Lambda function times out when it tries to publish messages to the SQS queue.
Which solutions will resolve this issue? (Choose two.)
- A. Create an interface endpoint for Amazon SQS in the VPC.
- B. Deploy an RDS proxy. Configure the Lambda function to connect to the DB instance through the proxy.
- C. Create a gateway endpoint for Amazon SQS in the VPC.
- D. Reconfigure the Lambda function so that the function is not connected to the VPC.
- E. Deploy a NAT gateway. Update the private subnet's route table to route all traffic to the NAT gateway.
Answer: A,E
A NAT gateway with a route from the private subnet lets the Lambda function reach SQS's public endpoint.
An interface VPC endpoint for SQS provides private connectivity to SQS without internet. Either restores outbound access so the publish call succeeds.
NEW QUESTION # 143
A company hosts an application on Amazon EC2 instances behind an Application Load Balancer (ALB). One of the company's vendors needs a static IP address. The vendor will add this static IP address to its outbound allow list so that the vendor can access the application on the EC2 instances.
Which solution will provide the static IP address?
- A. Associate an AWS WAF web ACL that has an IP match condition rule with the ALB.
- B. Create a VPC endpoint. Associate the VPC endpoint with the ALB.
- C. Replace the ALB with a Network Load Balancer.
- D. Associate an Elastic IP address with the ALB.
* Objective:
* Provide a static IP address that the vendor can whitelist for accessing the application.
* Using Network Load Balancer (NLB):
* Unlike Application Load Balancers, NLBs support static IP addresses through Elastic IPs.
* NLBs operate at the transport layer (Layer 4) and are ideal for use cases requiring a static IP.
* Steps to Implement:
* Step 1: Create an NLB in the same VPC as the application.
* Step 2: Associate Elastic IP addresses with the NLB subnets.
* Step 3: Update the target group to point to the existing EC2 instances.
* Step 4: Update DNS records to map the application domain (www.example.com) to the NLB's static IP or DNS name.
* AWS References:
* Elastic IPs with NLB:Static IPs for NLB
* NLB vs. ALB:Comparison of Load Balancers
* Why Other Options Are Incorrect:
* Option A: ALBs do not support Elastic IPs.
* Option B: AWS WAF is for web access control, not providing static IPs.
* Option C: VPC endpoints do not replace load balancers and are unrelated to static IP requirements.
NEW QUESTION # 144
You do not worry about that you get false information of SOA-C02 guide materials. According to personal preference and budget choice, choosing the right goods to join the shopping cart. The 3 formats of SOA-C02 study materials are PDF, Software/PC, and APP/Online. Each format has distinct strength and shortcomings. We have printable PDF format prepared by experts that you can study our SOA-C02 training engine anywhere and anytime as long as you have access to download. We also have installable software application which is equipped with SOA-C02 simulated real exam environment.
Certification SOA-C02 Questions: https://www.torrentexam.com/SOA-C02-exam-latest-torrent.html
- Knowledge SOA-C02 Points 📃 Questions SOA-C02 Exam 🧔 Latest SOA-C02 Dumps Ppt 🧸 Download ▷ SOA-C02 ◁ for free by simply searching on 《 [url]www.prepawayete.com 》 🦢Reliable SOA-C02 Study Guide[/url]
- Authorized Amazon SOA-C02 Free Exam Dumps With Interarctive Test Engine - Well-Prepared Certification SOA-C02 Questions 🦆 Simply search for ▷ SOA-C02 ◁ for free download on ( [url]www.pdfvce.com ) 👹SOA-C02 Test Prep[/url]
- SOA-C02 Free Exam Dumps - Amazon Certification SOA-C02 Questions: AWS Certified SysOps Administrator - Associate (SOA-C02) Pass for Sure ⏫ Easily obtain ✔ SOA-C02 ️✔️ for free download through 【 [url]www.examcollectionpass.com 】 🤎SOA-C02 Test Prep[/url]
- Reliable SOA-C02 Test Voucher 🤍 Questions SOA-C02 Exam 🐮 SOA-C02 Exam Overviews 🚦 Search for ➥ SOA-C02 🡄 and easily obtain a free download on ▛ [url]www.pdfvce.com ▟ 📍Questions SOA-C02 Exam[/url]
- SOA-C02 Practice Exam Questions 👲 Questions SOA-C02 Exam 🏫 New SOA-C02 Exam Notes 🔫 Immediately open ➥ [url]www.troytecdumps.com 🡄 and search for ▷ SOA-C02 ◁ to obtain a free download 🌒SOA-C02 Exam Score[/url]
- Latest SOA-C02 Dumps Ebook 🅿 SOA-C02 Visual Cert Exam 🐜 Reliable SOA-C02 Test Voucher ‼ Simply search for ▶ SOA-C02 ◀ for free download on { [url]www.pdfvce.com } 👙Reliable SOA-C02 Test Blueprint[/url]
- SOA-C02 Updated Torrent - SOA-C02 Valid Practice - SOA-C02 Test Engine 🏴 Search for ▶ SOA-C02 ◀ and easily obtain a free download on ➡ [url]www.dumpsquestion.com ️⬅️ 😉Latest SOA-C02 Study Materials[/url]
- SOA-C02 Exam Overviews 📌 Knowledge SOA-C02 Points 🕸 Reliable SOA-C02 Test Blueprint 🔃 Open website ⮆ [url]www.pdfvce.com ⮄ and search for ⮆ SOA-C02 ⮄ for free download ❇Latest SOA-C02 Dumps Ebook[/url]
- Newest SOA-C02 Free Exam Dumps, Ensure to pass the SOA-C02 Exam 😶 Enter ▛ [url]www.prep4sures.top ▟ and search for ➥ SOA-C02 🡄 to download for free 🐩Latest SOA-C02 Dumps Ebook[/url]
- Pass SOA-C02 Test Guide 🥄 SOA-C02 Exam Score 🤳 Latest SOA-C02 Dumps Ppt 🧗 Easily obtain ▶ SOA-C02 ◀ for free download through ☀ [url]www.pdfvce.com ️☀️ 🪀Valid SOA-C02 Exam Vce[/url]
- Latest Real SOA-C02 Exam 🧸 Questions SOA-C02 Exam 💖 SOA-C02 Practice Exam Questions 👔 Open website ➽ [url]www.pass4test.com 🢪 and search for { SOA-C02 } for free download 🔖Reliable SOA-C02 Study Guide[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. Free 2026 Amazon SOA-C02 dumps are available on Google Drive shared by TorrentExam: https://drive.google.com/open?id=15ZahEtaekOnN-QZf-DEo1VGiu2nUi55k
