Free PDF HP - High Hit-Rate HPE7-A03 - Aruba Certified Campus Access Architect E
Posted at 1/25/2026 17:04:59
View145
Replies0
P.S. Free 2026 HP HPE7-A03 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1vANeNEhV82vDO48JMaLR92JFbMG4H_m9
Do you want to pass your exam by using the least time? HPE7-A03 exam braindumps of us can do that for you. With skilled professionals to compile and verify, HPE7-A03 exam dumps of us is high quality and accuracy. You just need to spend 48 to 72 hours on practicing, and you can pass your exam. We are pass guaranteed and money back guaranteed. If you fail to pass the exam, we will give you full refund. Besides, we offer you free demo to have a try before buying HPE7-A03 Exam Dumps. We also have free update for one year after purchasing.
The APP online version of our HPE7-A03 real quiz boosts no limits for the equipment being used and it supports any electronic equipment and the off-line use. So you can apply this version of our HPE7-A03 exam questions on IPAD, phone and laptop just as you like. If only you open it in the environment with the network for the first time you can use our HPE7-A03 Training Materials in the off-line condition later. You will find that APP online version is quite enjoyable to learn our study materials.
Certification HPE7-A03 Training & Questions HPE7-A03 ExamIf you are already an employee or busy in your routine, you can prepare Aruba Certified Campus Access Architect Exam (HPE7-A03) exam quickly with PrepAwayTest pdf questions. HPE7-A03 pdf exam questions help applicants study for the Aruba Certified Campus Access Architect Exam (HPE7-A03) exam at any time from any location. With the pdf questions, it will be easy for you to complete the Aruba Certified Campus Access Architect Exam (HPE7-A03) exam preparation in a short time.
HP HPE7-A03 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Propose the Solution: The focal point of this topic is creating the design documentation and the final design. Moreover, the topic also focuses on presenting the solution.
| | Topic 2 | - Analyze Requirements: It focuses on determining possible high-level solutions. The topic also discusses mapping the needs into technical solutions and evaluating the proposed solution against project objectives and dependencies. Moreover, it also focuses on documenting assumptions.
| | Topic 3 | - Discover Requirements: This topic defines the goals and identifies the current environment and the objectives. Lastly, it also focuses on collecting information.
| | Topic 4 | - Architect the Solution: It measures your knowledge about identifying the solution options, designing high-level topologies, selecting the correct products, and determining the suitable overlay and underlay design. Additionally, the topic discusses how to verify that the design meets the original requirements.
HP Aruba Certified Campus Access Architect Exam Sample Questions (Q73-Q78):NEW QUESTION # 73
You hired a junior engineer to assist you with a large-scale network infrastructure project. The engineer has never worked on such a complex project 'ants to better understand the role that each role that each stakeholder will play in the project.
March the stakeholder title to the responsibilities that would most likely apply to their role.
* CISO: responsible for establishing security policy and selecting security controls for the infrastructure.
* Network Design/Architecture: responsible for authoring the low-level design, and creating the configuration to meet the technical requirements.
* Network Operations: responsible for supporting, troubleshooting, and monitoring the wired/wireless infrastructure.
* Security Operations: responsible for investigating IDS/IPS incidents and managing firewalls.
NEW QUESTION # 74
'Don't Buy at Us' is a US-based retail company that is expanding into Europe. They are expanding into EMEA with a regional headquarters called HQ2 inside The Netherlands. Their US- based headquarters HQ1 was refreshed last year based on the HPE Aruba Networking ESP architecture. You have created the design for HQ2 based on the same design as HQ1, a two-tier architecture. The high level is shown below.
Switch BOM for this project based on Two Tier:
Collapsed Core: 2 x Aruba 8360-16Y2C in VSX (ISL 2x100GbE DAC)
Access Stack: 10 x Stack of 6200F 48G Class4 PoE 4SFP+ 740W (each stack has 4 members, VSF with 10GbE VSF links) (2 x 10GbE uplink per stack) During the presentation of your design to the CTO of "Don't Buy at Us" you were informed about the changes they want you to incorporate into the updated design:
1. HQ2 will include the EMEA regional distribution center (EMEA-DISTR) next to the HQ2.
2. Only two pairs of OS1 are available between HQ2 and EMEA-DlSTR.
3. The uplinks from all access stacks need to increase to 2 x 25GbE, the fiber in HQ2 and EMEA- DISTRI is certified for 25GbE.
4. EMEA-DlSTR needs at least 7 x stack of Aruba 48 ports switches (each stack has 4 members).
Which answer based on best practice is presenting the correct Switch BOM tor the updated design?
Based on the requirements provided by "Don't Buy at Us," the updated design needs to accommodate 25GbE uplinks and a minimum of 7 stacks of 48-port Aruba switches for the EMEA-DISTR. Option C is the most suitable based on best practices, as it proposes:
A core configuration consisting of two Aruba 8360-12C in VSX for the collapsed core with ISL of
2x100GbE DAC, which will provide robust core networking with high-speed interconnects, suitable for the demands of a regional distribution center and headquarters. Aggregation with two stacks, each with 2 Aruba 8360-12C in VSX (ISL 2x100GbE DAC), accommodating the uplink capacity requirements.
Access stacks with a total of 17 stacks of Aruba 6300F 48-port 1GbE Class 4 PoE with 4-port SFP56 (each stack has 4 members, VSF with 50GbE VSF links, 2 x 25GbE uplinks per stack), which exceeds the minimum requirement of 7 stacks and provides the necessary uplink bandwidth. This configuration supports the 25GbE uplink speeds, satisfies the required number of switch stacks for the EMEA distribution center, and is compatible with the existing 25GbE- certified fiber infrastructure at HQ2 and EMEA-DISTR.
NEW QUESTION # 75
A global cruise line company needs to refresh its current fleet. They will refresh the 'insides' of the ship to be cost-effective and increase their sustainability. They will replace the complete WLAN/LAN hardware of the ship. In this refresh, the company will not refresh its current security requirements. The CIO also wants to limit the number of unused ports in the switches. Future expansion will always mean a refresh of hardware. They start with the smallest ship with a maximum of 800 guests.
Each ship has a LAN infrastructure consisting of two core switches, up to 10 redundant distribution switches, and up to 500 access switches (400 cabins, 100 technical rooms). The Core switches are located in the MDF of the ship and the distribution switches are located in the IDFs of the ship. Each cabin and technical room gets one single access switch.
The cabling structure of the ship will not be refreshed. Each IDF is connected to the MDF by SMF, of which two pairs are available for the interconnect between the core and distribution. The length of SM fiber between MDF and IDF is less than 300 meters (980 ft) and the type used is OS1. Each cabin is connected by a single OM2 pair to the IDF, the maximum length is 60 meters (200 ft). Each technical room is connected by a single OM2 pair to the IDF, with lengths between
100 and 150 meters (320 and 500 ft).
For each cabin/technical room the customer is looking to replace their current fan-less 2530/2540 without changing the requirements, except they need to upgrade the uplink to distribution switch to 10GbE to handle the increased network traffic, and the technical rooms need redundant power.
The WLAN infrastructure will be 1:1 refreshed without new cabling or new AP locations. Their WLAN infrastructure is based on the 200/300 series indoor and outdoor APs running InstantOS (less than 300 APs), the customer has no change in WLAN requirements.
The cruise line company will replace its current internet connection before the LAN/WLAN refresh. The new Internet connection will provide a 99.8% uptime, which is needed to ensure the paid quest Wi-Fi is always operational. With this new Internet connection, the CIO of the cruise line wants to base the design on the ESP architecture from Aruba because internet connection is guaranteed.
Based on the best practices, what should be recommended as the most cost-effective switch model for the technical rooms?
- A. HPE Aruba Networking 6300M 24p HPE Smart Rate 1G/2.5G/5G/10G Class6 PoE and 2p 50G and 2p 25G
- B. HPE Aruba Networking 6300M 12p Class8 PoE and 36p Class6 PoE HPE Smart Rate
1G/2.5G/5G and 2p 50G and 2p 10G - C. HPE Aruba Networking 6200M 36G 12SR5 Class6 PoE 4SFP+
- D. HPE Aruba Networking 6200M 24G Class4 PoE 4SFP+
Port Count: The 6200M 24G switch provides enough Gigabit Ethernet ports to accommodate the technical rooms. Since each technical room is connected to a single access switch, this model strikes a balance between adequate port density and minimizing unused ports.
Power over Ethernet (PoE): Class 4 PoE capabilities are sufficient for powering devices typically used in technical rooms, such as network devices and potentially cameras or phones, without the need for excessive power delivery.
10GbE Uplinks: The switch has 4 SFP+ ports for uplinks, which can be utilized to connect to the distribution layer with 10GbE, meeting the requirement for increased network traffic handling.
Cost-Effectiveness: The 6200M series is designed for mid-sized environments, making it a more economical choice compared to higher-end models that may offer features beyond what is needed for the technical rooms.
NEW QUESTION # 76
A global furniture retail company called 'No-Stair Inc.' requests you design their new WLAN infrastructure for a global footprint. Each location of No-Stair Inc.' has a similar layout: three small manager offices, a warehouse, and a 'retail' area. The 'retail' area and the warehouse together amount to 95% of the location. The IT department of the company Is minimally engaged In their LAN refresh so the CTO of the company has shared the information below Current WLAN Infrastructure Is based on the 802.1 In "WlF14Less" access-points series (both model 2013- INT (2.4 only Internal antenna) and model 2019-EXT (dual-band external antenna only)). These AP models are standalone without any centralized management. Last year 'No-Stair InC ran a project called secure. It' ensuring that all needed network security was Implemented to be fully compliant with their security standards.
During this project, they also upgraded the AAA infrastructure to handle the Increased AAA requests. No additional Wi-Fi or security requirements are listed for this WLAN refresh, which means that 'No-Stair Inc.' will continue to use bridged SSIDs. with local breakout into different VLANs.
The CTO of No-Stair Inc.' understands the need for you to ask additional questions to deliver the design The questions may be sent in written form and will be answered within two weeks.
Which additional question is correct in order to collect needed information for the WLAN design?
- A. Who is the campus switch vendor?
- B. What type of fiber connection Is used between the core and access layer switches?
- C. Is there a current RF survey report that you can share?
- D. IS there enough cooling In the MDF?
An RF (Radio Frequency) survey report is crucial for WLAN design as it provides detailed information about the current wireless environment, including signal strengths, interference sources, coverage gaps, and the effectiveness of the existing WLAN infrastructure. For a company like 'No-Stair Inc.' that is planning to refresh its WLAN across a global footprint, understanding the current RF conditions in each location is essential. This information helps in designing a WLAN infrastructure that can meet the specific needs of different areas within the locations, such as the retail area and warehouse, ensuring optimal coverage, performance, and user experience. An RF survey report would allow the designer to make informed decisions regarding the placement of new access points, the selection of appropriate antennas, and the configuration of WLAN parameters to improve coverage and capacity while minimizing interference.
NEW QUESTION # 77
XYZ Regional Hospital is an integrated healthcare system of hospitals, neighborhood health centers, and small doctor offices. XYZ Regional Hospital has recently merged with 4x neighborhood health centers and 125 doctor branch offices. The wireless, wired access, and AAA solutions are outdated and need to be replaced.
XYZ Regional Hospital is looking to future-proof and improve efficiency across all sites by enhancing wired and wireless access and migrating to a centralized and unified wired/wireless and policy management that can provide uninterrupted availability of all systems.
Locations:
- XYZ Regional Hospital is located in New York City
- Dila Health Center is located in City A
- Mount Health Center is located in City B
- Rock Health Center is located in City C
- Branch clinics are located at different locations across the United States Requirements:
- Provide, via management software, one single pane of glass to manage wired and wireless LANs, and VPNs across campus, branch, and remote via web/cloud architecture providing near real-time insight, troubleshooting tools, and Service Level performance reporting.
- Seamless integration across wired, wireless, WAN, SD-Branch, IoT
- Provide secure wireless access to all the employees of the Regional Hospital and partners, as well as provide wireless Internet access to medical citizens when they visit our facilities.
- All-access points must support the following features and specifications: 802.11.ax (Wi-Fi 6E Certified)
- Security options including WP2/WPA3, 802.1X with Radius secure authentication
- Identify and authenticate every wireless and wired device
- End-to-end role-based security
- Seamless mobility across the hospital for medical teams, patients, and visitors
- Cuts Wi-Fi deployment times from days to hours and enables Zero-Touch deployments across the site
- Establishes a resilient, future-ready network infrastructure with the intelligence, scalability, and intuitive toolsets to meet emerging needs
- Fully redundant branch solution with dynamic path selection to the hospital XYZ Regional Hospital is concerned about the performance of new latency sensitive applications that will be introduced when connected via wireless.
Which solution can address this concern?
- A. AirMatch
- B. Client Insight
- C. AirSlice
- D. IDS/IPS
AirSlice provides application-aware airtime scheduling, giving latency-sensitive applications dedicated, predictable airtime. This ensures consistent performance for medical apps requiring low latency when operating over the wireless network.
NEW QUESTION # 78
Our company has become the front-runner of this career and help exam candidates around the world win in valuable time. With years of experience dealing with HPE7-A03 exam, they have thorough grasp of knowledge which appears clearly in our HPE7-A03 Exam Questions. All HPE7-A03 study materials you should know are written in them with three versions to choose from: the PDF, Software and APP online versions.
Certification HPE7-A03 Training: https://www.prepawaytest.com/HP/HPE7-A03-practice-exam-dumps.html
- HPE7-A03 exam training material - HP HPE7-A03 demo free download study 📉 Search for ☀ HPE7-A03 ️☀️ on [url]www.troytecdumps.com immediately to obtain a free download 📗HPE7-A03 Exam Actual Questions[/url]
- HPE7-A03 Test Online 🍌 HPE7-A03 Test Online 🔤 Reliable HPE7-A03 Test Testking 🧡 Open website ⏩ [url]www.pdfvce.com ⏪ and search for ▛ HPE7-A03 ▟ for free download 🏫HPE7-A03 New Braindumps Ebook[/url]
- HPE7-A03 New Braindumps Ebook 🍒 HPE7-A03 Practice Exams Free 🥜 Reliable HPE7-A03 Test Testking 🍡 The page for free download of ⏩ HPE7-A03 ⏪ on ✔ [url]www.troytecdumps.com ️✔️ will open immediately ♣Latest HPE7-A03 Test Voucher[/url]
- Original HPE7-A03 Questions 📟 HPE7-A03 Actual Test 🐺 Reliable HPE7-A03 Test Testking ⏩ Open { [url]www.pdfvce.com } and search for ▷ HPE7-A03 ◁ to download exam materials for free ⛪Latest HPE7-A03 Study Guide[/url]
- HPE7-A03 New Braindumps Ebook 👳 Guide HPE7-A03 Torrent 😿 HPE7-A03 Exam Actual Questions 😡 Go to website ➽ [url]www.exam4labs.com 🢪 open and search for HPE7-A03 to download for free 🐚HPE7-A03 Practice Exams Free[/url]
- HPE7-A03 Test Online 🎰 HPE7-A03 Test Braindumps ⏪ HPE7-A03 Braindumps Downloads 🕶 Immediately open ▛ [url]www.pdfvce.com ▟ and search for ▷ HPE7-A03 ◁ to obtain a free download 👉HPE7-A03 Test Braindumps[/url]
- 100% Pass Quiz High-quality HP - HPE7-A03 Relevant Exam Dumps 🧩 Go to website ▷ [url]www.exam4labs.com ◁ open and search for ⇛ HPE7-A03 ⇚ to download for free 😶HPE7-A03 Test Online[/url]
- Free PDF Useful HP - HPE7-A03 Relevant Exam Dumps 🌙 Search for ⮆ HPE7-A03 ⮄ and easily obtain a free download on ➥ [url]www.pdfvce.com 🡄 ✨HPE7-A03 Braindumps Downloads[/url]
- Realistic HP HPE7-A03 Questions with Multiple Offers ⌛ Easily obtain ➤ HPE7-A03 ⮘ for free download through ➠ [url]www.examcollectionpass.com 🠰 🪑Reliable HPE7-A03 Test Testking[/url]
- HPE7-A03 Reasonable Exam Price 👞 HPE7-A03 Practice Exams Free 🦊 Reliable HPE7-A03 Test Testking ⛅ Simply search for ✔ HPE7-A03 ️✔️ for free download on ⇛ [url]www.pdfvce.com ⇚ 📓Reliable HPE7-A03 Test Testking[/url]
- 2026 Updated HPE7-A03 Relevant Exam Dumps Help You Pass HPE7-A03 Easily 🙋 The page for free download of ➡ HPE7-A03 ️⬅️ on ⇛ [url]www.prep4sures.top ⇚ will open immediately 📁Reliable HPE7-A03 Test Testking[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mecabricks.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
BTW, DOWNLOAD part of PrepAwayTest HPE7-A03 dumps from Cloud Storage: https://drive.google.com/open?id=1vANeNEhV82vDO48JMaLR92JFbMG4H_m9
