FCSS_LED_AR-7.6ԇY & FCSS_LED_AR-7.6gԇY
80
Posted at 1/25/2026 17:45:21      View184 | Replies1        Print      Only Author   [Copy Link] 1#
Է֤ITIǤΰkչϣ顢FortinetFCSS_LED_AR-7.6ԇY˺ϸ񤹤ҪޤFortinetFCSS_LED_AR-7.6ԇYϤyƤľԤʤǡҡXhs1991ṩYϤͨơʤFortinetFCSS_LED_AR-7.6ԇY˺ϸ񤹤뤳ȤǤޤFortinetFCSS_LED_AR-7.6ԇYʂ䤷Ƥ뤢ʤԇY˺ϸ񤵤뤿ˡҡXhs1991ģMԇYեȤ¤AƤޤ
ʂΕrgޤƤΤǡयYߤϤʤΥک`٤뤳ȤǤޤ FCSS_LED_AR-7.6YϤϡFCSS_LED_AR-7.6ԇY|ˌ֪R`ƤgHFCSS_LED_AR-7.6ԇY˱ҪʤΤ٤Ƥ򺬤ߤޤ FCSS_LED_AR-7.6ȥ`˥󥰥ɤxkȤڤ뤳ȤϤޤ󡣌յĤˡϲtʥƥĤФ뤳ȤʤʤοԤ̼ޤ FCSS_LED_AR-7.6ԇYʂȡäᡢԇYgФ˴󤭤ʥȥ쥹ˤ餵뤳ȤϤޤ
FCSS_LED_AR-7.6gԇYFCSS_LED_AR-7.6ԇYgˤʤꤿϤϡFCSS_LED_AR-7.6mԤθߤԇYɤΥЩ`xkΤyȸФϡPDFЩ`mƤԤޤ PDFЩ`ͨΥեǤ यYߤϡFCSS_LED_AR-7.6mǤԇYɤ򼈤ӡˢƤiߕ뤳ȤˑTƤޤ ϤϾ_Ǥ ޤʵ㤬Ϥϡˤ˺g|ԒǤޤ ˤϡ줬ͨϾYϤȿ뤫⤷ޤ ޤFortinet FCSS_LED_AR-7.6mǤԇYɤζयΥԩ`ӡˢơˤȹФ뤳ȤǤޤ
Fortinet FCSS_LED_AR-7.6 JԇYγ}죺
ȥԥå}
ȥԥå 1
  • ȥ饹 LAN : ΥɥᥤǤϡޥJ^MAC J^Хѥ磻쥹 ƥ NAC ݥꥷ` ݩ`չ_FortiLink NACʥߥå VLANVLAN ש`󥰤ʤɤθ߶Ȥʥ`ˤĤhޤ
ȥԥå 2
  • J^: ΥɥᥤǤϡRADIUS LDAP ʹä߶Ȥʥ``J^ǥ^ʹä 2 ҪJ^FortiAuthenticator Ǥ syslog RADIUS 󥰥 󥪥ΘɤˤĤhޤ
ȥԥå 3
  • Oҕȥȥ֥륷`ƥ: ΥǤϡߥᥫ˥ΘɡFortiAIOps ιFortiSwitch FortiAP Ȥ FortiGate ͨŤΥȥ֥륷`ƥ󥰡磻쥹ӾAαOҕĩ`ʹäˤĤhޤ
ȥԥå 4
  • й: ΥǤϡFortiLink Uɤ FortiManager ˤ FortiSwitch ιå ץӥ˥󥰤ΌgװVLANݩ`ȡȥ󥯤ΘɡFortiExtender FortiAP ǥХΥåȥåפˤĤhޤ
Fortinet FCSS - LAN Edge 7.6 Architect J FCSS_LED_AR-7.6 ԇY} (Q69-Q74):| # 69
In FortiManager CLI, how do you enable FortiAIOps monitoring?
Response:
  • A. config aiops settings set collection-mode full
  • B. config system global set ai-monitor enable
  • C. FortiAIOps is enabled by default in managed mode
  • D. config system aiops set enable
⣺C
| # 70
Which monitoring tools in FortiGate help visualize wireless performance metrics?
(Choose three)
Response:
  • A. Spectrum Analysis
  • B. Heatmaps in FortiPlanner
  • C. Threat Map
  • D. FortiView
  • E. Log & Report > WiFi Events
⣺ADE
| # 71
Refer to the exhibits which show the FortiSwitch and FortiGate interface configurations.
FortiSwitch VLAN configuration
Port2 interface configuration
Which two statements describe how port2 handles tagged and untagged traffic? (Choose two.) Response:
  • A. Port2 accepts ingress untagged traffic for VLAN IDs 100, 4091, and 4093 only.
  • B. Port2 assigns ingress untagged traffic to VLAN 100.
  • C. Port2 accepts ingress tagged traffic for VLAN IDs 4091 and 4093 only.
  • D. Port2 tags egress traffic for VLAN 100.
⣺BC
| # 72
Which shows the WTP profile configuration.
The AP profile is assigned to two FAP-231F APs that are installed in an open plan area.
The first AP has 32 clients associated with the 5 GHz radios and 22 clients associated with the 2.4 GHz radio.
The second AP has 12 clients associated with the 5 GHz radios and 20 clients associated with the 2.4 GHz radio.
A dual-band-capable client enters the area near the first AP and the first AP measures the new client at - 3 3 dBm signal strength. The second AP measures the new client at -43 dBm signal strength.
If the new client attempts to conned to the student 01 wireless network, which AP radio will the client be associated with?
  • A. The first AP 5 GHz interface because it has a stronger signal.
  • B. The second AP 2.4 GHz interface is preferred over 5 GHz for better speed and lower interference.
  • C. The second AP 5 GHz interface has fewer clients, which ensures better performance despite the weaker signal.
  • D. The first AP 2.4 GHz interface provides a stronger signal, which clients often prioritize.
⣺C
h
From theWTP profile:
set handoff-rssi 30
set handoff-sta-thresh 30
config radio-1
set band 802.11n-2G
set vaps "Student01"
config radio-2
set band 802.11ac-5G
set darrp enable
set arrp-profile "arrp-default"
Key points:
* Same SSID (Student01)is broadcast onboth APsand onboth bands(2.4 and 5 GHz).
* handoff-sta-thresh 30 enablesclient load-balancingbetween APs:
* When an AP radio hasmore than 30 associated clients, it starts rejecting new associations so that clients connect to a neighboring AP instead (as long as RSSI is still acceptable).
* Current client counts:
* AP1:32 clients on 5 GHz, 22 on 2.4 GHz
* AP2:12 clients on 5 GHz, 20 on 2.4 GHz
So on 5 GHz:
* AP1's 5-GHz radioexceedsthe 30-client threshold (32 > 30) # it will try topush new clients away.
* AP2's 5-GHz radio iswell belowthe threshold (12 clients) and will happily accept new clients.
The new dual-band client is seen at:
* -33 dBmby AP1
* -43 dBmby AP2
Even though AP1 has the stronger signal, its 5-GHz radio is already overloaded according to the configured threshold, so AP1 will refuse association attempts from that client. The client will then associate toAP2's 5- GHz radio, which:
* Hasfewer clients(better airtime per device), and
* Still has an acceptable signal (-43 dBm is easily usable on 5 GHz).
That matches optionCexactly.
Other options are incorrect because they ignore the configuredclient-load-balancing thresholdsand assume association based purely on RSSI or prefer 2.4 GHz, which is not what this profile is tuned to do.
| # 73
What is the main benefit of VLAN pooling in wireless deployments?
Response:
  • A. Forces clients to connect via MAC address
  • B. Disables rogue AP detection
  • C. Reduces DHCP exhaustion and improves load distribution
  • D. Enables NAT between VLANs
⣺C
| # 74
FCSS_LED_AR-7.6θ}оηͨƼ̽ΤL줿`뤬󤢤뤳Ȥ狼ޤϷdz˱ҪǤͬrˡFCSS_LED_AR-7.6ȥ`˥YϤˤόTҤ餷Υ`बꡢΤᡢ᰸΃Aܤ˹ǤޤԇY}ǤϡFCSS_LED_AR-7.6{ˆ}ˌꤹҎtꡢΥƥȤΥۥåȥݥåȤ᰸η_yǤޤˤꡢ``Ť֤äFCSS_LED_AR-7.6ƥȤΜʂ򤹤뤳ȤǤޤ
FCSS_LED_AR-7.6gԇY: https://www.xhs1991.com/FCSS_LED_AR-7.6.html
Posted at 1/26/2026 02:25:24        Only Author  2#
Im deeply impressed by your article, thank you for sharing it! Improve your IT expertise with free COH-285 100% accuracy access. Best of luck in your exams!
