[General] Free PDF 2026 Fortinet FCP_FAC_AD-6.5: Marvelous New Exam FCP—FortiAuthenticator
108
【General】 Free PDF 2026 Fortinet FCP_FAC_AD-6.5: Marvelous New Exam FCP—FortiAuthenticator
Posted at 1/25/2026 18:34:06      View:161 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4pass FCP_FAC_AD-6.5 dumps for free: https://drive.google.com/open?id=12-79gCDjx9fehVfi5JouDjKT51SdR31q
This FCP_FAC_AD-6.5 exam material contains all kinds of actual Fortinet FCP_FAC_AD-6.5 exam questions and practice tests to help you to ace your exam on the first attempt. A steadily rising competition has been noted in the tech field. Countless candidates around the globe aspire to be Fortinet FCP_FAC_AD-6.5 individuals in this field.
Fortinet FCP_FAC_AD-6.5 Exam Syllabus Topics:
  • Introduction and Initial Configuration: This section of the exam measures the skills of a Network Security Administrator and covers the foundational setup and basic configuration of FortiAuthenticator, including initial deployment steps and system preparation for identity management services.
  • 802.1X Authentication
  • Administrative Users and High Availability: This section of the exam measures the skills of a System Engineer and covers the management of administrative user accounts and the implementation of high availability configurations to ensure system reliability and redundancy.
  • Certificate Management: This section of the exam measures the skills of a Certificate Manager and covers the administration of digital certificates, including issuance, renewal, and revocation processes.
Topic 5
  • Administering and Authenticating Users: This section of the exam measures the skills of a Security Administrator and covers the processes for creating, managing, and authenticating user accounts within the FortiAuthenticator system.
Topic 6
  • PKI and FortiAuthenticator as a CA: This section of the exam measures the skills of a PKI Specialist and covers the use of FortiAuthenticator as a Certificate Authority (CA) within a Public Key Infrastructure (PKI).
Topic 7
  • This section of the exam measures the skills of a Network Security Engineer and covers the configuration of FortiAuthenticator for wired and wireless 802.1X authentication using supported EAP methods.
Topic 8
  • OAuth and SAML:This section of the exam measures the skills of an Identity and Access Management (IAM) Specialist and covers the implementation of OAuth services and SAML-based single sign-on configurations.
Topic 9
  • FSSO Process and Methods: This section of the exam measures the skills of a Network Architect and covers the Fortinet Single Sign-On (FSSO) framework, including its processes and various deployment methods.
Topic 10
  • Portal Services: This section of the exam measures the skills of a Portal Administrator and covers the configuration and management of self-service portals for guest and local user access.
Topic 11
  • Two-Factor Authentication: This section of the exam measures the skills of a Security Engineer and covers the implementation and configuration of two-factor authentication using FortiTokens and other verification methods.
Topic 12
  • FIDO2 Authentication: This section of the exam measures the skills of a Modern Authentication Specialist and covers the setup and use of FIDO2 standards for passwordless authentication.
Topic 13
  • Managing Users and Troubleshooting Authentication: This section of the exam measures the skills of a Technical Support Specialist and covers advanced user management techniques and methods for diagnosing and resolving authentication issues.
Pass Guaranteed Fortinet - FCP_FAC_AD-6.5 - High Pass-Rate New Exam FCP—FortiAuthenticator 6.5 Administrator MaterialsAre you still worried about not able to pass FCP_FAC_AD-6.5 exam certification? Then you can ask Prep4pass for help. It can bring you the master of the sophisticated techniques of IT industry and help you pass FCP_FAC_AD-6.5 certification exam easily. With Prep4pass's efforts for years, the passing rate of FCP_FAC_AD-6.5 Certification Exam has reached as high as 100%. Choosing Prep4pass is to choose the way to go to a beautiful future.
Fortinet FCP—FortiAuthenticator 6.5 Administrator Sample Questions (Q39-Q44):NEW QUESTION # 39
What is the main purpose of active authentication in network security?
  • A. Detecting software vulnerabilities
  • B. Accelerating internet speeds
  • C. Enforcing access controls based on user identity
  • D. Monitoring network traffic
NEW QUESTION # 40
In FortiAuthenticator, what is the purpose of a captive portal?
  • A. To restrict user access to specific websites
  • B. To manage hardware resources in the network
  • C. To capture and authenticate user credentials before granting access to the network
  • D. To encrypt all network traffic for security
NEW QUESTION # 41
Which three of the following can be used as SSO sources? (Choose three)
  • A. Fortigate
  • B. FortiClient SSO Mobility Agent
  • C. RADIUS accounting
  • D. SSH Sessions
  • E. FortiAuthenticator in SAML SP role
Answer: A,B,C
NEW QUESTION # 42
What happens when a certificate is revoked? (Choose two.)
  • A. External CAs will periodically query FortiAuthenticator and automatically download revoked certificates
  • B. All certificates signed by a revoked CA certificate are automatically revoked
  • C. Revoked certificates are automatically added to the CRL
  • D. Revoked certificates cannot be reinstated for any reason
NEW QUESTION # 43
What is the advantage of using FortiToken for two-factor authentication?
  • A. It doesn't require user interaction for authentication
  • B. It can be easily integrated with any third-party authentication service
  • C. It can generate unlimited tokens for free
  • D. It's a physical token made of solid gold
NEW QUESTION # 44
To pass the certification exam, you need to select right FCP_FAC_AD-6.5 study guide and grasp the overall knowledge points of the real exam. The test questions from our FCP_FAC_AD-6.5 dumps collection cover almost content of the exam requirement and the real exam. Trying to download the free demo in our website and check the accuracy of FCP_FAC_AD-6.5 Test Answers and questions. Getting certification will be easy for you with our materials.
Valid FCP_FAC_AD-6.5 Dumps Demo: https://www.prep4pass.com/FCP_FAC_AD-6.5_exam-braindumps.html
P.S. Free 2026 Fortinet FCP_FAC_AD-6.5 dumps are available on Google Drive shared by Prep4pass: https://drive.google.com/open?id=12-79gCDjx9fehVfi5JouDjKT51SdR31q
Posted at 2/10/2026 17:28:34        Only Author  2#
It provided me with so much to reflect on. Good luck on your exam! Here are the free Observability-Self-Hosted-Fundamentals reliable study plan resources.
