CTFL-AT study guide & real CTFL-AT braindumps - latest valid
Posted at 1/25/2026 22:26:24
View139
Replies0
What's more, part of that Exams4Collection CTFL-AT dumps now are free: https://drive.google.com/open?id=1eejU51gJepaaECCAncEnYQfUYejGdrVF
If you still have no confidence for passing test, here we will recommend you an excellent reference material. Our valid CTFL-AT exam collection pdf will help you pass exam and go to success, you will approach to IT field top. You can just spend short time in preparing for real test with our latest CTFL-AT Exam Collection Pdf. You can download free demo in our website for your reference to verify the reliability of our dumps before purchasing.
The CTFL-AT Certification is recognized globally and is highly valued in the software testing industry. It is a testament to the candidate's knowledge and skills in agile testing, and can greatly enhance their career prospects. ISTQB Certified Tester - Foundation Level Extension - Agile Tester certification is also a requirement for individuals who wish to pursue advanced certifications in the field of software testing, such as the CTAL-TA (Certified Tester Advanced Level - Test Analyst) and the CTAL-TM (Certified Tester Advanced Level - Test Manager).
New CTFL-AT Exam Preparation & Exam CTFL-AT DurationWith a vast knowledge in the field, Exams4Collection is always striving hard to provide actual, authentic ISQI Exam Questions so that the candidates can pass their ISTQB Certified Tester - Foundation Level Extension - Agile Tester (CTFL-AT) exam in less time. Exams4Collection tries hard to provide the best ISQI CTFL-AT dumps to reduce your chances of failure in the ISTQB Certified Tester - Foundation Level Extension - Agile Tester (CTFL-AT) exam. Exams4Collection provides an exam scenario with its ISQI CTFL-AT practice test (desktop and web-based) so the preparation of the ISTQB Certified Tester - Foundation Level Extension - Agile Tester (CTFL-AT) exam questions becomes quite easier.
ISQI ISTQB Certified Tester - Foundation Level Extension - Agile Tester Sample Questions (Q27-Q32):NEW QUESTION # 27
Iteration planning for Sprint 5 of your current project is complete. The plan for the sprint is to increase performance of the system, which of the following acceptance criteria would you expect for Sprint 5?
1) User access for all roles has been validated.
2) A static analysis tool has been executed for all code.
3) 100% of the existing regression test suite has passed.
4) System is responding in less than 3 seconds, 90% of the time.
5) A new version of internet Explorer has been included.
- A. 4, 5
- B. 3, 4
- C. 2, 5
- D. 1, 3
The acceptance criteria for a sprint are the conditions that must be met for the user stories to be considered done and deliver value to the customer1. The acceptance criteria should be specific, measurable, achievable, relevant, and testable2. In this case, the plan for the sprint is to increase performance of the system, so the acceptance criteria should reflect that goal. Therefore, the acceptance criteria that would be expected for Sprint 5 are:
* 100% of the existing regression test suite has passed. This criterion ensures that the system has not introduced any new defects or broken any existing functionality while improving performance3.
* System is responding in less than 3 seconds, 90% of the time. This criterion defines a clear and quantifiable performance target that can be verified by testing4.
The other options are not relevant or appropriate acceptance criteria for Sprint 5:
* User access for all roles has been validated. This criterion is not related to the performance of the system, but rather to the security or functionality of the system. It might be an acceptance criterion for a different sprint or user story, but not for Sprint 55.
* A static analysis tool has been executed for all code. This criterion is not a customer
NEW QUESTION # 28
You are developing the code that controls an industrial Espresso machine which will be operated by waiting staff in restaurants.
The machine is rather complicated and has lots of switches and buttons, so in the next iteration instructions will be provided to the operator on a small LCD screen.
A User Story for the Operator-Instructions module is as follows:
"As an operator of the Espresso machine, I would like to know how to steam milk, so I can add steamed milk to the coffee." The following is a list of risks identified for this story, with assigned probability and impact.
- A. Operators will not read the instructions and will try various switches and buttons until something works.
Probability: Low. Impact: Low - B. A small child may try to steam milk. Probability: High. Impact: Low
- C. An untrained customer will attempt to use the coffee machine. Probability: High. Impact: High
- D. The instructions may be incorrect or appear in the wrong order. Probability: Low. Impact: High
Risk-based testing is a technique that prioritizes testing activities based on the level of risk associated with each feature or requirement. The level of risk is usually calculated by multiplying the probability and impact of each risk. The higher the risk level, the more testing effort should be allocated to mitigate the risk. In this case, the risk level for each option is as follows: A. Risk level = Low x Low = Low B. Risk level = Low x High = Medium C. Risk level = High x High = High D. Risk level = High x Low = Medium Therefore, the highest risk level is C, followed by B and D, and then A. The User Story for the Operator-Instructions module should be tested according to this risk order, starting with C, then B, then D, and finally A. Hence, the answer is B, as it is the second highest risk level and should be tested after C. References: ISTQB Foundation Level Agile Tester Extension Syllabus1, page 16; ISTQB Agile Tester Sample Exam2, question 18.
NEW QUESTION # 29
Which two of the following statements are CORRECT with regards to test automation on agile projects?
1) Every test developed for past iterations is kept and executed as part of a regression suite for each new release of code.
2) It would be very difficult to ensure high quality in an agile project without test automation.
3) Automated acceptance tests are run regularly as part of the continuous integration full system build.
4) Automated regression suites are only run for the final release of code.
5) In agile projects, the results from automated acceptance tests provide feedback on the overall product quality.
- A. 2, 3
- B. 3, 4
- C. 1, 3
- D. 2, 5
Test automation is essential for agile projects, as it enables fast and frequent feedback on the quality of the product. Without test automation, it would be very difficult to ensure high quality in an agile project, as manual testing would be too slow and costly to keep up with the pace of development12. Automated acceptance tests are one of the key types of test automation on agile projects, as they verify that the user stories are implemented correctly and that the product meets the customer's expectations. Automated acceptance tests are run regularly as part of the continuous integration full system build, and the results provide feedback on the overall product quality12. Therefore, statements 2 and 5 are correct with regards to test automation on agile projects. References: 1: ISTQB Foundation Level Agile Tester Syllabus, Section 3.3.1, Test Automation1; 2:
ASTQB Agile Tester Certification Resources, Section 3.3.1, Test Automation2
NEW QUESTION # 30
Which of the following statements about Agile retrospectives is CORRECT?
- A. Unlike working sessions or meetings held in non-Agile projects, Agile retrospectives do not require follow-up activities.
- B. Agile retrospectives should be focused mainly on impediments that are outside the control of the team because these issues are more challenging.
- C. During Agile retrospectives, testers should be encouraged to provide constructive suggestions only on non-testing activities.
- D. In an Agile retrospective the moderator can encourage and make sure that good practices are kept by the team, by asking what the team is doing well.
An Agile retrospective is a regular meeting where the team reflects on their work process and identifies the areas for improvement12. The following statements about Agile retrospectives are correct12:
* During Agile retrospectives, testers should be encouraged to provide constructive suggestions on both testing and non-testing activities, as testing is an integral part of the Agile team and testers can contribute to the overall quality of the product and the process.
* In an Agile retrospective, the moderator can encourage and make sure that good practices are kept by the team, by asking what the team is doing well. This helps to reinforce the positive aspects of the team' s work and to appreciate the team members' efforts and achievements.
* Agile retrospectives should be focused mainly on impediments that are within the control of the team because these issues are more actionable and can be resolved by the team. Impediments that are outside the control of the team should also be discussed, but they may require the involvement of other stakeholders or external parties to be addressed.
The following statement about Agile retrospectives is incorrect12:
* Unlike working sessions or meetings held in non-Agile projects, Agile retrospectives do require follow- up activities. The team should agree on the action items that result from the retrospective and assign them to the responsible team members. The team should also monitor the progress and effectiveness of the action items in the next iteration and review them in the next retrospective.
Therefore, the correct answer is B, as it is the only statement that is correct about Agile retrospectives. References: ISTQB Foundation Level Agile Tester Extension Syllabus1, page 24; ISTQB Agile Tester Sample Exam2,
NEW QUESTION # 31
Which of the following statements about the Planning poker test estimate technique are CORRECT?
1) Planning poker is a consensus based technique using a deck of cards.
2) A low test estimate usually means the story should be broken down into multiple smaller stories.
3) A high test estimate usually means the story should be broken down into multiple smaller stories.
4) One poker round is played and then consensus has to be reached.
5) The risk level of each backlog item should be decided before the poker session.
- A. 1, 2, 3
- B. 1, 2, 4
- C. 1, 3, 5
- D. 2, 3, 4
NEW QUESTION # 32
Just look at the text version of the introduction, you may still be unable to determine whether this product is suitable for you, or worth your purchase. We are very fond of preparing a trial version of CTFL-AT study materials: ISTQB Certified Tester - Foundation Level Extension - Agile Tester for you. After you have used a trial version, you will have an overview of the content of the CTFL-AT simulating exam. This is enough to convince you that this is a product with high quality. We hope that you are making a choice based on understanding the products. We will respect your decision. CTFL-AT really wants to be your long-term partner.
New CTFL-AT Exam Preparation: https://www.exams4collection.com/CTFL-AT-latest-braindumps.html
- CTFL-AT Authorized Test Dumps ⚾ CTFL-AT Reliable Test Pdf 🎒 CTFL-AT Reliable Braindumps Files 😩 Open ➤ [url]www.verifieddumps.com ⮘ enter ⮆ CTFL-AT ⮄ and obtain a free download 🕌New CTFL-AT Test Dumps[/url]
- Valid CTFL-AT Learning Materials 🏓 Updated CTFL-AT Testkings 🕳 CTFL-AT Practice Exam Questions 😖 Search for ▛ CTFL-AT ▟ and download it for free on [url]www.pdfvce.com website 🏬Reliable CTFL-AT Study Notes[/url]
- CTFL-AT Paper 🍚 Valid CTFL-AT Learning Materials 🎴 Test CTFL-AT Dumps Demo 🏍 Search for CTFL-AT on ☀ [url]www.vceengine.com ️☀️ immediately to obtain a free download 🦊Valid CTFL-AT Learning Materials[/url]
- Valid Exam CTFL-AT Practice 🚝 Updated CTFL-AT Testkings 🏌 CTFL-AT Latest Test Discount 🎵 ➡ [url]www.pdfvce.com ️⬅️ is best website to obtain [ CTFL-AT ] for free download 💔Valid CTFL-AT Test Pattern[/url]
- CTFL-AT Latest Test Discount 🛷 CTFL-AT Exam Paper Pdf 🍧 Unlimited CTFL-AT Exam Practice 🛄 Go to website [url]www.troytecdumps.com open and search for ▶ CTFL-AT ◀ to download for free 🚍CTFL-AT Authorized Test Dumps[/url]
- Valid CTFL-AT Test Pattern 🧿 Unlimited CTFL-AT Exam Practice 📽 Valid CTFL-AT Test Pattern 🎭 Open website [ [url]www.pdfvce.com ] and search for ⮆ CTFL-AT ⮄ for free download 🤳CTFL-AT Paper[/url]
- CTFL-AT Paper 🏅 Updated CTFL-AT Testkings 🤏 Reliable CTFL-AT Study Notes 🥿 Go to website [ [url]www.dumpsquestion.com ] open and search for ➥ CTFL-AT 🡄 to download for free 🤟CTFL-AT Test Simulator Fee[/url]
- Reliable CTFL-AT Study Notes 🟩 CTFL-AT Practice Exam Questions 👼 CTFL-AT Practice Exam Questions 🎠 Easily obtain free download of ☀ CTFL-AT ️☀️ by searching on [url]www.pdfvce.com ⤴Exam CTFL-AT Topics[/url]
- CTFL-AT Reliable Test Online 🐸 CTFL-AT Reliable Braindumps Files 🕛 CTFL-AT Test Simulator Fee 🍄 Download ⏩ CTFL-AT ⏪ for free by simply entering ⇛ [url]www.pdfdumps.com ⇚ website 🖼CTFL-AT Exam Paper Pdf[/url]
- Latest CTFL-AT Exam Labs 🔽 CTFL-AT Latest Test Discount 🧅 Latest CTFL-AT Exam Labs 🎮 Easily obtain free download of ➽ CTFL-AT 🢪 by searching on [url]www.pdfvce.com ➡CTFL-AT Test Simulator Fee[/url]
- Best Accurate ISQI CTFL-AT Test Dumps | Try Free Demo before Purchase 🍁 Immediately open ▷ [url]www.prepawaypdf.com ◁ and search for ⇛ CTFL-AT ⇚ to obtain a free download 🕢CTFL-AT Authorized Test Dumps[/url]
- www.stes.tyc.edu.tw, k12.instructure.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.renderosity.com, www.stes.tyc.edu.tw, Disposable vapes
