[General] SD-WAN-Engineer Certification Training - SD-WAN-Engineer Latest Dumps Pdf
90
【General】 SD-WAN-Engineer Certification Training - SD-WAN-Engineer Latest Dumps Pdf
Posted at 1/25/2026 23:30:34      View:215 | Replies:2        Print      Only Author   [Copy Link] 1#
Our SD-WAN-Engineer study braindumps can be very good to meet user demand in this respect, allow the user to read and write in a good environment continuously consolidate what they learned. Our SD-WAN-Engineer prep guide has high quality. So there is all effective and central practice for you to prepare for your test. With our professional ability, we can accord to the necessary testing points to edit SD-WAN-Engineer Exam Questions. It points to the exam heart to solve your difficulty. So high quality materials can help you to pass your exam effectively, make you feel easy, to achieve your goal.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Topic 5
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
Hot SD-WAN-Engineer Certification Training | High-quality SD-WAN-Engineer Latest Dumps Pdf: Palo Alto Networks SD-WAN EngineerCompared with other products, one of the advantages of SD-WAN-Engineer Exam Braindumps is that we offer you free update for 365 days after purchasing. In this condition, you needn’t have to spend extra money for the updated version. You just need to spend some money, so you can get the updated version in the following year. It’s quite cost- efficient for you. Besides if we have the updated version, our system will send it to you automatically.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q48-Q53):NEW QUESTION # 48
When using the CloudBlade to integrate Prisma SD-WAN with Prisma Access, how does the system ensure that the IPSec tunnels between the branch ION and the Prisma Access Security Processing Node (SPN) are kept alive during periods of no user traffic?
  • A. Prisma Access initiates the connection to the branch every 60 seconds.
  • B. The administrator must configure a continuous ping script on a branch PC.
  • C. The CloudBlade automatically configures the ION to send Synthetic Probes (ICMP/HTTP) across the tunnel.
  • D. The IPSec tunnel uses standard DPD (Dead Peer Detection) and the ION sends keepalives.
Comprehensive and Detailed Explanation
The stability of VPN tunnels in the Prisma SD-WAN + Prisma Access integration relies on standard IPSec mechanisms.
Dead Peer Detection (DPD): The CloudBlade configuration automatically enables DPD on the IPSec tunnels it provisions.
Mechanism: DPD is a standard keepalive mechanism where the ION device sends periodic "R-U-THERE" messages to the Prisma Access gateway (and vice versa). If no acknowledgment is received after a specific count/timer, the ION marks the tunnel as down and attempts to re-key or switch to a backup path.
Synthetic Probes (B): While Synthetic Probes (part of ADEM or Path Quality monitoring) can be configured to measure latency/loss, the fundamental mechanism that keeps the IPSec security association (SA) active and detects link failure is DPD, not an application-layer probe.
NEW QUESTION # 49
A network engineer is troubleshooting an ION device that is showing as "Offline" in the Prisma SD-WAN portal, despite the site reporting that local internet access is working. The engineer has console access to the device.
Which CLI command should be used to specifically validate the device's ability to resolve the controller's hostname and establish a secure connection to it over a specific interface?
  • A. dump vpn summary
  • B. debug controller reachability <interface>
  • C. ping <controller-ip>
  • D. show system connectivity
The CLI command debug controller reachability <interface> (e.g., debug controller reachability 1) is the specific diagnostic tool designed to verify the entire connectivity chain required for management plane availability.
Unlike a simple ICMP ping (Option A), which only tests Layer 3 connectivity to an IP address, the debug controller reachability command performs a sequential set of tests:
DNS Resolution: It attempts to resolve the specific Locator service URL (locator.cgnx.net or region-specific FQDN) to verify DNS functionality.
TCP Connectivity: It tests the ability to establish a TCP connection to the controller on port 443 (HTTPS).
SSL/TLS Handshake: It validates that the device can successfully negotiate the secure tunnel required for authentication.
If this command fails at the DNS step, the issue is likely a missing DNS server in the interface config. If it fails at the TCP step, it implies an upstream firewall is blocking outbound port 443. This targeted output allows the engineer to pinpoint exactly why the device is offline in the portal.
NEW QUESTION # 50
An administrator needs to ensure that critical VoIP traffic is not dropped even when the branch's primary internet link is fully saturated with bulk file transfers.
Which QoS mechanism does Prisma SD-WAN automatically apply to the "Platinum" priority class to prevent starvation by lower-priority classes?
  • A. First-In, First-Out (FIFO)
  • B. Weighted Round Robin (WRR)
  • C. Strict Priority Queuing (SPQ)
  • D. Hierarchical Token Bucket (HTB) with guaranteed bandwidth
Prisma SD-WAN utilizes a hierarchical QoS model (typically based on Hierarchical Token Bucket or similar shaping algorithms) to manage bandwidth contention.
Guaranteed Bandwidth: The "Platinum" class (used for Real-Time voice/video) is assigned a guaranteed bandwidth percentage (floor) in the QoS profile. This ensures that even if "Gold" (Transactional) or "Silver" (Bulk) traffic is trying to consume 100% of the link, the scheduler reserves the specific portion (e.g., 30%) for Platinum traffic, preventing starvation.
Shaping, not Policing: Unlike simple policing which drops excess traffic hard, the ION device shapes the egress traffic. If the link is congested, the scheduler delays the lower-priority packets (buffering) to allow the high-priority Platinum packets to exit immediately.
Why not Strict Priority (A)? While Platinum behaves like a priority queue, pure Strict Priority can completely starve lower queues if the high-priority traffic is misbehaving or voluminous. Prisma SD-WAN typically uses bandwidth guarantees (floors) and limits (ceilings) to ensure fair sharing while protecting critical apps.
NEW QUESTION # 51
A site has two internet circuits: Circuit A with 500 Mbps capacity and Circuit B with 100 Mbps capacity.
Which path policy configuration will ensure traffic is automatically shifted from a saturated circuit to the circuit with available bandwidth?
  • A. Circuit B as an L3 failure path
  • B. Both circuits under active path
  • C. Circuit A as an active, Circuit B as a backup
  • D. Circuit B as an active, Circuit A as a backup
In Prisma SD-WAN (CloudGenix), Path Policies control how application traffic is steered across WAN links. To ensure that traffic is automatically shifted from a saturated circuit to another circuit with available bandwidth, both circuits must be configured as Active Paths within the policy rule.
When multiple paths are designated as "Active," the ION device treats them as a shared pool of available resources. The system continuously monitors the bandwidth utilization (capacity) and health (latency, jitter, loss) of all active links. If "Circuit A" (500 Mbps) becomes saturated or approaches its defined bandwidth limit, the ION's intelligent scheduler will automatically direct new application flows to "Circuit B" (100 Mbps) because it is a valid, healthy Active path with available capacity. This achieves effective load balancing and bandwidth aggregation.
In contrast, configuring "Circuit B" as a Backup Path (Option A or B) creates a strict priority relationship. Traffic would only move to the Backup path if the Active path completely failed or violated its configured SLA (Path Quality Profile) significantly enough to be considered "down." Mere bandwidth saturation might not trigger an SLA failure immediately, potentially leading to dropped packets on the saturated link while the backup link remains idle. Therefore, placing Both circuits under active path is the correct configuration for dynamic capacity management.
NEW QUESTION # 52
A remote branch site is reporting intermittent connectivity to the Data Center. The administrator checks the System > Alarms page and sees a "VPN_DOWN" alarm for the tunnel to the DC. However, the internet circuit status is "Up".
Which specific log file or diagnostic tool in the Prisma SD-WAN portal would provide the IKE (Internet Key Exchange) error codes (e.g., "NO_PROPOSAL_CHOSEN" or "AUTH_FAILED") to pinpoint the cause of the tunnel failure?
  • A. Flow Browser
  • B. Site Summary > Topology
  • C. Event Logs > System
  • D. Link Quality Graphs
To diagnose specific VPN negotiation failures (Phase 1 or Phase 2 IPSec issues), the Event Logs (specifically filtered for System or VPN events) are the correct resource.
Event Logs: This section records the control plane signaling messages. If a VPN tunnel fails to establish, the Event Log will generate an entry containing the specific IKE failure reason sent by the peer or generated locally. Common errors found here include INVALID_COOKIE, NO_PROPOSAL_CHOSEN (mismatch in encryption algorithms), or PRE_SHARED_KEY_MISMATCH.
Flow Browser (A): This shows user traffic (TCP/UDP sessions). If the VPN is down, user traffic won't even enter the tunnel, so the Flow Browser will just show dropped flows or blackholes, but it won't explain why the tunnel itself is broken.
Link Quality (D): This shows latency/loss graphs for established tunnels. It cannot diagnose why a tunnel failed to form in the first place.
NEW QUESTION # 53
Furthermore, after acquiring our Palo Alto Networks SD-WAN Engineer SD-WAN-Engineer Exam Questions preparation material, you will receive free updates for 365 days. Free4Dump provides up-to-date Palo Alto Networks SD-WAN Engineer exam questions, latest test dumps demo and latest test experience will make you success in your career. And price is affordable.
SD-WAN-Engineer Latest Dumps Pdf: https://www.free4dump.com/SD-WAN-Engineer-braindumps-torrent.html
Posted at 2/7/2026 22:24:56        Only Author  2#
Thank you so much for your article, it’s something I’ll remember. Elevate your career with the free New free study C_BCFIN_2502 questions test questions—key to promotions and raises!
Posted at 2/18/2026 03:46:34        Only Author  3#
Alle Menschen haben ihre eigenes Ziel, aber wir haben ein gleiches Ziel, dass Sie Real Estate New-Jersey-Real-Estate-Salesperson Prüfung bestehen. Dieses Ziel zu erreichen ist vielleicht nur ein kleiner Schritt für Ihre Entwicklung im IT-Gebiet. Aber es ist der ganze Wert unserer Real Estate New-Jersey-Real-Estate-Salesperson Prüfungssoftware. Wir tun alles wir können, um die Prüfungsaufgaben zu erweitern. Und die Prüfungsunterlagen werden von unsere IT-Profis analysiert. Dadurch können Sie unbelastet und effizient benutzen. Um zu garantieren, dass die Real Estate New-Jersey-Real-Estate-Salesperson Unterlagen, die Sie benutzen, am neuesten ist, bieten wir einjährige kostenlose Aktualisierung.
