[General] Free AP-215 Exam Questions - Test AP-215 Passing Score
90
【General】 Free AP-215 Exam Questions - Test AP-215 Passing Score
Posted at 1/25/2026 23:53:59      View:109 | Replies:0        Print      Only Author   [Copy Link] 1#
To address the problems of Marketing Cloud Intelligence Accredited Professional (AP-215) exam candidates who are busy, GuideTorrent has made the Marketing Cloud Intelligence Accredited Professional (AP-215) dumps PDF format of real Marketing Cloud Intelligence Accredited Professional (AP-215) exam questions. This format's feature to run on all smart devices saves your time. Because of this, the portability of Marketing Cloud Intelligence Accredited Professional (AP-215) dumps PDF aids in your preparation regardless of place and time restrictions.
We can ensure you a pass rate as high as 99% of our AP-215 exam questions. So with our AP-215 study guide, you will pass the AP-215 exam. And this is the right thing you can imagine. You surely desire the AP-215 certification. So with a tool as good as our AP-215 Exam Material, why not study and practice for just 20 to 30 hours and then pass the examination? It is more convenient for you to study and practice anytime, anywhere with our varied versions of AP-215 exam braindumps.
Easy to Use Salesforce AP-215 PDF Questions FileUsing the AP-215 Study Materials, you will find that you can grasp the knowledge what you need in the exam in a short time. Because users only need to spend little hours on the AP-215 study materials, our learning materials will help users to learn all the difficulties of the test site, to help users pass the qualifying examination and obtain the qualification certificate. If you think that time is important to you, try our learning materials and it will save you a lot of time.
Salesforce Marketing Cloud Intelligence Accredited Professional Sample Questions (Q48-Q53):NEW QUESTION # 48
An implementation engineer has been provided with the below dataset:
*Note: CPC = Cost per Click
Formula: Cost / Clicks
Which action should an engineer take to successfully integrate CPC?
  • A. Populate the logic within a custom measurement. No need to change Aggregation.
  • B. Populate the logic within a custom measurement. Set Aggregation to AVG.
  • C. Populate the logic within a custom measurement. Set Aggregation to SUM.
  • D. Unmap it, as Datorama will calculate it automatically.
CPC (Cost per Click) is a calculated metric that should be created using a custom measurement based on the formula provided (Cost / Clicks). This calculation does not require a change in the aggregation setting because it is derived from other base metrics that are already aggregated appropriately. In Salesforce Marketing Cloud Intelligence, custom measurements are used to create new metrics from existing data points, and the system will use the underlying data's aggregation to perform the calculation. Reference: Salesforce Marketing Cloud Intelligence documentation on creating custom measurements and calculated metrics.
NEW QUESTION # 49
A technical architect is provided with the logic and Opportunity file shown below:
The opportunity status logic is as follows:
For the opportunity stages "Interest", "Confirmed Interest" and "Registered", the status should be "Open".
For the opportunity stage "Closed", the opportunity status should be closed.
Otherwise, return null for the opportunity status.
Given the above file and logic and assuming that the file is mapped in a GENERIC data stream type with the following mapping:
"Day" - Standard "Day" field
"Opportunity Key" > Main Generic Entity Key
"Opportunity Stage" - Generic Entity key 2
A pivot table was created to present the count of opportunities in each stage. The pivot table is filtered on Jan 7th -11th.Which option reflects the stage(s) the opportunity key 123AA01 is associated with?
  • A. Interest & Registered
  • B. Confirmed Interest & Registered
  • C. Confirmed interest
  • D. interest
Filtering the pivot table on January 7th-11th, we see that the Opportunity Key 123AA01 appears on January 6th with the stage 'Interest' and then on January 10th with the stage 'Registered'. Even though the 'Interest' stage is not within the filtered dates, it is the initial stage of the opportunity, so it should be counted along with the 'Registered' stage which falls within the filter range.
NEW QUESTION # 50
The following file was uploaded into Marketing Cloud Intelligence as a generic dataset type:
The mapping is as follows:
Day - Day
Web_site_source - Main Generic Entity Attribute 01
Page Views - Generic Metric 1
*Note that 'web_site_key' and 'web_site_name' are NOT mapped.
How many rows will be stored in Marketing Cloud Intelligence after the above file is ingested?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
In Marketing Cloud Intelligence, when a file is uploaded as a generic dataset type and mapped accordingly, each unique combination of the mapped fields results in a separate row in the database. The file in question has been mapped with 'Day' to 'Day', 'Web_site_source' to 'Main Generic Entity Attribute 01', and 'Page Views' to 'Generic Metric 1'. The 'web_site_key' and 'web_site_name' are not mapped and thus, won't affect the row count.
Since there are 4 unique combinations of the mapped fields in the uploaded file (each day and source combination is unique), Marketing Cloud Intelligence will store 4 rows after ingestion, corresponding to each unique combination of 'Day' and 'Web_site_source'.
NEW QUESTION # 51
Your client would like to create a new harmonization field - Exam Topic.
The below table represents the harmonization logic from each source.
As can be seen from the table, there are in fact two fields that hold a certain connection: Exam ID and Exam Topic. The connection indicates that where an Exam ID is found - a single Exam Topic value is associated with it.
The client has a requirement to be able to view measurements from all data sources sliced by Exam Topic values, as seen in the following example:
The client suggested to create, without any mapping manipulations, several patterns via the harmonization center that will generate two Harmonized Dimensions:
Exam ID
Exam Topic
Given the above information, which statement is correct regarding the ability to implement this request with the above suggestion?
  • A. The Harmonized field for Exam ID is redundant. One Harmonized dimension for Exam Topic is enough for a sustainable and working solution
  • B. The above Patterns setup will not work for this use case.
  • C. Only if 5 different Patterns are created, from 5 different fields - the solution will work.
  • D. The solution will work - the client will be able to view Exam Topic with Email Sends.
If the harmonization logic consistently associates a single Exam Topic with each Exam ID across all data sources, then creating two harmonized dimensions may be unnecessary. One harmonized dimension for Exam Topic would suffice because it inherently carries the Exam ID's uniqueness within it. The harmonized dimension for Exam Topic would allow the client to slice the data by Exam Topic values, fulfilling the requirement.
NEW QUESTION # 52
A client would like to integrate the following two sources:
Google Campaign Manager:
IAS:
After configuring a Parent-Child relationship between the files, which query should an implementation engineer run in order to QA the setup?
  • A. Media Buy Name, Impressions
  • B. Creative Name, Impressions, Analyzed Impressions
  • C. Media Buy Type, Analyzed Impressions
  • D. Media Buy Type, Media Buy Name, Impressions, Analyzed Impressions
To QA the Parent-Child relationship setup between Google Campaign Manager and IAS data sources, it is essential to query fields that are common to both sources and that are relevant to the relationship. 'Media Buy Type' and 'Media Buy Name' are common identifiers between the two datasets. 'Impressions' from the Google Campaign Manager and 'Analyzed Impressions' from the IAS data are the metrics that should be compared to ensure they match or correlate as expected due to the Parent-Child relationship. The QA process involves checking that the data is correctly aligned and that the metrics from the parent source (Google Campaign Manager) are properly related to the metrics from the child source (IAS). Reference: Salesforce Marketing Cloud Intelligence documentation on data integration, Parent-Child relationships, and QA procedures for data setup.
NEW QUESTION # 53
It is human nature to pursue wealth and success. No one wants to be a common person. In order to become a successful person, you must sharpen your horizons and deepen your thoughts. Our AP-215 practice guide can help you update yourself in the shortest time. And according to the data of our loyal customers, we can claim that if you study with our AP-215 Exam Questions for 20 to 30 hours, then you can pass the exam with ease. And the price of our AP-215 study materials is quite favourable.
Test AP-215 Passing Score: https://www.guidetorrent.com/AP-215-pdf-free-download.html
The Salesforce AP-215 pdf dumps version allows you to print the Salesforce AP-215 exam questions easily and access it everywhere, So will you, This is GuideTorrent Test AP-215 Passing Score's commitment to all candidates, PDF version of AP-215 study guide is available for you to print out and note your studying thoughts on paper, You can download GuideTorrent Test AP-215 Passing Score exam questions PDF on your desktop computer, laptop, tabs, or even on your smartphones.
Of the available options, Mundu beats out the AP-215 competition, Crème fraise, bagels, capers, dill, crackers, fish knife, caviar, The Salesforce AP-215 Pdf Dumps version allows you to print the Salesforce AP-215 exam questions easily and access it everywhere.
Latest AP-215 Quiz Prep Aim at Assisting You to Pass the AP-215 Exam - GuideTorrentSo will you, This is GuideTorrent's commitment to all candidates, PDF version of AP-215 study guide is available for you to print out and note your studying thoughts on paper.
You can download GuideTorrent exam questions AP-215 Valid Dumps Demo PDF on your desktop computer, laptop, tabs, or even on your smartphones.
