New 1z0-1057-25 Mock Exam - 1z0-1057-25 Valid Dumps Files
Posted at 1/26/2026 01:21:48
Free update for 365 days is available for 1z0-1057-25 study guide, so that you can have a better understanding of what you are going to buy. Through free demo, you can also know what the complete version is like. In addition, with experienced experts to compile the 1z0-1057-25 Exam Dumps, quality can be guaranteed. Therefore, if you choose us, you can use them at ease. We have online and offline chat service stuff, who are quite familiar with 1z0-1057-25 study guide, if you have any questions, you can consult us.
A wise man can often make the most favorable choice to buy our 1z0-1057-25 study materials, i believe you are one of them. If you are not at ease before buying our 1z0-1057-25 actual exam, we have prepared a free trial for you. Just click on the mouse to have a look, giving you a chance to try on our 1z0-1057-25 learning guide. Perhaps this choice will have some impact on your life. And our 1z0-1057-25 training braindumps are the one which can change your life.
1z0-1057-25 Valid Dumps Files | 1z0-1057-25 Exam Dumps DemoIt is worth mentioning that, the simulation test is available in our software version. With the simulation test, all of our customers will get accustomed to the 1z0-1057-25 exam easily, and get rid of bad habits, which may influence your performance in the real 1z0-1057-25 exam. In addition, the mode of 1z0-1057-25 learning guide questions and answers is the most effective for you to remember the key points. During your practice process, the 1z0-1057-25 test questions would be absorbed, which is time-saving and high-efficient.
Oracle Project Management Cloud 2025 Implementation Professional Sample Questions (Q127-Q132):NEW QUESTION # 127
Your customer started operations and all projects in January 2015. They implemented Enterprise Project Structure for calculating project labor demand by using the Annual option. When they view the labor demand on 15-Dec-2015, the project hierarchy viewer shows data only for the year 2015. The client expected the demand to be shown for a year, from 15-Dec-2015 to 15-Dec-2016.
Identify how the project hierarchy viewer displays labor demand information. (Choose the best answer.)
- A. The date entered by a user as a parameter when running the Update EPS job was set to 01-Jan-2015, and hence the calculations show results for the year 2015.
- B. The project start date of Jan-2015 was used for calculating labor demand, and hence it calculated the demand for the year 2015.
- C. The current date is used for calculating labor demand for the current year.
- D. The current period start date is used for calculating labor demand for the current year.
Ref: https://docs.oracle.com/en/cloud ... em/analyze-project- management-performance.html#OAPEM1313471 Topic - Project Labor Demand: How It's Calculated Settings That Affect Project Labor Demand Project application administrators must do the following to set up how project labor demand is calculated:
* Organize projects into hierarchical groups on the Manage Enterprise Project Structure page.
* Change the quarterly FTE hours for the organization on the Define Project Management Implementation Options page, if different from 520 hours.
Note: You can choose to view labor demand annually instead of quarterly. The Project Hierarchy Viewer uses the current date to determine which year or quarter to display.
NEW QUESTION # 128
What are three configuration items that you need to set up by using the Project Organizations functional area in Project Financial Management configurations? (Choose three.)
- A. Manage Project Organization Classifications
- B. Mange Business Unit
- C. Manage Project Unit Organizations
- D. Manage Project Unit Options
- E. Mange Project Types
Answer: A,C,D
Reference https://docs.oracle.com/en/cloud ... pfm/define-project- organizations.html#OAPFM3094543 Topic - Manage Project Unit Organizations
NEW QUESTION # 129
You have been asked to set up one active person, who is not a team member in the project, as a quality manager for each quality task created under projects. However, when you try to assign the quality manager as Task Manager, you cannot find the person's name in the list of values. What is the reason for this problem?
- A. The "Require Task Managers to be Project Team Members" profile option is set to Yes.
- B. The quality manager belongs to a department that is not associated with the project.
- C. The quality manager is not assigned with a supervisor.
- D. The "Require Task Managers to be Project Team Members" profile option is set to No.
Ref: https://docs.oracle.com/en/cloud ... introducing-oracle- project-portfolio-management-cloud-services.html#FAPFM428138 Topic - Project Foundation Profile Options Profile Option Name - Task Managers Must Be Project Team Members Description - Specify whether task managers must be project team members.
Values - No (Default) / Yes
Setup Task Name - Require Task Managers to be Project Team Members
NEW QUESTION # 130
Your organization performs revenue recognition based on the Labor and Non-labor Burden schedule types.
Identify the setup required to enable this kind of revenue recognition. (Choose the best answer.)
- A. Create a revenue method with a revenue method classification of Rate Based.
- B. Create a revenue method classification with a revenue method of Percent Spent.
- C. Create a revenue method with a revenue method classification of Amount Based.
- D. Create a revenue method classification with a revenue method of Percent Complete.
To perform revenue recognition based on the Labor and Non-labor Burden schedule types, you need to create a revenue method with a revenue method classification of Rate Based. This classification allows you to use the burdened cost rates of labor and non-labor resources as the basis for revenue recognition. The burdened cost rates are derived from the burden schedules that are assigned to the project or task. Reference:
https://docs.oracle.com/en/cloud ... ge-project-revenue.
html#OAPFM2355981
NEW QUESTION # 131
As you go through the first-quarter close for your customer, you notice that the burden amounts calculated do not seem to be right. Based on the calculations, you notice that the amounts calculated are not considering the burden schedule override at a task level, which was done during the second month of the quarter.
- A. Only new expenditure items charged to the task use the new burden schedule; expenditure items processed earlier can be manually marked for reprocessing.
- B. All expenditure items charged to the task use the new burden schedule.
- C. You can enable automatic reprocessing of expenditure items processed before the burden schedule change.
- D. Only new expenditure items charged to the task use the new burden schedule; expenditure items processed earlier cannot be reprocessed.
Reference https://docs.oracle.com/cloud/r1 ... OAPJC/OAPJC1071490.
htm#OAPJC1071482
NEW QUESTION # 132
With a vast knowledge in the field, ActualTestsQuiz is always striving hard to provide actual, authentic Oracle Exam Questions so that the candidates can pass their Oracle Project Management Cloud 2025 Implementation Professional (1z0-1057-25) exam in less time. ActualTestsQuiz tries hard to provide the best Oracle 1z0-1057-25 dumps to reduce your chances of failure in the Oracle Project Management Cloud 2025 Implementation Professional (1z0-1057-25) exam. ActualTestsQuiz provides an exam scenario with its Oracle 1z0-1057-25 practice test (desktop and web-based) so the preparation of the Oracle Project Management Cloud 2025 Implementation Professional (1z0-1057-25) exam questions becomes quite easier.
1z0-1057-25 Valid Dumps Files: https://www.actualtestsquiz.com/1z0-1057-25-test-torrent.html
You can use different products for demo and you will be able to know the worth of the 1z0-1057-25 dumps pdf that you will be using for the preparation of Oracle 1z0-1057-25 exam, Oracle New 1z0-1057-25 Mock Exam Also, your normal life will not be disrupted, Oracle New 1z0-1057-25 Mock Exam What operating systems are supported by your Testing Engine software, In a field, you can try to get the 1z0-1057-25 certification to improve yourself, for better you and the better future.
Type the name of the group that you need to manage, 1z0-1057-25 Special Card Settings and Functions, You can use different products for demo and you will be able to know the worth of the 1z0-1057-25 Dumps PDF that you will be using for the preparation of Oracle 1z0-1057-25 exam.
Help You Learn, Prepare, and Practice for 1z0-1057-25 exam successAlso, your normal life will not be disrupted, What operating systems are supported by your Testing Engine software, In a field, you can try to get the 1z0-1057-25 certification to improve yourself, for better you and the better future.
Our 1z0-1057-25 test braindump are created based on the real test.
- Official 1z0-1057-25 Study Guide 🍄 1z0-1057-25 Exam Online 🔂 Study 1z0-1057-25 Material 🎼 ( [url]www.practicevce.com ) is best website to obtain ▛ 1z0-1057-25 ▟ for free download 🛵Sure 1z0-1057-25 Pass[/url]
- Trustworthy New 1z0-1057-25 Mock Exam Offers Candidates Pass-Sure Actual Oracle Oracle Project Management Cloud 2025 Implementation Professional Exam Products 🏫 Download ⮆ 1z0-1057-25 ⮄ for free by simply entering ⇛ [url]www.pdfvce.com ⇚ website ⚜Valid Exam 1z0-1057-25 Practice[/url]
- High-Efficient 1z0-1057-25 Exam Dumps: Oracle Project Management Cloud 2025 Implementation Professional and preparation materials - [url]www.examcollectionpass.com 🐗 Search for ➠ 1z0-1057-25 🠰 on 《 www.examcollectionpass.com 》 immediately to obtain a free download 🩲
ractice Test 1z0-1057-25 Fee[/url] - 100% Pass Quiz Oracle - 1z0-1057-25 - Oracle Project Management Cloud 2025 Implementation Professional –Professional New Mock Exam 🔃 Search for ✔ 1z0-1057-25 ️✔️ and easily obtain a free download on ( [url]www.pdfvce.com ) 🍨Exam 1z0-1057-25 Material[/url]
- High-Efficient 1z0-1057-25 Exam Dumps: Oracle Project Management Cloud 2025 Implementation Professional and preparation materials - [url]www.prepawayexam.com 🔉 Download ➠ 1z0-1057-25 🠰 for free by simply entering ⮆ www.prepawayexam.com ⮄ website 🛴New 1z0-1057-25 Test Voucher[/url]
- Trustworthy New 1z0-1057-25 Mock Exam Offers Candidates Pass-Sure Actual Oracle Oracle Project Management Cloud 2025 Implementation Professional Exam Products 👑 Search for ⮆ 1z0-1057-25 ⮄ and obtain a free download on 《 [url]www.pdfvce.com 》 💾1z0-1057-25 Reliable Exam Preparation[/url]
- 1z0-1057-25 Test Vce 🍽 Latest 1z0-1057-25 Dumps Book 😳 1z0-1057-25 Certification Questions 🏤 Search for [ 1z0-1057-25 ] and download exam materials for free through ➡ [url]www.pdfdumps.com ️⬅️ 🔌1z0-1057-25 Certification Questions[/url]
- [url=https://www.gema.it/?s=Diverse%20Formats%20for%20Oracle%201z0-1057-25%20Exam%20Questions:%20Choose%20What%20Works%20Best%20for%20You%20%e2%9b%bd%20Search%20on%20%e2%ae%86%20www.pdfvce.com%20%e2%ae%84%20for%20[%201z0-1057-25%20]%20to%20obtain%20exam%20materials%20for%20free%20download%20%f0%9f%a7%851z0-1057-25%20Exam%20Online]Diverse Formats for Oracle 1z0-1057-25 Exam Questions: Choose What Works Best for You ⛽ Search on ⮆ www.pdfvce.com ⮄ for [ 1z0-1057-25 ] to obtain exam materials for free download 🧅1z0-1057-25 Exam Online[/url]
- New 1z0-1057-25 Mock Exam - 100% First-grade Questions Pool ⏩ Open ▷ [url]www.practicevce.com ◁ enter ☀ 1z0-1057-25 ️☀️ and obtain a free download 😤Latest 1z0-1057-25 Dumps Book[/url]
- Trustworthy New 1z0-1057-25 Mock Exam Offers Candidates Pass-Sure Actual Oracle Oracle Project Management Cloud 2025 Implementation Professional Exam Products 🎩 Simply search for ➽ 1z0-1057-25 🢪 for free download on ( [url]www.pdfvce.com ) 🚰Lab 1z0-1057-25 Questions[/url]
- Diverse Formats for Oracle 1z0-1057-25 Exam Questions: Choose What Works Best for You 🍀 Easily obtain free download of ➤ 1z0-1057-25 ⮘ by searching on ➤ [url]www.dumpsquestion.com ⮘ 🧳Exam 1z0-1057-25 Actual Tests[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
