[General] Seeing Mule-Dev-301 Valid Test Braindumps - Say Goodbye to Salesforce Certified
115
【General】 Seeing Mule-Dev-301 Valid Test Braindumps - Say Goodbye to Salesforce Certified
Posted at 1/26/2026 02:00:12      View:125 | Replies:1        Print      Only Author   [Copy Link] 1#
Eliminates confusion while taking the Salesforce Mule-Dev-301 certification exam. Prepares you for the format of your Mule-Dev-301 exam dumps, including multiple-choice questions and fill-in-the-blank answers. Comprehensive, up-to-date coverage of the entire Salesforce Certified MuleSoft Developer II (Mule-Dev-301) certification curriculum. Salesforce Mule-Dev-301 practice questions are based on recently released Mule-Dev-301 exam objectives.
Customizable Salesforce Mule-Dev-301 practice exams (desktop and web-based) of SurePassExams are designed to give you the best learning experience. You can attempt these Mule-Dev-301 practice tests multiple times till the best preparation for the Mule-Dev-301 test. On every take, our Mule-Dev-301 Practice Tests save your progress so you can view it to see and strengthen your weak concepts easily. Customizable Mule-Dev-301 practice exams allow you to adjust the time and Mule-Dev-301 questions numbers according to your practice needs.
Real Mule-Dev-301 Exam Answers | Mule-Dev-301 Reliable Braindumps BookThe website pages list the important information about our Mule-Dev-301 real quiz, the exam name and code, the updated time, the total quantity of the questions and answers, the characteristics and merits of the product, the price, the discounts to the client, the details and the guarantee of our Mule-Dev-301 Training Materials, the contact methods, the evaluations of the client on our product and the related exams. You can analyze the information the website pages provide carefully before you decide to buy our Mule-Dev-301 real quiz
Salesforce Certified MuleSoft Developer II Sample Questions (Q29-Q34):NEW QUESTION # 29
Which pattern should be used to invoke multiple HTTP APIs in parallel and roll back failed requests in sequence?
  • A. A Parallel for Each scope with each HTTP request wrapped in a Try scope
  • B. A database as a transactional outbox and an Until Successful router to retry any requests
  • C. Scatter-Gather as central Saga orchestrator for all API request with compensating actions for failing routes
  • D. VM queues as a reliability pattern with error handlers to roll back any requests
To invoke multiple HTTP APIs in parallel and roll back failed requests in sequence, the developer should use a Scatter-Gather router as a central Saga orchestrator for all API requests with compensating actions for failing routes. A Scatter-Gather router executes multiple routes concurrently and aggregates the results. A Saga orchestrator coordinates a series of actions across different services and handles failures by executing compensating actions. Therefore, using a Scatter-Gather router as a Saga orchestrator allows invoking multiple HTTP APIs in parallel and rolling back any failed requests in sequence. Reference: https://docs.mulesoft.com/mule-runtime/4.3/scatter-gather-concept https://docs.mulesoft.com/mule-runtime/4.3/saga
NEW QUESTION # 30
A Mule application contain two policies Policy A and Policy A has order1, and Policy B has order 2. Policy A Policy B, and a flow are defined by he configuration below.
When a HTTP request arrives at the Mule application's endpoint, what will be the execution order?
  • A. F1, A1, B1, B2, A2
  • B. B1, A1, F1, A2, B2
  • C. F1, B1, A1, A2, B2
  • D. A1, B1, F1, B2, A2
Based on the configuration below, when a HTTP request arrives at the Mule application's endpoint, the execution order will be A1, B1, F1, B2, A2. This is because policies are executed before and after the API implementation flow according to their order attribute. Policy A has order 1, which means it is executed first before Policy B, which has order 2. The flow is executed after both policies are executed before the flow. Then, Policy B is executed after the flow before Policy A is executed after the flow. Reference: https://docs.mulesoft.com/api-manager/2.x/policies-policy-order
NEW QUESTION # 31
Which type of cache invalidation does the Cache scope support without having to write any additional code?
  • A. White-behind invalidation
  • B. Notification-based invalidation
  • C. Write-through invalidation
  • D. Time to live
The Cache scope supports time to live (TTL) as a cache invalidation strategy without having to write any additional code. TTL specifies how long the cached response is valid before it expires and needs to be refreshed. The Cache scope also supports custom invalidation strategies using MEL or DataWeave expressions. Reference: https://docs.mulesoft.com/mule-r ... #cache_invalidation
NEW QUESTION # 32
A developer deploys an API to CloudHub and applies an OAuth policy on API Manager. During testing, the API response is slow, so the developer reconfigures the API so that the out-of-the-box HTTP Caching policy is applied first, and the OAuth API policy is applied second.
What will happen when an HTTP request is received?
  • A. In case of a cache miss, only the HTTP Caching policy is evaluated; then the API retrieves the data from the API implementation, and the policy stores the data to be cached in Object Store
  • B. In case of a cache miss, both the OAuth and HTTP Caching policies are evaluated; then the API retrieves the data from the API implementation, and the policy does not store the data in Object Store
  • C. In case of a cache hit, both the OAuth and HTTP Caching policies are evaluated; then the cached response is returned to the caller
  • D. In case of a cache it, only the HTTP Caching policy is evaluating; then the cached response is returned to the caller
When an HTTP request is received and the HTTP Caching policy is applied first, it checks if there is a cached response for that request in Object Store. If there is a cache hit, meaning that a valid cached response exists, then only the HTTP Caching policy is evaluated and the cached response is returned to the caller without invoking the OAuth policy or the API implementation. If there is a cache miss, meaning that no valid cached response exists, then both the HTTP Caching policy and the OAuth policy are evaluated before invoking the API implementation. Reference: https://docs.mulesoft.com/api-ma ... icy#policy-ordering
NEW QUESTION # 33
A new Mule project has been created in Anypoint Studio with the default settings.
Which file inside the Mule project must be modified before using Maven to successfully deploy the application?
  • A. Settings.xml
  • B. Pom.xml
  • C. Config.yaml
  • D. Mule.artificact.json
To use Maven to successfully deploy the application, the developer needs to modify the pom.xml file inside the Mule project. The pom.xml file contains the configuration and dependencies of the Mule application, as well as the deployment information such as the CloudHub region, environment, and worker size. The developer needs to specify these properties in the pom.xml file before using Maven to deploy the application. Reference: https://docs.mulesoft.com/mule-r ... ployment-descriptor
NEW QUESTION # 34
By using our Mule-Dev-301 study engine, your abilities will improve and your mindset will change. Who does not want to be a positive person? This is all supported by strength! In any case, a lot of people have improved their strength through Mule-Dev-301 Exam simulating. They now have the opportunity they want. Whether to join the camp of the successful ones, purchase Mule-Dev-301 learning braindumps, you decide for yourself!
Real Mule-Dev-301 Exam Answers: https://www.surepassexams.com/Mule-Dev-301-exam-bootcamp.html
Salesforce Mule-Dev-301 Valid Test Braindumps Because it is Easy to Download PDF Format, With the passage of time, there will be more and more new information about Real Mule-Dev-301 Exam Answers - Salesforce Certified MuleSoft Developer II sure pass vce emerging in the field, Before you decide to buy, you can try a free trial version, so that you will know the quality of the Salesforce Mule-Dev-301 practice dumps, That is to say, there is absolutely no mistake in choosing our Mule-Dev-301 test guide to prepare your exam, you will pass your exam in first try and achieve your dream soon.
We believe that the study materials will keep the top selling Mule-Dev-301 products, Review high availability designs and implement optimal redundancy, Because it is Easy to Download PDF Format.
With the passage of time, there will be more Real Mule-Dev-301 Exam Answers and more new information about Salesforce Certified MuleSoft Developer II sure pass vce emerging in the field, Beforeyou decide to buy, you can try a free trial version, so that you will know the quality of the Salesforce Mule-Dev-301 practice dumps.
SurePassExams Salesforce Mule-Dev-301 Desktop Practice ExamThat is to say, there is absolutely no mistake in choosing our Mule-Dev-301 test guide to prepare your exam, you will pass your exam in first try and achieve your dream soon.
As long as you are still a sensible person, you will definitely choose Mule-Dev-301 practice quiz.
Posted at 2/20/2026 13:20:45        Only Author  2#
I’m truly grateful for your article, it left an indelible mark. Here’s the SAFe-Practitioner latest exam dumps free test that helped me secure my promotion and salary raise. It’s free today for all. Good luck in your career growth!
