[General] AZ-204 Valid Test Format, Practice Test AZ-204 Pdf
94
【General】 AZ-204 Valid Test Format, Practice Test AZ-204 Pdf
Posted at 1/26/2026 02:36:53      View:130 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PremiumVCEDump AZ-204 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1LW6MSIZjyXV5RLTnsIRlpQPV8U2EoH2q
Solutions is one of the top platforms that has been helping Microsoft AZ-204 exam candidates for many years. Over this long time period countless candidates have passed their dream AZ-204 exam. They all got help from Exams. The Microsoft AZ-204 questions are designed by experience and qualified AZ-204 expert. They work together and strive hard to design and maintain the top standard of PremiumVCEDump AZ-204 Questions. So you rest assured that the Microsoft AZ-204 questions you will not only ace your Developing Solutions for Microsoft Azure certification exam preparation but also be ready to perform well in the final AZ-204 exam.
Exam AZ-204: Developing Solutions for Microsoft AzureCandidates for this exam should have subject matter expertise designing, building, testing, and maintaining cloud applications and services on Microsoft Azure.
A candidate for this certification should have 1-2 years professional development experience and experience with Microsoft Azure. In addition, the candidate for this role should have the ability to program in a language supported by Azure and proficiency in Azure SDKs, Azure PowerShell, Azure CLI, data storage options, data connections, APIs, app authentication and authorization, compute and container deployment, debugging, performance tuning, and monitoring.
You may be eligible for ACE college credit if you pass this certification exam. See ACE college credit for certification exams for details.
Part of the requirements for:  Microsoft Certified: Azure Developer Associate
   Download exam skills outline
Practice Test AZ-204 Pdf | AZ-204 Detailed Study PlanA full Microsoft AZ-204 package is required to take each Success in Life. If you want to be successful, you need to prepare well for the Developing Solutions for Microsoft Azure AZ-204 exam. Buying the right Microsoft AZ-204 Exam Preparation Materials is one way to prepare for it. With the right study tools, you can easily prepare for the Developing Solutions for Microsoft Azure. Whether you want to study Microsoft AZ-204 Exam or pass other Developing Solutions for Microsoft Azure exam, if you want to prepare for Microsoft AZ-204 exam, you can choose Microsoft AZ-204 Valid Exam Questions exam.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q251-Q256):NEW QUESTION # 251
You are maintaining an existing application that uses an Azure Blob GPv1 Premium storage account. Data older than three months is rarely used.
Data newer than three months must be available immediately. Data older than a year must be saved but does not need to be available immediately.
You need to configure the account to support a lifecycle management rule that moves blob data to archive storage for data not modified in the last year.
Step 1: Upgrade the storage account to GPv2
Object storage data tiering between hot, cool, and archive is supported in Blob Storage and General Purpose v2 (GPv2) accounts. General Purpose v1 (GPv1) accounts don't support tiering.
You can easily convert your existing GPv1 or Blob Storage accounts to GPv2 accounts through the Azure portal.
Step 2: Copy the data to be archived to a Standard GPv2 storage account and then delete the data from the original storage account Step 3: Change the storage account access tier from hot to cool Note: Hot - Optimized for storing data that is accessed frequently.
Cool - Optimized for storing data that is infrequently accessed and stored for at least 30 days.
Archive - Optimized for storing data that is rarely accessed and stored for at least 180 days with flexible latency requirements, on the order of hours.
Only the hot and cool access tiers can be set at the account level. The archive access tier can only be set at the blob level.
https://docs.microsoft.com/en-us ... -blob-storage-tiers
NEW QUESTION # 252
You are developing an Azure-hosted e-commerce web application. The application will use Azure Cosmos DB to store sales orders. You are using the latest SDK to manage the sales orders in the database.
You create a new Azure Cosmos DB instance. You include a valid endpoint and valid authorization key to an appSettings.json file in the code project.
You are evaluating the following application code: (Line number are included for reference only.)
Graphical user interface, text, application Description automatically generated
Box 1: Yes
The createDatabaseIfNotExistsAsync method checks if a database exists, and if it doesn't, create it.
The Database.CreateContainerAsync method creates a container as an asynchronous operation in the Azure Cosmos service.
Box 2: Yes
The CosmosContainer.CreateItemAsync method creates an item as an asynchronous operation in the Azure Cosmos service.
Box 3: Yes
https://docs.microsoft.com/en-us ... aseifnotexistsasync
https://docs.microsoft.com/en-us ... reatecontainerasync
https://docs.microsoft.com/en-us ... ner.createitemasync
NEW QUESTION # 253
You manage an Azure Cosmos DB for a NoSQL API account named account1. You configure account1 with the default consistency level.
An application named app1 must access containers in account1 to perform read and write operations. The connections from app1 to account1 must be established by using the direct mode.
You plan to configure app1 to override the default consistency level by using the Azure Cosmos DB SDK client.
You need to set the maximum consistency level for app1 to use for read and write operations.
Which consistency level should you set? To answer, move the appropriate maximum consistency levels to the correct operation types. You may use each maximum consistency level once, more than once, or not at all.
You may need to move the split bar between panes or scroll to view content.
NEW QUESTION # 254
You are developing an application to use Azure Blob storage. You have configured Azure Blob storage to include change feeds.
A copy of your storage account must be created in another region. Data must be copied from the current storage account to the new storage account directly between the storage servers.
You need to create a copy of the storage account in another region and copy the data.
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
https://docs.microsoft.com/en-us ... ortal#modify-the-te
NEW QUESTION # 255
You need to implement the Log policy.
How should you complete the Azure Event Grid subscription? To answer, drag the appropriate JSON segments to the correct locations. Each JSON segment may be used once, more than once, or not at all. You may need to drag the split bar between panes to view content.
https://docs.microsoft.com/en-us ... ion-creation-schema
NEW QUESTION # 256
Thanks to modern technology, learning online gives people access to a wider range of knowledge, and people have got used to convenience of electronic equipment. As you can see, we are selling our AZ-204 learning guide in the international market, thus there are three different versions of our AZ-204 exam materials which are prepared to cater the different demands of various people. We here promise you that our AZ-204 Certification material is the best in the market, which can definitely exert positive effect on your study. Our Developing Solutions for Microsoft Azure learn tool create a kind of relaxing leaning atmosphere that improve the quality as well as the efficiency, on one hand provide conveniences, on the other hand offer great flexibility and mobility for our customers. That’s the reason why you should choose us.
Practice Test AZ-204 Pdf: https://www.premiumvcedump.com/Microsoft/valid-AZ-204-premium-vce-exam-dumps.html
P.S. Free 2026 Microsoft AZ-204 dumps are available on Google Drive shared by PremiumVCEDump: https://drive.google.com/open?id=1LW6MSIZjyXV5RLTnsIRlpQPV8U2EoH2q
