CMMC-CCP软件版 &最新CMMC-CCP試題
Posted at 1/26/2026 04:56:41
2026 Testpdf最新的CMMC-CCP PDF版考試題庫和CMMC-CCP考試問題和答案免費分享:https://drive.google.com/open?id=1lgK-nyAWRtMQsjjF7eoUfVS8VPx0NE_0
為了讓生活過得更加美好,參加 CMMC-CCP 認證考試獲取 Cyber AB 認證是每位選擇IT行業的工作人員必經之路。只有獲取了公司要求的這張證書既可獲得加薪和升遷的機會。Cyber AB 的 CMMC-CCP 考試認證的練習題及答可以幫助我們快捷方便的通往成功的道路,而且享受保障政策,已經有很多IT人士在行動了,就在 Testpdf 的 CMMC-CCP 考試培訓資料,不容錯過。
Cyber AB CMMC-CCP 考試大綱:| 主題 | 簡介 | | 主題 1 | - CMMC Ecosystem: This section of the exam measures the skills of consultants and compliance professionals and focuses on the different roles and responsibilities across the CMMC ecosystem. Candidates must understand the functions of entities such as the Department of Defense, CMMC-AB, Organizations Seeking Certification, Registered Practitioners, and Certified CMMC Professionals, as well as how the ecosystem supports cybersecurity standards and certification.
| | 主題 2 | - CMMC Model Construct and Implementation Evaluation: This section of the exam measures the evaluative skills of cybersecurity assessors, focusing on the application and assessment of the CMMC model. It includes understanding its levels, domains, practices, and implementation criteria, and how to assess whether organizations meet the required cybersecurity practices using evidence-based evaluation.
| | 主題 3 | - CMMC-AB Code of Professional Conduct (Ethics): This section of the exam measures the integrity of cybersecurity professionals by evaluating their understanding of the CMMC-AB Code of Professional Conduct. It emphasizes ethical responsibilities, including confidentiality, objectivity, professionalism, conflict-of-interest avoidance, and respect for intellectual property, ensuring candidates can uphold ethical standards throughout their CMMC-related duties.
最有效的CMMC-CCP软件版,免費下載CMMC-CCP考試指南得到妳想要的Cyber AB證書在現在這個人才濟濟的社會裏,還是有很多行業是缺乏人才的,比如IT行業就相當缺乏技術性的人才。而Cyber AB CMMC-CCP 認證考試就是個檢驗IT技術的認證考試之一。Testpdf是一個給你培訓Cyber AB CMMC-CCP 認證考試相關技術知識的網站。
最新的 Cyber AB CMMC CMMC-CCP 免費考試真題 (Q161-Q166):問題 #161
In many organizations, the protection of FCI includes devices that are used to scan physical documentation into digital form and print physical copies of digital FCI. What technical control can be used to limit multi- function device (MFD) access to only the systems authorized to access the MFD?
- A. Access lists only known to the IT administrator
- B. Documentation showing MFD configuration
- C. Virtual LAN restrictions
- D. Single administrative account
答案:C
解題說明:
Understanding Multi-Function Device (MFD) Security in CMMCMulti-function devices (MFDs), such asscanners, printers, and copiers,process, store, and transmit FCI, making them apotential attack surfacefor unauthorized access.
Thebest technical controlto limit MFD access to only authorized systems isVirtual LAN (VLAN) restrictions, whichsegment and isolate network traffic.
* VLAN Restrictions Provide Network Segmentation
* VLANsisolate the MFDfrom unauthorized systems, ensuringonly approved devicescan communicate with it.
* Prevents unauthorized network access bylimiting connectionsto specific IPs or subnets.
* Meets CMMC 2.0 Network Security Controls
* Aligns withCMMC System and Communications Protection (SC) Practicesfor network segmentation and access control.
* Reducesthe risk of unauthorized access to scanned and printed FCI.
* B. Single administrative account#Incorrect
* Asingle admin accountdoes not restrict accessbetween devices, only controlswho can configurethe MFD.
* C. Documentation showing MFD configuration#Incorrect
* Documentation helps with compliance butdoes not actively restrict access.
* D. Access lists only known to the IT administrator#Incorrect
* Access lists should besystem-enforced, not just "known" to the administrator.
* CMMC Practice SC.3.192 (Network Segmentation)- Requires restricting access usingnetwork segmentation techniques such as VLANs.
* NIST SP 800-171 (SC Family)- Supportsisolation of sensitive devicesusing VLANs and other segmentation controls.
Why the Correct Answer is "A. Virtual LAN (VLAN) Restrictions"?Why Not the Other Options?
Relevant CMMC 2.0 References:Final Justification:SinceVirtual LAN (VLAN) restrictions enforce access control at the network level, the correct answer isA. Virtual LAN (VLAN) restrictions.
問題 #162
A cyber incident is discovered that affects a covered contractor IS and the CDI residing therein. How long does the contractor have to inform the DoD?
- A. 48 hours
- B. 72 hours
- C. 96 hours
- D. 24 hours
答案:B
解題說明:
Contractors that handle Covered Defense Information (CDI) are required to report cyber incidents to the Department of Defense within 72 hours of discovery.
Supporting Extracts from Official Content:
* DFARS 252.204-7012(c)(1): "When the Contractor discovers a cyber incident that affects a covered contractor information system or the covered defense information residing therein, the Contractor shall conduct a review... and rapidly report the cyber incident to DoD within 72 hours of discovery." Why Option C is Correct:
* The regulation explicitly specifies 72 hours.
* Options A (24 hrs), B (48 hrs), and D (96 hrs) do not align with DFARS requirements.
References (Official CMMC v2.0 Content and Source Documents):
* DFARS 252.204-7012, Safeguarding Covered Defense Information and Cyber Incident Reporting.
* CMMC v2.0 Governance - Source Documents list includes DFARS 252.204-7012.
問題 #163
An assessor needs to get the most accurate answers from an OSC's team members. What is the BEST method to ensure that the OSC's team members are able to describe team member responsibilities?
- A. Interview groups of people to get collective answers.
- B. Let team members know the questions prior to the assessment.
- C. Ensure confidentiality and non-attribution of team members.
- D. Understand that testing is more important that interviews.
答案:C
解題說明:
During aCMMC assessment, assessors rely on interviews to validate the implementation of cybersecurity practices within anOrganization Seeking Certification (OSC). Ensuringconfidentiality and non- attributionallows employees to speak freely without fear of retaliation or bias, leading to more accurate and candid responses.
* CMMC Assessment Process and the Role of Interviews
* TheCMMC Assessment Guide(Level 2) states thatinterviews are a key methodto verify compliance with security controls.
* Employees may hesitate to provide truthful information if they fear negative consequences.
* To obtain accurate information, assessors must create an environment where team members feel safe.
* Ensuring Non-Attribution for Accurate Responses
* DoD Assessment Methodologyhighlights thatinterviewees should remain anonymousin reports.
* Non-attribution reduces the risk of OSC leadership influencing responses or retaliating against employees.
* Employees are more likely to provideaccurateandhonestdescriptions of their responsibilities when confidentiality is guaranteed.
* Why the Other Answer Choices Are Incorrect:
* (A) Interview groups of people to get collective answers:
* Group interviews may limit honest responses due topeer pressure or management presence.
* Employees mayhesitate to contradictsupervisors or peers in a group setting.
* (B) Understand that testing is more important than interviews:
* While testing (e.g., reviewing logs, configurations, and security settings) is crucial, interviews providecontexton how security practices are implemented and followed.
* Interviewscomplementtesting rather than being less important.
* (D) Let team members know the questions prior to the assessment:
* Advanced notice may allow employees toprepare rehearsed answers, which might not reflect actual practices.
* This couldreduce the effectivenessof the interview process.
Step-by-Step Breakdown:Final Validation from CMMC Documentation:TheCMMC Assessment Process Guideand DoDAssessment Methodologyemphasize the importance of confidentiality in interviews to ensure accuracy.Non-attribution protects employees and ensures assessors get honest, unfiltered answers.
Thus, the correct answer is:
C: Ensure confidentiality and non-attribution of team members.
問題 #164
Prior to conducting a CMMC Assessment, the contractor must specify the CMMC Assessment scope by categorizing all assets. Which two asset categories are always assessed against CMMC practices?
- A. Specialized Assets and Contractor Risk Managed Assets
- B. Security Protection Assets and CUI Assets
- C. CUI Assets and Specialized Assets
- D. Security Protection Assets and Contractor Risk Managed Assets
答案:B
解題說明:
Understanding CMMC Asset Scoping RequirementsBefore conducting aCMMC Level 2 Assessment, anOrganization Seeking Certification (OSC)must define theassessment scopeby categorizing all assets. This ensures that only relevant systems are assessed againstCMMC practices, reducing unnecessary compliance burdens.
According to theCMMC Scoping Guide for Level 2, there are four asset categories:
* CUI Assets- Assets that process, store, or transmitControlled Unclassified Information (CUI).
* Security Protection Assets (SPA)- Assets that providesecurity functions(e.g., firewalls, intrusion detection systems, identity management systems).
* Contractor Risk Managed Assets (CRMA)- Assets thatdo not directly store/process CUIbut interact with CUI environments (e.g., BYOD devices, personal computers used for remote access).
* Specialized Assets- Unique systems such asOperational Technology (OT), IoT, and Government Furnished Equipment (GFE), which may requirelimitedCMMC assessment.
Which Asset Categories Are Always Assessed?#1. CUI Assets(ALWAYS ASSESSED)
* These are theprimary focusof CMMC Level 2 since they handleCUI.
* All110 NIST SP 800-171 controlsapply to these assets.
#2. Security Protection Assets (SPA)(ALWAYS ASSESSED)
* Security tools that protectCUI Assetsarealways includedin the assessment.
* Examples includefirewalls, antivirus, endpoint detection and response (EDR) tools, and identity management systems.
* (A) CUI Assets and Specialized Assets#
* CUI Assets are assessed, butSpecialized Assets are only assessed in a limited manner, depending on their role inCUI security.
* (C) Specialized Assets and Contractor Risk Managed Assets#
* Specialized Assets and CRMAsare typicallynot fully assessedagainst CMMC controls unless they directly impactCUI security.
* (D) Security Protection Assets and Contractor Risk Managed Assets#
* SPAs are always assessed, butCRMAs are not necessarily assessedunless they directly impact CUI.
* TheCMMC Scoping Guide (Level 2)clearly states thatCUI Assets and Security Protection Assetsarealways assessedagainst CMMC practices.
Why the Other Answer Choices Are Incorrect:Final Validation from CMMC Documentation:Thus, the correct answer is:
B: Security Protection Assets and CUI Assets.
問題 #165
An OSC receives an email with "CUI//SP-PRVCY//FED Only" in the body of the message Which organization's website should the OSC go to identify what this marking means?
- A. NARA
- B. DoD 239.7601 Definitions page
- C. DoD Contractors FAQ page
- D. CMMC-AB
答案:A
解題說明:
* What Does "CUI//SP-PRVCY//FED Only" Mean?
* The email containsControlled Unclassified Information (CUI)withspecific categories and dissemination controls.
* CUI//SP-PRVCY//FED Onlybreaks down as follows:
* CUI# Controlled Unclassified Information designation.
* SP-PRVCY#Specifiedcategory forPrivacy Information(SP stands for "Specified").
* FED Only# Restriction forFederal Government use only(not for contractors or the public).
* Who Maintains the Official CUI Registry?
* TheNational Archives and Records Administration (NARA) oversees the CUI Programand maintains the officialCUI Registry(https://www.archives.gov/cui).
* The CUI Registry providesdefinitions, marking guidance, and categoriesfor all CUI labels, including "SP-PRVCY" and dissemination controls like "FED Only."
* Why NARA is the Correct Answer:
* NARA is the governing body responsible for defining and managing CUI markings.
* Any organization handling CUI shouldrefer to the NARA CUI Registryfor official marking interpretations.
* DoD contractors and other organizationsmust comply with NARA guidelines when handling, marking, and disseminating CUI.
* B. CMMC-AB- TheCMMC Accreditation Bodymanages certification assessments butdoes not define or interpret CUI markings.
* C. DoD Contractors FAQ Page- The DoD may provide general contractor guidance, butCUI markings are governed by NARA, not an FAQ page.
* D. DoD 239.7601 Definitions Page- This refers to generalDoD acquisition definitions, butCUI categories and markings fall under NARA's authority.
References:NARA CUI Registry(https://www.archives.gov/cui)
DoD CUI Program Guidance(DoD CIO Site)
CMMC 2.0 Level 2 Compliance Requirements(Cyber AB)
#Final Answer: A. NARA
問題 #166
Testpdf不僅能為那你節約寶貴的時間,還可以讓你安心地參加考試以及順利的通過。Testpdf具有很好的可靠性,在專業IT行業人士中有很高的聲譽。你可以通過免費下載我們的Testpdf提供的部分關於Cyber AB CMMC-CCP考題及答案作為嘗試來確定我們的可靠性,相信你會很滿意的。我對我們Testpdf的產品有信心,相信很快Testpdf的關於Cyber AB CMMC-CCP考題及答案就會成為你的不二之選。你也會很快很順利的通過Cyber AB CMMC-CCP的認證考試。選擇我們Testpdf是明智的,Testpdf會是你想要的滿意的產品。
最新CMMC-CCP試題: https://www.testpdf.net/CMMC-CCP.html
- 選擇我們高效率的值得信賴的CMMC-CCP软件版: Certified CMMC Professional (CCP) Exam,Cyber AB CMMC-CCP考試對您來說不再難 🕜 免費下載[ CMMC-CCP ]只需進入➥ [url]www.newdumpspdf.com 🡄網站CMMC-CCP PDF[/url]
- 高質量的CMMC-CCP软件版,由Cyber AB權威專家撰寫 🐘 ▷ [url]www.newdumpspdf.com ◁是獲取⮆ CMMC-CCP ⮄免費下載的最佳網站CMMC-CCP考古题推薦[/url]
- CMMC-CCP考古題更新 🤭 CMMC-CCP考題 🥉 免費下載CMMC-CCP考題 🌲 開啟▷ tw.fast2test.com ◁輸入➠ CMMC-CCP 🠰並獲取免費下載CMMC-CCP考試大綱
- CMMC-CCP考試大綱 🔌 CMMC-CCP題庫資訊 🥯 CMMC-CCP考試大綱 🤒 ✔ [url]www.newdumpspdf.com ️✔️上的免費下載▷ CMMC-CCP ◁頁面立即打開CMMC-CCP熱門考古題[/url]
- 最優質的CMMC-CCP软件版擁有模擬真實考試環境與場境的軟件VCE版本&權威的Cyber AB CMMC-CCP 🦇 透過➥ [url]www.newdumpspdf.com 🡄搜索▛ CMMC-CCP ▟免費下載考試資料免費下載CMMC-CCP考題[/url]
- CMMC-CCP软件版將是您最好的助力Certified CMMC Professional (CCP) Exam 🖊 ✔ [url]www.newdumpspdf.com ️✔️是獲取➠ CMMC-CCP 🠰免費下載的最佳網站CMMC-CCP最新試題[/url]
- CMMC-CCP指南 🦖 CMMC-CCP真題 👶 新版CMMC-CCP題庫 🍂 在✔ [url]www.newdumpspdf.com ️✔️上搜索✔ CMMC-CCP ️✔️並獲取免費下載CMMC-CCP考古题推薦[/url]
- CMMC-CCP考古題更新 🏨 CMMC-CCP考試心得 🥎 CMMC-CCP真題 🤙 到【 [url]www.newdumpspdf.com 】搜尋➠ CMMC-CCP 🠰以獲取免費下載考試資料CMMC-CCP題庫資料[/url]
- CMMC-CCP題庫資訊 👳 CMMC-CCP題庫資訊 🎬 免費下載CMMC-CCP考題 🩱 在➥ [url]www.pdfexamdumps.com 🡄上搜索➡ CMMC-CCP ️⬅️並獲取免費下載CMMC-CCP真題[/url]
- CMMC-CCP软件版 - 保證高通過率 🙎 免費下載【 CMMC-CCP 】只需在➽ [url]www.newdumpspdf.com 🢪上搜索CMMC-CCP最新考古題[/url]
- 權威的CMMC-CCP软件版,最有效的考試指南幫助妳壹次性通過CMMC-CCP考試 👋 到{ [url]www.newdumpspdf.com }搜尋➡ CMMC-CCP ️⬅️以獲取免費下載考試資料CMMC-CCP考試心得[/url]
- www.stes.tyc.edu.tw, app.parler.com, knowyourmeme.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
