NCM-MCI-6.10 Test Lab Questions & NCM-MCI-6.10 Free Dumps
Posted at 1/26/2026 06:32:16
By using our NCM-MCI-6.10 study engine, your abilities will improve and your mindset will change. Who does not want to be a positive person? This is all supported by strength! In any case, a lot of people have improved their strength through NCM-MCI-6.10 Exam simulating. They now have the opportunity they want. Whether to join the camp of the successful ones, purchase NCM-MCI-6.10 learning braindumps, you decide for yourself!
Under the instruction of our NCM-MCI-6.10 exam torrent, you can finish the preparing period in a very short time and even pass the exam successful, thus helping you save lot of time and energy and be more productive with our Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) prep torrent. In fact the reason why we guarantee the high-efficient preparing time for you to make progress is mainly attributed to our marvelous organization of the content and layout which can make our customers well-focused and targeted during the learning process with our NCM-MCI-6.10 Test Braindumps. The high pass rate of our NCM-MCI-6.10 exam prep is 99% to 100%.
Quiz 2026 NCM-MCI-6.10: Latest Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Test Lab QuestionsYour dream is very high, so you have to find a lot of material to help you prepare for the exam. Itexamguide Nutanix NCM-MCI-6.10 Exam Materials can help you to achieve your ideal. Itexamguide Nutanix NCM-MCI-6.10 exam materials is a collection of experience and innovation from highly certified IT professionals in the field. Our products will let you try all the problems that may arise in a really examinations. We can give you a guarantee, to ensure that candidates get a 100% correct answer.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q28-Q33):NEW QUESTION # 28
TASK 1
A newly created Windows VM "SQL02" is experiencing poor storage performance when compared to
"SQL01" running within the same cluster, on the same storage container.
The cluster is in a healthy state.
Create a new session named Monitor SQL02 with meaningful metrics. Right click on the session page and click Select All then paste this into Notepad and save it as Task 1.txt on the desktop.
Also, save the analysis as a report named MonitorSQL02 and send the report as a PDF on a daily basis to perf_group@ACME.org. Reports should not be retained. If any new objects need to be created, use monitovm2 in the name.
Finally, correct the issue within "SQL02".
Notes:
* Do not power on the VMs.
* While you will be creating a session, you will need to examine the VM configurations to determine the issue.
* Do not delete the VM to resolve the issue, any other destructive change is acceptable.
See the Explanation below for detailed answer.
Here is the step-by-step solution to all three tasks, performed within the Nutanix Prism interface.
Task 1: Create Monitoring Session & Save Metrics
* From the Prism Central dashboard, navigate to Operations > Analysis.
* Click the + New Session button.
* Name the session Monitor SQL02.
* In the "Entities" search box, type SQL01 and select VM: SQL01.
* In the "Entities" search box, type SQL02 and select VM: SQL02.
* Click Add Charts > New Chart.
* Title: Storage IOPS
* Metric: Storage Controller IOPS
* Click Add.
* Title: Storage Latency
* Metric: Storage Controller Latency
* Click Add.
* Title: Storage Bandwidth
* Metric: Storage Controller Bandwidth
* Click Add.
* Click Save Session.
* With the "Monitor SQL02" session open, right-click anywhere on the page and click Select All.
* Right-click again and select Copy.
* Open Notepad, paste the content, and save the file to the desktop as Task 1.txt.
(The content pasted into Task 1.txt would be the session's chart configurations, showing metrics for SQL01 and SQL02.)
Task 2: Create and Schedule the Report
* While still in the "Monitor SQL02" analysis session, click the Save as Report button (it looks like a bookmark icon).
* Name the report MonitorSQL02 and click Save.
* Navigate to Operations > Reports.
* Find the MonitorSQL02 report in the list. Select its checkbox.
* Click the Actions dropdown and select Schedule.
* Configure the schedule with the following settings:
* Schedule Name: monitovm2_daily_report
* Recurrence: Daily
* Start Time: (Set to a time, e.g., 8:00 AM)
* Repeat every: 1 day(s)
* Retention Policy: Uncheck the "Retain a copy of the report" box. (This ensures reports are not retained).
* Email Report: Check this box.
* Format: PDF
* Recipients: perf_group@ACME.org
* Click Save.
Task 3: Identify and Correct the Performance Issue
This task is performed without powering on the VMs, indicating a configuration error.
Investigation
* Navigate to VMs > Table view.
* Click on the SQL01 (the good VM) and select the Configuration tab.
* Expand the Disks section. Observe that the primary disk is attached to a SCSI bus (e.g., scsi.0). This is the high-performance standard.
* Return to the VM list and click on SQL02 (the problem VM).
Root Cause
You discover that the primary disk for SQL02 is attached to an IDE bus. The IDE bus has significant performance limitations and is not suitable for a database server, causing the poor storage performance.
Correction
* With the SQL02 VM selected, click the Update button.
* In the "Update VM" dialog, scroll down to the Disks section.
* Find the disk attached to the IDE bus. Click the Edit (pencil) icon for that disk.
* Change the Bus Type dropdown from IDE to SCSI.
* The Device Index will automatically populate (e.g., scsi.0).
* Click Save in the "Update Disk" dialog.
* (Note: A "VirtIO SCSI Controller" will be automatically added to the VM configuration if one was not already present.)
* Click Save in the "Update VM" dialog.
The VM SQL02 is now configured to use the high-performance VirtIO-SCSI controller, which will resolve the storage performance discrepancy once the VM is powered on.
NEW QUESTION # 29
Due to new security requirements, an administrator has been tasked with updating the security settings for user accounts within Prism Element on Cluster 1.
An SSL Certificate Signing Request with Subject Alternative Name should be generated for submission to the security team's Certificate Authority with the following details:
countryName = US
stateOrProvinceName = North Carolina
localityName = Durham
organizationName = ACME
organizationalUnitName = Infrastructure
commonName = prism_element.ACME.org
emailAddress = administrator@ACME.org
Alternate names = cvm1.ACME.org, cvm2.ACME.org, cvm3.ACME.org
Encryption: RSA 2048, sha256
When the Certificate Signing Request is generated, place a copy of both the .cnf file and the .csr file on the desktop named 'prism_element_acme.cnf' and 'prism_element_acme.csr' Save a copy of the command(s) used for this scenario to a new file on the desktop named "Task 5.txt".
Note: You must copy and paste the command(s) and output from SSH to the "Task 5.txt" file to achieve all points available.
Here is the step-by-step solution to generate the Certificate Signing Request (CSR) on Cluster 1.
This entire process is performed from an SSH session connected to a CVM (Controller VM) on Cluster 1.
1. Access Cluster 1 CVM
* From Prism Central, navigate to Hardware > Clusters and click on Cluster 1 to open its Prism Element (PE) interface.
* In the Cluster 1 PE, navigate to Hardware > CVMs to find the IP address of any CVM in the cluster.
* Use an SSH client (like PuTTY) to connect to the CVM's IP address.
* Log in with the admin user and password.
2. Create the Configuration File (.cnf)
To include the Subject Alternative Names (SANs), you must first create a configuration file.
* In the CVM's command line, create the .cnf file using a text editor:
vi prism_element_acme.cnf
* Press i to enter "Insert" mode.
* Paste the following text exactly into the editor:
Ini, TOML
[ req ]
default_bits = 2048
distinguished_name = req_distinguished_name
req_extensions = v3_req
prompt = no
[ req_distinguished_name ]
C = US
ST = North Carolina
L = Durham
O = ACME
OU = Infrastructure
CN = prism_element.ACME.org
[ v3_req ]
subjectAltName = @alt_names
[ alt_names ]
DNS.1 = cvm1.ACME.org
DNS.2 = cvm2.ACME.org
DNS.3 = cvm3.ACME.org
* Press Esc to exit "Insert" mode, then type :wq and press Enter to save and quit vi.
3. Generate the CSR and Key
* Run the following openssl command. This command uses the .cnf file to generate the new CSR (.csr) and a corresponding private key (.key), applying the sha256 encryption as requested.
Bash
openssl req -new -nodes -out prism_element_acme.csr -keyout prism_element_acme.key -config prism_element_acme.cnf -sha256
* The command will output the following, confirming the key generation:
* Generating a 2048 bit RSA private key
* writing new private key to 'prism_element_acme.key'
4. Save Files to the Desktop
You will now copy the contents of the generated files from the CVM to your desktop.
* For Task 5.txt (Commands and Output):
* Open a new Notepad file on the desktop.
* Copy and paste all the commands you ran in the SSH session and their full output (as shown in steps 2 and 3) into this file.
* Save the file on the desktop as Task 5.txt.
* For prism_element_acme.cnf:
* In the CVM SSH session, display the file's content:
cat prism_element_acme.cnf
* Copy the entire text output (starting from [ req ]).
* Paste the content and save the file as prism_element_acme.cnf.
* For prism_element_acme.csr:
cat prism_element_acme.csr
* Copy the entire text output, including the -----BEGIN CERTIFICATE REQUEST----- and ----- END CERTIFICATE REQUEST----- lines.
* Open a new C:UsersadminDesktopNotepad file on the desktop.
* Paste the content and save the file as prism_element_acme.csr.
NEW QUESTION # 30
Task 12
The application team is reporting performance degradation for a business-critical application that runs processes all day on Saturdays.
The team is requesting monitoring or processor, memory and storage utilization for the three VMs that make up the database cluster for the application: ORA01, ORA02 and ORA03.
The report should contain tables for the following:
At the cluster level, only for the current cluster:
The maximum percentage of CPU used
At the VM level, including any future VM with the prefix ORA:
The maximum time taken to process I/O Read requests
The Maximum percentage of time a VM waits to use physical CPU, out of the local CPU time allotted to the VM.
The report should run on Sundays at 12:00 AM for the previous 24 hours. The report should be emailed to appdev@cyberdyne.net when competed.
Create a report named Weekends that meets these requirements
Note: You must name the report Weekends to receive any credit. Any other objects needed can be named as you see fit. SMTP is not configured.
See the Explanation for step by step solution.
To create a report named Weekends that meets the requirements, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter Weekends as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select Cluster. Click Next.
Under the Custom Columns option, add the following variable: CPU Usage (%). Click Next.
Under the Aggregation option for CPU Usage (%), select Max. Click Next.
Under the Filter option, select Current Cluster from the drop-down menu. Click Next.
Click on Add to add this custom view to your report. Click Next.
Under the Custom Views section, select Data Table again. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, I/O Read Latency (ms), VM Ready Time (%). Click Next.
Under the Aggregation option for I/O Read Latency (ms) and VM Ready Time (%), select Max. Click Next.
Under the Filter option, enter ORA* in the Name field. This will include any future VM with the prefix ORA.
Click Next.
Under the Report Settings option, select Weekly from the Schedule drop-down menu and choose Sunday as the day of week. Enter 12:00 AM as the time of day. Enter appdev@cyberdyne.net as the Email Recipient.
Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
NEW QUESTION # 31
Task 5
An administrator has noticed that after a host failure, the SQL03 VM was not powered back on from another host within the cluster. The Other SQL VMs (SQL01, SQL02) have recovered properly in the past.
Resolve the issue and configure the environment to ensure any single host failure affects a minimal number os SQL VMs.
Note: Do not power on any VMs
One possible reason why the SQL03 VM was not powered back on after a host failure is that the cluster was configured with the default (best effort) VM high availability mode, which does not guarantee the availability of VMs in case of insufficient resources on the remaining hosts. To resolve this issue, I suggest changing the VM high availability mode to guarantee (reserved segments), which reserves some memory on each host for failover of VMs from a failed host. This way, the SQL03 VM will have a higher chance of being restarted on another host in case of a host failure.
To change the VM high availability mode to guarantee (reserved segments), you can follow these steps:
Log in to Prism Central and select the cluster where the SQL VMs are running.
Click on the gear icon on the top right corner and select Cluster Settings.
Under Cluster Services, click on Virtual Machine High Availability.
Select Guarantee (Reserved Segments) from the drop-down menu and click Save.
To configure the environment to ensure any single host failure affects a minimal number of SQL VMs, I suggest using anti-affinity rules, which prevent VMs that belong to the same group from running on the same host. This way, if one host fails, only one SQL VM will be affected and the other SQL VMs will continue running on different hosts.
To create an anti-affinity rule for the SQL VMs, you can follow these steps:
Select Virtual Machines from the drop-down menu and click on Create Group.
Enter a name for the group, such as SQL Group, and click Next.
Select the SQL VMs (SQL01, SQL02, SQL03) from the list and click Next.
Select Anti-Affinity from the drop-down menu and click Next.
Review the group details and click Finish.
I hope this helps. How else can I help?
https://portal.nutanix.com/page/ ... ity-policies-c.html
A screenshot of a computer Description automatically generated with medium confidence
NEW QUESTION # 32
Task 13
An administrator found a CentOS VM, Cent_Down, on the cluster with a corrupted network stack. To correct the issue, the VM will need to be restored from a previous snapshot to become reachable on the network again.
VM credentials:
Username: root
Password: nutanix/4u
Restore the VM and ensure it is reachable on the network by pinging 172.31.0.1 from the VM.
Power off the VM before proceeding.
To restore the VM and ensure it is reachable on the network, you can follow these steps:
Log in to the Web Console of the cluster where the VM is running.
Click on Virtual Machines on the left menu and find Cent_Down from the list. Click on the power icon to power off the VM.
Click on the snapshot icon next to the power icon to open the Snapshot Management window.
Select a snapshot from the list that was taken before the network stack was corrupted. You can use the date and time information to choose a suitable snapshot.
Click on Restore VM and confirm the action in the dialog box. Wait for the restore process to complete.
Click on the power icon again to power on the VM.
Log in to the VM using SSH or console with the username and password provided.
Run the command ping 172.31.0.1 to verify that the VM is reachable on the network. You should see a reply from the destination IP address.
Go to VMS from the prism central gui
Select the VMand go to More -> Guest Shutdown
Go to Snapshots tab and revert to latest snapshot available
power on vm and verify if ping is working
NEW QUESTION # 33
With all NCM-MCI-6.10 practice questions being brisk in the international market, our NCM-MCI-6.10 exam materials are quite catches with top-ranking quality. But we do not stop the pace of making advancement by following the questions closely according to exam. So our experts make new update as supplementary updates. So that our NCM-MCI-6.10 study braindumps are always the latest for our loyal customers and we will auto send it to you as long as we update it.
NCM-MCI-6.10 Free Dumps: https://www.itexamguide.com/NCM-MCI-6.10_braindumps.html
So choosing appropriate NCM-MCI-6.10 test guide is important for you to pass the exam, Nutanix NCM-MCI-6.10 Test Lab Questions There are 24/7 customer assist to support you in case you may encounter some problems, First, our NCM-MCI-6.10 practice briandumps have varied versions as the PDF, software and APP online which can satify different needs of our customers, Itexamguide is the best platform where you can get reliable, update and valid Nutanix NCM-MCI-6.10 exam preparation material.
Using a Report AutoFormat, They Should Know Better, So choosing appropriate NCM-MCI-6.10 test guide is important for you to pass the exam, There are 24/7 customer assist to support you in case you may encounter some problems.
100% Pass Quiz 2026 Nutanix NCM-MCI-6.10 Fantastic Test Lab QuestionsFirst, our NCM-MCI-6.10 practice briandumps have varied versions as the PDF, software and APP online which can satify different needs of our customers, Itexamguide is the best platform where you can get reliable, update and valid Nutanix NCM-MCI-6.10 exam preparation material.
The Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) PDF dumps file is the PDF version of real Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) exam questions that work with all devices and operating systems.
- NCM-MCI-6.10 Actual Braindumps 🏠 Online NCM-MCI-6.10 Training Materials 🤾 Exam NCM-MCI-6.10 Pass4sure 👙 Enter ⇛ [url]www.examcollectionpass.com ⇚ and search for ➥ NCM-MCI-6.10 🡄 to download for free 🐲Reliable NCM-MCI-6.10 Test Camp[/url]
- NCM-MCI-6.10 Reliable Exam Online 🕊 New NCM-MCI-6.10 Test Vce 💽 NCM-MCI-6.10 Vce Test Simulator 🙎 Download ⇛ NCM-MCI-6.10 ⇚ for free by simply searching on ➠ [url]www.pdfvce.com 🠰 🧦NCM-MCI-6.10 Reliable Exam Online[/url]
- Nutanix NCM-MCI-6.10 Exam | NCM-MCI-6.10 Test Lab Questions - Bringing Candidates Good NCM-MCI-6.10 Free Dumps 🌂 Download 「 NCM-MCI-6.10 」 for free by simply searching on ➥ [url]www.pdfdumps.com 🡄 😩Exam NCM-MCI-6.10 Pass4sure[/url]
- NCM-MCI-6.10 Prepaway Dumps 🔌 NCM-MCI-6.10 Actual Braindumps 🚉 Latest NCM-MCI-6.10 Test Testking 🙊 Download ▛ NCM-MCI-6.10 ▟ for free by simply entering ▶ [url]www.pdfvce.com ◀ website ↘NCM-MCI-6.10 Valid Test Tutorial[/url]
- Useful NCM-MCI-6.10 Test Lab Questions, NCM-MCI-6.10 Free Dumps 🎢 Open website ➠ [url]www.easy4engine.com 🠰 and search for ⇛ NCM-MCI-6.10 ⇚ for free download 🕟Exam NCM-MCI-6.10 Actual Tests[/url]
- Convenient and Accessible Nutanix NCM-MCI-6.10 Exam Questions in PDF Format 🗜 Download 《 NCM-MCI-6.10 》 for free by simply searching on ⇛ [url]www.pdfvce.com ⇚ 🍁Exam NCM-MCI-6.10 Pass4sure[/url]
- NCM-MCI-6.10 Prepaway Dumps 🔌 NCM-MCI-6.10 Reliable Test Review 📲 New NCM-MCI-6.10 Test Vce 🥨 Download ( NCM-MCI-6.10 ) for free by simply entering [ [url]www.dumpsquestion.com ] website 🚄NCM-MCI-6.10 Reliable Test Review[/url]
- Prominent Features of Pdfvce Nutanix NCM-MCI-6.10 Practice Questions 🌹 Search for 《 NCM-MCI-6.10 》 and easily obtain a free download on ⇛ [url]www.pdfvce.com ⇚ 🏳Online NCM-MCI-6.10 Training Materials[/url]
- NCM-MCI-6.10 Test Prep is Effective to Help You Get Nutanix Certificate - [url]www.examcollectionpass.com 🍀 Go to website ➡ www.examcollectionpass.com ️⬅️ open and search for ➡ NCM-MCI-6.10 ️⬅️ to download for free 🪕NCM-MCI-6.10 Latest Test Experience[/url]
- NCM-MCI-6.10 Braindumps Torrent 📞 Reliable NCM-MCI-6.10 Practice Questions ❤️ NCM-MCI-6.10 New Real Test 🕓 Search for “ NCM-MCI-6.10 ” and easily obtain a free download on ➠ [url]www.pdfvce.com 🠰 🍄NCM-MCI-6.10 Reliable Exam Online[/url]
- Online NCM-MCI-6.10 Training Materials 🚇 NCM-MCI-6.10 Vce Test Simulator ⬜ NCM-MCI-6.10 Valid Test Tutorial 🦆 Simply search for ⇛ NCM-MCI-6.10 ⇚ for free download on ( [url]www.testkingpass.com ) 🚟NCM-MCI-6.10 Braindumps Torrent[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, gifyu.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
