完全覆蓋的新版CDT題庫&保證Construction Specifications Institute CDT考試成功 -專業的CDT權威考題
Posted at 1/26/2026 07:06:48
P.S. Testpdf在Google Drive上分享了免費的2026 Construction Specifications Institute CDT考試題庫:https://drive.google.com/open?id=1GhHZ20qaGmAHizTZLQiDLscp_t2pxN4d
有人問,成功在哪里?我告訴你,成功就在Testpdf。選擇Testpdf就是選擇成功。Testpdf Construction Specifications Institute的CDT考試培訓資料是幫助所有IT認證的考生通過認證的,它針對Construction Specifications Institute的CDT考試認證的,經過眾多考生反映,Testpdf Construction Specifications Institute的CDT考試培訓資料在考生中得到了很大的反響,建立了很好的口碑,說明選擇Testpdf Construction Specifications Institute的CDT考試培訓資料就是選擇成功。
目前Construction Specifications Institute的CDT認證考試真的是一門人氣很高的考試。還沒有取得這個考試的認證資格的你,是不是也想參加考試呢?確實,這是一門很難的考試。但是這並不代表不能獲得高分輕鬆通過考試。那麼,還不知道通過這個考試的捷徑在哪里的你,是不是想知道通過考試的技巧呢?現在我來告訴你,就是利用Testpdf的CDT考古題。
CDT權威考題 - CDT學習資料通過Construction Specifications Institute CDT認證考試肯定會給你帶來很好的工作前景,因為Construction Specifications Institute CDT認證考試是一個檢驗IT知識的測試,而通過了Construction Specifications Institute CDT認證考試,證明你的IT專業知識很強,有很強的能力,可以勝任一份很好的工作。
最新的 CDT Certification CDT 免費考試真題 (Q70-Q75):問題 #70
During design, in a design-build delivery method, what is the design-builder responsible for delivering to the owner?
- A. Record documents
- B. Submittals
- C. Construction documents
- D. Geotechnical reports
答案:C
問題 #71
Which of the following participants is involved in the Integrated Project Delivery (IPD) method?
- A. Commissioning agent
- B. Authority having jurisdiction
- C. Inspector
- D. Contractor
答案:D
問題 #72
Which party is usually required to maintain record drawings during the project according to the Project Delivery Practice Guide?
- A. Architect
- C. Contractor
- D. Owner
答案:C
解題說明:
Comprehensive and Detailed Explanation From Exact Extract (CSI-based)
According to CSI's Project Delivery Practice Guide and CDT body of knowledge, the Contractor is typically required-by the conditions of the Contract-to maintain record drawings during construction.
These are sometimes called "as-built" or "marked-up" drawings.
CSI explains that:
* The Contractor must keep on site a current set of drawings and, as the work progresses, mark changes, deviations, and concealed conditions that differ from the original contract drawings.
* This responsibility is usually stated in the General Conditions and/or Division 01, and is part of the contractor's obligation to provide Project Record Documents at closeout.
* At the end of the project, these contractor-maintained record drawings and related record information are typically delivered to the Architect/Engineer and then to the Owner as part of closeout, but the party maintaining them during the project itself is the Contractor.
The Architect uses the contractor's record information to prepare formal record documents only if required by the contract, but the day-to-day updating and maintenance during construction is assigned to the Contractor in standard CSI-aligned practice.
Relevant CSI concepts (paraphrased):
* CSI Project Delivery Practice Guide - sections on "Construction Phase" and "Project Record Documents" explaining that the contractor keeps a set of marked-up record drawings during the work.
* CSI CDT Study Materials - topic on roles and responsibilities for record documents and closeout.
問題 #73
What is the basis of payment for a contract negotiated between an owner and a contractor for a fixed price?
- A. Cost-plus-fee
- B. Unit price
- C. Cost-plus-fee with guaranteed maximum price
- D. Stipulated sum
答案:D
解題說明:
CSI's treatment of methods of payment / contract pricing (as used in standard owner-contractor agreements and CDT content) includes several common bases of payment:
* Stipulated Sum (Lump Sum)
* The contractor agrees to provide the work for a single fixed price.
* The price does not change except through formal changes to the work (change orders).
* This is the classic "fixed-price" contract form.
* Unit Price
* The contractor is paid based on measured quantities of work completed multiplied by agreed unit rates.
* Final cost depends on actual quantities installed, not a single fixed total.
* Cost-Plus-Fee
* The owner reimburses actual cost of the work (labor, materials, equipment, etc.) plus a fee (fixed or percentage) as contractor's compensation.
* The final cost is not fixed; it varies with actual costs incurred.
* Cost-Plus-Fee with Guaranteed Maximum Price (GMP)
* A variation of cost-plus where the total reimbursable cost plus fee is capped at a guaranteed maximum.
* Still not the same as a straightforward fixed lump sum; the basis is cost reimbursement up to a cap.
The question specifically asks: "for a fixed price." In CSI and standard contract terminology, "fixed price"
= "stipulated sum" (or lump sum). That is:
* The owner and contractor negotiate a single dollar amount for the entire scope of work;
* The contractor's compensation is that stipulated sum, adjusted only by approved changes.
Why the other options are not correct:
* B. Unit price - The total cost is not fixed at the time of contracting; it depends on actual installed quantities.
* C. Cost-plus-fee - Costs are reimbursed; final price is open-ended and therefore not fixed.
* D. Cost-plus-fee with guaranteed maximum price - This sets a cap, but the actual final cost is not a single fixed price; it is "actual cost plus fee" up to the GMP.
Therefore, the correct basis of payment for a fixed-price contract is Stipulated sum (Option A), consistent with CSI's classification of contract types and standard owner-contractor agreements.
Key CSI References (titles only, no links):
* CSI Project Delivery Practice Guide - sections on "Basis of Payment" and contract pricing methods (stipulated sum, unit price, cost-plus, GMP).
* CSI CDT Body of Knowledge - Contract Types and Methods of Payment.
* Standard owner-contractor agreements discussed in CSI materials (e.g., stipulated sum as the fixed- price form).
問題 #74
During the schematic design phase, a contingency line item in the estimate would be included to cover which of the following?
- A. Unknown factors
- B. Allowances
- C. Alternates
- D. Unit prices
答案:A
解題說明:
In CSI-based project cost planning, contingency is defined as an amount added to an estimate or budget to cover uncertainties and unknowns that cannot yet be clearly defined at the current level of design development.
CSI's practice guides and CDT materials explain (paraphrased):
* In early design phases, such as schematic design, the design is only partially developed. Important elements are still undecided, and system configurations may change. Because of this, the cost estimate is inherently less precise.
* A contingency line item is therefore included to cover:
* Incomplete design information,
* Potential scope refinement,
* Normal estimating uncertainties, and
* Other unknown factors at that stage.
* As the project moves into design development and later into the construction documents phase, the design becomes more complete and the uncertainty decreases, so contingency percentages typically decrease.
By contrast, CSI differentiates contingency from other estimating tools:
* Allowances: Specific sums in the contract for known-but-not-fully-defined items (e.g., "flooring allowance of X per m"). These are identified items with placeholder values, not general unknowns.
* Unit prices: Agreed rates for measuring work (e.g., $/m of rock excavation) used when quantities are uncertain, but scope categories are known and clearly described in the documents.
* Alternates: Defined options requested by the owner (additive or deductive) for comparison and selection-again, specifically described items, not "unknowns." Because the question specifically references the schematic design phase and asks what the contingency line item covers, the CSI-aligned answer is "Unknown factors" - Option C.
* A. Allowances - These are separate, explicit line items in the estimate or specifications and are not what contingency is intended to cover.
* B. Unit prices - These deal with agreed rates for work whose quantities may vary, not with broad early- phase uncertainty.
* D. Alternates - Alternates are specifically described choices requested for comparison; they are priced individually, not absorbed into contingency.
Key CSI-aligned references (no links):
* CSI Project Delivery Practice Guide - sections on cost planning and contingencies by phase.
* CSI CDT Body of Knowledge - definitions and uses of contingency, allowances, unit prices, and alternates in estimating.
問題 #75
作為Construction Specifications Institute行業的一員,你有在為通過一些CDT認證考試而頭痛嗎。CDT認證你考試一般都是為了檢驗考生的相關專業知識和經驗的考試,不是很容易通過的。對於第一次參加Construction Specifications Institute認證考試的考生來說,選擇一個好的具有針對性的培訓方案是很有必要的。Testpdf能為很多參加CDT認證考試的考生提供具有針對性的培訓方案,包括考試之前的模擬測試,針對性教學課程,和與真實考試有95%相似性的練習題及答案。快將我們Testpdf加入你的購車吧。
CDT權威考題: https://www.testpdf.net/CDT.html
關於CDT認證考試的相關資料,有很多網站都可以提供,不要再猶豫了,如果想體驗一下考古題的內容,那麼快點擊Testpdf CDT權威考題的網站獲取吧,本站CDT認證題庫學習資料根據Construction Documents Technologist CDT考試的變化動態更新,我們會在第壹時間更新CDT題庫學習資料,確保Construction Documents Technologist CDT考試學習資料是最新的,助您通過Construction Documents Technologist CDT認證考試! Testpdf是到目前為止國內最早的微軟思科認證專業網站,從2000年建站至今已經10年的時間,壹直致力於報道微軟思科認證原創文章是我們壹貫保持的特點,Testpdf的CDT考古題是你準備CDT認證考試時最不能缺少的資料。
不多久,蘇玄就是追上了紀浮屠,難道是有人要插手冰虹城的事務,關於CDT認證考試的相關資料,有很多網站都可以提供,不要再猶豫了,如果想體驗一下考古題的內容,那麼快點擊Testpdf的網站獲取吧,本站CDT認證題庫學習資料根據Construction Documents Technologist CDT考試的變化動態更新,我們會在第壹時間更新CDT題庫學習資料,確保Construction Documents Technologist CDT考試學習資料是最新的,助您通過Construction Documents Technologist CDT認證考試! Testpdf是到目前為止國內最早的微軟思科認證專業網站,從2000年建站至今已經10年的時間,壹直致力於報道微軟思科認證原創文章是我們壹貫保持的特點。
Construction Specifications Institute 新版CDT題庫:Construction Documents Technologist幫助您壹次通過CDT考試Testpdf的CDT考古題是你準備CDT認證考試時最不能缺少的資料,4、Testpdf實行“產品無效,退還購買費用”承諾。
- 值得信賴的新版CDT題庫 |第一次嘗試易於學習和通過考試和精心準備的Construction Specifications Institute Construction Documents Technologist 🍺 複製網址➡ [url]www.newdumpspdf.com ️⬅️打開並搜索➤ CDT ⮘免費下載CDT熱門題庫[/url]
- 最有效的新版CDT題庫,免費下載CDT考試資料得到妳想要的Construction Specifications Institute證書 🚄 ➡ [url]www.newdumpspdf.com ️⬅️上的[ CDT ]免費下載只需搜尋CDT新版題庫上線[/url]
- CDT學習資料 💯 CDT真題 🌒 CDT資料 🛰 ▛ [url]www.newdumpspdf.com ▟是獲取➥ CDT 🡄免費下載的最佳網站免費下載CDT考題[/url]
- 可靠的新版CDT題庫和資格考試領先提供商和驗證的CDT權威考題 🍴 在➽ [url]www.newdumpspdf.com 🢪網站下載免費➠ CDT 🠰題庫收集CDT软件版[/url]
- CDT更新 👯 CDT題庫資訊 😙 CDT熱門題庫 🧫 在⇛ [url]www.testpdf.net ⇚網站上免費搜索[ CDT ]題庫CDT題庫下載[/url]
- 有用的Construction Specifications Institute 新版CDT題庫是行業領先材料&一流的CDT權威考題 💄 打開「 [url]www.newdumpspdf.com 」搜尋“ CDT ”以免費下載考試資料CDT資料[/url]
- CDT熱門題庫 🐡 CDT新版題庫上線 🐫 CDT考試備考經驗 🦩 打開網站⏩ [url]www.kaoguti.com ⏪搜索☀ CDT ️☀️免費下載CDT題庫分享[/url]
- [url=https://jonathancanady.com/?s=%e5%80%bc%e5%be%97%e4%bf%a1%e8%b3%b4%e7%9a%84%e6%96%b0%e7%89%88CDT%e9%a1%8c%e5%ba%ab%20|%e7%ac%ac%e4%b8%80%e6%ac%a1%e5%98%97%e8%a9%a6%e6%98%93%e6%96%bc%e5%ad%b8%e7%bf%92%e5%92%8c%e9%80%9a%e9%81%8e%e8%80%83%e8%a9%a6%e5%92%8c%e7%b2%be%e5%bf%83%e6%ba%96%e5%82%99%e7%9a%84Construction%20Specifications%20Institute%20Construction%20Documents%20Technologist%20%f0%9f%8e%be%20[%20www.newdumpspdf.com%20]%e6%9c%80%e6%96%b0%e2%96%9b%20CDT%20%e2%96%9f%e5%95%8f%e9%a1%8c%e9%9b%86%e5%90%88CDT%e8%80%83%e9%a1%8c%e5%a5%97%e8%a3%9d]值得信賴的新版CDT題庫 |第一次嘗試易於學習和通過考試和精心準備的Construction Specifications Institute Construction Documents Technologist 🎾 [ www.newdumpspdf.com ]最新▛ CDT ▟問題集合CDT考題套裝[/url]
- CDT題庫下載 🦇 CDT題庫資訊 💽 CDT考試重點 🔁 ▷ [url]www.newdumpspdf.com ◁上的免費下載⏩ CDT ⏪頁面立即打開CDT考試備考經驗[/url]
- 授權的新版CDT題庫和資格考試領導和有用的考試CDT權威考題 💰 複製網址“ [url]www.newdumpspdf.com ”打開並搜索✔ CDT ️✔️免費下載CDT考試備考經驗[/url]
- 最新的新版CDT題庫 |高通過率的考試材料|完美的CDT權威考題 👉 ☀ [url]www.newdumpspdf.com ️☀️網站搜索✔ CDT ️✔️並免費下載CDT考題資源[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, gifyu.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Testpdf最新的CDT PDF版考試題庫和CDT考試問題和答案免費分享:https://drive.google.com/open?id=1GhHZ20qaGmAHizTZLQiDLscp_t2pxN4d
