[General] Valid Mule-Dev-201 Cram Materials | Mule-Dev-201 Reliable Study Materials
110
General Valid Mule-Dev-201 Cram Materials | Mule-Dev-201 Reliable Study Materials
Posted at 1/26/2026 07:18:41      View139 | Replies0        Print      Only Author   [Copy Link] 1#
Our IT professionals have made their best efforts to offer you the latest Mule-Dev-201 study guide in a smart way for the certification exam preparation. With the help of our Mule-Dev-201 dumps collection, all level of candidates can grasp the key content of the real exam and solve the difficulty of Mule-Dev-201 Real Questions easily. The most important is that our test engine enables you practice Mule-Dev-201 exam pdf on the exact pattern of the actual exam.
The Salesforce Certified MuleSoft Developer (Mule-Dev-201) actual questions we sell also come with a free demo. Spend no time, otherwise, you will pass on these fantastic opportunities. Start preparing for the Salesforce Mule-Dev-201 exam by purchasing the most recent Salesforce Mule-Dev-201 Exam Dumps. PremiumVCEDump also guarantees that it will provide your money back if in any case, you are unable to pass the Mule-Dev-201 exam but the terms and conditions are there that you must have to follow.
Mule-Dev-201 Reliable Study Materials, Mule-Dev-201 Answers Real QuestionsThe contents of our Mule-Dev-201 study materials are all compiled by industry experts based on the examination outlines and industry development trends over the years. Mule-Dev-201 exam guide is not simply a patchwork of test questions, but has its own system and levels of hierarchy, which can make users improve effectively. Our Mule-Dev-201 Study Materials contain test papers prepared by examination specialists according to the characteristics and scope of different subjects. And if you study with our Mule-Dev-201 exam questions, you are bound to pass the Mule-Dev-201 exam.
Salesforce Certified MuleSoft Developer Sample Questions (Q78-Q83):NEW QUESTION # 78
Refer to the exhibits.
The Validation component in theTry scope throws an error.
What response message is returned to a client request to the main flow's HTTP Listener?
The Validation component in the Try scope throws an error. What response message is returned to a client request to the main flow's HTTP Listener?
  • A. Validation Error
  • B. Success - main flow
  • C. Error - main flow
  • D. Error - Try scope
Note that private flow has error scope defined as On Error Continue . So when error occurs in private flow , it is handled by this On Error Continue scopewhich sends success response back to main flow and does not throw back an error. So main continues normally and payload is set to Success - main flow.
Hence correct answer is Success - main flow
1) HTTP listener received request
2) The Flow Referencecalls the child flow
3) The Is Number validator creates an Error Object because the payload isn't an integer. Child Flow execution stops
#[error.description] = "payload is not a valid INTEGER value"
#[error.errorType] = VALIDATION:INVALID_NUMBER
4) The OnError Continue handles the errorThe payload is set to "Error - Sub Flow"
5) "Error - Sub Flow" is returned to the main flow as if the child flow was a success. The Set Payload is executed. The payload is reset to "Success - Finished Main Flow"
6) "Success- Main Flow" is returned to the requestor in the body of the HTTP request. HTTP Status Code:
200
As you can see, in the above example, because the error was caught by an On Error Continue scope in the child flow (RED in, GREEN out) when the Mule Message returns to the parent flow, the parent flow knows none-the-different that there was a failure because the on error continue returns a 200 success message. Note that because, to the mainFlow, the childFlow appeared to succeed, the processing of mainFlow resumed after the flow reference.
A picture containing timeline Description automatically generated
NEW QUESTION # 79
What should be changed to fix the 415 error?
  • A. set theresponse Content-Type header to application/json
  • B. set the request Content-Type header to text/plain
  • C. Set the request Content-Type header to application/] son
  • D. set the response Content-Type header to text/plain
The HTTP 415 Unsupported Media Type client error response code indicates that the server refuses to accept the request because the payload format is in an unsupported format. The format problem might be due to the request's indicated Content-Type or Content-Encoding , or as a result of inspecting the data directly. In this case as per RAML specification data is expected in application/json and in request Content-Type is set as "text
/plain" which is incorrect. Hence solution is set the request Content-Type header to application/json
https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/415
NEW QUESTION # 80
An API implementation has beendeployed to CloudHub and now needs to be governed. IT will not allocate additional vCore for a new Mule application to act as an API proxy.
What is the next step to preseive the current vCore usage, but still allow the Mule application to be managed by APIManager?
  • A. Deploy the same API implementation behind a VPC and configure the VPC to connect to API Manager
  • B. Modify the API implementation to use auto-discovery to register with API Manager
  • C. Upload the Mule application's JAR file to the API instance in API Manager
  • D. Register the same API implementation in Runtime Manager to connect to API Manager
Correct answer is Modify the API implementation to use auto-discovery to register with API Manager API Autodiscovery Configuring autodiscovery allows a deployed Mule runtime engine (Mule) application to connect with API Manager to download and manage policies and to generate analytics data. Additionally, with autodiscovery, you can configure your Mule applications to act as their own API proxy.
When autodiscovery is correctly configured in your Mule application, you can say that your application's API is tracked by (green dot) or paired to API Manager. You can associate an API in a Mule setup with only one autodiscovery instance at a given time.
MuleSoft Doc Ref : https://docs.mulesoft.com/api-ma ... scovery-new-concept
NEW QUESTION # 81
An API specification is designed using RAML. What is the next step to create a REST Connector from this APIspecification?
  • A. Publish the API specification to Any point Exchange
  • B. Add the specification to a Mule project's src/main/resources/api folder
  • C. Download the API specification and build the interface using APIkit
  • D. Implement the API specification using flow designer in Design Center
API Exchange creates REST conenctor automtaically once API is published. Hence correct answer is Publish the API specification to Any point Exchange
NEW QUESTION # 82
What is the trait name you would usefor specifying client credentials in RAML?
  • A. client-id
  • B. client-id-required
  • C. headers
  • D. cannot be specified in RAML
client-id-required enforces clients to add client_id and client_secret.
Please refer to below steps.
* Add a section called traits: at the root level to define query parameters:
* traits:
* - client-id-required:
* queryParameters:
* client_id:
* type: string
* client_secret:
* type: string
* 2) Reference the trait in each of the methods to specify that each of the methods require these queryparameters. After each method in the RAML file, add is: [client-id-required]. For example:
* /users:
* get:
* is: [client-id-required]
* description: Gets a list of JSONPlaceholder users.
NEW QUESTION # 83
In order to provide a convenient study method for all people, our company has designed the online engine of the Mule-Dev-201 study practice dump. The online engine is very convenient and suitable for all people to study, and you do not need to download and install any APP. We believe that the Mule-Dev-201 exam questions from our company will help all customers save a lot of installation troubles. You just need to have a browser on your device you can use our study materials. We can promise that the Mule-Dev-201 Prep Guide from our company will help you prepare for your exam well. If you decide to buy and use the study materials from our company, it means that you are not far from success.
Mule-Dev-201 Reliable Study Materials: https://www.premiumvcedump.com/Salesforce/valid-Mule-Dev-201-premium-vce-exam-dumps.html
According to our survey, our Mule-Dev-201 quiz guide has the highest passing rate, And we offer considerable services on the Mule-Dev-201 exam questions for 24/7, Salesforce Valid Mule-Dev-201 Cram Materials Although more and more people sign up to attend this examination of, the official did not reduce its difficulty and it is still difficult to pass the exam, As there are all keypoints in the Mule-Dev-201 practice engine, it is easy to master and it also helps avoid a waste of time for selecting main content.
What's more, Mule-Dev-201 latest study material is the best valid and latest, which can ensure 100% pass, Search Folders Create Unique Views, According to our survey, our Mule-Dev-201 Quiz guide has the highest passing rate.
100% Pass Mule-Dev-201 - Pass-Sure Valid Salesforce Certified MuleSoft Developer Cram MaterialsAnd we offer considerable services on the Mule-Dev-201 exam questions for 24/7, Although more and more people sign up to attend this examination of, the official did not reduce its difficulty and it is still difficult to pass the exam.
As there are all keypoints in the Mule-Dev-201 practice engine, it is easy to master and it also helps avoid a waste of time for selecting main content, You need a useful plan to prepare the Salesforce Mule-Dev-201 exam of this distinguished certification.
