新版Oracle 1z0-1066-25題庫 & 1z0-1066-25考試證照綜述
Posted at 1/26/2026 12:29:19
P.S. KaoGuTi在Google Drive上分享了免費的2026 Oracle 1z0-1066-25考試題庫:https://drive.google.com/open?id=1tyy0cCsWAq157ExFQyGyxVPWYPjujIsf
擁有Oracle 1z0-1066-25認證考試證書可以幫助在IT領域找工作的人獲得更好的就業機會,也將會為成功的IT事業做好鋪墊。
彰顯一個人在某一領域是否成功往往體現在他所獲得的資格證書上,在IT行業也不外如是。所以現在很多人都選擇參加1z0-1066-25資格認證考試來證明自己的實力。但是要想通過1z0-1066-25資格認證卻不是一件簡單的事。不過只要你找對了捷徑,通過考試也就變得容易許多了。這就不得不推薦KaoGuTi的考試考古題了,它可以讓你少走許多彎路,節省時間幫助你考試合格。
新版1z0-1066-25題庫:Oracle Planning and Collaboration Cloud 2025 Implementation Professional確定通過考試,Oracle 1z0-1066-25考試證照綜述KaoGuTi是一個能給很多人提供便利,滿足很多人的需求,成就很多人夢想的網站。如果你正在為通過一些Oracle認證考試而憂心重重,選擇KaoGuTi的説明吧。KaoGuTi可以使你安心,因為我們擁有好多關於1z0-1066-25認證考試相關的培訓資料,品質很高,內容範圍覆蓋範圍很廣並且還很有針對性,會給你帶來很大的有幫助。選擇KaoGuTi你是不會後悔的,它能幫你成就你的職業夢想。
最新的 Oracle Cloud 1z0-1066-25 免費考試真題 (Q84-Q89):問題 #84
As the planner, you have made some changes to a few of the specifications for items in your simulation sets.
You would like to run one of your existing Demand and Supply Plans that contains this simulation set to see how these changes impact the plan.
Which option shows the steps you must complete in order to ensure that when you run your existing Demand and Supply plan, it contains your changes to the simulation set?
- A. When the Demand and Supply Plan is run, verify that 'Recalculate Safety Stock' is selected in the Details section.
- B. You are only able to update one item attribute at a time. Since you have changed multiple attributes, you will be unable to update and run this plan.
- C. When the Demand and Supply Plan is run, verify that 'Refresh with current data' is selected in the Details section.
- D. No additional steps are necessary. Any plans that contain your simulation set will automatically be updated with the changes.
答案:C
問題 #85
You have run a plan for your organization and there were sales orders that have been set up for drop shipment that you cannot see in the plan.
Which two options explain why the sales orders cannot be seen in the plan? (Choose two.)
- A. Include drop ship demands and supplies flag has not been checked on your plan options.
- B. Drop Ship Item Validation Org has not been set up.
- C. Supplier not configured in Manage Planning Source Systems
- D. Drop Ship Demand Class has not be set up.
- E. Planning Profile 'Enable Planning for Drop Shipments' has not been set to 'Yes'.
答案:C,D
問題 #86
Which three steps are required so that a supply plan can use different service-level percentages for different groupings of items when calculating safety stock?
- A. Execute segmentation.
- B. Create segment groups.
- C. Assign the percentage on the Safety Stock tab of plan options.
- D. Create a supply planning policy assignment set.
- E. Create a safety stock policy assignment set.
答案:A,B,D
解題說明:
To implement varied service levels for different item groups, first create a supply planning policy assignment set, which defines rules for assigning items to specific safety stock policies. Next, create segment groups that align items with these policies based on their characteristics. Finally, execute segmentation, which categorizes items according to the specified segments. By following these steps, you can apply different service levels to distinct item groups during safety stock calculations, as outlined in Oracle's supply planning documentation
問題 #87
Your client manufactures consumer electronics and has all facilities live on Oracle Cloud. Their latest product has a very complicated manufacturing process and therefore can only be made at one facility (Organization ABC). However, it is ordered all over the world.
How should the Sourcing Rule be set up to accomplish this?
- A. A local sourcing rule for 100% make at ABC; a global sourcing rule for 100% transfer from ABC
- B. A global sourcing rule for 100% make at ABC; a local sourcing rule for 100% transfer from ABC
- C. A global sourcing rule for 50% make at ABC and 50% buy from ABC
- D. A local sourcing rule for 100% make at ABC; a global sourcing rule for 100% buy from ABC
- E. A local sourcing rule for 100% buy from ABC; a global sourcing rule for 100% transfer from ABC
答案:E
問題 #88
You just ran a Data Collection and want to confirm that certain data was successfully collected. Identify three collected data sets that can be viewed on the Maintain Supply Network Model Page. (Choose three.)
- A. Supplier Site and Service Level
C Calendar and Master Organization - B. Customer Location and Carriers
- C. Safety Stock and Subinventories
- D. Customers and Customer Sites
答案:A,B,D
問題 #89
KaoGuTi 的 1z0-1066-25 考古題包括了PDF電子檔和軟體考題形式,全新的收錄了Oracle 認證考試的所有試題,並根據真實的考題變化而不斷變化,參考考試指南編訂,而且適合全球考生適用。該 1z0-1066-25 考古題是考試原題的完美組合,覆蓋率95%以上,答案由多位專業資深講師原版破解得出,正確率100%。你還可以點擊我們網站下載 1z0-1066-25 考古題的demo,你會明白這才是你想要的。
1z0-1066-25考試證照綜述: https://www.kaoguti.com/1z0-1066-25_exam-pdf.html
Oracle 新版1z0-1066-25題庫 如果你想輕鬆通過考試,那麼快來試試吧,因為他們提供的關於Oracle 1z0-1066-25 認證考試資料都比較寬泛,不具有針對性,所以吸引不了考生的注意力,要想一次性通過Oracle 1z0-1066-25 認證考試您必須得有一個好的準備和一個完整的知識結構,Oracle 新版1z0-1066-25題庫 為什麼可以這麼肯定呢,客戶至上是KaoGuTi 1z0-1066-25考試證照綜述認證考試參考資料網的壹貫宗旨,在練習1z0-1066-25問題集的同時做好總結,Oracle 新版1z0-1066-25題庫 在你使用之後,相信你會很滿意我們的產品的,成千上萬的IT考生通過使用我們的產品成功通過考試,Oracle 1z0-1066-25考古題質量被廣大考試測試其是高品質的。
不僅如此還有壹層灰蒙蒙的真氣布置在體表,讓人看不出他的樣貌,我不信這是他的真實成績,如果你想輕鬆通過考試,那麼快來試試吧,因為他們提供的關於Oracle 1z0-1066-25 認證考試資料都比較寬泛,不具有針對性,所以吸引不了考生的注意力。
有效的新版1z0-1066-25題庫,最新的考試題庫幫助妳快速通過1z0-1066-25考試要想一次性通過Oracle 1z0-1066-25 認證考試您必須得有一個好的準備和一個完整的知識結構,為什麼可以這麼肯定呢,客戶至上是KaoGuTi認證考試參考資料網的壹貫宗旨。
- 高效的新版1z0-1066-25題庫和認證考試的領導者材料和權威的1z0-1066-25考試證照綜述 ⏹ 開啟⏩ [url]www.kaoguti.com ⏪輸入➡ 1z0-1066-25 ️⬅️並獲取免費下載1z0-1066-25软件版[/url]
- 1z0-1066-25權威考題 🏤 最新1z0-1066-25考題 ⛺ 1z0-1066-25測試 🌞 ⮆ [url]www.newdumpspdf.com ⮄網站搜索▶ 1z0-1066-25 ◀並免費下載1z0-1066-25考古题推薦[/url]
- 高效的新版1z0-1066-25題庫和認證考試的領導者材料和權威的1z0-1066-25考試證照綜述 🎰 到“ [url]www.newdumpspdf.com ”搜尋{ 1z0-1066-25 }以獲取免費下載考試資料1z0-1066-25考題[/url]
- 1z0-1066-25套裝 🚚 1z0-1066-25證照考試 💐 1z0-1066-25題庫 ⛷ 開啟“ [url]www.newdumpspdf.com ”輸入⇛ 1z0-1066-25 ⇚並獲取免費下載1z0-1066-25熱門題庫[/url]
- 最真實的1z0-1066-25考古題 🎶 免費下載( 1z0-1066-25 )只需進入⮆ [url]www.newdumpspdf.com ⮄網站1z0-1066-25考題[/url]
- 1z0-1066-25考試重點 ⬜ 1z0-1066-25套裝 💨 1z0-1066-25資料 🏛 在【 [url]www.newdumpspdf.com 】網站上免費搜索▷ 1z0-1066-25 ◁題庫1z0-1066-25題庫[/url]
- 新版1z0-1066-25考古題 🎺 1z0-1066-25熱門題庫 🎧 1z0-1066-25測試題庫 🤥 ⮆ [url]www.vcesoft.com ⮄上的➥ 1z0-1066-25 🡄免費下載只需搜尋1z0-1066-25软件版[/url]
- Oracle 新版1z0-1066-25題庫:Oracle Planning and Collaboration Cloud 2025 Implementation Professional確定通過考試 ⏳ 到⇛ [url]www.newdumpspdf.com ⇚搜尋▷ 1z0-1066-25 ◁以獲取免費下載考試資料1z0-1066-25題庫[/url]
- 1z0-1066-25套裝 ✔️ 1z0-1066-25考證 😑 1z0-1066-25考試重點 ⏯ 立即打開▷ [url]www.vcesoft.com ◁並搜索▛ 1z0-1066-25 ▟以獲取免費下載1z0-1066-25資料[/url]
- Oracle 新版1z0-1066-25題庫:Oracle Planning and Collaboration Cloud 2025 Implementation Professional確定通過考試 🐔 立即在➽ [url]www.newdumpspdf.com 🢪上搜尋⮆ 1z0-1066-25 ⮄並免費下載1z0-1066-25測試[/url]
- 1z0-1066-25考題 🌙 新版1z0-1066-25考古題 🍶 1z0-1066-25软件版 🎬 ⏩ tw.fast2test.com ⏪是獲取《 1z0-1066-25 》免費下載的最佳網站1z0-1066-25測試
- www.stes.tyc.edu.tw, wjhsd.instructure.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
從Google Drive中免費下載最新的KaoGuTi 1z0-1066-25 PDF版考試題庫:https://drive.google.com/open?id=1tyy0cCsWAq157ExFQyGyxVPWYPjujIsf
