Exam 1Z0-1079-24 Price & Vce 1Z0-1079-24 Test Simulator
89
Posted at 1/26/2026 13:12:55      View128 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest Prep4sureExam 1Z0-1079-24 PDF Dumps and 1Z0-1079-24 Exam Engine Free Share: https://drive.google.com/open?id=1szHOO0-esKHEwzNiufZpAuiPozNPBJ5s
A minor mistake may result you to lose chance even losing out on your 1Z0-1079-24 Exam. So we hold responsible tents when compiling the 1Z0-1079-24 learning guide. The principles of our 1Z0-1079-24practice materials can be expressed in words like clarity, correction and completeness. Experts expressed their meaning with clarity by knowledgeable and understandable words which cannot be misunderstood.
With our wide range of Oracle 1Z0-1079-24 exam questions types and difficulty levels, you can tailor your Oracle 1Z0-1079-24 exam practice to your needs. Your performance and exam skills will be improved with our Oracle 1Z0-1079-24 Practice Test software. The software provides you with a range of Oracle 1Z0-1079-24 exam dumps, all of which are based on past Oracle 1Z0-1079-24 certifications.
2026 1Z0-1079-24: Accurate Exam Oracle Fusion Transportation and Global Trade Management Cloud 2024 Implementation Professional PriceThe 1Z0-1079-24 exam questions are designed and verified by experienced and qualified Oracle 1Z0-1079-24 exam trainers. So you rest assured that with 1Z0-1079-24 exam dumps you can streamline your 1Z0-1079-24 exam preparation process and get confidence to pass 1Z0-1079-24 exam in first attempt. The countless candidates have already passed their 1Z0-1079-24 Certification Exam and they all used the real, valid, and updated Prep4sureExam 1Z0-1079-24 exam questions. So, why not, take a decision right now and ace your 1Z0-1079-24 exam preparation with top-notch 1Z0-1079-24 exam questions?
Oracle Fusion Transportation and Global Trade Management Cloud 2024 Implementation Professional Sample Questions (Q35-Q40):NEW QUESTION # 35
Which two statements regarding OTM Agents at installation are true? (Choose two.)
  • A. By default, some agents are active, while others are inactive. The Administrator or other authorized persons must review the agents and activate or deactivate appropriately
  • B. All agents are active. The Administrator or other authorized persons must review and activate those they want to run in their environment
  • C. OTM will install agents into domains such as PUBLIC and SERVPROV
  • D. OTM will install agents into the designated "company" domain, but not into domains such as PUBLIC and SERVPROV
  • E. All agents are inactive. The Administrator or other authorized persons must review and activate those they want to run in their environment.
NEW QUESTION # 36
Which three statements are true when configuring allocation rules for OTM Freight Payment? (Choose three.)
  • A. For a service provider, one can assign one allocation rule based on the planned cost and another based on the actual cost
  • B. One cannot use the same rule in more than one allocation rule profile
  • C. The allocation rules in the profile can be sequenced in the allocation rule profile
  • D. OTM uses the first allocation rule that applies
  • E. Allocation rules need to be set up before the allocation rule profiles
Answer: A,C,D
NEW QUESTION # 37
When creating Ground Schedules, you must select the Trip type. Which two Trip types will you use? (Choose two.)
  • A. Static
  • B. Multi-Modal
  • C. OTM allows the user to configure custom Trip types based on need
  • D. Dynamic
  • E. Voyage
Reference: https://docs.oracle.com/en/cloud ... /21a/otmol/schedule manager/ground schedule.htm
NEW QUESTION # 38
What does OTM automatically do when a new 3w/ice Provider is created?
  • A. OTM assigns the default Calendar defined in the Parameter Set
  • B. OTM creates a corresponding LOCATION, with the location Role of "CARRIER"
  • C. OTM associates the Service Provider calendar with the calendar of the CORPORATION ID identified during setup
  • D. OTM sends an email or fax to the Service Provider contact, depending on the contact's preferred contact method
NEW QUESTION # 39
In which two case will you use the "Show Routing Options" shipment planning method? (Choose two.)
  • A. when you want to specify the carrier that you want to receive the shipment tender
  • B. when you want to override the delivery constraints on the Order Base
  • C. when you want to view OTM's recommendation without actually planning the shipment
  • D. when you want to auto-tender the shipment after planning is complete
  • E. when you want to specify the itinerary that you want to use for the shipment
NEW QUESTION # 40
The Prep4sureExam is committed to presenting the excellent viable observe cloth to prevail within the Oracle 1Z0-1079-24 examination. With actual PDF questions, customizable exercise checks, and 24/7 guide, customers can be assured that they're getting the fine possible prep cloth. The 1Z0-1079-24 is a fantastic choice for absolutely everyone looking to increase their profession with the 1Z0-1079-24 certification. Purchase Now.
Vce 1Z0-1079-24 Test Simulator: https://www.prep4sureexam.com/1Z0-1079-24-dumps-torrent.html
You can spend less time and money for attending 1Z0-1079-24 test certification, Oracle Exam 1Z0-1079-24 Price Are you interested in IT industry, This format is also embedded with multiple Oracle 1Z0-1079-24 Practice Exam and all specs of the desktop software, On the other hand, as we all know, the most expensive product is not necessarily the best one, and vice versa, what's more, as the old saying goes:" Practice is the sole criterion for testing truth." We have enough confidence for our 1Z0-1079-24 actual lab questions so that we would like to let as many people as possible , no matter they are rich or poor to have a try and then prove how useful our 1Z0-1079-24 exam preparation are, that is why we always keep a favorable price for our best products, And we offer good sercives on our 1Z0-1079-24 learning guide to make sure that every detail is perfect.
These are all part of the grammar of photography, Vce 1Z0-1079-24 Test Simulator just as there is a grammar associated with words sentence structure, capital letters, paragraphs) that make it possible to read 1Z0-1079-24 a story, so there is a grammar of photography that allows us to read a photograph.
Download Prep4sureExam Oracle 1Z0-1079-24 Exam Dumps Today and Start this JourneyWorking with Dates, You can spend less time and money for attending 1Z0-1079-24 test certification, Are you interested in IT industry, This format is also embedded with multiple Oracle 1Z0-1079-24 Practice Exam and all specs of the desktop software.
On the other hand, as we all know, the most expensive product is not necessarily the best one, and vice versa, what's more, as the old saying goes:" Practice is the sole criterion for testing truth." We have enough confidence for our 1Z0-1079-24 actual lab questions so that we would like to let as many people as possible , no matter they are rich or poor to have a try and then prove how useful our 1Z0-1079-24 exam preparation are, that is why we always keep a favorable price for our best products.
DOWNLOAD the newest Prep4sureExam 1Z0-1079-24 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1szHOO0-esKHEwzNiufZpAuiPozNPBJ5s
