Quiz 2026 Salesforce Latest PDI: Platform Developer I (PDI) Sample Questions Pdf
Posted at 1/26/2026 18:17:16
View135
Replies1
BONUS!!! Download part of BraindumpQuiz PDI dumps for free: https://drive.google.com/open?id=17ju8X6coxEwjEsU6PAMi0C4jhZ6BeyXD
The only aim of our company is to help each customer pass their exam as well as getting the important certification in a short time. If you want to pass your exam and get the PDI certification which is crucial for you successfully, I highly recommend that you should choose the PDI Study Materials from our company so that you can get a good understanding of the exam that you are going to prepare for.
In order to prepare for the Salesforce PDI certification exam, developers must have a strong foundation in programming concepts and experience working with the Salesforce platform. They can also take advantage of various training resources, such as online courses, study guides, and practice exams, to help them prepare for the exam and gain the knowledge and skills needed to pass.
Salesforce PDI (Platform Developer I) Certification Exam is designed for developers who are responsible for designing and developing custom applications on the Salesforce platform. Passing PDI Exam demonstrates that the developer has the skills and knowledge necessary to develop custom applications and solutions on the Salesforce platform.
Salesforce PDI Exam is an important certification for developers who work with the Salesforce platform. Platform Developer I (PDI) certification demonstrates to employers and clients that the developer has the knowledge and skills to develop custom solutions using the platform. In addition, the certification can lead to increased job opportunities and higher salaries for developers.
Download PDI Demo & PDI Exam VceBraindumpQuiz will provide you with actual Platform Developer I (PDI) (PDI) exam questions in pdf to help you crack the Salesforce PDI exam. So, it will be a great benefit for you. If you want to dedicate your free time to preparing for the Platform Developer I (PDI) (PDI) exam, you can check with the soft copy of pdf questions on your smart devices and study when you get time. On the other hand, if you want a hard copy, you can print Platform Developer I (PDI) (PDI) exam questions.
Salesforce Platform Developer I (PDI) Sample Questions (Q73-Q78):NEW QUESTION # 73
A developer identifies the following triggers on the Expense _c object:
The triggers process before delete, before insert, and before update events respectively.
Which two techniques should the developer implement to ensure trigger best practices are followed?
Choose 2 answers
- A. Maintain all three triggers on the Expense __c object, but move the Apex logic out of the trigger definition.
- B. Create helper classes to execute the appropriate logic when a record is saved.
- C. Unify the before insert and before update triggers and use Flow for the delete action.
- D. Unity all three triggers In a single trigger on the Expense__c object that Includes all events.
* A. Unify all three triggers in a single trigger on the Expense__c object that includes all events:
* Salesforce best practices recommend having only one trigger per object to avoid redundancy and conflicts.
* By combining all the events (before delete, before insert, and before update) into a single trigger, the developer can manage the logic in an organized and maintainable manner.
* This also simplifies debugging and ensures that the trigger logic executes in a predictable order.
* C. Create helper classes to execute the appropriate logic when a record is saved:
* Using helper classes allows for a clean separation of concerns. The trigger becomes a dispatcher that delegates logic to dedicated classes.
* For example, you can create methods like applyDefaultsToExpense(), validateExpenseUpdate(), and deleteExpense() in a helper class and invoke them from the trigger.
* This improves reusability, readability, and testability of the code.
Why not the other options?
* B. Unify the before insert and before update triggers and use Flow for the delete action:
* While Flow is a powerful tool, it is not ideal for deleting records or replacing Apex trigger functionality, especially when triggers already exist for other events.
* D. Maintain all three triggers on the Expense__c object but move the Apex logic out of the trigger definition:
* Maintaining multiple triggers on the same object can lead to conflicts and execution order issues, even if the logic is moved to helper classes.
Trigger Best Practices
Trigger Design Patterns
NEW QUESTION # 74
A developer wants to improve runtime performance of Apex calls by caching results on the client.
What is the most efficient way to implement this and follow best practices?
- A. Set a cookie in the browser for use upon return to the page.
- B. Decorate the server-side method with @AuraEnsbled(storable=true).
- C. Call the setStorable () method on the action in the JavaScript client-side code.
- D. Decorate the server-side method with @AuraZnabled(cacheable=true).
To improve runtime performance by caching Apex call results on the client, the developer should decorate the server-side method with @AuraEnabled(cacheable=true).
@AuraEnabled(cacheable=true) Annotation:
When applied to an Apex method, it enables the method's results to be cached on the client, improving performance for subsequent calls.
This is especially effective in Lightning Web Components (LWC) and can also be used in Aura components.
"To cache method results, annotate the method with @AuraEnabled(cacheable=true). Methods annotated with cacheable=true are called cached methods."
- Lightning Web Components Developer Guide: Call Apex Methods
Why Not Other Options:
A . Call the setStorable() method on the action in the JavaScript client-side code: This approach is used in Aura components but is less efficient and not considered best practice compared to using cacheable=true.
"For improved performance, use @AuraEnabled(cacheable=true) instead of action.setStorable()."
- Aura Components Developer Guide: Calling Server-Side Actions
B . Set a cookie in the browser for use upon return to the page: Managing cookies for caching Apex results is not efficient and can lead to security and scalability issues.
C . Decorate the server-side method with @AuraEnabled(storable=true): There is no storable=true parameter for @AuraEnabled. The correct parameter is cacheable=true.
Best Practices:
Use @AuraEnabled(cacheable=true): This is the recommended way to cache Apex method results in Lightning components.
"Apex methods annotated with @AuraEnabled(cacheable=true) are cached on the client and shared across components."
- Lightning Web Components Developer Guide: Apex Methods Cache
Conclusion: By decorating the Apex method with @AuraEnabled(cacheable=true), the developer enables client-side caching of the method's results, improving runtime performance in an efficient and recommended way.
NEW QUESTION # 75
An Opportunity needs to have an amount rolled up from a custom object that is not in a master-detail relationship.
How can this be achieved?
- A. Write a trigger on the Opportunity object and use tree sorting to sum the amount for all related child objects under the Opportunity.
- B. Use the Streaming API to create real-time roll-up summaries.
- C. Write a trigger on the child object and use an aggregate function to sum the amount for all related child objects under the Opportunity.
- D. Use the Metadata API to create real-time roll-up summaries.
Why a Trigger on the Child Object?
Since the relationship is not master-detail, a trigger on the child object can perform aggregate calculations and update the parent Opportunity.
Why Not Other Options?
A: Tree sorting is unnecessary and unrelated to roll-up summaries.
B and D: Neither Streaming API nor Metadata API is suitable for real-time roll-up calculations.
References:Custom Roll-Up Summaries:https://developer.salesforce.com/docs/atlas.en-us.apexcode.meta
/apexcode/apex_triggers_best_practices.htm
NEW QUESTION # 76
A development team wants to use a deployment script to automatically deploy to a sandbox during their development cycles.
Which two tools can they use to run a script that deploys to a sandbox?
Choose 2 answers
- A. SFDX CLI
- B. Developer Console
- C. Ant Migration Tool
- D. Change Sets
NEW QUESTION # 77
If apex code executes inside the execute() method of an Apex class when implementing the Batchable interface, which statement are true regarding governor limits? Choose 2 answers
- A. The Apex governor limits are relaxed while calling the costructor of the Apex class.
- B. The Apex governor limits might be higher due to the asynchronous nature of the transaction. (Missed)
- C. The Apex governor limits cannot be exceeded due to the asynchronous nature of the transaction,
- D. The apex governor limits are reset for each iteration of the execute() mrthod. (Missed)
NEW QUESTION # 78
Our PDI study materials take the clients needs to pass the test smoothly into full consideration. The questions and answers boost high hit rate and the odds that they may appear in the real exam are high. Our PDI study materials have included all the information which the real exam is about and refer to the test papers in the past years. Our PDI study materials analysis the popular trend among the industry and the possible answers and questions which may appear in the real exam fully. Our PDI Study Materials stimulate the real exams environment and pace to help the learners to get a well preparation for the real exam in advance. Our PDI study materials wont deviate from the pathway of the real exam and provide wrong and worthless study materials to the clients.
Download PDI Demo: https://www.braindumpquiz.com/PDI-exam-material.html
- Valid PDI Test Papers 🌠 PDI Lead2pass 🥖 PDI Test Dumps Pdf 🥽 The page for free download of ➽ PDI 🢪 on ⏩ [url]www.vceengine.com ⏪ will open immediately 🚢Updated PDI Testkings[/url]
- PDI Test Question ⛽ Updated PDI Testkings 💲 Free PDI Exam Dumps 🥌 Search for ▶ PDI ◀ and easily obtain a free download on ▷ [url]www.pdfvce.com ◁ 🐢
DI Test Dumps Pdf[/url] - Quiz 2026 Authoritative PDI: Platform Developer I (PDI) Sample Questions Pdf 🔫 Immediately open [ [url]www.pass4test.com ] and search for ⏩ PDI ⏪ to obtain a free download 📊
DI Latest Study Guide[/url] - UPDATED Salesforce PDI PDF QUESTIONS [2026]-QUICK TIPS TO PASS 👣 Go to website ⏩ [url]www.pdfvce.com ⏪ open and search for ➤ PDI ⮘ to download for free 🎮Free PDI Exam Dumps[/url]
- Pass Guaranteed Quiz 2026 Salesforce Valid PDI Sample Questions Pdf 🐰 Open ✔ [url]www.practicevce.com ️✔️ enter PDI and obtain a free download ✳Top PDI Exam Dumps[/url]
- Improve Your Chances of Success with Salesforce's Realistic PDI Exam Questions and Accurate Answers 🐢 Search for ☀ PDI ️☀️ and obtain a free download on [url]www.pdfvce.com 📀Valid Test PDI Tips[/url]
- Valid Test PDI Tips 🔪 Review PDI Guide ⏰ Updated PDI Testkings 📘 Search for ➡ PDI ️⬅️ and download it for free immediately on [ [url]www.practicevce.com ] 🙉
DI Updated Demo[/url] - PDI Updated Demo 🌳 PDI Lead2pass 💇 PDI Updated Demo 🕵 Easily obtain ▷ PDI ◁ for free download through ▷ [url]www.pdfvce.com ◁ 🌸
DI Lead2pass[/url] - Quiz 2026 Authoritative PDI: Platform Developer I (PDI) Sample Questions Pdf 😞 Download PDI for free by simply searching on ⏩ [url]www.troytecdumps.com ⏪ 🔨Valid Test PDI Tips[/url]
- Improve Your Chances of Success with Salesforce's Realistic PDI Exam Questions and Accurate Answers ➡ Easily obtain ⮆ PDI ⮄ for free download through [ [url]www.pdfvce.com ] 📒
DI Valid Exam Prep[/url] - Updated PDI Testkings 😗 Valid PDI Test Papers ✔️ PDI Lead2pass 💅 Search for ➤ PDI ⮘ and download exam materials for free through ➤ [url]www.pdfdumps.com ⮘ 📶Free PDI Exam Dumps[/url]
- www.stes.tyc.edu.tw, gettr.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, k12.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New PDI dumps are available on Google Drive shared by BraindumpQuiz: https://drive.google.com/open?id=17ju8X6coxEwjEsU6PAMi0C4jhZ6BeyXD
