[Hardware] SC-401 Lab Questions & Braindumps SC-401 Torrent
115
【Hardware】 SC-401 Lab Questions & Braindumps SC-401 Torrent
Posted at 1/26/2026 18:24:26      View:108 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TorrentVCE SC-401 dumps from Cloud Storage: https://drive.google.com/open?id=1W2G1fh79Knca8MyN1GWL5Eh3mpuFuDw4
We all know that the SC-401 exam is not easy to pass and the certification is not easy to get. But where is a will, there is a way. if you are really determined, go buy SC-401 study materials now. With the help of SC-401 learning guide, your road will go more smoothly. If you want to know more about our products, maybe you can use the trial version of SC-401 simulating exam first. Of course, you can also spend a few minutes looking at the feedbacks to see how popular our SC-401 exam questions are.
Microsoft SC-401 Exam Syllabus Topics:
  • Implement Data Loss Prevention and Retention: This section evaluates Data Protection Officers on designing and managing data loss prevention (DLP) policies and retention strategies. It includes setting policies for data security, configuring Endpoint DLP, and managing retention labels and policies. Candidates must understand adaptive scopes, policy precedence, and data recovery within Microsoft 365.
  • Manage Risks, Alerts, and Activities: This section assesses Security Operations Analysts on insider risk management, monitoring alerts, and investigating security activities. It covers configuring risk policies, handling forensic evidence, and responding to alerts using Microsoft Purview and Defender tools. Candidates must also analyze audit logs and manage security workflows.
  • Implement Information Protection: This section measures the skills of Information Security Analysts in classifying and protecting data. It covers identifying and managing sensitive information, creating and applying sensitivity labels, and implementing protection for Windows, file shares, and Exchange. Candidates must also configure document fingerprinting, trainable classifiers, and encryption strategies using Microsoft Purview.
  • Protect Data Used by AI Services: This section evaluates AI Governance Specialists on securing data in AI-driven environments. It includes implementing controls for Microsoft Purview, configuring Data Security Posture Management (DSPM) for AI, and monitoring AI-related security risks to ensure compliance and protection.
Braindumps SC-401 Torrent | Fresh SC-401 DumpsBecause industry of information technology is fast-moving. To excel in this advanced industry, pass the SC-401 exam of the Microsoft SC-401 certification. Hundreds of applicants have faced issues in updated dumps material to crack the Microsoft SC-401 examination in one go.
Microsoft Administering Information Security in Microsoft 365 Sample Questions (Q148-Q153):NEW QUESTION # 148
You have a Microsoft 365 E5 subscription. The subscription contains a user named User1 and the sensitivity labels shown in the following table.
You publish the labels to User1.
The subscription contains the files shown in the following table.
Which files can Microsoft 365 Copilot summarize for User1?
  • A. File2 and File3 only
  • B. File3 only
  • C. File1, File2, and File3
  • D. File2 only
For Microsoft 365 Copilot to summarize data within a file, the user must have both the EXTRACT and VIEW usage rights on the sensitivity label applied to that file, according to Microsoft Learn.
This ensures that Copilot can access and process the file's content for summarization purposes.
If a file is encrypted using Azure Rights Management without a sensitivity label, the same permissions (EXTRACT and VIEW) are still required for Copilot to function.
https://learn.microsoft.com/en-u ... -architecture-data- protection-auditing
NEW QUESTION # 149
You have a Microsoft 365 tenant and 500 computers that run Windows 11. The computers are onboarded to Microsoft Purview.
You discover that a third-party application named Tailspin_scanner.exe accessed protected sensitive information on multiple computers.
Tailspin_scanner.exe is installed locally on the computers.
You need to block Tailspin_scanner.exe from accessing sensitive documents without preventing the application from accessing other documents.
Solution: From the Microsoft 365 Endpoint data loss prevention (Endpoint DLP) settings, you add a folder path to the file path exclusions.
Does this meet the goal?
  • A. No
  • B. Yes
Folder path to the file path exclusions excludes certain paths and files from DLP monitoring.
Use the unallowed apps list instead.
https://docs.microsoft.com/en-us ... lp-using?view=o365- worldwide
NEW QUESTION # 150
You have a Microsoft 365 subscription.
You create and run a content search from the Microsoft Purview portal.
You need to download the results of the content search.
What should you obtain first?
  • A. an export key
  • B. a certificate
  • C. a password
  • D. a pin
When you run a Content Search in the Microsoft Purview compliance portal and want to download/export the search results, you must:
Select Export results in the Content Search tool.
Purview generates an Export key.
Use the eDiscovery Export Tool (ClickOnce application) to download the results.
The Export key is required to authenticate the export process.
Certificate # Not used in this process.
Password # Not required for export.
PIN # Not relevant here.
Export Key # # Mandatory to export search results.
# Reference:
Export Content Search results - Microsoft Learn
NEW QUESTION # 151
You have a Microsoft 365 ES subscription that uses Microsoft Teams and contains the users shown in the following table.
You have the retention policies shown in the following table.
The users perform the actions shown in the following table.
NOTE: Each correct selection is worth one point
NEW QUESTION # 152
You receive an email that contains a list of words that will be used for a sensitive information type.
You need to create a file that can be used as the source of a keyword dictionary.
In which format should you save the list?
  • A. an ACCDB database file that contains a table named Dictionary
  • B. a text file that has one word on each line
  • C. an XML file that contains a keyword tag for each word
  • D. an XLSX file that contains one word in each cell of the first row
The keywords for your dictionary could come from various sources, most commonly from a file (such as a .csv or .txt list) imported in the service or by PowerShell cmdlet.
Note:
There are several versions of this question in the exam. The question has two possible correct answers:
1. a CSV file that contains words separated by commas
2. a text file that has one word on each line
Other incorrect answer options you may see on the exam include the following:
- a TSV file that contains words separated by tabs
- an XLSX file that contains one word in each cell of the first row
- a DOCX file that has one word on each line
https://docs.microsoft.com/en-us ... e/create-a-keyword- dictionary?view=o365-worldwide
NEW QUESTION # 153
TorrentVCE provides you with the best preparation material. What makes TorrentVCE SC-401 brain dumps the first choice for their exam preparation is obviously its superior content that beats its competitors in quality and usefulness. TorrentVCE currently has a clientele of more than 60,000 satisfied customers all over the world. This is factual proof of the incomparable quality of our products. The way our brain dumps introduce you the syllabus contents of SC-401 Exam increases your confidence to perform well in the actual exam paper.
Braindumps SC-401 Torrent: https://www.torrentvce.com/SC-401-valid-vce-collection.html
DOWNLOAD the newest TorrentVCE SC-401 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1W2G1fh79Knca8MyN1GWL5Eh3mpuFuDw4
Posted at 2/4/2026 05:18:17        Only Author  2#
The article is so insightful and inspiring, thanks for sharing! Reliable DevOps-SRE test forum provides great resources for free, and I hope you find them useful.
Posted at 2/17/2026 00:27:15        Only Author  3#
Liking it because this content is awesome. We’re providing Reliable L4M6 exam blueprint, packed with valuable resources, for free, to help you.
