[General] Get Plat-Arch-204 Exam Questions To Gain Brilliant Results
110
General Get Plat-Arch-204 Exam Questions To Gain Brilliant Results
Posted at 1/26/2026 18:47:26      View200 | Replies3        Print      Only Author   [Copy Link] 1#
The Salesforce Plat-Arch-204 practice exam software of Actual4Dumps has questions that have a striking resemblance to the queries of the Salesforce Certified Platform Integration Architect (Plat-Arch-204) real questions. It has a user-friendly interface. You don't require an active internet connection to run it once the Plat-Arch-204 Practice Test software is installed on Windows computers and laptops.
Salesforce Plat-Arch-204 Exam Syllabus Topics:
  • Translate Needs to Integration Requirements: This domain involves converting business needs into technical specifications by documenting systems and patterns, evaluating constraints, defining security requirements, and determining performance needs like volumes, response times, and latency.
  • Maintain Integration: This domain focuses on monitoring integration performance, defining error handling and recovery procedures, implementing escalation processes, and establishing reporting needs for ongoing integration health monitoring.
  • Evaluate the Current System Landscape: This domain covers analyzing existing technical environments to understand current systems, their standards, protocols, limitations, and boundaries, while identifying constraints and authentication
  • authorization requirements.
Plat-Arch-204 Test Practice | Plat-Arch-204 Pass4sure Study MaterialsOur users are all over the world and they have completed their exams through the help of our Plat-Arch-204 study guide. As you can see the feedbacks from our loyal customers, all of them are grateful to our Plat-Arch-204 exam braindumps and become succussful people with the Plat-Arch-204 Certification. And what are you waiting for? Just selecting our Plat-Arch-204 learning materials, the next one to get an international certificate is you!
Salesforce Certified Platform Integration Architect Sample Questions (Q122-Q127):NEW QUESTION # 122
Northern Trail Outfitters (NTO) uses different shipping services for each of the 34 countries it serves. Services are added and removed frequently to optimize shipping times and costs. Sales representatives need to select between valid service(s) for the customer's country and request shipping estimates from that service. Which solution should an architect propose?
  • A. Store shipping services in a picklist that is dependent on a country picklist.
  • B. Use middleware to abstract the call to the specific shipping services.
  • C. Use Platform Events to construct and publish shipper-specific events.
When an organization must interact with multiple external services (34 different shipping providers) that change frequently, the primary architectural goal is to decouple Salesforce from the specific endpoints and protocols of those services.11 The architect should propose us12ing middleware to abstract the call. By introducing a middleware layer (such as an ESB or iPaaS), Salesforce makes a single, standardized call to the middleware, passing the country and order details. The middleware then handles the "rocess Orchestration":
Service Routing: Determining which shipping service is valid for the specified country.
Protocol Mediation: Translating the standard Salesforce request into the specific format (REST, SOAP, XML, etc.) required by each individual shipping provider.
Maintenance: When a shipper is added or removed, the change is made in the middleware without requiring any code or metadata updates in Salesforce.
Option A (Picklists) creates a high administrative burden and does not solve the underlying technical complexity of making callouts to dozens of different APIs. Option B (Platform Events) is asynchronous and would introduce unnecessary latency for a sales rep who needs an estimate "on the spot" to complete an order. Middleware abstraction provides a scalable, maintainable, and agile architecture that allows NTO to optimize its shipping operations without disrupting the CRM user experience.
NEW QUESTION # 123
An integration architect has received a request to prevent employees that leave the company from accessing data in Salesforce after they are deactivated in the company's HR system. What should the integration architect determine before recommending a solution?
  • A. Data access prevention requirements, then identify frequency
  • B. Inbound integration requirements, then identify frequency
  • C. Data access prevention requirements, integration requirements, and system constraints
NEW QUESTION # 124
Northern Trail Outfitters uses a custom Java application to display code coverage and test results for all enterprise applications. Which Salesforce API should an integration architect use to include Salesforce in this application?
  • A. Analytics REST API
  • B. Tooling API
  • C. Metadata API
The Tooling API is specifically designed for developer-centric tools that need fine-grained access to Salesforce metadata and runtime information. It exposes specialized objects like ApexCodeCoverage, ApexCodeCoverageAggregate, and ApexTestResult. These objects allow external applications to query the results of test runs and specific line-by-line coverage metrics. While the Metadata API (Option A) is used for deployments, it does not provide the same granular query access to test execution results. The Tooling API is the industry standard for integrating Salesforce into enterprise CI/CD pipelines and quality dashboards.
NEW QUESTION # 125
A customer of Salesforce has used Platform Events to integrate their Salesforce instance with an external third-party artificial intelligence (AI) system. The AI system provides a prediction score for each lead that is received by Salesforce. Once the prediction score is received, the lead information is saved to Platform Events for other processes. The trigger on the Platform Events has failed ever since it was rolled out to production. Which type of monitoring should the integration consultant have considered to monitor this integration?
  • A. Set up debug logs for Platform Event triggers to monitor performance.
  • B. Monitor Platform Events created per hour limits across the Salesforce instance.
  • C. Validate that the Platform Event definition matches lead's definition.
Troubleshooting failures in Platform Event-triggered logic is challenging because these triggers execute under the "Automated Process" system user, making them invisible to standard user-level monitoring. To diagnose why a trigger is failing in production, an Integration Architect must set up debug logs specifically for that trigger or the automated process user.
Debug logs provide a granular view into the execution execution path, including Apex errors, governor limit consumption, and specific DML failures. Without these logs, it is impossible to determine if the failure is due to a null pointer exception, a validation rule violation, or a record locking conflict.678 Option B is a design-time validation step; while important, it would not help mon9itor or troubleshoot a runtime failure in a deployed trigger. Option C focuses on high-level consumption limits; while reaching the "Created Per Hour" limit would prevent events from1011 being published, it would not explain why an existing trigger is failing once the event has already arrived in the bus. By proactively establishing debug logs for the integration's triggers, the consultant can pinpoint the exact line of code or system constraint causing the failure, ensuring a faster "Mean Time to Repair" (MTTR) for critical AI-driven business processes.
NEW QUESTION # 126
Northern Trail Outfitters (NTO) wants to improve the quality of callouts from Salesforce to its REST APIs by adhering to RAML (REST API Markup Language) specifications. The RAML specs serve as interface contracts. Which design specification should the integration architect include to ensure that Apex REST API Clients' unit tests confirm adherence to the RAML specs?
  • A. Call the HttpCalloutMock implementation from the Apex REST API Clients.
  • B. Require the Apex REST API Clients to implement the HttpCalloutMock.
  • C. Call the Apex REST API Clients in a test context to get the mock response.
In Salesforce, you cannot perform real HTTP callouts during unit tests. To test integration logic, developers must use the HttpCalloutMock interface to simulate the API's response. To ensure that the Apex code adheres to the RAML contract, the architect should require that the test mock implementation strictly follows the RAML specifications.
By requiring the Apex REST API Clients to implement the HttpCalloutMock (or more specifically, creating a mock class that implements it), the developer creates a controlled testing environment. The mock class should be coded to return a payload that matches the RAML-defined structure (fields, data types, and status codes). When the test runs, the Apex client receives this "contract-compliant" response. The unit test then uses assertions to verify that the Apex code correctly parses and handles this specific data structure.
Option B is technically imprecise; you don't "call" the mock from the client, you provide the mock to the test runtime using Test.setMock(). Option C describes the general process of testing but does not address the "design specification" needed to ensure contract adherence. By mandating a mock implementation that mirrors the RAML contract, the architect ensures that if the API contract changes in the RAML file, the unit tests will fail if the Apex code is not updated to match, thereby maintaining high integration quality and preventing runtime errors.
NEW QUESTION # 127
Actual4Dumps Salesforce Plat-Arch-204 practice exam support team cooperates with users to tie up any issues with the correct equipment. If Salesforce Certified Platform Integration Architect (Plat-Arch-204) certification exam material changes, Actual4Dumps also issues updates free of charge for three months following the purchase of our Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam questions.
Plat-Arch-204 Test Practice: https://www.actual4dumps.com/Plat-Arch-204-study-material.html
Posted at 2/3/2026 18:00:25        Only Author  2#
Thank you for bringing such an extraordinary article! This Valid NSE5_FSW_AD-7.6 test guide helped me achieve a promotion and salary increase. Now its free for everyone. Wishing you all a smooth path to promotion!
Posted at 2/9/2026 16:52:13        Only Author  3#
It was a truly rewarding and enlightening piece of writing. Workday-Pro-HCM-Reporting reliable exam questions fee test questionsyour key to advancing in your career and boosting your salary!
Posted at 2/17/2026 09:32:21        Only Author  4#
I really appreciate your article, it has been an eye-opening experience. The Upgrade MCAE-Con-201 dumps resources are excellent, and theres no cost to access them.
