[General] Salesforce OmniStudio-Developer Detail Explanation, OmniStudio-Developer Questio
92
【General】 Salesforce OmniStudio-Developer Detail Explanation, OmniStudio-Developer Questio
Posted at 1/26/2026 20:38:06      View:194 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that ITexamReview OmniStudio-Developer dumps now are free: https://drive.google.com/open?id=1a37OmrB77z_MqgGayd4hTtxxRC2QIxZv
Managing time during the Salesforce OmniStudio-Developer exam is a challenging task. Most candidates cannot manage their time during the Salesforce OmniStudio-Developer exam, leave the questions, and fail. Time management skills can help students gain excellent marks in the OmniStudio-Developer Exam. Salesforce OmniStudio-Developer practice exam on the software helps you identify which kind of Salesforce Certified OmniStudio Developer OmniStudio-Developer questions are more time-consuming, and they would be able to assess their efficiency in answering questions.
Salesforce OmniStudio Developer certification exam covers various topics, including Salesforce CPQ, Salesforce B2B Commerce, MuleSoft, and Salesforce Platform Events. OmniStudio-Developer exam also assesses the candidate's understanding of the Salesforce development lifecycle, data modeling, and security frameworks. Salesforce Certified OmniStudio Developer certification exam comprises 60 multiple-choice questions that must be completed within 105 minutes. The passing score for the Salesforce OmniStudio Developer certification exam is 65%, and the exam fee is $200.
Salesforce OmniStudio-Developer Exam is a certification exam designed for professionals who want to prove their expertise in using the Salesforce OmniStudio platform. OmniStudio-Developer exam is intended for individuals who have experience in developing and deploying Salesforce solutions and have a deep understanding of the Salesforce platform. Salesforce Certified OmniStudio Developer certification validates the candidate's skills in designing, building, and deploying Salesforce solutions using the OmniStudio platform.
2026 100% Free OmniStudio-Developer –Authoritative 100% Free Detail Explanation | OmniStudio-Developer Questions AnswersIf you are worried that it is not easy to obtain the certification of OmniStudio-Developer. Our OmniStudio-Developer study questions can meet your needs. Once you use our OmniStudio-Developer exam materials, you don't have to worry about consuming too much time, because high efficiency is our great advantage. You only need to spend 20 to 30 hours on practicing and consolidating of our OmniStudio-Developer learning material, you will have a good result. After years of development practice, our OmniStudio-Developer test torrent is absolutely the best. You will embrace a better future if you choose our OmniStudio-Developer exam materials.
Salesforce Certified OmniStudio Developer Sample Questions (Q49-Q54):NEW QUESTION # 49
Refer to the exhibit below. In this integration production structure, what Send JSON Path would be used to send the Output of the Action1 element to a Remote Action?
  • A. BlockA: BlockB. Action 1
  • B. Action1. BlockB. Block A
  • C. Action1: BlockB. Block A
  • D. BlockB: BlockB. Action1
NEW QUESTION # 50
A developer needs to display read-only contact information in a OmniScript. The developer will format the information as a table, using merge codes to dynamically include first name, last name, street address, state, postal, code, and country from the data JSON.
Which OmniScript element should the developer use to meet this requirement?
  • A. Text Block
  • B. Text area
  • C. Rich text Area
  • D. Edit Block
A Text Block element allows the developer to display read-only text in a table format, using merge codes to dynamically include data from the data JSON. A Rich Text Area element is used to display formatted text with images and links. A Text Area element is used to display editable text in a single line or multiple lines. An Edit Block element is used to display editable fields in a form layout.
NEW QUESTION # 51
A customerhas anew Engagement Manager who is going to be the new Primary Contact for the Account.
What type of mapping does a DataRaptor Load use to create the new contact and then add it as the new Primary Contact?
  • A. Relationship Query
  • B. Linked Mapping
  • C. Lookup Key
  • D. Lookup Mapping
According to the DataRaptor Load Overview page, a Linked Mapping is used to "create or update multiple records in different objects that are related by lookup fields".
NEW QUESTION # 52
A developer creates a Flexcardthat displaysa contact's mailing address and passes the contact's postal code to a child FlexCard.
When configuration text elements in the child FlexCard, what syntax should a developer use to refer to the contact's postal code?
  • A. {Records.postalcode}
  • B. {Postalcode}
  • C. {Parent.postalcode}
  • D. {Params.postalcode}
The Params node contains the data that is passed from the parent FlexCard to the child FlexCard. The developer should use {Params.postalcode} to refer to the contact's postal code in the child FlexCard.
NEW QUESTION # 53
A developer needs to display the following information together on oneFlexCard:
* Account name, address, phone number, website
* Primary contact first name, contact name, address, phone number, email The account information must always be visible, and the contact information should only be visible as needed by the user.
What approach should the developer use to display the contact information on the card?
  • A. Use a conditional FlexCard State
  • B. Set the class'' collapsible'' on the block element
  • C. Set the collapsible property on the block element
  • D. Use aData tableelement
Setting the collapsible property on the block element allows the user to expand or collapse the block as needed. Using a Data table element is not suitable for displaying contact information. Setting the class'' collapsible'' on the block element has no effect. Using a conditional FlexCard State requires a condition to be met, not a user choice.
NEW QUESTION # 54
The development of science and technology makes our life more comfortable and convenient, which also brings us more challenges. Many company requests candidates not only have work experiences, but also some professional certifications. Therefore it is necessary to get a professional Salesforce certification to pave the way for a better future. The OmniStudio-Developer question and answers produced by our company, is helpful for our customers to pass their OmniStudio-Developer exams and get the OmniStudio-Developer certification within several days. Our OmniStudio-Developer exam questions are your best choice.
OmniStudio-Developer Questions Answers: https://www.itexamreview.com/OmniStudio-Developer-exam-dumps.html
DOWNLOAD the newest ITexamReview OmniStudio-Developer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1a37OmrB77z_MqgGayd4hTtxxRC2QIxZv
Posted at 4/19/2026 23:10:31        Only Author  2#
Als ein professioneller Lieferant der IT Zertifizierungsprüfungssoftewaren, bieten wir nicht nur die Produkte wie ACAMS CGSS Prüfungsunterlagen, deren Qualität und Wirkung garantiert werden, sondern auch hochqualifizierter 24/7 Kundendienst. Wenn Sie neben ACAMS CGSS noch Prüfungsunterlagen anderer Prüfungen suchen oder Fragen für den Kauf haben, können Sie direkt auf unserer Website online fragen. Innerhalb einem Jahr nach dem Kauf der ACAMS CGSS Prüfungssoftware, geben wir Ihnen Bescheid, sobald die ACAMS CGSS Prüfungsunterlagen aktualisiert haben.
