Valid PDII Cram Materials - High-Efficient New PDII Test Pdf and Correct Latest
88
Posted at 1/26/2026 22:35:22      View:133 | Replies:5        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PracticeTorrent PDII dumps from Cloud Storage: https://drive.google.com/open?id=1qFk_bAZb63i57vPuGkSgQj7cV_xA08wm
You will never be afraid of the PDII exam, we believe that our PDII preparation materials will help you change your present life. It is possible for you to start your new and meaningful life in the near future, if you can pass the PDII exam and get the certification. So it is very important for you to prepare for the PDII Practice Exam, you must pay more attention to the PDII certification guide to help you. And our PDII exam questions can give you all the help to obtain the certification.
Salesforce Certified Platform Developer II (PDII) Certification Exam is a highly sought-after certification for developers who want to demonstrate their expertise in the Salesforce platform. Platform Developer II certification validates the skills and knowledge needed to design and develop complex business logic, data models, and interfaces using Apex and Visualforce. It is the second level of certification for Salesforce developers, following the Certified Platform Developer I (PDI) certification.
To be eligible for the Salesforce PDII Certification Exam, candidates must have obtained the Salesforce Certified Platform Developer I certification and have at least two years of experience in developing custom applications on the Salesforce platform. PDII Exam consists of 60 multiple-choice questions and five coding challenges that test the candidate's ability to design, develop, and deploy complex applications on the Salesforce platform. PDII exam covers a wide range of topics, including data modeling, Apex programming, Lightning components, and integration with external systems. Upon passing the exam, candidates will receive the Salesforce Certified Platform Developer II certification, which is recognized as a valuable credential by employers and clients worldwide.
New PDII Test Pdf & Latest PDII Test MaterialsIn order to meet a wide range of tastes, our company has developed the three versions of the PDII preparation questions, which includes PDF version, online test engine and windows software. According to your own budget and choice, you can choose the most suitable one for you. And if you don't know which one to buy, you can free download the demos of the PDII Study Materials to check it out. The demos of the PDII exam questions are a small part of the real exam questions.
Salesforce PDII certification is a valuable credential for experienced Salesforce developers who are looking to enhance their skills and advance their careers. To prepare for the exam, candidates must have a deep understanding of the Salesforce platform and its advanced capabilities, as well as experience in developing complex customizations and integrating with external systems. With the right preparation, candidates can confidently take and pass the PDII Exam, and join the elite group of Salesforce Certified Platform Developer II professionals.
Salesforce Platform Developer II Sample Questions (Q70-Q75):NEW QUESTION # 70
An Apex trigger and Apex class increment a counter, Edit_Count_c, any time that the Case is changed.
A new process on the case object was just created in production for when a Case is created or updated< since the process was created, they are reports that the Count is being incremented by more than one on Case edit.
Which change in the Apex code will fix the problem?
A)
B)
C)
D)
  • A. Option A
  • B. Option C
  • C. Option B
  • D. Option D
NEW QUESTION # 71
A developer sees test failures in the sandbox but not in production. No code or metadata changes have been actively made to either environment since the sandbox was created.
Which consideration should be checked to resolve the issue?
  • A. Ensure the Apex classes are on the same API version.
  • B. Ensure the sandbox Is on the same release as production.
  • C. Ensure that Disable Parallel Apex Testing Is unchecked.
  • D. Ensure test classes are using SeeAllData = true.
If test failures are occurring in a sandbox but not in production and there have been no active code or metadata changes, it could be due to differences in the Salesforce release versions between the two environments. Sandboxes can be on preview instances which get upgraded to new releases before production instances. This can lead to differences in behavior and could affect test executions. Ensuring that both the sandbox and production are on the same release can resolve such issues. API version differences and parallel testing settings typically do not cause discrepancies if the code hasn't changed, and while using SeeAllData=true is generally not recommended due to its dependence on the organization's data, it's unlikely to be the cause if the issue is related to the environment rather than the data.
Sandbox Preview Instructions
Understand the Salesforce Release Process
NEW QUESTION # 72
A developer created a Lightning web component for the Account record page that displays the five most recently contacted Contacts for an Account. The Apex method, getRecentContacts, returns a list of Contacts and will be wired to a property in the component.
Which two lines must change in the above ode to make the Apex method able to be wired?
Choose 2 answers
  • A. Add AuraEnanled(cacheabletrue) to the line 08
  • B. Add @AuraEnabled (cacheabletrue) to line 03.
  • C. Remove private from line 09.
  • D. Add public to line 04.
NEW QUESTION # 73
A developer is developing a reusable Aura component that will reside on an sObject Lightning page with the following HTML snippet:
Caura: component implements-"forcethaaRecordid, flexipage:availableForAllPageTypes">
<div>Hello!</div>
</aura:component>
How can the component's controller get the context of the Lightning page that the sobject is an without
requiring additional best coverage?
  • A. Use the getSObjectType () method in an Apex class
  • B. Create a design attribute and configure via App Builder
  • C. Add force:hasSobjectName to the implements attribute
  • D. Set the object type as a component attribute.
NEW QUESTION # 74
Choose the correct definition for <apex:actionStatus>
  • A. Sends an AJAX request according to the time interval you specify. If this ever gets re-rendered, it resets
  • B. Allows for controller methods to be called directly from Javascript. Must be encapsulated in
    <apex:form> tags. Unlike actionSupport, these function<apex:actionPoller>s can be called directly from Javascript code
  • C. Adds AJAX support to another component (e.g. onClick, onMouseUp, onFocus, etc.)
  • D. Signifies which components should be processed by the server when an AJAX request is generated
  • E. Can be associated with an AJAX request (actionFunction/actionSupport/actionPoller) and shows content conditionally depending on the status of the request (in progress/complete). Use the "id" field to specify name; use "status" field on related components to connect them
Answer: E
NEW QUESTION # 75
New PDII Test Pdf: https://www.practicetorrent.com/PDII-practice-exam-torrent.html
P.S. Free 2026 Salesforce PDII dumps are available on Google Drive shared by PracticeTorrent: https://drive.google.com/open?id=1qFk_bAZb63i57vPuGkSgQj7cV_xA08wm
Posted at 1/29/2026 04:57:14        Only Author  2#
Thank you for sharing this inspiring piece, it's really uplifting! Let’s do this! Wishing for success in the New ITIL-4-DITS test dumps exam!
Posted at 2/3/2026 16:34:57        Only Author  3#
The article was quite thought-provoking. Get ahead with the free New C-TB120-2504 study plan exam questions—career progression and raises await!
Posted at 2/8/2026 09:52:11        Only Author  4#
What an extraordinary article, I’m so appreciative of your sharing. Wishing you the best of luck! Here are the free FCSS_LED_AR-7.6 test questions pdf study materials.
Posted at 2/11/2026 03:14:42        Only Author  5#
After reading this article, I feel I have grown a lot. The IFC reliable test collection materials test was a key factor in my professional growth, and now I’m sharing it with you for free!
Posted at 2/20/2026 00:36:09        Only Author  6#
自宅にいても外にいても、Plat-Arch-204テストトレントを勉強できます。 Plat-Arch-204学習ツールの指導の下では、試験の準備に20〜30時間しかかからないため、他にやることがあるので、時間を心配する必要はありません。 Plat-Arch-204試験資料を使用して、独自に学習できます。毎日多くの時間を費やす必要はなく、試験に合格し、最終的には証明書を取得します。 Plat-Arch-204認定は、就職面接の重要なタグになる可能性があり、他の人よりも競争上の優位性があります。
