[General] Reliable 1z0-1057-25 Guide Files, Latest 1z0-1057-25 Test Vce
101
【General】 Reliable 1z0-1057-25 Guide Files, Latest 1z0-1057-25 Test Vce
Posted at 1/26/2026 23:51:35      View:88 | Replies:0        Print      Only Author   [Copy Link] 1#
If you try to get the Oracle Project Management Cloud 2025 Implementation Professional certification that you will find there are so many chances wait for you. You can get a better job; you can get more salary. But if you are trouble with the difficult of 1z0-1057-25 exam, you can consider choose our 1z0-1057-25 Exam Questions to improve your knowledge to pass 1z0-1057-25 exam, which is your testimony of competence. Now we are going to introduce our 1z0-1057-25 test guide to you, please read it carefully.
Many exam candidates attach great credence to our 1z0-1057-25 simulating exam. You can just look at the hot hit on our website on the 1z0-1057-25 practice engine, and you will be surprised to find it is very popular and so many warm feedbacks are written by our loyal customers as well. Our 1z0-1057-25 study prep does not need any ads, their quality has propaganda effect themselves. As a result, the pass rate of our 1z0-1057-25 exam braindumps is high as 98% to 100%.
Get the Oracle 1z0-1057-25 Certification to Boost Your Professional CareerTaking these mock exams is important because it tells you where you stand. People who are confident about their knowledge and expertise can take these 1z0-1057-25 practice tests and check their scores to know where they lack. This is good practice to be a pro and clear your Oracle Project Management Cloud 2025 Implementation Professional (1z0-1057-25) exam with amazing scores. 2Pass4sure practice tests simulate the real 1z0-1057-25 exam questions environment.
Oracle Project Management Cloud 2025 Implementation Professional Sample Questions (Q118-Q123):NEW QUESTION # 118
Your client uses Resource Breakdown Structures (RBS) and Resource Mapping to associate amounts to resources. After making some changes to the resources at project level, forecasts are regenerated. After reviewing the cost amounts associated with the resources, you suspect that the cost association does not match your client's expectations. Identify two valid rules based on which cost association works. (Choose two.)
  • A. If there is only one level in RBS to which the transaction maps, the cost amounts are mapped to that level.
  • B. If one branch contains a user-defined resource type, precedence is given to the branch that contains a user-defined resource type.
  • C. If a transaction maps to more than one level, Oracle PPM Cloud sums the precedence numbers for all resource type in the branch and gives precedence to the resource element in the branch with the highest sum.
  • D. If the sum of precedence numbers is the same for more than one branch, precedence is given to the branch with the lowest number at the lowest level.
Reference https://docs.oracle.com/cd/E3758 ... /F458900AN13D82.htm How Resource Mapping Is Calculated You can track the cost impact of every resource that has been assigned to a project task and use the resource breakdown structure to view the breakdown of these costs. Oracle Fusion Projects associates the costs of the resources used for tasks with branches and levels in the resource breakdown structure. The process for determining the correct association is managed by rules of precedence.
Oracle Fusion Projects uses the following rules to associate cost amounts with resources:
* Select the lowest level in the resource breakdown structure to which a transaction can map.
* If there is only one level to which the transaction maps, the cost amounts are mapped to that level.
* If the transaction maps to more than one level, Oracle Fusion Projects sums the precedence numbers for all resource types in the branch and gives precedence to the resource element in the branch with the lowest sum.
* If more than one branch has the lowest precedence number at the lower level, the application uses the precedence number of the next level up.
* If the sum of precedence numbers is the same for more than one branch, precedence is given to the branch with the lowest number at the lowest level.
* If one branch contains a user-defined resource type, precedence is given to the branch that does not contain a user-defined resource type.
Note Oracle Fusion Projects gives more precedence to a lower precedence number. For example, a resource element with a precedence number of 1 is given precedence over a resource element with a precedence number of 10.
NEW QUESTION # 119
While creating a new project template, you notice that a default Asset Cost Allocation method is being automatically associated. Identify the source setup from which the default value is being inherited. (Choose the best answer.)
  • A. project classification
  • B. project organization
  • C. project unit
  • D. project type
Ref: https://docs.oracle.com/en/cloud ... pjf/define-project.
html#OAPJF220111
Asset Cost Allocation Methods
The asset cost allocation method determines how indirect or common costs incurred on a project are allocated to multiple assets.
You can specify an asset cost allocation method to enable Oracle Fusion Project Costing to automatically allocate unassigned asset lines and common costs across multiple assets. Unassigned asset lines typically occur when more than one asset is assigned to an asset grouping level.
Projects and project templates inherit a default asset cost allocation method from the associated project type.
You can override the default at the project level. If you use capital events to allocate costs, then you can also override the asset cost allocation method at the event level Asset Cost Allocation Methods The following table describes the available asset cost allocation methods.
Method
Basis of Cost Allocation
Actual Units
Number of units defined for each asset
Current Cost
Construction-in-process (CIP) cost of each asset
Estimated Cost
Estimated cost of each asset
Standard Unit Cost
Combination of the standard unit cost and the number of units defined for each asset Spread Evenly Equal allocation of cost to each asset
NEW QUESTION # 120
You are implementing Project Portfolio Management (PPM) for a professional services firm. The firm rents multiple buildings for its operations. At the end of each month, they review the rent expense for the month and want to allocate the rental cost to all the projects and tasks that are executed by associates in each of the buildings. The source amounts must be proportionally allocated to the tasks based on the raw costs of the tasks from the previous month. Considering that all these costs are in General Ledger, what three allocation setups should you complete in PPM? (Choose three.)
  • A. Allocate rental costs once each accounting period by using the "full" allocation method.
  • B. Allocate to all eligible tasks and prorate the allocation by the total actual raw cost accrued for each task during the previous accounting period.
  • C. Define allocation basis by using Actual Amounts with a project-to-date amount class.
  • D. Allocate rental costs once each accounting period by using the "spread evenly" allocation method.
  • E. Define allocation basis by using Actual Amounts with a period-to-date amount class.
Answer: A,B,E
To allocate the rental cost to the projects and tasks based on the raw costs of the tasks from the previous month, you need to do the following:
* Allocate rental costs once each accounting period by using the "full" allocation method. This method allocates the entire source amount to the target tasks in one run.
* Allocate to all eligible tasks and prorate the allocation by the total actual raw cost accrued for each task during the previous accounting period. This ensures that the source amount is proportionally allocated to the tasks based on their relative raw costs.
* Define allocation basis by using Actual Amounts with a period-to-date amount class. This allows you to use the actual raw costs of the tasks as the basis for allocation and to use the amounts from the previous accounting period. Reference: https://docs.oracle.com/en/cloud ... olio-management/20c
/oapfm/manage-project-costs.html#OAPFM2355951
NEW QUESTION # 121
Your customer has separate organizations to maintain indirect, capital, and billing types of projects.
Identify the two setups that can be used to fulfill this requirement. (Choose two.)
  • A. Business Unit
  • B. Project Type
  • C. Organization Tree
  • D. Project Organization Classification
  • E. Project Accounting Business Function
NEW QUESTION # 122
You have been hired as a project manager for implementing the Project Financial Management and Project Execution Management offering by an organization. The Chief Information Officer of the deploying organization has requested you to explain the benefits of using the implementation project-based approach over the functional area-based approach.
Which two are the main benefits of using the implementation projects within Functional Setup Manager?
(Choose two.)
  • A. Implementation Project helps in assigning responsibility of managing setup data to a broad group of users.
  • B. Implementation Project helps you to monitor progress of the setup tasks.
  • C. Implementation Project helps you to use the manage setup data entry in bulk option.
  • D. Implementation Project gives you the flexibility to set up different functional areas of the offering at different times.
Some of the main benefits of using the implementation projects within Functional Setup Manager are:
* Implementation Project helps in assigning responsibility of managing setup data to a broad group of users. You can assign tasks to different users who are responsible for entering and validating setup data for different functional areas of the offering.
* Implementation Project helps you to monitor progress of the setup tasks. You can track the status and completion percentage of each task and view the dependencies and prerequisites among tasks.
Implementation Project does not give you the flexibility to set up different functional areas of the offering at different times, as this is determined by the configuration package that you select for your implementation. Implementation Project does not help you to use the manage setup data entry in bulk option, as this is a separate feature that allows you to import and export setup data across instances using spreadsheets. Reference: https://docs.oracle.com/en/cloud ... olio-management/20c
/oapfm/implement-project-financial-management-applications.html#OAPFM2356051
NEW QUESTION # 123
2Pass4sure provides accurate and up-to-date Oracle 1z0-1057-25 Exam Questions that ensure exam success. With these Oracle 1z0-1057-25 practice questions, you can pass the 1z0-1057-25 exam on the first try. 2Pass4sure understands the stress and anxiety that exam candidates experience while studying. As a result, they provide personalized Oracle 1z0-1057-25 Practice Exam material to assist you in efficiently preparing for the exam.
Latest 1z0-1057-25 Test Vce: https://www.2pass4sure.com/Project-Financials-Management-Cloud/1z0-1057-25-actual-exam-braindumps.html
Oracle Reliable 1z0-1057-25 Guide Files Every question paper consists of questions and answers are given at the end, The most professional support service are provided to help the 1z0-1057-25 candidates at anytime and anywhere, Authoritative and trustworthy 1z0-1057-25 actual test guide, It is the shortcut to pass exam by reciting the valid 1z0-1057-25 dumps torrent, If you don't receive our 1z0-1057-25 study materials in five minutes, please contact with our online worker.
This chapter covers the following topics: Cisco IP Telephony 1z0-1057-25 Security life cycle, Screwing up a.k.a, Every question paper consists of questions and answers are given at the end.
The most professional support service are provided to help the 1z0-1057-25 candidates at anytime and anywhere, Authoritative and trustworthy 1z0-1057-25 actual test guide.
1z0-1057-25 still valid dumps, Oracle 1z0-1057-25 dumps latestIt is the shortcut to pass exam by reciting the valid 1z0-1057-25 dumps torrent, If you don't receive our 1z0-1057-25 study materials in five minutes, please contact with our online worker.
