[General] OmniStudio-Developer Valid Test Review - Valid OmniStudio-Developer Exam Forum
84
【General】 OmniStudio-Developer Valid Test Review - Valid OmniStudio-Developer Exam Forum
Posted at 1/27/2026 01:58:27      View:105 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Pass4Test OmniStudio-Developer dumps for free: https://drive.google.com/open?id=1oVeUrmF-wvrSQXq2_JySg3EMsN5d3d4J
Our PDF version of the OmniStudio-Developer learning braindumps can print on papers and make notes. Then windows software of the OmniStudio-Developer exam questions, which needs to install on windows software. Also, the windows software is intelligent to simulate the real test environment. Then the online engine of the OmniStudio-Developer Study Materials, which is convenient for you because it doesn’t need to install on computers. It supports Windows, Mac, Android, iOS and so on. This version just can run on web browser.
Salesforce OmniStudio-Developer exam is designed to test the skills and knowledge of professionals who work with Salesforce's OmniStudio platform. Salesforce Certified OmniStudio Developer certification is for individuals who have experience developing and customizing solutions using OmniStudio's suite of tools. The OmniStudio-Developer Certification is an important credential that demonstrates mastery of advanced features and functionality of the OmniStudio platform.
Valid OmniStudio-Developer Exam Forum & Latest OmniStudio-Developer Exam DumpsAll questions in our OmniStudio-Developer pass guide are at here to help you prepare for the certification exam. We have developed our learning materials with accurate OmniStudio-Developer exam answers and detailed explanations to ensure you pass test in your first try. Our PDF files are printable that you can share your OmniStudio-Developer free demo with your friends and classmates. You can practice OmniStudio-Developer real questions and review our study guide anywhere and anytime.
Salesforce Certified OmniStudio Developer Sample Questions (Q82-Q87):NEW QUESTION # 82
A developer needs to create a list of cases for an account in a single Datable in a FlexCard. Like the one shown below.
How can the developer configure the FlexCard to display the case records in this way?
  • A. Disable the Repeat Record feature on the FlexCard setup tab
  • B. Select the Repeatable Mode propertyon thedata table elements
  • C. Enable the Repeat Records feature on the FlexCard Setup tab
  • D. Enable the record Looping feature on the data table elements
The Repeatable Mode property on the data table elements allows the developer to display multiple records in a single data table. The Repeat Records feature on the FlexCard Setup tab is used to display multiple FlexCards for each record in a data source. The Record Looping feature on the data table elements is used to iterate over a list of records and perform actions on each record. The Overwrite Target for all Null input checkbox on the Account id field is used to overwrite the existing value in the target object with null if the input value is null.
NEW QUESTION # 83
A developer is creating an OmniScript that provisions trail orgs to their customers. The following text block in the Omniscript uses a merge code to display the ID for the new trail org:
  • A. To %%sDetails: Customer|0: ID%%
  • B. To %sDetails: Customer|0: ID$
  • C. To %Details: Customer|1: ID%
  • D. To %Details: Customer|n: ID%
NEW QUESTION # 84
A developer needs to transform contact data into a JSON array.
Given the input JSON shown above, what are two ways a developer could configure a DATARaptor transform to achieve the expected Output JSON? Choose 2 answers
  • A. Set the Input JSON path as List(Contact) and the OutputJSON Path as Contact.
  • B. Set the Input JSON Path as Contact the out JSON Path as contact and output Data type as List.
  • C. Use a formula LIST(Contact), and add the output of the formula as the input in the Transform tab.
  • D. Set the input JSON Path as Contact and the OutPut JSON Path as List (Contact)
NEW QUESTION # 85
A developer is creating a FlexCard for a new Community page. The FlexCard will display case information along with actions to close the case and update the case, and it will be styled using the Community's theme.
What must the developer do to configure the FlexCard for deployment in acommunity?
  • A. Configure the Component Visibility in the Custom Component
  • B. Add the FlexCard's API name to the FlexCard Player component
  • C. Set the Deployment property in Card Configuration to "Community"
  • D. Set the Target property in Publish Options to "CommunityPage"
The FlexCard Player component is used to display FlexCards in a community page. The developer needs to add the FlexCard's API name to the FlexCard Player component to configure the FlexCard for deployment in a community.
NEW QUESTION # 86
A developer is configuring a DataRaptor Load to Save contract dat
a. The developer needs to set the record type of the contact using DeveloperName.
Which two configuration actions should the developer take to set this up in the DataRaptor Load?
  • A. Select RecordType in the Lookup Object list. ID in the Lookup Field list, and Development in the Lookup requested Field list.
  • B. Check is Lookup property when mapping the fields.
  • C. Add Link to RecordType object in the Contact Object with the id field of RecordType object.
  • D. Select RecordType in the Lookup object list. Development in the lookup Field list, and ID in the Lookup Requested Field list.
NEW QUESTION # 87
We promise during the process of installment and payment of our Salesforce Certified OmniStudio Developer prep torrent, the security of your computer or cellphone can be guaranteed, which means that you will be not afraid of virus intrusion and personal information leakage. Besides we have the right to protect your email address and not release your details to the 3rd parties. Moreover if you are not willing to continue our OmniStudio-Developer Test Braindumps service, we would delete all your information instantly without doubt. The main reason why we try our best to protect our customers’ privacy is that we put a high value on the reliable relationship and mutual reliance to create a sustainable business pattern.
Valid OmniStudio-Developer Exam Forum: https://www.pass4test.com/OmniStudio-Developer.html
DOWNLOAD the newest Pass4Test OmniStudio-Developer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1oVeUrmF-wvrSQXq2_JySg3EMsN5d3d4J
