JN0-664 Valid Exam Online - Realistic Quiz Juniper Valid Service Provider, Profe
Posted at 1/27/2026 02:29:21
View134
Replies0
DOWNLOAD the newest TestValid JN0-664 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1ihIGvzW-ZwLC2EolrV6DIDEEDopUgdoi
Annual test syllabus is essential to predicate the real JN0-664 questions. So you must have a whole understanding of the test syllabus. After all, you do not know the JN0-664 exam clearly. It must be difficult for you to prepare the JN0-664 exam. Then our JN0-664 Study Materials can give you some guidance for our professional experts have done all of these above matters for you by collecting the most accurate questions and answers. And you can have a easy time to study with them.
When you first contacted us with JN0-664 quiz torrent, you may be confused about our JN0-664 exam question and would like to learn more about our products to confirm our claims. We have a trial version for you to experience. If you encounter any questions about our JN0-664 learning materials during use, you can contact our staff and we will be happy to serve for you. Maybe you will ask if we will charge an extra service fee. We assure you that we are committed to providing you with guidance on JN0-664 Quiz torrent, but all services are free of charge. As for any of your suggestions, we will take it into consideration, and effectively improve our JN0-664 exam question to better meet the needs of clients. In the process of your study, we have always been behind you and are your solid backing. This will ensure that once you have any questions you can get help in a timely manner.
Secure High Grades in Exam using Juniper JN0-664 QuestionsOur JN0-664 learning materials are known for instant download. You can get the download link and password within ten minutes after purchasing, therefore you can start your learning as quickly as possible. Besides, JN0-664 exam dumps contain most of knowledge points of the exam, and it will be enough for you to pass the exam, and in the process of practicing JN0-664 Exam Dumps, your professional ability will also be improved. We offer you free update for 365 days after purchasing. The latest version for JN0-664 training materials will be sent to your email automatically.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q79-Q84):NEW QUESTION # 79
Click the Exhibit button.
Referring to the exhibit, which two statements are correct regarding the output shown in the exhibit? (Choose two.)
- A. The multicast traffic is using the RPT.
- B. The multicast group is an ASM group.
- C. The multicast traffic is using the SPT.
- D. The multicast group is an SSM group.
In the provided exhibit, the output of the `show pim join extensive 232.1.1.1` command is shown. This command provides detailed information about the PIM join state for the specified multicast group (232.1.1.1) on the router R1. To determine the correct statements regarding the multicast traffic, let's analyze the output and the terms involved:
1. **ASM vs. SSM**:
- **ASM (Any-Source Multicast)**: In ASM, receivers are interested in receiving multicast traffic from any source sending to a particular multicast group.
- **SSM (Source-Specific Multicast)**: In SSM, receivers are interested in receiving traffic only from specific sources for a multicast group.
- **Group Address Range**:
- ASM uses the range 224.0.0.0 to 239.255.255.255.
- SSM uses the range 232.0.0.0 to 232.255.255.255.
Since the group address 232.1.1.1 falls within the SSM range (232.0.0.0/8), there might be confusion.
However, considering the flags and states in the output, it's evident that the PIM mode and source information are consistent with ASM behavior.
2. **Multicast Trees**:
- **RPT (Rendezvous Point Tree)**: Multicast traffic initially uses the RPT, where the Rendezvous Point (RP) acts as an intermediate point.
- **SPT (Shortest Path Tree)**: After the initial join via RPT, traffic can switch to SPT, which is a direct path from the source to the receiver.
3. **Output Analysis**:
- **Flags**:
- The flags `sparse, rp-tree, wildcard` indicate that the group 232.1.1.1 is currently using RPT. This is typical for ASM, where traffic initially goes through the RP.
- The flags `sparse, spt` indicate that for the source 172.16.1.2, traffic has switched to SPT, meaning it is using the shortest path from the source directly to the receivers.
**Conclusion**:
Based on the analysis:
- **A. The multicast group is an ASM group**: This statement is correct as the configuration and behavior indicate ASM operation.
- **B. The multicast traffic is using the SPT**: This statement is also correct because the flags for the source
172.16.1.2 indicate that the traffic is using the SPT.
Thus, the correct answers are:
**A. The multicast group is an ASM group.**
**B. The multicast traffic is using the SPT.**
**References**:
- Juniper Networks PIM Documentation: [PIM
Overview](https://www.juniper.net/document ... t/pim-overview.html)
- Junos OS Multicast Routing Configuration Guide: [Multicast Routing Configuration Guide](https://www.juniper.net/document ... ticast-routing.html)
NEW QUESTION # 80
Which two statements describe PIM-SM? (Choose two)
- A. Routers with receivers send join messages to their upstream neighbors.
- B. Traffic is initially flooded to all routers and an S,G is maintained for each group
- C. Routers without receivers must periodically prune themselves from the SPT.
- D. Traffic is only forwarded to routers that request to join the distribution tree.
PIM sparse mode (PIM-SM) is a multicast routing protocol that uses a pull model to deliver multicast traffic.
In PIM-SM, routers with receivers send join messages to their upstream neighbors toward a rendezvous point (RP) or a source-specific tree (SPT). The RP or SPT acts as the root of a shared distribution tree for a multicast group. Traffic is only forwarded to routers that request to join the distribution tree by sending join messages.
PIM-SM does not flood traffic to all routers or prune routers without receivers, as PIM dense mode does.
NEW QUESTION # 81
Exhibit
Click the Exhibit button-Referring to the exhibit, which two statements are correct about BGP routes on R3 that are learned from the ISP-A neighbor? (Choose two.)
- A. By default, the next-hop value for these routes is not changed by ISP-A before being sent to R3.
- B. The next-hop value for these routes is changed by ISP-A before being sent to R3.
- C. The BGP local-preference value that is used by ISP-A is not advertised to R3.
- D. All BGP attribute values must be removed before receiving the routes.
BGP is an exterior gateway protocol that uses path vector routing to exchange routing information among autonomous systems. BGP uses various attributes to select the best path to each destination and to propagate routing policies. Some of the common BGP attributes are AS path, next hop, local preference, MED, origin, weight, and community. BGP attributes can be classified into four categories: well-known mandatory, well-known discretionary, optional transitive, and optional nontransitive. Well-known mandatory attributes are attributes that must be present in every BGP update message and must be recognized by every BGP speaker.
Well-known discretionary attributes are attributes that may or may not be present in a BGP update message but must be recognized by every BGP speaker. Optional transitive attributes are attributes that may or may not be present in a BGP update message and may or may not be recognized by a BGP speaker. If an optional transitive attribute is not recognized by a BGP speaker, it is passed along to the next BGP speaker. Optional nontransitive attributes are attributes that may or may not be present in a BGP update message and may or may not be recognized by a BGP speaker. If an optional nontransitive attribute is not recognized by a BGP speaker, it is not passed along to the next BGP speaker. In this question, we have four routers (R1, R2, R3, and R4) that are connected in a full mesh topology and running IBGP. R3 receives the 192.168.0.0/16 route from its EBGP neighbor and advertises it to R1 and R4 with different BGP attribute values. We are asked which statements are correct about the BGP routes on R3 that are learned from the ISP-A neighbor. Based on the information given, we can infer that the correct statements are:
* By default, the next-hop value for these routes is not changed by ISP-A before being sent to R3. This is because the default behavior of EBGP is to preserve the next-hop attribute of the routes received from another EBGP neighbor. The next-hop attribute indicates the IP address of the router that should be used as the next hop to reach the destination network.
* The BGP local-preference value that is used by ISP-A is not advertised to R3. This is because the local-preference attribute is a well-known discretionary attribute that is used to influence the outbound traffic from an autonomous system. The local-preference attribute is only propagated within an autonomous system and is not advertised to external neighbors.
References: : https://www.cisco.com/c/en/us/su ... l-bgp/13753-25.html :
https://www.cisco.com/c/en/us/su ... l-bgp/13762-40.html :
https://www.cisco.com/c/en/us/su ... l-bgp/13759-37.html
NEW QUESTION # 82
R4 is directly connected to both RPs (R2 and R3). R4 is currently sending all joins upstream to R3 but you want all joins to go to R2 instead.
Referring to the exhibit, which configuration change will solve this issue?
- A. Change the bootstrap priority on R2 to be higher than R3.
- B. Change the group-range to be more specific on R2 than R3.
- C. Change the default route in inet.2 on R4 from R3 as the next hop to R2.
- D. Change the local address on R2 to be higher than R3.
NEW QUESTION # 83
Exhibit
Referring to the exhibit, you are receiving the 192.168 0 0/16 route on both R3 and R4 from your EBGP neighbor You must ensure that R1 and R2 receive both BGP routes from the route reflector In this scenario, which BGP feature should you configure to accomplish this behavior?
- A. add-path
- B. multihop
- C. route-target
- D. multipath
BGP add-path is a feature that allows the advertisement of multiple paths through the same peering session for the same prefix without the new paths implicitly replacing any previous paths. This behavior promotes path diversity and reduces multi-exit discriminator (MED) oscillations. BGP add-path is implemented by adding a path identifier to each path in the NLRI. The path identifier can be considered as something similar to a route distinguisher in VPNs, except that a path ID can apply to any address family. Path IDs are unique to a peering session and are generated for each network3. In this question, we have a route reflector (RR) that receives two routes for the same prefix (192.168.0.0/16) from an EBGP neighbor. By default, the RR will only advertise its best path to its clients (R1 and R2). However, we want R1 and R2 to receive both routes from the RR. To achieve this, we need to configure BGP add-path on the RR and enable it to send multiple paths for the same prefix to its clients.
NEW QUESTION # 84
It is apparent that a majority of people who are preparing for the JN0-664 exam would unavoidably feel nervous as the exam approaching, If you are still worried about the coming exam, since you have clicked into this website, you can just take it easy now, I can assure you that our company will present the antidote for you--our JN0-664 Learning Materials. And you will be grateful to choose our JN0-664 study questions for its high-effective to bring you to success.
Valid JN0-664 Vce Dumps: https://www.testvalid.com/JN0-664-exam-collection.html
Juniper JN0-664 Valid Exam Online Worrying over the issue of passing exam has put many exam candidates under great stress, Juniper JN0-664 Valid Exam Online We simulated the most realistic examination room environment so that users can really familiarize themselves with the examination room, Juniper JN0-664 Valid Exam Online Find a method that fits your needs, What's more, we can assure you that you can pass the exam as well as getting the related certification in a breeze with the guidance of our JN0-664 quiz practice materials.
The database files you create can't be shared by any other database or JN0-664 transaction log, A silhouette means that the image will have no background of its own, allowing other images or text to be seen behind it.
Actual Juniper JN0-664 Exam Questions C Smart Strategy to Get CertifiedWorrying over the issue of passing exam has put many exam candidates under Reliable Test JN0-664 Test great stress, We simulated the most realistic examination room environment so that users can really familiarize themselves with the examination room.
Find a method that fits your needs, What's more, we can assure you that you can pass the exam as well as getting the related certification in a breeze with the guidance of our JN0-664 Quiz practice materials.
Our system will send the downloading link of JN0-664 dumps torrent to your email address automatically.
- Desktop Juniper JN0-664 Practice Exam Software Offers a Realistic Certification Test Environment 🙅 The page for free download of ➠ JN0-664 🠰 on ➡ [url]www.troytecdumps.com ️⬅️ will open immediately 💷JN0-664 Training Material[/url]
- Practice Test JN0-664 Pdf 🍇 JN0-664 Detailed Study Dumps ☕ Accurate JN0-664 Prep Material 🎁 The page for free download of [ JN0-664 ] on [url]www.pdfvce.com will open immediately 👙Composite Test JN0-664 Price[/url]
- New JN0-664 Test Duration 😟 Exam JN0-664 Labs 🖤 Reliable JN0-664 Braindumps Questions 🦃 Go to website [url]www.prep4away.com open and search for JN0-664 to download for free 🩺Reliable JN0-664 Dumps Free[/url]
- Desktop Juniper JN0-664 Practice Exam Software Offers a Realistic Certification Test Environment 🍝 Search for ➥ JN0-664 🡄 on ▛ [url]www.pdfvce.com ▟ immediately to obtain a free download ✔JN0-664 Reliable Exam Pdf[/url]
- Juniper JN0-664 Questions To Complete Your Preparation [2026] ⛪ Search for ➡ JN0-664 ️⬅️ and easily obtain a free download on ▛ [url]www.pdfdumps.com ▟ 🌐JN0-664 100% Correct Answers[/url]
- JN0-664 Training Material 🖊 Reliable JN0-664 Braindumps Questions 🍙 Reliable JN0-664 Braindumps Questions 🚅 Download ⮆ JN0-664 ⮄ for free by simply searching on ➽ [url]www.pdfvce.com 🢪 ⏫
ractice Test JN0-664 Pdf[/url] - JN0-664 Valid Exam Online - JN0-664: Service Provider, Professional (JNCIP-SP) First-grade Valid Exam Online 🥺 Open website ✔ [url]www.practicevce.com ️✔️ and search for JN0-664 for free download 🍲JN0-664 Related Certifications[/url]
- Pass JN0-664 Exam with 100% Pass Rate JN0-664 Valid Exam Online by Pdfvce 🦧 Open ➡ [url]www.pdfvce.com ️⬅️ and search for ➥ JN0-664 🡄 to download exam materials for free 🐴Reliable JN0-664 Braindumps Questions[/url]
- New JN0-664 Valid Exam Online Pass Certify | Valid Valid JN0-664 Vce Dumps: Service Provider, Professional (JNCIP-SP) 🧓 Go to website [url]www.prepawayexam.com open and search for [ JN0-664 ] to download for free 🌅JN0-664 Exam Dumps[/url]
- New JN0-664 Valid Exam Online Pass Certify | Valid Valid JN0-664 Vce Dumps: Service Provider, Professional (JNCIP-SP) 🎁 Copy URL ➽ [url]www.pdfvce.com 🢪 open and search for JN0-664 to download for free 🤠Test JN0-664 Dumps.zip[/url]
- Reliable JN0-664 Braindumps Questions 🍡 New JN0-664 Test Duration ➰ JN0-664 Test Pattern ⏸ Enter ➠ [url]www.easy4engine.com 🠰 and search for ▶ JN0-664 ◀ to download for free 📊Test JN0-664 Dumps.zip[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of TestValid JN0-664 dumps for free: https://drive.google.com/open?id=1ihIGvzW-ZwLC2EolrV6DIDEEDopUgdoi
