[General] Microsoft - MB-240 - Perfect Microsoft Dynamics 365 Field Service Functional Con
92
General Microsoft - MB-240 - Perfect Microsoft Dynamics 365 Field Service Functional Con
Posted at 1/27/2026 03:22:55      View159 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that Exam-Killer MB-240 dumps now are free: https://drive.google.com/open?id=1ZkOJAeUhC1UcHdS-t14AFTECeHEAIXFg
Microsoft MB-240 dumps PDF version is printable and embedded with valid Microsoft MB-240 questions to help you get ready for the MB-240 exam quickly. Microsoft Dynamics 365 Field Service Functional Consultant (MB-240) exam dumps pdf are also usable on several smart devices. You can use it anywhere at any time on your smartphones and tablets. We update our Microsoft MB-240 Exam Questions bank regularly to match the changes and improve the quality of MB-240 questions so you can get a better experience.
Earning the Microsoft MB-240 certification can be beneficial for professionals who work with Microsoft Dynamics 365 Field Service. Microsoft Dynamics 365 Field Service Functional Consultant certification can demonstrate to employers and customers that a candidate has the skills and knowledge necessary to configure and manage Field Service applications effectively. Additionally, certified professionals may be eligible for higher salaries and more advanced job opportunities. Overall, the Microsoft MB-240 Exam is an essential step for any functional consultant looking to specialize in Field Service applications in Microsoft Dynamics 365.
To prepare for the Microsoft MB-240 exam, Microsoft offers various training resources, including instructor-led training, online courses, and self-paced learning modules. Candidates can also take advantage of practice exams and study guides to help them prepare for the exam.
Free PDF Quiz 2026 High Pass-Rate Microsoft MB-240 Mock TestIf you are worried about your exam, and want to pass the exam just one time, we can do that for you. MB-240 exam materials are compiled by experienced experts, and they are quite familiar with the exam center, and therefore the quality can be guaranteed. In addition, you can receive the downloading link and password within ten minutes, so that you can begin your learning immediately. We provide you with free update for one year and the update version for MB-240 Exam Torrent will be sent to your email automatically.
Microsoft Dynamics 365 Field Service Functional Consultant Sample Questions (Q126-Q131):NEW QUESTION # 126
You are a Field Service resource manager for Contoso, Ltd. and are setting up characteristics for field technicians who are responsible for repairs on rental equipment.
Work performed on certain types of backhones, trenchers, and excavating equipment requires different attributes to be identified for proper work order assignment and scheduling.
Which two characteristics are valid? Each correct answer presents a complete solution.
  • A. Skill
  • B. Certification
  • C. Approval Status
  • D. Rating Value
Section: Schedule and dispatch work orders
https://docs.microsoft.com/en-us ... echnician-resources
NEW QUESTION # 127
A field service agent is performing maintenance work on Internet of Things (IoT) devices that are located at a customer site. The devices are reporting readings in real time. Why is the agent only able to see a limited amount of data from the devices?
  • A. By default, only the last 20 readings are displayed.
  • B. Microsoft Dynamics 365 is not connected to Azure.
  • C. Only system admins can see historic data.
  • D. The IoT devices are no longer registered.
https://docs.microsoft.com/en-us ... -service/connected- field-service
NEW QUESTION # 128
Your customer asks you to create a dashboard.
The application must meet the following requirements:
- Capture work orders, asset information, and customer information.
- Allow actions to be taken directly from the dashboard.
- Allow data filtration.
You need to determine the type of dashboard you should create in the app designer.
Which type of dashboard should you create?
  • A. Single-stream interactive
  • B. Multi-stream interactive
  • C. Classic
  • D. Power BI
NEW QUESTION # 129
The field service team manager needs you to give a new technician user access to the system. The technicianwill use the mobile application to fill out work orders when they are onsite doing filed work to repair factorymotors at customer sites. When the dispatcher takes vacation, the new technician user will manage dispatcher functions.Which two field service security roles will the new technician user need? Each correct answer presents part ofthe solution.
  • A. Field Service-User
  • B. Field Service-Dispatcher
  • C. Field Service-Mobile User
  • D. Field Service-App Access and Field Service -Resource
NEW QUESTION # 130
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
You are a Dynamics 365 for Field Service system administrator.
You are configuring a new instance of Dynamics 365 for Field Service. The organization needs to automatically generate work orders based on agreements, and send invoices on a recurring basis by customer.
Solution: You implement the following configuration changes.
1) Create Agreement
2) Define Booking Setup
3) Set Booking Recurrence
4) Create Invoice Setup
5) Define Invoice Recurrence
Does this meet the goal?
  • A. Yes
  • B. No
Section: Configure field service applications
NEW QUESTION # 131
Our Microsoft Dynamics 365 Field Service Functional Consultant study questions have a high quality, that mainly reflected in the passing rate. More than 99% students who use our MB-240 exam material passed the exam and successfully obtained the relating certificate. This undoubtedly means that if you purchased MB-240 exam guide and followed the information we provided you, you will have a 99% chance of successfully passing the exam. So our MB-240 study materials are a good choice for you. In order to gain your trust, we will provide you with a full refund commitment. If you failed to pass the exam after you purchase MB-240 Exam Material, whatever the reason, you just need to submit your transcript to us and we will give you a full refund. We dare to make assurances because we have absolute confidence in the quality of Microsoft Dynamics 365 Field Service Functional Consultant study questions. We also hope you can believe that MB-240 exam guide is definitely the most powerful weapon to help you pass the exam.
Training MB-240 Kit: https://www.exam-killer.com/MB-240-valid-questions.html
BTW, DOWNLOAD part of Exam-Killer MB-240 dumps from Cloud Storage: https://drive.google.com/open?id=1ZkOJAeUhC1UcHdS-t14AFTECeHEAIXFg
Posted at 2/22/2026 22:04:18        Only Author  2#
Your article is incredibly inspiring, thank you for sharing! Upgrade your IT knowledge with free Exam H12-811_V1.0-ENU pass guide. Wishing you success in your exams!
