[Hardware] Juniper JN0-683 Download Demo, Online JN0-683 Tests
92
【Hardware】 Juniper JN0-683 Download Demo, Online JN0-683 Tests
Posted at 1/27/2026 03:39:40      View:131 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-683 dumps are available on Google Drive shared by VCEPrep: https://drive.google.com/open?id=1fp6TY573oddMIq2rw3ZwMIeWThgFtLGM
Briefly speaking, our JN0-683 training guide gives priority to the quality and service and will bring the clients the brand new experiences and comfortable feelings. For we have engaged in this career for years and we are always trying our best to develope every detail of our JN0-683 study quiz. With our JN0-683 exam questions, you will find the exam is just a piece of cake. What are you still hesitating for? Hurry to buy our JN0-683 learning engine now!
Juniper JN0-683 Exam Syllabus Topics:
  • EVPN-VXLAN Signaling: This section assesses an understanding of Ethernet VPN (EVPN) concepts, including route types, multicast handling, and Multiprotocol BGP (MBGP). It also covers EVPN architectures like CRB and ERB, MAC learning, and symmetric routing.
  • Layer 3 Fabrics: This section measures the knowledge of professionals managing IP-based networks in data centers. It covers IP fabric architecture and routing, ensuring candidates understand how the network is structured for scalability and how traffic is routed efficiently.
  • Data Center Multitenancy and Security: This section tests knowledge of single-tenant and multitenant data center setups. Candidates such as Data Center Professionals are evaluated on ensuring tenant traffic isolation at both Layer 2 and Layer 3 levels in shared infrastructure environments.
  • Data Center Deployment and Management: This section assesses the expertise of data center networking professionals like architects and engineers, focusing on key deployment concepts. Topics include Zero-touch provisioning (ZTP), which automates device setup in data centers without manual input.
Topic 5
  • VXLAN: This part requires knowledge of VXLAN, particularly how the control plane manages communication between devices, while the data plane handles traffic flow. Demonstrate knowledge of how to configure, Monitor, or Troubleshoot VXLAN.
Online JN0-683 Tests & Certification JN0-683 Test QuestionsOur experts generalize the knowledge of the exam into our JN0-683 exam materials showing in three versions. PDF version of JN0-683 study questions - support customers' printing request, and allow you to have a print and practice in papers. Software version of JN0-683 learning guide - supporting simulation test system. App/online version of mock quiz - Being suitable to all kinds of equipment or digital devices, and you can review history and performance better. And you can choose the favorite one.
Juniper Data Center, Professional (JNCIP-DC) Sample Questions (Q26-Q31):NEW QUESTION # 26
Which two statements are true about IP fabrics using unnumbered BGP? (Choose two.)
  • A. Unnumbered BGP requires that family inet is configured on each interface.
  • B. Unnumbered BGP requires that family inet6 is configured on each interface.
  • C. Unnumbered BGP peering automatically provisions IPv6 peering.
  • D. Unnumbered BGP peering automatically provisions IPv4 peering.
https://www.juniper.net/document ... numbered/index.html
NEW QUESTION # 27
You are deploying multiple Juniper switches al the same location. Your switches are currently using the factory-default configuration.
In this scenario, which two statements are correct? (Choose two.)
  • A. The DHCP server configuration can provide Junos version requirements to DHCP clients.
  • B. The DHCP server configuration cannot provide Junos version requirements to DHCP clients.
  • C. The switch will try to request an IP address from a DHCP server using all interfaces that are connected and are operational.
  • D. The switch will try to request an IP address from a DHCP server using only the management interface.
* DHCP Behavior in Factory-Default Configuration:
* Option B:In the factory-default configuration, Juniper switches are designed to send DHCP requests on all operational interfaces. This behavior ensures that the switch can obtain an IP address for management and further configuration from any available DHCP server.
* Option D:The DHCP server can provide additional configuration parameters, including the required Junos version. This allows for automated provisioning and ensures that the switch is running the correct software version.
Conclusion:
* Option B:Correct-The switch will use any operational interface to request an IP address via DHCP.
* Option D:Correct-The DHCP server can specify Junos version requirements, enabling automated software management.
NEW QUESTION # 28
Exhibit.
Host A is connected to vlan 100 on lead. Host B is connected to vlan 200 on leaf1. Host A and Host B ate unable to communicate. You have reviewed the touting and your hosts have the correct default route (.1) Referring to the exhibit, which two commands will solve the problem? (Choose two.)
  • A. delete vlans vn200 13-interface irb.200
  • B. set vlans vn100 13-interface irb.100
  • C. set routing-options static route 0.0.0.0/0 next-hop 192.168.200.10
  • D. set interfaces irb unit 100 family inet address 192-168.100.1
In the provided network configuration, Host A is in VLAN 100 and Host B is in VLAN 200. The issue arises because these two hosts are unable to communicate, which indicates that either the interfaces are not properly linked to their respective VLANs, or there is a missing static route required for inter-VLAN routing.
Step-by-Step Analysis:
* VLAN Assignment:
* The exhibit shows that irb.200 is correctly associated with VLAN 200 in the configuration.
However, there is no corresponding irb.100 for VLAN 100. Without irb.100, the network lacks the logical interface to handle routing for VLAN 100. Thus, adding irb.100 to VLAN 100 is necessary.
Command to solve this:
* Static Route Configuration:
* For inter-VLAN routing to occur, a static route needs to be configured that allows traffic to pass between different subnets (in this case, between VLAN 100 and VLAN 200). The command set routing-options static route 0.0.0.0/0 next-hop 192.168.200.10 would add a static route that directs all traffic from VLAN 100 to the correct gateway (192.168.200.10), which is necessary to route traffic between the two VLANs.
Explanation of Incorrect Options:
* Option A (delete vlans vn200 13-interface irb.200): This would remove the logical interface associated with VLAN 200, which is not desired because we need VLAN 200 to remain active and properly routed.
* Option B (set interfaces irb unit 100 family inet address 192-168.100.1): This command would incorrectly assign an IP address that does not correspond with the subnet of VLAN 100 (192.168.200.1
/24). This could create a misconfiguration, leading to routing issues.
Data Center References:
For a Data Center, proper VLAN management and static routing are crucial for ensuring that different network segments can communicate effectively, especially when dealing with separated subnets or zones like in different VLANs. This aligns with best practices in DCIM (Data Center Infrastructure Management) which stress the importance of proper network configuration to avoid downtime and ensure seamless communication between all critical IT infrastructure components.
Ensuring that the correct interfaces are associated with the correct VLANs and having the proper static routes in place are both essential steps in maintaining a robust and reliable data center network.
This detailed analysis reflects best practices as noted in standard data center design and network configuration guides.
NEW QUESTION # 29
You are adding a server lo a tenant's network within your data center and must limit access to a specific traffic type within the tenant network without pushing all tenant traffic through a firewall.
What will satisfy this requirement?
  • A. Put the new server on a unique subnet within the tenant's network.
  • B. Use route leaking with EVPN and a routing policy.
  • C. Use filter-based forwarding.
  • D. Use a static route in the tenant VRF with a firewall as the next hop for traffic to the new server.
* Controlling Traffic Within a Tenant's Network:
* The requirement is to limit access to specific traffic types within a tenant's network without routing all tenant traffic through a firewall. This requires a selective method that can direct specific types of traffic to different paths based on the nature of the traffic.
* Filter-Based Forwarding (FBF):
* FBF is a technique that allows for routing decisions based on filters applied to the traffic, such as matching on source IP addresses, destination IP addresses, or even specific application types (like HTTP or FTP). This allows specific types of traffic to be forwardedto a specific next hop (e.g., a firewall) without affecting the entire traffic flow within the tenant's network.
Conclusion:
* Option B:Correct-Filter-based forwarding allows for granular control of traffic, ensuring that only specific types of traffic within the tenant's network are redirected through a firewall, satisfying the requirement.
NEW QUESTION # 30
You are asked to deploy 100 QFX Series devices using ZTP. Each QFX5120 requires a different configuration.
In this scenario, what are two components that you would configure on the DHCP server?
(Choose two.)
  • A. the MAC address of the FTP server
  • B. the management IP address for each QFX5120
  • C. the IP address of the FTP server
  • D. the MAC address for each QFX5120
The IP address of the FTP server: In a Zero Touch Provisioning (ZTP) deployment, the DHCP server needs to provide the IP address of a server (such as an FTP or TFTP server) that holds the configuration files or software images required for the device. The QFX devices will reach out to this server during the boot process to download their necessary configuration and images.
The management IP address for each QFX5120: The DHCP server should also provide the management IP address for each QFX5120, allowing the devices to connect to the network and communicate with the ZTP server for configuration.
NEW QUESTION # 31
We have a lot of regular customers for a long-term cooperation now since they have understood how useful and effective our JN0-683 actual exam is. In order to let you have a general idea about the shining points of our JN0-683 training materials, i would like to introduce the free demos of our JN0-683 study engine for you. There are the real and sample questions in the free demos to show you that how valid and latest our JN0-683 learning dumps are. So just try now!
Online JN0-683 Tests: https://www.vceprep.com/JN0-683-latest-vce-prep.html
2026 Latest VCEPrep JN0-683 PDF Dumps and JN0-683 Exam Engine Free Share: https://drive.google.com/open?id=1fp6TY573oddMIq2rw3ZwMIeWThgFtLGM
