[General] Juniper JN0-481 Latest Exam Fee | JN0-481 Interactive EBook
98
General Juniper JN0-481 Latest Exam Fee | JN0-481 Interactive EBook
Posted at 1/27/2026 07:53:33      View139 | Replies3        Print      Only Author   [Copy Link] 1#
2026 Latest Exam4Free JN0-481 PDF Dumps and JN0-481 Exam Engine Free Share: https://drive.google.com/open?id=1n8_HqTTHiN6_in3faZwfjZyO0y4MiMBE
Our JN0-481 study materials can come today. With so many loyal users, our good reputation is not for nothing. To buy our JN0-481 exam braindumps, you don't have to worry about information leakage. Selecting a brand like JN0-481 learning guide is really the most secure. And we are responsible and professional to protact your message as well. At the same time, if you have any problem when you buy or download our JN0-481 Practice Engine, just contact us and we will help you in a minute.
If you are a college student, you can learn and use online resources through the student learning platform over the JN0-481 study materials. On the other hand, the JN0-481 study engine are for an office worker, free profession personnel have different learning arrangement, such extensive audience greatly improved the core competitiveness of our products, to provide users with better suited to their specific circumstances of high quality learning resources, according to their aptitude, on-demand, maximum play to the role of the JN0-481 Exam Question.
Advantages Of Juniper JN0-481 PDF Dumps FormatMany candidates find the Data Center, Specialist (JNCIS-DC) (JN0-481) exam preparation difficult. They often buy expensive study courses to start their Data Center, Specialist (JNCIS-DC) (JN0-481) certification exam preparation. However, spending a huge amount on such resources is difficult for many Juniper JN0-481 Exam applicants. The latest Juniper JN0-481 exam dumps are the right option for you to prepare for the Data Center, Specialist (JNCIS-DC) (JN0-481) certification test at home.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q54-Q59):NEW QUESTION # 54
In Juniper Apstra. which three modes are available for devices? (Choose three.)
  • A. Active
  • B. Deploy
  • C. Ready
  • D. Stopped
  • E. Drain
Answer: B,C,E
Juniper Apstra supports three deploy modes for devices: Deploy, Drain, and Ready. These modes determine the configuration and state of the devices in the data center fabric.
Deploy: This mode applies the full Apstra-rendered configuration to the device, according to the Apstra Reference Design. The device state becomes IS-ACTIVE and the device is ready to carry traffic in the fabric.
Drain: This mode adds a "drain" configuration to the device, which prevents any new traffic from entering the device. The device state becomes IS-READY and the device is prepared for maintenance or decommissioning.
Ready: This mode removes the Apstra-rendered configuration from the device, leaving only the basic configuration such as device hostname, interface descriptions, and port speed/breakout.
The device state becomes IS-READY and the device is not part of the fabric.
NEW QUESTION # 55
What does EVPN use lo identity which remote leaf device advertised the EVPN route?
  • A. a VRF target value
  • B. a route target value
  • C. a route distinguisher value
  • D. a community tag
EVPN uses a route distinguisher (RD) value to identify which remote leaf device advertised the EVPN route. An RD is a 64-bit value that is prepended to the EVPN NLRI to create a unique VPNv4 or VPNv6 prefix. The RD value is usually derived from the IP address of the PE that originates the EVPN route. By comparing the RD values of different EVPN routes, a PE can determine which remote PE advertised the route and which VRF the route belongs to.
NEW QUESTION # 56
Which statement is true when onboarding a Juniper Networks device using a Juniper Apstra ZTP server?
  • A. The Hostname will be the serial-number of the device.
  • B. The Management IP address cannot be predetermined.
  • C. The State can be set In the ztp.Json file on the ZTP server.
  • D. The Device Key lo be used can be set In the dhcpd.conf file on the ZTP server.
The ztp.Json file on the Apstra ZTP server contains the configuration parameters for each device that is onboarded using ZTP. One of the parameters is the State, which can be one of the following values: init, ready, in_progress, done, error, or disabled. The State indicates the current status of the device in the ZTP process. For example, if the State is ready, it means that the device is ready to be onboarded by the Apstra ZTP server. If the State is done, it means that the device has completed the ZTP process and is managed by the Apstra server. The State can be manually set or changed in the ztp.Json file to control the behavior of the device during ZTP.
NEW QUESTION # 57
What are two system-defined user roles that are available in Juniper Apstra? (Choose two.)
  • A. user
  • B. authorized
  • C. root
  • D. viewer
Juniper Apstra provides four system-defined user roles that are available in the Apstra GUI environment. They are: administrator, device_ztp, viewer, and user. Based on the web search results, we can infer the following statements:
viewer: This role includes permissions to only view various elements in the Apstra system, such as blueprints, devices, design, resources, external systems, platform, and others. Users with this role cannot create, edit, or delete any element.
user: This role includes permissions to view and edit various elements in the Apstra system, such as blueprints, devices, design, resources, external systems, platform, and others. Users with this role cannot create or delete any element.
authorized: This is not a system-defined user role in Juniper Apstra. It is a term used to describe users who have been authenticated by an external system, such as LDAP, Active Directory, TACACS+, or RADIUS.
root: This is not a system-defined user role in Juniper Apstra. It is a term used to describe the superuser account on a Linux system, which has full access to all commands and files. Creating a user in the Apstra GUI does not provide that user access to the Apstra platform via SSH. To access the Apstra platform via SSH, you must create a local Linux system user.
NEW QUESTION # 58
In the Apstra design phase, what is the role of DC Reference Design?
  • A. It refers to the design of data center furniture layout
  • B. It provides a blueprint for the overall data center architecture and configuration
  • C. It specifies the color scheme for network cables
  • D. It determines the placement of security cameras in the data center
NEW QUESTION # 59
Without bothering to stick to any formality, our JN0-481 learning quiz can be obtained within five minutes. No need to line up or queue up to get our JN0-481 practice materials. They are not only efficient on downloading aspect, but can expedite your process of review. No harangue is included within JN0-481 Training Materials and every page is written by our proficient experts with dedication. And we have demos of the JN0-481 study guide, you can free download before purchase.
JN0-481 Interactive EBook: https://www.exam4free.com/JN0-481-valid-dumps.html
Juniper JN0-481 Latest Exam Fee Most of the materials on the market do not have a free trial function, PDF version of JN0-481 training materials is familiar by most learners, We gave 100% success rates in JN0-481 in just few months of starting our services, because we have well-designed material prepared by industry professionals, Now, JN0-481 test dumps bring you hopes for high passing rate.
A lot of people have given up when they are preparing for the JN0-481 exam, Configuring YouTube for Blog Posting, Most of the materials on the market do not have a free trial function.
PDF version of JN0-481 Training Materials is familiar by most learners, We gave 100% success rates in JN0-481 in just few months of starting our services, because we have well-designed material prepared by industry professionals.
100% Pass 2026 Juniper JN0-481: The Best Data Center, Specialist (JNCIS-DC) Latest Exam FeeNow, JN0-481 test dumps bring you hopes for high passing rate, JN0-481 test questions vce is useful and valid.
Posted at 2/1/2026 06:38:37        Only Author  2#
Truly an impressive article, Im grateful for your share. AP-209 valid practice questions book provides fantastic content for free.
Posted at 2/11/2026 23:26:17        Only Author  3#
Im sincerely grateful for your article, it really stood out to me. The PEGACPSSA24V1 real question on the exam helped me achieve career growth with a promotion and pay raise. Now, it's available for free. Best of luck to everyone!
Posted at 2/19/2026 01:52:09        Only Author  4#
This article is very well written and worth studying. This Latest test guide SPLK-1002 materials helped me get a promotion and salary increase. Now its free to all. Hope you achieve your career goals!
