[Linux] Error MIPI CSI - PACKET_ERR_F_BNDRY_MATCG PACKET_ERR_F_SEQ PACKET_ERR_FRAME_DATA
32
Linux Error MIPI CSI - PACKET_ERR_F_BNDRY_MATCG PACKET_ERR_F_SEQ PACKET_ERR_FRAME_DATA
Posted at 5/14/2025 17:57:48      View2290 | Replies3        Print      Only Author   [Copy Link] 1#
Can you tell me where I can find the decryption of these errors?
regs_v2x.h
#define PACKET_ERR_F_BNDRY_MATCG  GENMASK(3, 0)
#define PACKET_ERR_F_SEQ    GENMASK(7, 4)
#define PACKET_ERR_FRAME_DATA    GENMASK(11, 8)
#define PACKET_ERR_ID      GENMASK(15, 12)
#define PACKET_ERR_ECC_1BIT    GENMASK(19, 16)
#define PACKET_ERR_ECC_2BIT    BIT(20)
#define PACKET_ERR_CHECKSUM    GENMASK(27, 24)
where are the messages created - "MIPI error: packet: 0x%08x\n" and use the error
kernel/drivers/media/platform/rockchip/isp/capture_v21.c:
void rkisp_mipi_v21_isr(unsigned int phy, unsigned int packet,
      unsigned int overflow, unsigned int state,
      struct rkisp_device *dev)
  struct v4l2_device *v4l2_dev = &dev->v4l2_dev;
  struct rkisp_stream *stream;
  u32 packet_err = PACKET_ERR_F_BNDRY_MATCG | PACKET_ERR_F_SEQ |
    PACKET_ERR_FRAME_DATA | PACKET_ERR_ECC_1BIT |
    PACKET_ERR_ECC_2BIT | PACKET_ERR_CHECKSUM;
  u32 state_err = RAW_WR_SIZE_ERR | RAW_RD_SIZE_ERR;
  int i, id;
  v4l2_dbg(3, rkisp_debug, &dev->v4l2_dev,
     "csi state:0x%x\n", state);
  dev->csi_dev.irq_cnt++;
  if (phy && (dev->isp_inp & INP_CSI) &&
      dev->csi_dev.err_cnt++ < RKISP_CONTI_ERR_MAX)
    v4l2_warn(v4l2_dev, "MIPI error: phy: 0x%08x\n", phy);
  if ((packet & packet_err) && (dev->isp_inp & INP_CSI) &&
      dev->csi_dev.err_cnt < RKISP_CONTI_ERR_MAX) {
    if (packet & 0xfff)
      dev->csi_dev.err_cnt++;
    v4l2_warn(v4l2_dev, "MIPI error: packet: 0x%08x\n", packet);
  if (overflow && dev->csi_dev.err_cnt++ < RKISP_CONTI_ERR_MAX)
    v4l2_warn(v4l2_dev, "MIPI error: overflow: 0x%08x\n", overflow);
  if (state & state_err)
    v4l2_warn(v4l2_dev, "MIPI error: size: 0x%08x\n", state);
  if (state & ISP21_MIPI_DROP_FRM)
    v4l2_warn(v4l2_dev, "MIPI drop frame\n");
  /* first Y_STATE irq as csi sof event */
  if (state & (RAW0_Y_STATE | RAW1_Y_STATE)) {
    for (i = 0; i < HDR_DMA_MAX - 1; i++) {
      if (!((RAW0_Y_STATE << i) & state) ||
          dev->csi_dev.tx_first[i])
        continue;
      dev->csi_dev.tx_first[i] = true;
      id = i ? 2 : 0;
      rkisp_csi_sof(dev, id);
      stream = &dev->cap_dev.stream[id + RKISP_STREAM_DMATX0];
      atomic_inc(&stream->sequence);
  if (state & (RAW0_WR_FRAME | RAW1_WR_FRAME)) {
    dev->csi_dev.err_cnt = 0;
      if (!((RAW0_WR_FRAME << i) & state))
        continue;
      if (!dev->csi_dev.tx_first[i]) {
        id = i ? RKISP_STREAM_DMATX2 : RKISP_STREAM_DMATX0;
        stream = &dev->cap_dev.stream[id];
      dev->csi_dev.tx_first[i] = false;
  if (state & ISP21_RAW3_WR_FRAME) {
    stream = &dev->cap_dev.stream[RKISP_STREAM_DMATX3];
  if (dev->csi_dev.err_cnt > RKISP_CONTI_ERR_MAX) {
    if (!(dev->isp_state & ISP_MIPI_ERROR)) {
      dev->isp_state |= ISP_MIPI_ERROR;
      rkisp_write(dev, CSI2RX_MASK_PHY, 0, true);
      rkisp_write(dev, CSI2RX_MASK_PACKET, 0, true);
      rkisp_write(dev, CSI2RX_MASK_OVERFLOW, 0, true);
      if (dev->hw_dev->monitor.is_en) {
        if (!completion_done(&dev->hw_dev->monitor.cmpl))
          complete(&dev->hw_dev->monitor.cmpl);
        dev->hw_dev->monitor.state |= ISP_MIPI_ERROR;
full_kernel_log.zip
26.01 KB, Down times: 0
Posted at 9/18/2025 11:18:25        Only Author  2#
The program is really engaging with valuable formulas. Research and completely easy to share and bring a lot of new product building designs. Geometry Dash Lite is not simply a jumping game over obstacles, but a whole world of brilliant geometry waiting for you to explore. Your geometry dash lite task is to control the character to overcome consecutive platforms, avoiding hitting spike traps or dangerous blocks.
Posted at 12/24/2025 04:27:05        Only Author  3#
Hey, Ive been eyeing a new laptop for a while but saving up was taking longer than expected. A buddy of mine mentioned big bass and I figured Id try it out. I started with a small bet, but after a few losses, I took a bigger risk and hit a nice win! The bonuses for players from the United Kingdom were definitely a sweet bonus. If you're looking for a bit of fun and maybe some extra funds, it might be worth checking out.
Posted at 1/10/2026 07:46:22        Only Author  4#
This article is exceptional in every way, Im so thankful for your share. Good luck! Here are the free Testking Arch-301 learning materials materials for you.
