[General] Latest HPE7-A02 Test Pdf & HPE7-A02 Reliable Test Syllabus
101
【General】 Latest HPE7-A02 Test Pdf & HPE7-A02 Reliable Test Syllabus
Posted at 1/27/2026 10:44:11      View:105 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that PracticeTorrent HPE7-A02 dumps now are free: https://drive.google.com/open?id=1-tKciiwTWW9BhF0uelfSv-2TUudlcntR
With our HPE7-A02 test engine, you can practice until you get right. With the options to highlight missed questions, you can analysis your mistakes and know your weakness in the HPE7-A02 exam test. The intelligence of the HPE7-A02 test engine has inspired the enthusiastic for the study. In order to save your time and energy, you can install HPE7-A02 Test Engine on your phone or i-pad, so that you can study in your spare time. You will get a good score with high efficiency with the help of HPE7-A02 practice training tools.
You will identify both your strengths and shortcomings when you utilize PracticeTorrent HP HPE7-A02 practice exam software. You will also face your doubts and apprehensions related to the HP HPE7-A02 exam. Our Aruba Certified Network Security Professional Exam (HPE7-A02) practice test software is the most distinguished source for the HP HPE7-A02 exam all over the world because it facilitates your practice in the practical form of the HP HPE7-A02 certification exam.
HPE7-A02 Reliable Test Syllabus, HPE7-A02 Valid Test SampleAfter taking a bird's eye view of applicants' issues, PracticeTorrent has decided to provide them with the real HPE7-A02 Questions. These HPE7-A02 dumps pdf is according to the new and updated syllabus so they can prepare for HPE7-A02 certification anywhere, anytime, with ease. A team of professionals has made the product of PracticeTorrent after much hard work with their complete potential so the candidates can prepare for Aruba Certified Network Security Professional Exam (HPE7-A02) practice test in a short time.
HP Aruba Certified Network Security Professional Exam Sample Questions (Q107-Q112):NEW QUESTION # 107
A company is using HPE Aruba Networking ClearPass Device Insight (CPDI) (the standalone application).
You have identified a device, which is currently
classified as one type, but you want to classify it as a custom type. You also want to classify all devices with similar attributes as this type, both already-discovered devices and new devices discovered later.
What should you do?
  • A. In the device details, select reclassify, create a user rule based on its attributes, and choose "Save & Reclassify."
  • B. Create a user rule from the Generic Devices page, select the desired attributes for the rule, and choose
    "Save."
  • C. Create a user tag from the Generic Devices page, select the desired attributes for the tag, and save the tag.
  • D. In the device details, select filter, create a user tag based on the device attributes, and save the tag.
When using HPE Aruba Networking ClearPass Device Insight (CPDI) and you need to reclassify a device to a custom type and apply this classification to all devices with similar attributes, both already discovered and newly discovered, you should follow these steps:
1.Navigate to the device details in CPDI.
2.Select the option to reclassify the device.
3.Create a user rule based on the desired attributes of the device.
4.Choose the "Save & Reclassify" option.
This process ensures that the device is reclassified according to the new custom type and that the rule is applied to all existing and future devices with matching attributes, maintaining consistent classification across the network.
Reference: The ClearPass Device Insight user guide includes detailed instructions on device classification, rule creation, and managing device attributes to maintain accurate network visibility and security.
NEW QUESTION # 108
A company is using HPE Aruba Networking Central SD-WAN Orchestrator to establish a hub-spoke VPN between branch gateways (BGWs) at 1164 site and VPNCs at multiple data centers. What is part of the configuration that admins need to complete?
  • A. In VPNCs' groups, establish VPN pools to control which branches connect to which VPNCs.
  • B. At the global level, create default IPsec policies for the SD-WAN Orchestrator to use.
  • C. In BGWs' groups, select the VPNCs to which to connect in a DC preference list.
  • D. In BGWs' and VPNCs' groups, create default IKE policies for the SD-WAN Orchestrator to use.
* Hub-Spoke VPN Configuration:
* HPE Aruba Central SD-WAN Orchestrator enables hub-spoke topology where branch gateways (BGWs) connect to VPN concentrators (VPNCs) located at data centers.
* A key step in configuring this is defining which VPNCs the BGWs will prefer for connectivity.
* The DC Preference List is configured in the BGW groups to prioritize the data centers to which BGWs connect.
* Option Analysis:
* Option A: Incorrect. VPN pools control IP allocation, not which branches connect to VPNCs.
* Option B: Incorrect. IKE policies define key exchange mechanisms but are not part of the connection preference process.
* Option C: Correct. Admins configure a DC preference list in BGW groups to determine connectivity priorities with VPNCs.
* Option D: Incorrect. IPsec policies define encryption parameters at a global level, but this is not specific to the hub-spoke connection configuration.
NEW QUESTION # 109
You have configured an AOS-CX switch to implement 802.1X on edge ports. Assume ports operate in the default auth-mode. VolP phones are assigned to the
"voice" role and need to send traffic that is tagged for VLAN 12.
Where should you configure VLAN 12?
  • A. As the trunk native VLAN in the "voice" role (and not in the edge port settings)
  • B. As a trunk allowed VLAN on edge ports and the trunk native VLAN in the "voice" role
  • C. As the trunk native VLAN on edge ports and the trunk native VLAN on the "voice" role
  • D. As the allowed trunk VLAN in the "voice" role (and not in the edge port settings)
When configuring 802.1X authentication on edge ports of an AOS-CX switch and assigning VoIP phones to a "voice" role, the correct approach is to configure VLAN 12 as the allowed trunk VLAN in the "voice" role.
This setup ensures that traffic tagged for VLAN 12 is appropriately managed by the role applied to the VoIP phones. In AOS-CX switches, the role-based VLAN configuration allows for more granular control and ensures that the VoIP phones' traffic is handled correctly without altering the edge port settings, which typically operate with default settings for authentication.
NEW QUESTION # 110
You are setting up user-based tunneling (UBT) between access layer AOS-CX switches and AOS-10 gateways. You have selected reserved (local) VLAN mode.
Tunneled devices include IoT devices, which should be assigned to:
* Roles: iot on the switches and iot-wired on the gateways
* VLAN: 64, for which the gateways route traffic.
IoT devices connect to the access layer switches' edge ports, and the access layer switches reach the gateways on their uplinks.
Where must you configure VLAN 64?
  • A. In the iot-wired role and the access switch uplinks
  • B. In the iot role and the access switch uplinks
  • C. In the iot role and the iot-wired role and on no physical interfaces
  • D. In the iot-wired role and on no physical interfaces
Comprehensive Detailed Explanation
In a user-based tunneling (UBT) setup with reserved VLAN mode, VLAN 64 is used for routing traffic at the gateways. Since the IoT traffic is tunneled to the AOS-10 gateway:
* On the gateways:
* VLAN 64 must be configured in the iot-wired role for routing purposes.
* On the switches:
* VLAN 64 does not need to be configured on the access switch physical uplinks because the IoT traffic is tunneled directly to the gateway and does not rely on VLAN configurations at the access layer switches.
* Reserved VLAN mode:
* Ensures that traffic is encapsulated within the UBT tunnel, and VLANs like 64 are only relevant at the gateway for routing and enforcement.
Therefore, the correct configuration is to define VLAN 64 in the iot-wired role on the AOS-10 gateways and not on any physical interfaces.
References
* Aruba AOS-CX UBT configuration guide.
* Aruba AOS-10 Gateway Role and VLAN Management documentation.
NEW QUESTION # 111
(Note that the HPE Aruba Networking Central interface shown here might look slightly different from what you see in your HPE Aruba Networking Central interface as versions change; however, similar concepts continue to apply.) An HPE Aruba Networking 9x00 gateway is part of an HPE Aruba Networking Central group that has the settings shown in the exhibit. What would cause the gateway to drop traffic as part of its IDPS settings?
  • A. Traffic showing anomalous behavior
  • B. Traffic matching a rule in the active ruleset
  • C. Its IDPS engine failing
  • D. Its site-to-site VPN connections failing
In the exhibit, the HPE Aruba Networking Central settings for the 9x00 gateway show that traffic inspection is enabled, and the gateway is set to operate in IDS (Intrusion Detection System) mode with the fail strategy set to "Block". This configuration means that the gateway will drop traffic if it matches a rule in the active ruleset.
1.Active Ruleset: The ruleset version 9861 is active, and the gateway is configured to automatically update the ruleset daily.
2.Traffic Matching Rules: When traffic matches a rule in the active ruleset, it is flagged as suspicious or malicious.
3.Block Mode: Since the fail strategy is set to "Block", any traffic that matches a rule in the active ruleset will be dropped to prevent potential threats.
Reference: The documentation for HPE Aruba Networking Central and gateway IDS/IPS configuration provides detailed information on how traffic is inspected and the implications of different fail strategies, including blocking traffic that matches the active ruleset.
NEW QUESTION # 112
For further and better consolidation of your learning on our HPE7-A02 exam questions, our company offers an interactive test engine-Software test engine. And this version is also popular for the advantage of silulating the real HPE7-A02 exam. Please pay attention to the point that the Software version of our HPE7-A02 praparation guide can only apply in the Windows system. When you are practicing with it, you will find that every time you finished the exam, the exam scores will come out.
HPE7-A02 Reliable Test Syllabus: https://www.practicetorrent.com/HPE7-A02-practice-exam-torrent.html
Besides, HPE7-A02 test engine is customizable and advanced which creates a real exam simulation environment to prepare for your success, In addition, after the purchase, the candidate will be entitled to a one-year free update, which will help the candidate keep the latest news feeds, and will not leave any opportunity that may lead them to fail the HPE7-A02 Guaranteed Questions Answers exam, We believe that you will benefit a lot from it if you buy our HPE7-A02 study materials and pass the HPE7-A02 exam easily.
There are two types of formatting that can be applied to selected text: character HPE7-A02 and paragraph, While there haven't been precisely similar studies done comparing male and female names, there is plenty of anecdotal evidence.
Latest HPE7-A02 Test Pdf | Professional HP HPE7-A02 Reliable Test Syllabus: Aruba Certified Network Security Professional ExamBesides, HPE7-A02 Test Engine is customizable and advanced which creates a real exam simulation environment to prepare for your success, In addition, after the purchase, the candidate will be entitled to a one-year free update, which will help the candidate keep the latest news feeds, and will not leave any opportunity that may lead them to fail the HPE7-A02 Guaranteed Questions Answers exam.
We believe that you will benefit a lot from it if you buy our HPE7-A02 study materials and pass the HPE7-A02 exam easily, We check the HP ACNSP HPE7-A02 actual prep exam every day to confirm there is updated information or not.
HPE7-A02 practice materials guarantee you an absolutely safe environment.
DOWNLOAD the newest PracticeTorrent HPE7-A02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-tKciiwTWW9BhF0uelfSv-2TUudlcntR
