[General] New Salesforce Mule-Dev-202 Exam Discount - Detailed Mule-Dev-202 Study Dumps
87
【General】 New Salesforce Mule-Dev-202 Exam Discount - Detailed Mule-Dev-202 Study Dumps
Posted at 1/27/2026 11:10:25      View:118 | Replies:2        Print      Only Author   [Copy Link] 1#
You don't need to worry about wasting your precious time but failing to get the Mule-Dev-202 certification. Many people have used our Mule-Dev-202 study materials and the pass rate of the exam is 99%. If any incident happens and you don't pass the Mule-Dev-202 exam, we will give you a full refund. Our sincerity stems are from the good quality of our products. We will give you one year's free update of the exam study materials you purchase and 24/7 online service. Now just make up your mind and get your Mule-Dev-202 Exam Torrent!
In order to meet the different demands of the different customers, these experts from our company have designed three different versions of the Mule-Dev-202 reference guide. All customers have the right to choose the most suitable version according to their need. The PDF version of the Mule-Dev-202 exam prep has many special functions, including download the demo for free, support the printable format and so on. We can make sure that the PDF version of the Mule-Dev-202 Test Questions will be very convenient for all people. Of course, if you choose our Mule-Dev-202 study materials, you will love it.
Detailed Mule-Dev-202 Study Dumps - Mule-Dev-202 Lab QuestionsThere are some prominent features that are making the Mule-Dev-202 exam dumps the first choice of Mule-Dev-202 certification exam candidates. The prominent features are real and verified Salesforce Certified MuleSoft Hyperautomation Developer exam questions, availability of Mule-Dev-202 exam dumps in three different formats, affordable price, 1 year free updated Mule-Dev-202 Exam Questions download facility, and 100 percent Salesforce Mule-Dev-202 exam passing money back guarantee. We are quite confident that all these Mule-Dev-202 exam dumps feature you will not find anywhere. Just download the Salesforce Mule-Dev-202 Certification Exams and start this journey right now.
Salesforce Certified MuleSoft Hyperautomation Developer Sample Questions (Q61-Q66):NEW QUESTION # 61
Northern Trail Outfitters must create a near real-time inventory API that can be used within its retail POS systems, across its mobile and online stores, and by its strategic B2B e-commerce partners. The API must provide accurate and up-to-date product inventory levels. The data currently resides in both SAP and NetSuite.
According to best practices, which hyperautomation tool should be used to build this solution?
  • A. Salesforce Flow
  • B. Anypoint Platform
  • C. MuleSoft Composer
  • D. MuleSoft RPA
To create a near real-time inventory API that integrates data from SAP and NetSuite and can be used across various platforms and partners, the Anypoint Platform is the most suitable tool:
Anypoint Platform:
Anypoint Platform provides comprehensive integration capabilities, including real-time data processing, API management, and connectivity to various systems like SAP and NetSuite.
It supports building robust, scalable APIs that can handle near real-time data synchronization, ensuring accurate and up-to-date inventory levels across multiple channels.
Best Practices:
Using Anypoint Platform, you can design and manage APIs with fine-grained control over security, performance, and monitoring, adhering to best practices for enterprise integration.
Anypoint Platform Documentation
NEW QUESTION # 62
A Salesforce admin for AnyAirlines constructs a MuleSoft Composer flow that retrieves a record based on a unique ID using the Get Records action from a Salesforce connector. They will use the result to send a Slack message.
How can they achieve this task?
  • A. 1. Add a For Each loop after the Salesforce action step iterating over the collection of Salesforce records.2. Use a Slack action step to construct the messages from the record being processed.
  • B. 1. Add a Slack action step after the Salesforce action step.2. Use the first record from the collection of Salesforce records to construct the message.
  • C. 1. Add a Slack action step after the Salesforce action step.2. Use the record to construct the message.
  • D. 1. Add an If/Else Block after the Salesforce action step, which contains a branch checking if the Salesforce action step returned exactly one record.2. In the branch, add a Slack action step and use the record to construct the message.
Salesforce Action Step:Start by adding a Salesforce action step that uses the Get Records action to retrieve the record based on a unique ID. This action retrieves the specific record needed.
Reference:MuleSoft Composer Salesforce Connector
Add Slack Action Step:After retrieving the record, add a Slack action step. This step will be used to send the message to Slack.
Reference:MuleSoft Composer Slack Connector
Use the Record:Use the retrieved record directly to construct the message in the Slack action step. This ensures the message contains the relevant information from the Salesforce record.
Reference:Building Messages in Composer
No Need for Collection Handling:Since the Get Records action retrieves a single record based on a unique ID, there is no need to handle collections or iterate through records.
Reference:Get Records Action
NEW QUESTION # 63
An RPA process is invoked by a MuleSoft Composer flow. The RPA process has a User Task that can take up to 24 hours to complete.
  • A. Wait for the RPA process to complete and invoke a second MuleSoft Composer flow via REST API.
  • B. Create a second MuleSoft Composer flow that starts when the RPA process is complete.
  • C. Create a second MuleSoft Composer flow that runs on a schedule and checks if the RPA process is complete.
  • D. Wait for the RPA process to complete and use the results in the same MuleSoft Composer flow.
  • E. Using best practices, how should the results be consumed by MuleSoft Composer?
When an RPA process involves a User Task that can take a significant amount of time (up to 24 hours) to complete, it is best to use a follow-up mechanism to handle the results once the process is finished:
Second MuleSoft Composer Flow:
Create a second MuleSoft Composer flow that is triggered when the RPA process completes. This ensures that the first flow is not held up while waiting for the long-running RPA process to finish.
The second flow can start based on an event, such as the completion status of the RPA process, ensuring timely and efficient processing of the results.
Trigger Mechanism:
Configure the RPA process to notify MuleSoft Composer when it is complete, possibly using a REST API or another integration method.
Best Practices:
This approach adheres to best practices by keeping flows modular and focused on specific tasks, making them easier to manage and troubleshoot.
MuleSoft Composer Documentation
MuleSoft RPA Documentation
NEW QUESTION # 64
An AnyAirlines employee determines that an RPA process is a strong candidate for automation. When approving the process, the employee needs to specify a group of potential users to manage the RPA process throughout its lifecycle.
According to best practices, which group should the employee choose?
  • A. Center of Excellence
  • B. Center for Enablement
  • C. Scrum team
  • D. Multiple project managers
When approving an RPA process and specifying a group of potential users to manage it throughout its lifecycle, the best practice is to choose the Center of Excellence (CoE):
The CoE is a team of experts who are responsible for overseeing the implementation, governance, and management of RPA processes within the organization.
They ensure that best practices are followed, provide guidance and support to project teams, and manage the overall RPA strategy and roadmap.
Lifecycle Management:
The CoE is well-equipped to manage the RPA process from initial development through deployment and ongoing maintenance. They have the expertise to handle any issues that arise and ensure the process remains efficient and effective.
Best Practices:
By involving the CoE, the organization ensures that the RPA process adheres to established best practices, maintains high quality, and delivers the expected benefits.
RPA Center of Excellence Best Practices
NEW QUESTION # 65
Northern Trail Outfitters developed an integration between its two Salesforce orgs using MuleSoft Composer.
Which two actions should be taken before testing the Composer flow? (Choose two.)
  • A. Ensure the credentials to the target production org are still valid.
  • B. Ensure action steps are connected to a sandbox instance of Salesforce.
  • C. Ensure the flow trigger is connected to a sandbox instance of Salesforce.
  • D. Ensure MuleSoft Composer is installed on both the source and target orgs.
NEW QUESTION # 66
The Salesforce Mule-Dev-202 exam questions are the ideal and recommended study material for quick and easiest Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) exam dumps preparation. The Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) practice questions are designed and verified by qualified and renowned Salesforce Certification Exams trainers. They work closely and check all Mule-Dev-202 Exam Dumps step by step. They also ensure the best possible answer for all Mule-Dev-202 exam questions and strive hard to maintain the top standard of Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) exam dumps all the time.
Detailed Mule-Dev-202 Study Dumps: https://www.examslabs.com/Salesforce/Salesforce-MuleSoft/best-Mule-Dev-202-exam-dumps.html
Salesforce New Mule-Dev-202 Exam Discount Are you stuck by the aimless study plan and cannot make full use of sporadic time, The experts in our company are always keeping a close eye on even the slightest change on the Mule-Dev-202 exam questions in the field, You can avail these Salesforce Mule-Dev-202 changes for free up to 90 days, We provide you with our best Salesforce Mule-Dev-202 exam study material, which builds your ability to get high-paying jobs.
The widget can be shrunk to its minimum size hint, Source the products, which Mule-Dev-202 means getting the best possible deal from all the possible vendors, Are you stuck by the aimless study plan and cannot make full use of sporadic time?
Perfect New Mule-Dev-202 Exam Discount & Leading Offer in Qualification Exams & Fantastic Salesforce Salesforce Certified MuleSoft Hyperautomation DeveloperThe experts in our company are always keeping a close eye on even the slightest change on the Mule-Dev-202 Exam Questions in the field, You can avail these Salesforce Mule-Dev-202 changes for free up to 90 days.
We provide you with our best Salesforce Mule-Dev-202 exam study material, which builds your ability to get high-paying jobs, Secondly, our Mule-Dev-202 exam questions will spare no effort to perfect after-sales services.
Posted at 2/14/2026 16:27:23        Only Author  2#
What a fantastic and inspiring article, thanks for sharing! AP-222 interactive practice exam offers a wealth of content and is available for free, hoping it assists you.
Posted at 2/16/2026 12:07:58        Only Author  3#
Thank you for sharing, this article really left a deep impression on me! These Arch-302 certification cost questions were the reason for my success, and now I’m offering them to you for free!
