[Hardware] 最受推薦的CloudSec-Pro認證指南,真實還原Palo Alto Networks CloudSec-Pro考試內容
98
【Hardware】 最受推薦的CloudSec-Pro認證指南,真實還原Palo Alto Networks CloudSec-Pro考試內容
Posted at 1/27/2026 12:21:52      View:354 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 PDFExamDumps最新的CloudSec-Pro PDF版考試題庫和CloudSec-Pro考試問題和答案免費分享:https://drive.google.com/open?id=1B4C8XdQJKG-3bBwR2f0NfEE8MAbl7L7u
在談到CloudSec-Pro考試認證,很難忽視的是可靠性,PDFExamDumps的CloudSec-Pro考試培訓資料是特別設計,以最大限度的提高你的工作效率,本站在全球範圍內執行這項考試通過率最大化。
PDFExamDumps就是一個能成就很多IT專業人士夢想的網站。如果你有IT夢,就趕緊來PDFExamDumps吧,它有超級好培訓資料即PDFExamDumps Palo Alto Networks的CloudSec-Pro考試培訓資料, 這個培訓資料是每個IT人士都非常渴望的,因為它會讓你通過考試獲得認證,從此以後在職業道路上步步高升。
100%有保障的CloudSec-Pro認證指南,最好的學習資料幫助妳快速通過CloudSec-Pro考試如果你參加Palo Alto Networks CloudSec-Pro認證考試,你選擇PDFExamDumps就是選擇成功!祝你好運。
最新的 Cloud Security Engineer CloudSec-Pro 免費考試真題 (Q149-Q154):問題 #149
A user from an organization is unable to log in to Prisma Cloud Console after having logged in the previous day.
Which area on the Console will provide input on this issue?
  • A. SSO
  • B. Audit Logs
  • C. Access Control
  • D. Users & Groups
答案:B
解題說明:
In the event a user is unable to log in to the Prisma Cloud Console, Audit Logs serve as a critical area for investigating the issue. Audit Logs provide a detailed record of activities, including login attempts, within the Prisma Cloud environment. By examining the Audit Logs, administrators can identify failed login attempts, understand the reasons behind login failures (e.g., incorrect credentials, account lockouts, or access policy changes), and take appropriate actions to resolve the login issues, ensuring users can access the console as expected.
問題 #150
Which step should a SecOps engineer implement in order to create a network exposure policy that identifies instances accessible from any untrusted internet sources?
  • A. In Policy Section-> Add Policy-> Network type -> Define Policy details Like Name.Severity-> Configure RQL query "config from network where source.network = UNTRUSTJNTERNET and dest.resource.type = 'Instance' and dest.cloud.type = 'AWS'" -> Define recommendation for remediation & save.
  • B. In Policy Section-> Add Policy-> Network type -> Define Policy details Like Name.Severity-> Configure RQL query "network from vpc.flow_record where source.publicnetwork IN ('Suspicious IPs', 'Internet IPs') and dest.resource IN (resource where role IN ('Instance ))" -> define compliance standard -> Define recommendation for remediation & save.
  • C. In Policy Section-> Add Policy-> Network type -> Define Policy details Like Name.Severity-> Configure RQL query "network from vpc.flow_record where source.publicnetwork IN ('Suspicious IPs', 'Internet IPs') and dest.resource IN (resource where role IN ( Instance ))" -> define compliance standard -> Define recommendation for remediation & save.
  • D. In Policy Section-> Add Policy-> Config type -> Define Policy details Like Name,Severity-> Configure RQL query "config from network where source.network = UNTRUSTJNTERNET and dest.
    resource.type = 'Instance' and dest.cloud.type = 'AWS*" -> define compliance standard -> Define recommendation for remediation & save.
答案:D
解題說明:
To create a network exposure policy that identifies instances accessible from any untrusted internet sources, a SecOps engineer would need to navigate to the Policy section within Prisma Cloud and add a new policy of the Config type. They would define the details of the policy such as the name and severity level and then configure the RQL query to specify conditions that match instances accessible from untrusted internet sources. The RQL query provided in the answer specifies that the source of the network traffic should be from an untrusted internet and that the destination resource should be an instance in the AWS cloud. After defining the compliance standards and providing recommendations for remediation, the policy can be saved to be enforced within the environment.
問題 #151
What will happen when a Prisma Cloud Administrator has configured agentless scanning in an environment that also has Host and Container Defenders deployed?
  • A. Agentless scans do not conflict with Defender scans, so both will run.
  • B. Agentless scan will automatically be disabled, so Defender scans are the only scans occurring.
  • C. Defender scans will automatically be disabled, so agentless scans are the only scans occurring.
  • D. Both agentless and Defender scans will be disabled and an error message will be received.
答案:A
解題說明:
In a Prisma Cloud environment where both agentless scanning and Defender-based scans (Host and Container Defenders) are configured, there is no inherent conflict between these two scanning methods. Both agentless scans and Defender scans are designed to complement each other, providing comprehensive coverage and depth in the security analysis of the environment. Agentless scans offer a broad, less intrusive overview, while Defender scans provide deep, detailed insights into the security posture. Therefore, both types of scans will run concurrently, enhancing the overall security visibility and protection of the environment without disabling or interfering with each other's operations.
The agentless scanning architecture lets you inspect a host and the container images in that host without having to install an agent or affecting its execution. https://docs.paloaltonetworks.com/prisma/prisma-cloud
/prisma-cloud-admin-compute/agentless-scanning/onboard-accounts
問題 #152
Which three steps are involved in onboarding an account for Data Security? (Choose three.)
  • A. Enter the RoleARN and SNSARN
  • B. Enable Flow Logs
  • C. Create a read-only role with in-line policies
  • D. Create a Cloudtrail with SNS Topic
  • E. Create a S3 bucket
答案:A,D,E
解題說明:
Onboarding an account for Data Security involves several critical steps to ensure comprehensive coverage and effective monitoring. The steps involved include B. Create a Cloudtrail with SNS Topic to track and manage API calls and relevant notifications, D. Enter the RoleARN and SNSARN to provide necessary access and integration points for data security functions, and E. Create a S3 bucket which serves as a storage solution for logging and data capture essential for security analysis.
問題 #153
What are two key requirements for integrating Okta with Prisma Cloud when multiple Amazon Web Services (AWS) cloud accounts are being used? (Choose two.)
  • A. A valid subscription for the IAM security module
  • B. Super Administrator permissions
  • C. An Okta API token for the primary AWS account
  • D. Multiple instances of the Okta app
答案:A,D
解題說明:
https://docs.paloaltonetworks.co ... -cloud-iam-security
/integrate-prisma-cloud-with-okta
問題 #154
為了每位IT認證考試的考生切身利益,我們網站提供PDFExamDumps Palo Alto Networks的CloudSec-Pro考試培訓資料是根據考生的需要而定做的,由我們PDFExamDumps資質深厚的IT專家專門研究出來的,他們的奮鬥結果不僅僅是為了幫助你們通過考試,而且是為了讓你們有一個更好的明天。
最新CloudSec-Pro考題: https://www.pdfexamdumps.com/CloudSec-Pro_valid-braindumps.html
PDFExamDumps確保廣大考生獲得最好和最新的Palo Alto Networks CloudSec-Pro題庫學習資料,您可以隨時隨地的訪問我們網站尋找您需要的考古題,根據過去的考試練習題和答案的研究,PDFExamDumps能有效的捕捉Palo Alto Networks CloudSec-Pro考古題 認證考試試題內容,當你成功購買了 CloudSec-Pro 考古題,如果官方改變了考試的大綱,我們會立即通知客戶,軟體版本的 CloudSec-Pro 考試題庫作為一個測試引擎,可以幫助你隨時測試自己的準備情況,如果在這期間,CloudSec-Pro的考試知識點發生變動,我們會在第壹時間更新相關題庫學習資料,並免費提供給您更新下載,目前PDFExamDumps 最新CloudSec-Pro考題 Palo Alto Networks 最新CloudSec-Pro考題證照可以區分成資料庫管理與企業資源規劃兩部份,Palo Alto Networks CloudSec-Pro認證指南 有的人說那我多讀書多看書不就好了嗎?
烏依古爾那裏妳就不要再接觸了,老頭圍繞著海岬獸不停打轉著嘴裏不停的嘀咕:好東西啊,PDFExamDumps確保廣大考生獲得最好和最新的Palo Alto Networks CloudSec-Pro題庫學習資料,您可以隨時隨地的訪問我們網站尋找您需要的考古題。
真實的CloudSec-Pro認證指南&保證Palo Alto Networks CloudSec-Pro考試成功與頂級的最新CloudSec-Pro考題根據過去的考試練習題和答案的研究,PDFExamDumps能有效的捕捉Palo Alto Networks CloudSec-Pro考古題 認證考試試題內容,當你成功購買了 CloudSec-Pro 考古題,如果官方改變了考試的大綱,我們會立即通知客戶,軟體版本的 CloudSec-Pro 考試題庫作為一個測試引擎,可以幫助你隨時測試自己的準備情況。
如果在這期間,CloudSec-Pro的考試知識點發生變動,我們會在第壹時間更新相關題庫學習資料,並免費提供給您更新下載。
Posted at 1/28/2026 16:06:36        Only Author  2#
The content of the article is thought-provoking, and I’ve learned a lot from it. The ISO-IEC-27001-Lead-Auditor latest exam simulator free exam was the key to my career success—now, I’m giving it away for free!
Posted at 2/13/2026 06:55:07        Only Author  3#
No hesitation, just hitting like for this great content. Sharpen your IT skills by accessing free Terraform-Associate-003 latest test questions vce. Wishing you all the best!
Posted at 2/24/2026 00:44:17        Only Author  4#
Truly a magnificent read, thank you for this wonderful share. Get your free Valid dumps C_BCFIN_2502 book questions now! Wishing everyone success in their exams!
