[General] NSE5_FNC_AD_7.6 Test Question | NSE5_FNC_AD_7.6 Latest Test Testking
102
【General】 NSE5_FNC_AD_7.6 Test Question | NSE5_FNC_AD_7.6 Latest Test Testking
Posted at 1/27/2026 14:58:35      View:113 | Replies:1        Print      Only Author   [Copy Link] 1#
One of the advantages of taking the Dumpcollection Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) practice exam (desktop and web-based) is that it helps applicants to focus on their weak areas. It also helps applicants to track their progress and make improvements. Fortinet NSE5_FNC_AD_7.6 Practice Exams are particularly helpful in identifying areas where one needs more practice.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:
  • Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
  • Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
  • Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
  • Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
Dumpcollection Fortinet NSE5_FNC_AD_7.6 Real Questions Come In Three Different FormatsDumpcollection informs you that the Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) questions regularly change the content of the Fortinet NSE 5 - FortiNAC-F 7.6 Administrator real exam. Therefore, you must stay informed as per these changes to save time, money, and mental peace. As was already discussed, Dumpcollection satisfies the needs of Fortinet NSE5_FNC_AD_7.6 Exam candidates. The customer will receive updates of Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) real dumps for up to 365 days after buying the product.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q32-Q37):NEW QUESTION # 32
When configuring FortiNAC-F to manage FortiGate VPN users, an endpoint compliance policy must be created for the integration.
Why is the endpoint compliance policy necessary for this type of integration?
  • A. To validate the VPN client being used
  • B. To validate the VPN user credentials
  • C. To designate the required agent type
  • D. To confirm the installed endpoint certificate
The integration of FortiNAC-F with FortiGate VPN requires a specific policy workflow to bridge the gap between initial user authentication and full network access. When a user connects to the VPN, the FortiGate typically provides the User ID and IP address, but FortiNAC-F requires a MAC address to uniquely identify and manage the endpoint's record.
According to the FortiGate VPN Integration Guide, the Endpoint Compliance Policy is a mandatory component of this setup because it is used to designate the required agent type. Because a VPN connection is Layer 3, FortiNAC cannot "see" the MAC address through traditional SNMP or L2 polling. The compliance policy instructs the system to present a Captive Portal to the remote user, requiring them to download and run either the Persistent or Dissolvable Agent. The agent then reports the device's MAC address back to FortiNAC, allowing the system to correlate the VPN session with a host record.
Once the agent is running and the MAC is known, FortiNAC-F can evaluate the device's security posture (if scanning is configured) and send the necessary FSSO tags back to the FortiGate to lift the initial network restrictions. Without the compliance policy to enforce the agent requirement, the connection would remain in an isolated "IP-only" state with no unique hardware identity.
"The Endpoint Compliance Policy is necessary to control the agent requirement for VPN users. Create a default VPN Endpoint Compliance Policy to distribute an agent via captive portal for isolated machines. This policy allows the administrator to designate the required agent type (Persistent or Dissolvable) that will be used to collect the hardware (MAC) address and perform health scans on the remote endpoint." - FortiNAC FortiGate VPN Integration Guide: Default Endpoint Compliance Policy (Optional) Section.
NEW QUESTION # 33
While deploying FortiNAC-F devices in a 1+1 HA configuration, the administrator has chosen to use the shared IP address option.
Which condition must be met for this type of deployment?
  • A. The isolation network type is layer 3.
  • B. The isolation network type is Layer 2.
  • C. There is a direct cable link between FortiNAC-F devices.
  • D. The primary and secondary administrative interfaces are on the same subnet.
In a 1+1 High Availability (HA) deployment, FortiNAC-F supports two primary methods for management access: individual IP addresses or a Shared IP Address (also known as a Virtual IP or VIP). The Shared IP option is part of a Layer 2 HA design, which simplifies administration by providing a single URL or IP that always points to whichever appliance is currently in the "Active" or "In Control" state.
For a Shared IP configuration to function correctly, the Primary and Secondary administrative interfaces (port1) must be on the same subnet. This requirement exists because the Shared IP is a logical address that is dynamically assigned to the physical interface of the active unit. Since only one unit can own the IP at a time, both units must reside on the same broadcast domain (Layer 2) to ensure that ARP requests for the Shared IP are correctly answered and that the gateway remains reachable regardless of which unit is active. If the appliances were on different subnets (a Layer 3 HA design), a shared IP could not be used because it cannot "float" across different network segments; instead, administrators would need to manage each unit via its unique physical IP or use a FortiNAC Manager.
"For L2 HA configurations, click the Use Shared IP Address checkbox and enter the Shared IP Address information... If your Primary and Secondary Servers are not in the same subnet, do not use a shared IP address. The shared IP address moves between appliances during a failover and recovery and requires both units to reside on the same network." - FortiNAC-F High Availability Reference Manual: Shared IP Configuration.
NEW QUESTION # 34
When configuring isolation networks in the configuration wizard, why does a layer 3 network typo allow for mora than ono DHCP scope for each isolation network typo?
  • A. Configuring more than one DHCP scope allows for DHCP server redundancy
  • B. There can be more than one isolation network of each type
  • C. Any scopes beyond the first scope are used if the initial scope runs out of IP addresses.
  • D. The layer 3 network type allows for one scope for each possible host status.
In FortiNAC-F, the Layer 3 Network type is specifically designed for deployments where the isolation networks-such as Registration, Remediation, and Dead End-are separated from the FortiNAC appliance's service interface (port2) by one or more routers. This architecture is common in large, distributed enterprise environments where endpoints in different physical locations or branches must be isolated into subnets that are local to their respective network equipment.
The reason the Configuration Wizard allows for more than one DHCP scope for a single isolation network type (state) is that there can be more than one isolation network of each type across the infrastructure. For instance, if an organization has three different sites, each site might require its own unique Layer 3 registration subnet to ensure efficient routing and to accommodate local IP address management. By allowing multiple scopes for the "Registration" state, FortiNAC can provide the appropriate IP address, gateway, and DNS settings to a rogue host regardless of which site's registration VLAN it is placed into.
When an endpoint is isolated, the network infrastructure (via DHCP Relay/IP Helper) directs the DHCP request to the FortiNAC service interface. FortiNAC then identifies which scope to use based on the incoming request's gateway information. This flexibility ensures that the system is not limited to a single flat subnet for each isolation state, supporting a scalable, multi-routed network topology.
"Multiple scopes are allowed for each isolation state (Registration, Remediation, Dead End, VPN, Authentication, Isolation, and Access Point Management). Within these scopes, multiple ranges in the lease pool are also permitted... This configWizard option is used when Isolation Networks are separated from the FortiNAC Appliance's port2 interface by a router." - FortiNAC-F Configuration Wizard Reference Manual: Layer 3 Network Section.
NEW QUESTION # 35
An administrator manages a corporate environment where all users log into the corporate domain each time they connect to the network. The administrator wants to leverage login scripts to use a FortiNAC-F agent to enhance endpoint visibility Which agent can be deployed as part of a login script?
  • A. Persistent
  • B. Passive
  • C. Mobile
  • D. Dissolvable
In a corporate domain environment where "enhanced endpoint visibility" is required, the Persistent Agent is the recommended choice. Unlike the Dissolvable Agent, which is temporary and intended for one-time compliance scans during registration, the Persistent Agent is an "install-and-stay-resident" application.
The Persistent Agent is specifically designed to be distributed through automated enterprise methods, including login scripts, Group Policy Objects (GPO), or third-party software management tools. When deployed via a login script, the agent can be configured to silently install and immediately begin communicating with the FortiNAC-F service interface. Once active, it provides continuous visibility by reporting host details such as logged-on users, installed applications, and adapter information. It also listens for Windows session events (logon/logoff) to trigger automatic single-sign-on (SSO) registration in FortiNAC-F, ensuring that as soon as a user connects to the domain, their device is identified and assigned the correct network access policy.
"The Persistent Agent can be distributed to Windows domain machines via login script or by any other software distribution method your organization might use. The Persistent Agent remains installed on the host at all times. Once the agent is installed it runs in the background and communicates with FortiNAC at intervals established by the FortiNAC administrator." - FortiNAC-F Administration Guide: Persistent Agent Overview.
NEW QUESTION # 36
A FortiNAC-F N+1 HA configuration is shown.
What will occur if CA-2 fails?
  • A. CA-3 will continue to operate as a secondary in an N+1 HA configuration.
  • B. CA-3 will be promoted to a primary and share management responsibilities with CA-1.
  • C. CA-1 and CA-3 will operate as a 1+1 HA cluster with CA-3 acting as a hot standby.
  • D. CA-3 will be promoted to a primary and FortiNAC-F manager will load balance between CA-1 and CA-3.
In an N+1 High Availability (HA) configuration, a single secondary Control and Application (CA) server provides backup for multiple primary CA servers. The FortiNAC-F Manager (FortiNAC-M) acts as the centralized orchestrator for this cluster, monitoring the health of all participating nodes.
According to the FortiNAC-F 7.6.0 N+1 Failover Reference Manual, when a primary CA (such as CA-2 in the exhibit) fails, the secondary CA (CA-3) is automatically promoted by the Manager to take over the specific workload and database functions of that failed primary. Crucially, the documentation specifies that even after this promotion, the system architecture maintains its N+1 logic. The secondary CA effectively "assumes the identity" of the failed primary while continuing to operate within the N+1 framework established by the Manager.
It does not merge with CA-1 to form a traditional 1+1 active/passive cluster (A), nor does it engage in load balancing (D), as FortiNAC-F HA is designed for redundancy and failover rather than active traffic distribution. Furthermore, CA-3 does not "share" management with CA-1 (C); it independently handles the tasks originally assigned to CA-2. Throughout this failover state, the Manager continues to oversee the group, and CA-3 remains the designated secondary unit currently acting in a primary capacity for the downed node until CA-2 is restored.
"In an N+1 Failover Group, the Secondary CA is designed to take over the functionality of any single failed primary component within the group. The FortiNAC Manager monitors the primaries and initiates the failover to the secondary... Once failover occurs, the secondary continues to operate as the backup unit for the failed primary while remaining part of the managed N+1 HA configuration." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual: Failover Behavior Section.
NEW QUESTION # 37
Dumpcollection gives its customers an opportunity to try its NSE5_FNC_AD_7.6 product with a free demo. If you want to clear the Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) test, then you need to study well with real NSE5_FNC_AD_7.6 exam dumps of Dumpcollection. These NSE5_FNC_AD_7.6 Exam Dumps are trusted and updated. We guarantee that you can easily crack the NSE5_FNC_AD_7.6 test if use our actual Fortinet NSE5_FNC_AD_7.6 dumps.
NSE5_FNC_AD_7.6 Latest Test Testking: https://www.dumpcollection.com/NSE5_FNC_AD_7.6_braindumps.html
Posted at 2/8/2026 08:10:17        Only Author  2#
I appreciate you sharing this motivating article! I used the WRT Popular Exams set to achieve my promotion and pay raise. It’s now free for everyone. Best of luck in your promotions!
