[General] Updated New CCAAK Test Vce Free - How to Study & Well Prepare for Confluent
82
General Updated New CCAAK Test Vce Free - How to Study & Well Prepare for Confluent
Posted at 1/27/2026 16:18:03      View160 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New CCAAK dumps are available on Google Drive shared by Actual4dump: https://drive.google.com/open?id=1aNH6luVeOGs4krkf9ATKOMLQcG8nXDFn
Passing the test CCAAK certification can help you realize your goal and find an ideal job. Buying our CCAAK latest question can help you pass the exam successfully. CCAAK exam question provides the free update and the discounts for the old client and our experts check whether our test bank has been updated on the whole day and if there is the update the system will send the update automatically to the client. Thus you can have an efficient learning and a good preparation of the exam. It is believed that our CCAAK latest question is absolutely good choices for you
Confluent CCAAK Exam Syllabus Topics:
  • Apache Kafka® Fundamentals: This section of the exam measures skills of a Kafka Administrator and covers core concepts such as Kafka architecture, components, and data flow. It assesses the candidates understanding of topics like topics and partitions, brokers, producers, consumers, and message retention.
  • Apache Kafka® Security: This section of the exam measures skills of a Site Reliability Engineer and focuses on securing Kafka environments. It includes authentication mechanisms such as TLS and SASL, authorization using ACLs, and encrypting data at rest and in transit to ensure secure communication and access control.
  • Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
  • Observability: This section of the exam measures skills of a Site Reliability Engineer and focuses on monitoring Kafka clusters. It assesses knowledge of metrics, logging, and alerting tools, including how to use them to maintain cluster health and performance visibility.
Topic 5
  • Kafka Connect: This section of the exam measures skills of a Site Reliability Engineer and addresses the use and management of Kafka Connect for data integration. It includes setting up connectors, managing configurations, and ensuring efficient movement of data between Kafka and external systems.
CCAAK Reliable Exam Pass4sure, CCAAK Cert GuideWe are professional in this career to help all our worthy customers to obtain the CCAAK certification for years. You can get prepared with our CCAAK exam materials only for 20 to 30 hours before you go to attend your exam. we can claim that you will achieve guaranteed success with our CCAAK Study Guide for that our high pass rate is unmarched 98% to 100%. And all the warm feedback from our clients proved our strength, you can totally relay on us with our CCAAK practice quiz!
Confluent Certified Administrator for Apache Kafka Sample Questions (Q45-Q50):NEW QUESTION # 45
What are benefits to gracefully shutting down brokers? (Choose two.)
  • A. It will automatically re-elect leaders on restart.
  • B. It will migrate any partitions the server is the leader for to other replicas prior to shutting down.
  • C. It will sync all its logs to disk to avoid needing to do any log recovery when it restarts.
  • D. It will balance the partitions across brokers before restarting.
A graceful shutdown ensures that logs are flushed to disk, minimizing recovery time during restart.
Kafka performs controlled leader migration during a graceful shutdown to avoid disruption and ensure availability.
NEW QUESTION # 46
An employee in the reporting department needs assistance because their data feed is slowing down. You start by quickly checking the consumer lag for the clients on the data stream.
Which command will allow you to quickly check for lag on the consumers?
  • A. bin/kafka-consumer-group-throughput.sh
  • B. bin/kafka-consumer-groups.sh
  • C. bin/kafka-reassign-partitions.sh
  • D. bin/kafka-consumer-lag.sh
The kafka-consumer-groups.sh script is used to inspect consumer group details, including consumer lag, which indicates how far behind a consumer is from the latest data in the partition.
The typical usage is bin/kafka-consumer-groups.sh --bootstrap-server <broker> --describe --group <group_id>
NEW QUESTION # 47
Which secure communication is supported between the REST proxy and REST clients?
  • A. Kerberos
  • B. TLS (HTTPS)
  • C. SCRAM
  • D. MD5
NEW QUESTION # 48
How does Kafka guarantee message integrity after a message is written on a disk?
  • A. A message cannot be altered once it has been written.
    C A message can be grouped with message sharing the same key to improve read performance
  • B. A message can be edited by the producer, producing to the message offset.
  • C. Only message metadata can be altered using command line (CLI) tools.
Kafka ensures message immutability for data integrity. Once a message is written to a Kafka topic and persisted to disk, it cannot be modified. This immutability guarantees that consumers always receive the original message content, which is critical for auditability, fault tolerance, and data reliability.
NEW QUESTION # 49
Which of the following are Kafka Connect internal topics? (Choose three.)
  • A. connect-offsets
  • B. connect-status
  • C. connect-confiqs
  • D. connect-standalone
  • E. connect-distributed
Answer: A,B,C
connect-configs stores connector configurations.
connect-status tracks the status of connectors and tasks (e.g., RUNNING, FAILED).
connect-offsets stores source connector offsets for reading from external systems.
NEW QUESTION # 50
As we all know, if you want to pass the CCAAK exam, you need to have the right method of study, plenty of preparation time, and targeted test materials. However, most people do not have one or all of these. That is why I want to introduce our CCAAK Original Questions to you. So why not try our Confluent original questions, which will help you maximize your pass rate? Even if you unfortunately fail to pass the exam, we will give you a full refund.
CCAAK Reliable Exam Pass4sure: https://www.actual4dump.com/Confluent/CCAAK-actualtests-dumps.html
DOWNLOAD the newest Actual4dump CCAAK PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1aNH6luVeOGs4krkf9ATKOMLQcG8nXDFn
Posted at 3/6/2026 22:34:18        Only Author  2#
That article opened up a whole new world of ideas for me. Free Valid Managing-Cloud-Security test pattern exam papersgood luck with your preparation!
