[Linux] 4 USB 3.1 ports are not working on the AIO-3588JQ board
23
Linux 4 USB 3.1 ports are not working on the AIO-3588JQ board
Posted at 5/29/2025 23:21:11      View1693 | Replies7        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: Proj
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: Many things... rk3588-firefly-aio-3588.dtb has not been changed
  • Log: log_config.zip
I rebuilt the core for the AIO-3588JQ board with the rk3588-firefly-aio-3588.dtb configuration (I didn't change anything there). And for some reason, 4 usb 3.1 ports are not working for me. I use an SSD drive as the core storage medium (u-boot was reassembled and uploaded to eMMC). USB 2.0 is working (the ones on the pin connector
  1. # ls -la /sys/bus/usb/devices/
  2. total 0
  3. drwxr-xr-x    2 root     root             0 Feb 11 13:50 .
  4. drwxr-xr-x    4 root     root             0 Feb 11 13:50 ..
  5. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 1-0:1.0 -> ../../../devices/platform/usbhost3_0/fcd00000.usb/xhci-hcd.3.auto/usb1/1-0:1.0
  6. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 2-0:1.0 -> ../../../devices/platform/usbhost3_0/fcd00000.usb/xhci-hcd.3.auto/usb2/2-0:1.0
  7. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 3-0:1.0 -> ../../../devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.5.auto/usb3/3-0:1.0
  8. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 4-0:1.0 -> ../../../devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.5.auto/usb4/4-0:1.0
  9. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 5-0:1.0 -> ../../../devices/platform/fc800000.usb/usb5/5-0:1.0
  10. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 6-0:1.0 -> ../../../devices/platform/fc880000.usb/usb6/6-0:1.0
  11. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 6-1 -> ../../../devices/platform/fc880000.usb/usb6/6-1
  12. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 6-1:1.0 -> ../../../devices/platform/fc880000.usb/usb6/6-1/6-1:1.0
  13. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 7-0:1.0 -> ../../../devices/platform/fc840000.usb/usb7/7-0:1.0
  14. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 8-0:1.0 -> ../../../devices/platform/fc8c0000.usb/usb8/8-0:1.0
  15. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb1 -> ../../../devices/platform/usbhost3_0/fcd00000.usb/xhci-hcd.3.auto/usb1
  16. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb2 -> ../../../devices/platform/usbhost3_0/fcd00000.usb/xhci-hcd.3.auto/usb2
  17. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb3 -> ../../../devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.5.auto/usb3
  18. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb4 -> ../../../devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.5.auto/usb4
  19. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb5 -> ../../../devices/platform/fc800000.usb/usb5
  20. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb6 -> ../../../devices/platform/fc880000.usb/usb6
  21. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb7 -> ../../../devices/platform/fc840000.usb/usb7
  22. lrwxrwxrwx    1 root     root             0 Feb 11 13:50 usb8 -> ../../../devices/platform/fc8c0000.usb/usb8
Copy the code
  1. # ls -la /sys/bus/platform/devices/usb*
  2. lrwxrwxrwx    1 root     root             0 Feb 11 14:46 /sys/bus/platform/devices/usbdrd3_0 -> ../../../devices/platform/usbdrd3_0
  3. lrwxrwxrwx    1 root     root             0 Feb 11 14:46 /sys/bus/platform/devices/usbdrd3_1 -> ../../../devices/platform/usbdrd3_1
  4. lrwxrwxrwx    1 root     root             0 Feb 11 14:46 /sys/bus/platform/devices/usbhost3_0 -> ../../../devices/platform/usbhost3_0
Copy the code
  1. # ls -la /sys/bus/platform/devices/usbdrd3_1/
  2. total 0
  3. drwxr-xr-x    4 root     root             0 Feb 11 14:46 .
  4. drwxr-xr-x  230 root     root             0 Feb 11 13:50 ..
  5. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 driver -> ../../../bus/platform/drivers/dwc3-of-simple
  6. -rw-r--r--    1 root     root          4096 Feb 11 14:47 driver_override
  7. drwxr-xr-x    3 root     root             0 Feb 11 14:47 fc400000.usb
  8. -r--r--r--    1 root     root          4096 Feb 11 14:47 modalias
  9. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 of_node -> ../../../firmware/devicetree/base/usbdrd3_1
  10. drwxr-xr-x    2 root     root             0 Feb 11 14:47 power
  11. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 subsystem -> ../../../bus/platform
  12. -rw-r--r--    1 root     root          4096 Feb 11 14:47 uevent
Copy the code
  1. # ls -la /sys/bus/platform/devices/usbdrd3_1/fc400000.usb/
  2. total 0
  3. drwxr-xr-x    3 root     root             0 Feb 11 14:47 .
  4. drwxr-xr-x    4 root     root             0 Feb 11 14:46 ..
  5. -rw-r--r--    1 root     root          4096 Feb 11 14:47 driver_override
  6. -r--r--r--    1 root     root          4096 Feb 11 14:47 modalias
  7. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 of_node -> ../../../../firmware/devicetree/base/usbdrd3_1/usb@fc400000
  8. drwxr-xr-x    2 root     root             0 Feb 11 14:47 power
  9. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 subsystem -> ../../../../bus/platform
  10. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 supplier:platform:fd5d4000.syscon:usb2-phy@4000 -> ../../../virtual/devlink/platform:fd5d4000.syscon:usb2-phy@4000--platform:fc400000.usb
  11. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 supplier:platform:fd8d8000.power-management:power-controller -> ../../../virtual/devlink/platform:fd8d8000.power-management:power-controller--platform:fc400000.usb
  12. lrwxrwxrwx    1 root     root             0 Feb 11 14:47 supplier:platform:fed90000.phy -> ../../../virtual/devlink/platform:fed90000.phy--platform:fc400000.usb
  13. -rw-r--r--    1 root     root          4096 Feb 11 14:47 uevent
Copy the code
As I understand it, I am not creating a usbdrd3_1 controller...I don't understand, maybe some driver is not installed..
Anyone who understands, please look at my configuration file, maybe I didn't install some driver..
log_config.zip
83.51 KB, Down times: 0
Posted at 1/10/2026 19:38:13        Only Author  2#
No hesitation, just hitting like for this great content. The Test VMA centres questions were key in securing my promotion and raisenow its your turn! Get them for free!
Posted at 1/14/2026 09:50:56        Only Author  3#
After reading this article, Ive gained a new perspective on how to look at the problem. Enhance your IT abilities and get free Exam PA-Life-Accident-and-Health braindumps. Best wishes for success!
Posted at 1/15/2026 03:55:46        Only Author  4#
CSA-JPN}^ȥԇYΥǩ`ˤä_kơ¤ServiceNowԇY֪R򺬤ƤޤʤԇYʂ䤷CSA-JPNԇYϸ񤹤Ҫʤ顢ҡΆ}Ϥʤ뤳ȤǤޤҡȫĤ|ߤCSA-JPN}ϤʤΕrgȽUgΥȤp٤ơʤԇYؤκϸ뤳ȤǤޤ
Posted at 1/18/2026 22:19:23        Only Author  5#
I cant thank you enough for your article, its definitely made an impression. The Latest exam collection HPE6-A87 file test was the secret to my promotion and pay raisetoday, Im giving it to you for free!
Posted at 1/19/2026 19:32:11        Only Author  6#
Falls Sie in der Prfung durchgefallen sind nach der Nutzung der Network Appliance NS0-005 Dumps, können Sie volle Rckerstattung bekommen, womit Sie die Prfungsunterlagen frher gekauft haben. Das ist die Garantie von ZertSoft fr alle Kunden. Diese Vorteile der ausgezeichneten Prfungsunterlagen zur Network Appliance NS0-005 Zertifizierung sind nicht die Worten, sondern von allen Kunden geprft. Die Prfungsunterlagen von ZertSoft werden seit langem immer geprft. Die Network Appliance NS0-005 Prfungsunterlagen von ZertSoft sind die Ergebnisse der gesammelten Erfahrungen von IT-Eliten. Deshalb sind diese Dumps echt und die Unterlagen sind seit langem immer sehr populär.
Posted at 1/24/2026 11:34:05        Only Author  7#
Im giving this a like without a second thought. Thanks to the Reliable test Global-Economics-for-Managers sample online, I got promoted and received a salary boost. Its free now. Wishing you all a successful career advancement!
Posted at 1/31/2026 22:08:11        Only Author  8#
EchteFrage bietet eine klare und ausgezeichnete Lösung fr jeden F5 304 Prfungskandidaten. Wir versorgen Sie mit den ausfhrlichen F5 304 Prfungsfragen und Antworten. Unser Team von IT-Experten ist das erfahrenste und qualifizierteste. Unsere Testfragen und Antworten sind fast gelich wie die echte Prfung. Das ist wirklich großartig. Am wichtigsten ist, dass die Erfolgsquote von EchteFrage die höchste in der Welt ist.
