[General] ISC - Useful Valid CISSP Test Review
101
General ISC - Useful Valid CISSP Test Review
Posted at 1/27/2026 22:28:56      View89 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Braindumpsqa CISSP dumps for free: https://drive.google.com/open?id=1KWuLOP8MIfDeIa-hXJ2GH-3sJHY9MOTi
Our ISC CISSP dumps assists the candidates of the test with its three formats to advance their preparation as per various learning needs. A team of experts at Braindumpsqa has designed the CISSP Pdf Format to help applicants who are too busy to prepare intensively for the ISC CISSP certification exam on the first go.
You will become accustomed to and familiar with the free demo for ISC CISSP Exam Questions. Exam self-evaluation techniques in our CISSP desktop-based software include randomized questions and timed tests. These tools assist you in assessing your ability and identifying areas for improvement to pass the ISC Certified Information Systems Security Professional (CISSP) exam.
Valid Test CISSP Fee & New CISSP Study PlanDo you want to pass the ISC CISSP exam on the first attempt but do not know where to start the preparation? Then Braindumpsqa has a solution to all your problems. Braindumpsqa is among the greatest resources for preparing for ISC CISSP Certification test. With real CISSP PDF Questions of Braindumpsqa you can simply prepare for your CISSP exam from home, the office, or your place of work.
ISC Certified Information Systems Security Professional (CISSP) Sample Questions (Q963-Q968):NEW QUESTION # 963
What is probing used for?
  • A. To induce a user into taking an incorrect action
  • B. To use up all of a target's resources
  • C. To give an attacker a road map of the network
  • D. To covertly listen to transmissions
The correct answer is "To give an attacker a road map of the network". Probing is a procedure whereby the intruder runs programs that scan the network to create a network map for later intrusion.
Answer "To induce a user into taking an incorrect action" is spoofing, c is the objective of a
DoS attack, and d is passive eavesdropping.
NEW QUESTION # 964
Under what conditions would the use of a "Class C" hand-held fire extinguisher be preferable to the use of a "Class A" hand-held fire extinguisher?
  • A. When the fire is caused by flammable products.
  • B. When the fire is located in an enclosed area.
  • C. When the fire is in its incipient stage.
  • D. When the fire involves electrical equipment.
Explanation/Reference:
Class C fire extinguishers are used for fires involving electrical equipment.
Class C fires are electrical fires which that may occur in electrical equipment or wiring. Class C fire extinguishers use non-conductive agents such as gas, CO2 or dry powders.
Class A fire extinguishers use water or foam. Water or foam used on an electrical fire would conduct the electricity and make the fire worse. Therefore, for an electrical fire, a Class C fire extinguisher is preferable to a Class A fire extinguisher.
Incorrect Answers:
A: A fire being in its incipient stage (just starting) is not a reason to use a Class C fire extinguisher.
Therefore, this answer is incorrect.
C: For a fire in an enclosed area, a Class A fire extinguisher that uses water or foam is preferred (unless the elements of the fire require a different fire extinguisher). This is because other fire extinguishers can use gases that are harmful to life. Therefore, this answer is incorrect.
D: All products that are burning in a fire are 'flammable'. The specific type of product needs to be determined to determine which fire extinguisher to use. Therefore, this answer is incorrect.
Harris, Shon, All In One CISSP Exam Guide, 6th Edition, McGraw-Hill, 2013, p. 472
NEW QUESTION # 965
What is the MOST important criterion that needs to be adhered to during the data collection process of an active investigation?
  • A. Complying with the organization's security policy
  • B. Capturing an image of the system
  • C. Maintaining the chain of custody
  • D. Outlining all actions taken during the investigation
When collecting and handling evidence during an investigation, it is important to create an accurate chain of custody document.
NEW QUESTION # 966
Which of the following addresses cumbersome situations where users need to log on multiple times to access different resources?
  • A. Triple Sign-On (TSO) systems
  • B. Double Sign-On (DS0) systems
  • C. Single Sign-On (SSO) systems
  • D. Dual Sign-On (DSO) systems
NEW QUESTION # 967
Which of the following is a PRIMARY security weakness in the design of Domain Name System (DNS)?
  • A. Each DNS server must hold the address of the root servers.
  • B. A DNS server does not authenticate source of information.
  • C. A DNS server database can be injected with falsified checksums.
  • D. A DNS server can be disabled in a denial-of-service (DoS) attack.
NEW QUESTION # 968
Our CISSP exam dumps strive for providing you a comfortable study platform and continuously explore more functions to meet every customers requirements. We may foresee the prosperous talent market with more and more workers attempting to reach a high level through the ISC certification. To deliver on the commitments of our CISSP Test Prep that we have made for the majority of candidates, we prioritize the research and development of our CISSP test braindumps, establishing action plans with clear goals of helping them get the ISC certification.
Valid Test CISSP Fee: https://www.braindumpsqa.com/CISSP_braindumps.html
We've set strong guarantee to promise you to pass CISSP test, The CISSP questions & answers have been examined by the most capable professors tens of thousands of times, Using the online virtual Valid Test CISSP Fee practice engine atBraindumpsqa Valid Test CISSP Fee, no need to purchase anything else or attend expensive training, we promise that you can pass the certification exam at the first try , or else give you a FULL REFUND, As you can see, we have invested big amount of money to give the most convinience for you to get our CISSP exam braindumps.
Motivating Yourself in a Bad Environment, This CISSP dump still valid in Pakistan as well, We've set strong guarantee to promise you to Pass CISSP Test, The CISSP questions & answers have been examined by the most capable professors tens of thousands of times.
Effective ISC CISSP Questions - Get Ready For The CISSP ExamUsing the online virtual ISC Certification practice engine atBraindumpsqa, no need to purchase Valid Test CISSP Fee anything else or attend expensive training, we promise that you can pass the certification exam at the first try , or else give you a FULL REFUND.
As you can see, we have invested big amount of money to give the most convinience for you to get our CISSP exam braindumps, So we try to emulate with the best from the start until we are now.
