[General] New Amazon SCS-C03 Test Online & Exam SCS-C03 Duration
103
【General】 New Amazon SCS-C03 Test Online & Exam SCS-C03 Duration
Posted at 1/27/2026 22:40:10      View:100 | Replies:0        Print      Only Author   [Copy Link] 1#
Our SCS-C03 training braindump is elaborately composed with major questions and answers. We are choosing the key from past materials to finish our SCS-C03 guide question. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the SCS-C03 Test Question. Then, you will have enough confidence to pass the SCS-C03 exam. What are you waiting for? Just come and buy our SCS-C03 exam questions!
Being a social elite and making achievements in your own field may be the dream of all people. However, only a very few people seize the initiative in their life. Perhaps our research data will give you some help. As long as you spend less time on the game and spend more time on learning, the SCS-C03 study materials can reduce your pressure so that users can feel relaxed and confident during the preparation and certification process. It is believed that many users have heard of the SCS-C03 Study Materials from their respective friends or news stories. So why don't you take this step and try? You will not regret your wise choice.
SCS-C03 Exam Guide - SCS-C03 Test Questions & SCS-C03 Exam TorrentOur company has collected the frequent-tested knowledge into our practice materials for your reference according to our experts’ years of diligent work. So our SCS-C03 exam materials are triumph of their endeavor. By resorting to our SCS-C03 Practice Guide, we can absolutely reap more than you have imagined before. We have clear data collected from customers who chose our SCS-C03 training engine, the passing rate is 98-100 percent.
Amazon AWS Certified Security – Specialty Sample Questions (Q62-Q67):NEW QUESTION # 62
A company has security requirements for Amazon Aurora MySQL databases regarding encryption, deletion protection, public access, and audit logging. The company needs continuous monitoring and real-time visibility into compliance status.
Which solution will meet these requirements?
  • A. Use AWS Security Hub configuration policies.
  • B. Use AWS Audit Manager with a custom framework.
  • C. Enable AWS Config and use managed rules to monitor Aurora MySQL compliance.
  • D. Use EventBridge and Lambda with custom metrics.
AWS Config is the AWS service designed to continuously evaluate resource configurations against defined rules. According to the AWS Certified Security - Specialty Study Guide, AWS Config managed rules exist specifically to check database encryption, public accessibility, deletion protection, and log exports for Amazon RDS and Aurora.
AWS Config provides a real-time compliance timeline and displays the compliance state of each resource against each rule at any point in time. This granular visibility is required to assess ongoing compliance with security policies.
Audit Manager generates reports but does not provide continuous compliance monitoring. Security Hub aggregates findings but does not track configuration drift. EventBridge and Lambda introduce unnecessary complexity.
Referenced AWS Specialty Documents:
AWS Certified Security - Specialty Official Study Guide
AWS Config Managed Rules for RDS
AWS Continuous Compliance Monitoring
NEW QUESTION # 63
A company needs a cloud-based, managed desktop solution for its workforce of remote employees. The company wants to ensure that the employees can access the desktops only by using company-provided devices. A security engineer must design a solution that will minimize cost and management overhead.
  • A. Deploy a fleet of Amazon EC2 instances. Assign an instance to each employee with certificate-based device authentication that uses Windows Active Directory.
  • B. Deploy a custom virtual desktop infrastructure (VDI) solution with a restriction policy to allow access only from corporate devices.
  • C. Deploy Amazon WorkSpaces. Set up a trusted device policy with IP blocking on the authentication gateway by using AWS Identity and Access Management (IAM).
  • D. Deploy Amazon WorkSpaces. Create client certificates, and deploy them to trusted devices. Enable restricted access at the directory level.
Amazon WorkSpaces is a fully managed desktop-as-a-service solution designed to minimize infrastructure and operational overhead. According to AWS Certified Security - Specialty documentation, WorkSpaces supports device trust by using client certificates to restrict access to approved devices.
By deploying client certificates only to company-managed devices and enforcing restricted access at the directory level, the organization ensures that only trusted endpoints can authenticate. This approach avoids the cost and complexity of building and maintaining a custom VDI or managing individual EC2 instances.
Option A and B significantly increase management overhead. Option C is incorrect because IAM does not manage WorkSpaces authentication gateway policies or device trust.
AWS best practices highlight Amazon WorkSpaces with certificate-based device trust as the most efficient solution for secure, managed desktops.
Amazon WorkSpaces Security Controls
Amazon WorkSpaces Device Trust
NEW QUESTION # 64
A company uses AWS to run a web application that manages ticket sales in several countries. The company recently migrated the application to an architecture that includes Amazon API Gateway, AWS Lambda, and Amazon Aurora Serverless. The company needs the application to comply with Payment Card Industry Data Security Standard (PCI DSS) v4.0. A security engineer must generate a report that shows the effectiveness of the PCI DSS v4.0 controls that apply to the application. The company's compliance team must be able to add manual evidence to the report.
  • A. Enable AWS Trusted Advisor. Configure all the Trusted Advisor checks. Manually map the checks against the PCI DSS v4.0 standard to generate the report.
  • B. Enable and configure AWS Config. Deploy the Operational Best Practices for PCI DSS conformance pack in AWS Config. Use AWS Config to generate the report.
  • C. Enable AWS Security Hub. Enable the Security Hub PCI DSS security standard. Use the AWS Management Console to download the report from the security standard.
  • D. Create an AWS Audit Manager assessment that uses the AWS managed PCI DSS v4.0 standard framework. Add all evidence to the assessment. Generate the report in Audit Manager for download.
AWS Audit Manager is specifically designed to help organizations continuously audit their AWS usage against compliance frameworks and generate audit-ready reports. According to AWS Certified Security - Specialty documentation, Audit Manager includes AWS managed frameworks for compliance standards, including PCI DSS v4.0.
Audit Manager automatically collects evidence from AWS services such as API Gateway, Lambda, RDS, CloudTrail, and Config, and maps the evidence directly to PCI DSS controls. Importantly, Audit Manager allows compliance teams to upload and attach manual evidence, which is a key requirement in this scenario.
Option C provides visibility into control status but does not support adding manual evidence. Option B evaluates configuration compliance but does not generate formal compliance reports. Option A requires extensive manual effort and is not aligned with PCI reporting workflows.
AWS documentation positions Audit Manager as the authoritative service for compliance reporting and audit evidence management.
AWS Audit Manager PCI DSS Framework
AWS Compliance Reporting Best Practices
NEW QUESTION # 65
An AWS Lambda function was misused to alter data, and a security engineer must identify who invoked the function and what output was produced. The engineer cannot find any logs created by the Lambda function in Amazon CloudWatch Logs.
Which of the following explains why the logs are not available?
  • A. The version of the Lambda function that was invoked was not current.
  • B. The execution role for the Lambda function did not grant permissions to write log data to CloudWatch Logs.
  • C. The Lambda function was invoked by using Amazon API Gateway, so the logs are not stored in CloudWatch Logs.
  • D. The execution role for the Lambda function did not grant permissions to write to the Amazon S3 bucket where CloudWatch Logs stores the logs.
AWS Lambda automatically sends function execution logs to Amazon CloudWatch Logs when logging is enabled in the function code. However, this logging capability depends on the Lambda execution role having the appropriate permissions. According to the AWS Certified Security - Specialty Study Guide, the execution role must include permissions such as logs:CreateLogGroup, logs:CreateLogStream, and logsutLogEvents.
If these permissions are missing, Lambda cannot create log groups or streams, and no execution logs will appear in CloudWatch Logs-even though the function was successfully invoked. This is the most common reason Lambda logs are unavailable during forensic investigations.
Option B is incorrect because Lambda logs are stored in CloudWatch Logs regardless of whether the invocation source is API Gateway, EventBridge, or another AWS service. Option C is incorrect because CloudWatch Logs does not require direct S3 permissions from the Lambda execution role. Option D is irrelevant because Lambda versions do not affect logging behavior.
AWS documentation emphasizes verifying execution role permissions as a first step when Lambda logs are missing.
AWS Lambda Execution Roles
Amazon CloudWatch Logs Integration with Lambda
NEW QUESTION # 66
A company's security team wants to receive near-real-time email notifications about AWS abuse reports related to DoS attacks. An Amazon SNS topic already exists and is subscribed to by the security team.
What should the security engineer do next?
  • A. Create an Amazon EventBridge rule that matches AWS Health events for AWS_ABUSE_DOS_REPORT and publishes to SNS.
  • B. Poll Trusted Advisor for abuse notifications by using a Lambda function.
  • C. Detect abuse reports by using CloudTrail logs and CloudWatch alarms.
  • D. Poll the AWS Support API for abuse cases by using a Lambda function.
AWS abuse notifications are delivered as AWS Health events. According to the AWS Certified Security - Specialty Study Guide, Amazon EventBridge integrates natively with AWS Health and can be used to detect specific event types such as AWS_ABUSE_DOS_REPORT in near real time.
By creating an EventBridge rule that filters for the abuse report event type and publishes directly to Amazon SNS, the solution remains fully managed, low latency, and cost effective.
Polling APIs introduces delay and complexity. CloudTrail does not log abuse notifications. EventBridge with AWS Health is the recommended mechanism for reacting to AWS service events.
AWS Health and EventBridge Integration
AWS Abuse Notification Handling
NEW QUESTION # 67
Some customers might worry that passing the exam is a time-consuming process. Now our SCS-C03 actual test guide can make you the whole relax down, with all the troubles left behind. Involving all types of questions in accordance with the real exam content, our SCS-C03 exam questions are compiled to meet all of your requirements. The comprehensive coverage would be beneficial for you to pass the exam. Only need to spend about 20-30 hours practicing our SCS-C03 study files can you be fully prepared for the exam. With deeply understand of core knowledge SCS-C03 actual test guide, you can overcome all the difficulties in the way. So our SCS-C03 exam questions would be an advisable choice for you.
Exam SCS-C03 Duration: https://www.dumpsactual.com/SCS-C03-actualtests-dumps.html
In addition to premium VCE file for Exam SCS-C03 Duration - AWS Certified Security – Specialty exam, we release software and test engine version which may be more humanized, easy to remember and boosting your confidence, The desktop AWS Certified Security – Specialty (SCS-C03) practice exam software helps its valued customer to be well aware of the pattern of the real SCS-C03 exam, You will be able to see instant results after going through the SCS-C03 practice exam To confirm the product licence.
You will find plenty of material that is applicable New SCS-C03 Test Online to you, The Parts of a Message, In addition to premium VCE file for AWS Certified Security – Specialty exam, we release software and test engine SCS-C03 version which may be more humanized, easy to remember and boosting your confidence.
SCS-C03 Exam New Test Online & Newest Exam SCS-C03 Duration Pass SuccessThe desktop AWS Certified Security – Specialty (SCS-C03) practice exam software helps its valued customer to be well aware of the pattern of the real SCS-C03 exam, You will be able to see instant results after going through the SCS-C03 practice exam To confirm the product licence.
All you have learned on our SCS-C03 study materials will play an important role in your practice, POPULAR VENDORS EXAMS.
