Valid CDCS Test Sample & CDCS Valid Exam Bootcamp
Posted at 1/28/2026 00:12:28
View115
Replies1
BONUS!!! Download part of ActualTestsQuiz CDCS dumps for free: https://drive.google.com/open?id=1i7YPxehtPRv77PrUDxbTtoXtG_m7QveF
ActualTestsQuiz online digital EXIN CDCS exam questions are the best way to prepare. Using our EXIN CDCS exam dumps, you will not have to worry about whatever topics you need to master. To practice for a EXIN CDCS Certification Exam in the ActualTestsQuiz (free test), you should perform a self-assessment. The CDCS practice test ActualTestsQuiz keeps track of each previous attempt and highlights the improvements with each attempt.
EXIN CDCS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
| | Topic 2 | - Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
| | Topic 3 | - Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
CDCS Valid Exam Bootcamp | CDCS Latest Exam DumpsThe CDCS study materials from our company are very convenient for all people, including the convenient buying process, the download way and the study process and so on. Upon completion of your payment, you will receive the email from us in several minutes, and then you will have the right to use the CDCS Study Materials from our company. In addition, there are three different versions for all people to choose. According to your actual situation, you can choose the suitable version from our CDCS study materials.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q70-Q75):NEW QUESTION # 70
An air-conditioner unit needs to be selected. Two types are available:
Unit-A has a Sensible Heat Ratio (SHR) of 0.7.
Unit-B has a Sensible Heat Ratio (SHR) of 0.9.
From an efficiency point of view, which one should be selected?
- A. It does not matter, as the Sensible Heat Ratio has nothing to do with efficiency.
- B. Unit B
- C. Unit A
- D. Not relevant, as Sensible Heat Ratio is only specified for air-conditioner equipment to indicate the ratio between intake temperature and exhaust temperature.
From an efficiency standpoint, Unit B with a Sensible Heat Ratio (SHR) of 0.9 is preferable. A higher SHR indicates that a greater proportion of the air conditioner's capacity is dedicated to sensible cooling (temperature reduction) rather than latent cooling (moisture removal). In data centers, sensible cooling is more critical since IT equipment primarily generates heat without adding significant moisture.
Detailed Explanation:
An SHR of 0.9 means that 90% of the cooling capacity is used for sensible cooling, which is more efficient for environments like data centers where humidity control is typically less of a concern. Opting for an air conditioner with a higher SHR ensures that most of the cooling energy is focused on temperature reduction, making Unit B more efficient in this scenario.
EPI Data Center Specialist References:
EPI data center best practices recommend choosing cooling units with higher SHR values in data centers, as they better match the cooling needs of IT equipment. High SHR units improve cooling efficiency by concentrating on sensible heat removal, which is vital for maintaining the optimal thermal environment.
NEW QUESTION # 71
Do you need to consider bullet (ballistic) protection when designing a data center?
- A. Yes, but only when the data center is built in an area with a high criminality rate or with a risk of terrorist attacks
- B. No, there is no reason for implementing bullet protection as you cannot predict the type of weapons that might be used
- C. No; bullet protection is not a requirement of ANSI/TIA-942
- D. Yes, bullet protection is a requirement of ANSI/TIA-942 for Rated-3/4 data centers
ANSI/TIA-942 requires a risk assessment-based approach to physical security; ballistic protection is not mandated but may be justified by threat analysis.
* A is incomplete (it may still be required by risk).
References: ANSI/TIA-942-B 6.4 Physical Security (threat/risk assessment), ISO 31000 (risk management).
NEW QUESTION # 72
What is needed to determine the Relative Humidity (RH)?
- A. Cold surface with dew collection counter
- B. Dry bulb temperature, wet bulb temperature, and psychrometric chart
- C. Wet bulb temperature, local atmospheric pressure, and calculator
- D. Dry bulb temperature, airflow, and conversion table
Relative Humidity (RH) is defined as the ratio of the actual water vapor content in the air to the maximum possible water vapor content at a given temperature. To calculate RH:
* Dry bulb temperature (DBT): the ambient air temperature.
* Wet bulb temperature (WBT): the temperature measured by a thermometer covered with a wet wick, influenced by evaporative cooling.
Using DBT and WBT, the humidity ratio and dew point can be determined with a psychrometric chart or Mollier diagram. From there, RH is calculated as:
A black text on a white background AI-generated content may be incorrect.
Options A and B are incomplete, while option C is an experimental method, not standard practice. The recognized method is option D.
References: ASHRAE Fundamentals Handbook - Psychrometrics, ISO 7726 (Measurement of Physical Quantities in Thermal Environments).
NEW QUESTION # 73
What is the first step in the design stage of the data center life cycle?
- A. Select vendors
- B. Freeze the design
- C. Define the scope of the project
- D. Do a design validation
The life cycle begins with planning and design. The very first step is to clearly define the project scope:
business requirements, capacity, availability targets, compliance standards, and budget. Without scope definition, design validation or vendor selection would be premature.
* Vendor selection (A) happens much later during procurement.
* Validation (B) occurs after conceptual and detailed designs are prepared.
* Freezing design (D) is the final stage before implementation.
Therefore, defining the project scope is the correct initial step.
References: ANSI/TIA-942-B Annex F (Lifecycle), ISO/IEC 30182 (Smart City & DC Lifecycle), PMI PMBOK (Scope Definition).
NEW QUESTION # 74
A data center requires an audit to find out whether it conforms with ANSI/TIA-942 Rated-3 (concurrently maintainable).
Will the network architecture be part of this audit?
- A. Yes, but only if the network administration does not comply with ANSI/TIA-606.
- B. No, as concurrently maintainable only applies to electrical and mechanical (power and cooling).
- C. No, only the type of cabling used will be audited.
- D. Yes, amongst other aspects, the network architecture should be Rated-3 compliant with the requirements of ANSI/TIA-942.
For a Rated-3 data center, network architecture is indeed a key component of the audit under ANSI/TIA-942. This rating requires concurrent maintainability across all systems, including telecommunications infrastructure. The network architecture must therefore meet specific redundancy and reliability standards to ensure uninterrupted operations during maintenance or failure of any single component.
Rated-3 requirements extend beyond electrical and mechanical systems to include network architecture. This ensures that telecommunications systems are also designed for concurrent maintainability, thus contributing to overall uptime and resilience.
EPI endorses comprehensive assessments for Rated-3 facilities, emphasizing that network systems must meet standards for redundancy and concurrent maintainability, which align with ANSI/TIA-942's holistic approach to data center reliability.
NEW QUESTION # 75
Our website provides the most up to date and accurate EXIN CDCS learning materials which are the best for clearing CDCS real exam. It is best choice to accelerate your career as a professional in the information technology industry. We are proud of our reputation of helping people clear CDCS Actual Test in your first attempt. Our pass rate reached almost 86% in recent years.
CDCS Valid Exam Bootcamp: https://www.actualtestsquiz.com/CDCS-test-torrent.html
- Valid CDCS Test Online 🌭 Test CDCS Question 🥕 CDCS Dump 🍠 Search for CDCS and obtain a free download on [url]www.verifieddumps.com 🤪Latest CDCS Exam Notes[/url]
- Vce CDCS Exam 🧽 CDCS Pass Exam 🔴 CDCS Reliable Dumps Sheet 🎌 Open website ➠ [url]www.pdfvce.com 🠰 and search for [ CDCS ] for free download ⬛CDCS Exam Simulator Free[/url]
- CDCS Valid Exam Pass4sure 🎯 Valid CDCS Test Online 🥕 CDCS Exam Simulator Free 🥙 Open ➡ [url]www.validtorrent.com ️⬅️ enter ⮆ CDCS ⮄ and obtain a free download 🟡CDCS Real Questions[/url]
- Use EXIN CDCS Questions - Best Strategy To Beat The Exam Stress 🤗 Simply search for ➡ CDCS ️⬅️ for free download on ⏩ [url]www.pdfvce.com ⏪ 🦄CDCS Pass Exam[/url]
- Authoritative 100% Free CDCS C 100% Free Valid Test Sample | CDCS Valid Exam Bootcamp 👹 Search for CDCS and easily obtain a free download on [ [url]www.practicevce.com ] 🦨CDCS Dump[/url]
- CDCS Exam Simulator Free 🎍 CDCS Reliable Dumps Sheet 😅 CDCS Exam Actual Tests 💝 Download [ CDCS ] for free by simply searching on ▛ [url]www.pdfvce.com ▟ 👎CDCS Pass Exam[/url]
- CDCS Intereactive Testing Engine ⚽ CDCS Pass Exam 💜 CDCS Dump 🌌 Search for { CDCS } and easily obtain a free download on ▷ [url]www.prepawayete.com ◁ 😉Reliable CDCS Practice Questions[/url]
- Use EXIN CDCS Questions - Best Strategy To Beat The Exam Stress 🎎 Search for ⇛ CDCS ⇚ and obtain a free download on ✔ [url]www.pdfvce.com ️✔️ 🧵
remium CDCS Exam[/url] - Use EXIN CDCS Questions - Best Strategy To Beat The Exam Stress 📥 Search for ☀ CDCS ️☀️ on ⇛ [url]www.troytecdumps.com ⇚ immediately to obtain a free download 🦌Reliable CDCS Practice Questions[/url]
- Use EXIN CDCS Questions - Best Strategy To Beat The Exam Stress ▶ Download ▛ CDCS ▟ for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🚢CDCS Dump[/url]
- CDCS Testking Exam Questions 📞 CDCS Reliable Dumps Sheet 👏 Reliable CDCS Practice Questions 📨 Search for ▶ CDCS ◀ and download exam materials for free through ➡ [url]www.validtorrent.com ️⬅️ 🐸CDCS Exam Actual Tests[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, paidforarticles.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that ActualTestsQuiz CDCS dumps now are free: https://drive.google.com/open?id=1i7YPxehtPRv77PrUDxbTtoXtG_m7QveF
