[General] Latest 800-150 Exam Topics - 800-150 Latest Test Materials
126
【General】 Latest 800-150 Exam Topics - 800-150 Latest Test Materials
Posted at 1/28/2026 00:13:13      View:104 | Replies:3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PDF4Test 800-150 dumps from Cloud Storage: https://drive.google.com/open?id=1_w5vPlVvkz8mCfvMEgna1nvoDc5POjos
There are three versions of 800-150 training materials for the candidate of you, and different versions have different advantages, you can use it in accordance with your own habit. Free update for each version for one year, namely, you don’t need to buy the same version for many times, and the update version will send to you automatically. You will get the latest version of 800-150 Training Materials.
Cisco 800-150 Exam Syllabus Topics:
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Cisco’s software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Cisco’s cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
  • Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Cisco’s UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
800-150 Latest Test Materials, Reliable Study 800-150 QuestionsThe PDF4Test is committed to ace your Supporting Cisco Devices for Field Technicians (800-150) exam preparation and ensure your success on the first attempt. To achieve this objective the PDF4Test is offering top-rated, real, and updated Supporting Cisco Devices for Field Technicians (800-150) exam questions in three different formats. The names of these formats are 800-150 PDF dumps file, desktop practice test software, and web-based practice test software.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q87-Q92):NEW QUESTION # 87
How many bits are borrowed from the default host portion of the address to create subnets in a Class B network with a subnet mask 255.255.255.0?
  • A. 8 bits
  • B. 5 bits
  • C. 3 bits
  • D. 3 bits
In a Class B network, the default subnet mask is 255.255.0.0, which allocates:
* 16 bits for the network portion
* 16 bits for the host portion
When the subnet mask is changed to255.255.255.0, it becomes:
* 24 bits for the network portion
* 8 bits for the host portion
This indicates that8 bitshave been borrowed from the host portion to create additional subnets. Borrowing bits allows for the division of the original network into smaller sub-networks, enhancing organization and security within the network.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco IOS Software Basics
NEW QUESTION # 88
What is the first action that must be taken before removing a standby supervisor module from a Cisco MDS
9700 Series Switch?
  • A. Perform a manual failover to the standby supervisor.
  • B. Shut down the entire switch.
  • C. Put themodule into out-of-service mode.
  • D. Disconnect all network interface cables.
In theFLDTEC course, the process for removing or replacing asupervisor module- especially thestandby supervisor- in a modular switch like theCisco MDS 9700is clearly outlined. Cisco documentation states:
"Before removing a standby supervisor module, it must first be placed into out-of-service mode using the CLI command system no supervisor <slot-number> or via the appropriate management interface." This action ensures the systemacknowledges the supervisor is no longer participating in redundancy, allowing a safe and controlled removal without impacting system operations.
Why not the other options?
* A. Shut down the entire switch# Not required; MDS switches are built for high availability and allow hot-swap operations.
* C. Disconnect all network interface cables# This applies to line cards or interfaces, not to supervisor removal specifically.
* D. Perform a manual failover# Failover is requiredwhen removing the active supervisor, not the standby one.
NEW QUESTION # 89
What is the primary role of a switch in a local area network?
  • A. to provide wireless connectivity to LAN devices
  • B. to divide the network into separate collision domains
  • C. to encrypt data transmissions for security
  • D. to route data packets between different networks
In a local area network (LAN), the primary function of a switch is to operate at Layer 2 (Data Link Layer) of the OSI model. Switches use MAC addresses to forward frames to the appropriate destination ports. This targeted forwarding mechanism divides the network into separate collision domains for each switch port. By isolating collision domains, switches significantly reduce the chance of collisions, enhancing the performance and efficiency of the network.
Unlike hubs, which forward all traffic to all ports (thus creating a single collision domain), switches intelligently forward only the necessary traffic to the correct port. This capability allows multiple simultaneous conversations on different switch ports without interference.
Routers, which operate at Layer 3 (Network Layer), are used to route packets between different networks, not within the same LAN. Wireless connectivity is provided by wireless access points (WAPs), not switches. Encryption is typically handled by security protocols or devices such as firewalls and not by switches directly.
NEW QUESTION # 90
What is the first action that must be taken before removing a standby supervisor module from a Cisco MDS 9700 Series Switch?
  • B. Put the module into out-of-service mode.
  • C. Shut down the entire switch.
In the FLDTEC course, the process for removing or replacing a supervisor module - especially the standby supervisor - in a modular switch like the Cisco MDS 9700 is clearly outlined. Cisco documentation states:
"Before removing a standby supervisor module, it must first be placed into out-of-service mode using the CLI command system no supervisor <slot-number> or via the appropriate management interface." This action ensures the system acknowledges the supervisor is no longer participating in redundancy, allowing a safe and controlled removal without impacting system operations.
A . Shut down the entire switch → Not required; MDS switches are built for high availability and allow hot-swap operations.
C . Disconnect all network interface cables → This applies to line cards or interfaces, not to supervisor removal specifically.
D . Perform a manual failover → Failover is required when removing the active supervisor, not the standby one.
NEW QUESTION # 91
Which step must be performed immediately after disconnecting the network cable when replacing an SFP transceiver module?
  • A. Install the replacement SFP module.
  • B. Disconnect the SFP latch.
  • C. Reinstall dust plugs in the optical bores.
  • D. Observe the port status LED.
After disconnecting the network cable from an SFP transceiver, the immediate next step is to reinstall the dust plugs into the optical bores. This action prevents contamination from dust or debris that can damage the optical interfaces or degrade performance.
It's important to protect the exposed optical port before handling the rest of the transceiver module. Dust plugs help maintain the integrity of the component until a new cable or module is connected.
NEW QUESTION # 92
Our 800-150 preparation exam have assembled a team of professional experts incorporating domestic and overseas experts and scholars to research and design related exam bank, committing great efforts to work for our candidates. Most of the experts have been studying in the professional field for many years and have accumulated much experience in our 800-150 Practice Questions. So we can say that our 800-150 exam questions are the first-class in the market. With our 800-150 learning guide, you will get your certification by your first attempt.
800-150 Latest Test Materials: https://www.pdf4test.com/800-150-dump-torrent.html
BONUS!!! Download part of PDF4Test 800-150 dumps for free: https://drive.google.com/open?id=1_w5vPlVvkz8mCfvMEgna1nvoDc5POjos
Posted at 1/29/2026 21:05:18        Only Author  2#
The article was full of valuable insights. Elevate your IT abilities with free ARA-C01 test tips. Best wishes for success!
Posted at 2/3/2026 04:20:04        Only Author  3#
I’m deeply thankful for your article, it truly impressed me. The New XK0-005 exam discount resources are free and very helpful.
Posted at 2/7/2026 06:44:30        Only Author  4#
The content of this article is thought-provoking, thank you for sharing! Sharpen your IT knowledge with free Formal SC-400 test. Best of luck to you!
