[Hardware] Reliable and Guarantee Refund of Salesforce PDII Exam Dumps According to Terms a
【Hardware】 Reliable and Guarantee Refund of Salesforce PDII Exam Dumps According to Terms a
Posted at 1/28/2026 01:52:50      View:103 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsMaterials PDII dumps from Cloud Storage: https://drive.google.com/open?id=1CStqDQtGlAHpLWRdCJu7S2k7G1LTl0yV
If you don't prepare with real PDII questions, you fail, lose time and money. DumpsMaterials product is specially designed to help you pass the exam on the first try. The study material is easy to use. You can choose from 3 different formats available according to your needs. The 3 formats are Salesforce PDII desktop practice test software, browser based practice exam, and PDF.
Salesforce Certified Platform Developer II (PDII) certification exam is designed for professionals who have experience in building advanced applications on the Salesforce platform. Platform Developer II certification is one of the most prestigious and in-demand certifications in the Salesforce ecosystem. It validates the developer's expertise in designing and implementing complex business logic, data models, and custom user interfaces using Apex, Visualforce, and other advanced features of the Salesforce platform.
New PDII Exam Topics, PDII Pdf FormatAs usual, you just need to spend little time can have a good commend of our study materials, then you can attend to your PDII exam and pass it at your first attempt. We also hire a team of experts, and the content of PDII question torrent is all high-quality test guidance materials that have been accepted by experienced professionals. PDII practice materials will be the most professional and dedicated tutor you have ever met.
Salesforce Platform Developer II Sample Questions (Q105-Q110):NEW QUESTION # 105
A developer is writing a complex application involving triggers, workflow rules, Apex classes, and processes. The developer needs to carefully consider the order of execution when developing the application.
1. Before Triggers
2. After Triggers
3. Post commit logic such as sending email
4. DML committed to the database
5. Workflow rules
6. Roll-up summary calculations
In what order do the following operations execute?
  • A. 1,5,6,2,4,3
  • B. 1,6,5,2,4,3
  • C. 1,2,4,5,6,3
  • D. 1,2,5,6,4,3
NEW QUESTION # 106
How can Apex be used with Visual Workflow?
  • A. To set the version of a Flow being run.
  • B. To add custom styling to a Flow.
  • C. To start a Flow automatically.
  • D. To control access to a Flow
NEW QUESTION # 107
Consider the following code snippet:
Choose 2 answers
  • A. Create a Named Credential, endpoint_NC, to store the endpoint and credentials.
  • B. Store the URL of the endpoint in a custom Label named endpointURL.
  • C. Use req.setEndpoint,calloat;eodPolat NC'); within the callout request.
  • D. Use reg.setEndpoint(Label.endPoinrURL);,
The two changes that the developer should implement in the Apex class to ensure the LWC can display data efficiently while preserving security are to store the URL of the endpoint in a custom Label named endpointURL, and to use req.setEndpoint('callout:endpoint_NC'); within the callout request. Storing the URL of the endpoint in a custom Label allows the developer to avoid hard-coding the URL in the Apex code, and to manage the URL value from the Setup menu. This makes the code more maintainable and flexible, and also prevents exposing the URL to unauthorized users. Using req.setEndpoint('callout:endpoint_NC'); within the callout request allows the developer to use a Named Credential to store the endpoint and the credentials for the external system. This simplifies the authentication process, and also ensures that the credentials are secure and encrypted. The setEndpoint() method accepts a callout: prefix followed by the name of the Named Credential to use for the callout request. The getSubjectType() method is not a valid answer, as it is used to get the subject type of a Platform Event, but it does not affect the efficiency or security of the data display. The WHERE clause is not a valid answer, as it is used to filter the records in a SOQL query, but it does not affect the efficiency or security of the data display. Reference: [Custom Labels], [Named Credentials], [Apex Developer Guide]
NEW QUESTION # 108
A large company uses Salesforce across several departments. Each department has its own Salesforce Administrator. It was agreed that each Administrator would have their own sandbox in which to test changes. Recently, users notice that fields that were recently added for one department suddenly disappear without warning. Also, Workflows that once sent emails and created tasks no longer do so. Which two statements are true regarding these issues and resolution? Choose 2 answers
  • A. The administrators are deploying their own Change Sets over each other, thus replacing entire Page Layouts and Workflows in Production
  • B. The administrators are deploying their own Change Sets, thus deleting each other's fields from the objects in production.
  • C. Page Layouts should never be deployed via Change Sets, as this causes Workflows and Field-level Security to be reset and fields to disappear.
  • D. A sandbox should be created to use as a unified testing environment instead of deploying Change Sets directly to production.
NEW QUESTION # 109
Universal Containers develops a Visualforce page that requires the inclusion of external JavaScript and C55 files. They want to ensure efficient loading and caching of the page.
Which feature should be utilized to achieve this goal?
  • A. ActionFunction
  • B. RemoteAction
  • C. Static resources
  • D. PageBlockTable
NEW QUESTION # 110
The PDII exam prep is produced by our expert, is very useful to help customers pass their exams and get the certificates in a short time. We are going to show our PDII guide braindumps to you. We can sure that our product will help you get the certificate easily. If you are wailing to believe us and try to learn our PDII Exam Torrent, you will get an unexpected result.
New PDII Exam Topics: https://www.dumpsmaterials.com/PDII-real-torrent.html
DOWNLOAD the newest DumpsMaterials PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1CStqDQtGlAHpLWRdCJu7S2k7G1LTl0yV
Posted at 2/6/2026 13:55:33        Only Author  2#
Your article was such a breath of fresh air, thank you! Don’t miss your chance to get the free FCP_FMG_AD-7.6 exam topic questions—the key to promotion and salary growth!
